Results 1 to 28 of 28
    Reputation: Jim Hannoonen's Avatar
    Mar 2013
    Getting my tire seated properly
    I'm having a hard time getting my rear tire to seat properly. It's a 26x4.0 Devist8er and there is a low spot that I just can't remedy.
    I know it's not the tire, because I've previously had it seat properly, but now it's just effed.
    I've tried deflating and spraying windex on the bead and re-inflating (an old bike shop trick) and also riding it with extremely low PSI, but to no avail.
    I'm new to this fatbike stuff. Is there something I'm missing?
    FYI, this is only on the rear wheel. The front is perfect.
    Thanks,
    Mar 2013
    Quote Originally Posted by MiniTrail View Post
    dishsoap in water, slather the bead with it and add pressure
    How did I not think of this?
    Feb 2012
    My Devist8or did the same thing, a bulge I could not fix. I replaced it with Floaters. Problem solved. Man, I hated that tire. The soap trick should work though.
    will rant for food
    Quote Originally Posted by Stockli Boy View Post
    Same here.
    nvphatty
    Guest
    My h8ters were the same but after numerous tries and soapy water it finally took a seat.
    Thingamejigger
    Reputation: Flying_Scotsman's Avatar
    A good blast of silicone spray around the bead, pump it up to 30psi and leave it a day is another method.
    Oct 2012
    Quote Originally Posted by Flying_Scotsman View Post
    Won't that promote slippage later on?
    Nemophilist
    Reputation: TrailMaker's Avatar
    Hey;
    I've got a GFS (Graceful Fat Sheba rim) that tires simply will not pop out on. No matter what. 30psi. 40psi. Soaped to death. Nothing short of taking it out and riding the shirt out of it popped the Hudu on it the first time. So, I just swapped tires the other day, and same old story. I've learned it is the rim because any tire on Rolling Daryls don't do this. So, it was soaped to death, 35psi, but still no pop. Big lump/drop in the tire. I aired it down and banged the whole wheel/tire on the porch at about a 45* angle. POP! It's the only thing I've found that worked.
    Most people ply the Well Trodden Path. A few seek a different way, and leave a Trail behind.
    - John Hajny, a.k.a. TrailMaker
    Mar 2013
    Re: Getting my tire seated properly
    i have BFL on my 70mm rim (on one fatty) tried to seat iy but no luck ,used washing liquid and the tyre just kept popping off the rim then dried it pumped up to 40psi and POP everything exploded (tube bust and tyre popped off rim ) same with my floaters never got them seated either i must be doing something wrong but tried evrything
    Sent from my Transformer TF101 using Tapatalk 2
    I have used ky on my pugs...
    That allowed it to pop into place quickly!
    nvphatty
    Guest
    Quote Originally Posted by cholula405 View Post
    way TMI
    Mar 2013
    FYI, the dish soap worked perfectly. Just lubed the crap out of it and pumped it up to 30 psi and viola!
    No "pop" though. I was kinda bummed about that. I like the pop...
    nvphatty
    Guest
    Quote Originally Posted by Jim Hannoonen View Post
    yea they just slide into place without the confirmed 'pop'....meh.
    Mar 2013
    I was able to get out and ride though without bouncing all over the place.
    gran jefe
    so does it ride better?
    Mar 2013
    MUCH better. Really, it wasn't so much an issue off road, but on the pavement, it was almost unbearable.
    All fixed now. =)
    gran jefe
    wow, cool.
    Apr 2013
    I grab across the tread of the tire and push and pull it back and forth, all the way around the wheel. Works best with about one third of the pressure you typically run, then inflate to whatever you prefer. Get my tires to seat perfectly all the time, just takes a bit of elbow grease and a dash of patience.
    nvphatty
    Guest
    Quote Originally Posted by BoostedThrills View Post
    so no 1tblsp of lard or 3oz veggie oil??
    Vagician
    Reputation: EPcycles's Avatar
    Dec 2009
    Quote Originally Posted by TrailMaker View Post
    Jim, Glad to hear that the dish soaped worked. That's my preferred method also.
    40psi.... I've often wondered where the breaking point of some of these tires is but am not brave enough to find out. I had a regular mtb tire bead break at 65psi and it was much louder than a shotgun being fired right next to my head. Couldn't hear anything for days. It had so much force that it knocked the rim out of true also. I'd love to see a fatty go..... from afar.
    gran jefe
    Quote Originally Posted by nvphatty View Post
    if your abuelita is making tamales, ask her for some manteca.
    Nov 2012
    I think that the "breaking point" for a Floater tire mounted tubeless is in the 50-55 psi range. At this point, the bead breaks and the tire goes "bang" off of the rim. Don't as me how I know this! The tire says 8-20 psi on the sidewall...
    Vagician
    Dec 2009
    Quote Originally Posted by JoeG View Post
    Might I ask why one would put 50 psi mounted tubeless in a 20 psi non tubeless tire?
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Lol no kidding!
    I get uneasy over 30psi or so....
    Nov 2012
    It is one of the following:
    a. To see how much pressure it could hold.
    b. To see how long my ears would ring for if the tire burst.
    c. Because I was trying an experiment with a Stan's rim strip, and the tire would not seat.
    So, whadda think? Is it a, b, or c?
    Hint - I usually had to put 30-35 psi into the tires to get the beads to seat all the way around with tubes (either On-One OEM or Q-tubes),
    Fat & Single
    Reputation: ozzybmx's Avatar
    Hey;
    The GFS rims have no "ridge" on the bead and the bead is very shallow. I had a complete fail at any tubeless attempt on them.
    Evil Following
    Trek 9.9 Superfly SL
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
  1. Properly mounting a MTB tire
    By dhosinski in forum Wheels and Tires
    Last Post: 11-11-2012, 08:37 PM
  2. Replies: 22
    Last Post: 03-10-2012, 12:20 AM
  3. How to climb properly seated?
    By Loll in forum California - Norcal
    Last Post: 01-06-2012, 09:19 PM
  4. Replies: 7
    Last Post: 09-08-2011, 08:40 PM
  5. help with transition from seated to standing
    By duke walker in forum Singlespeed
    Last Post: 03-28-2011, 03:57 PM
