Results 1 to 29 of 29
    Oct 2012
    getting fatter and taller
    I know someone will eventually come out with tires wider than 4.8".
    they are already getting hard to manage the diameter at 30" for a Bud.
    Wouldn't it be logical to go to a smaller 24"(507mm bsd) rim for even the 4.8" tires?
    Of course, they could even come out with a new size rim in between, and make everyone buy the wheels and tires together.
    It would be nice to be able to swap out between 2" wide tires(29x2.XX), 4" wide tires(26x3.8-4.0), 5" wide tires(25[~530mmbsd]x4.8-5.x), and 6" wide tires(24[507bsd]x6.0) all on the same frame, without changing BB height, gearing, standover height and trail.
    Or, why not make the tires with a lower aspect ratio, so that a 26(559)x4,5,and 6" all have the same outside diameter on a 26" rim?
    I'm pretty sure it is possible to make a tire that is 6" in width, but only as tall as a 4" tire. They've been doing it for a while on motorcycles now. Maybe it would add weight?
    Reputation: Velobike's Avatar
    Quote Originally Posted by autodoctor911 View Post
    ...Or, why not make the tires with a lower aspect ratio, so that a 26(559)x4,5,and 6" all have the same outside diameter on a 26" rim?
    I'm pretty sure it is possible to make a tire that is 6" in width, but only as tall as a 4" tire...
    That's the way it needs to go IMO, otherwise the bounce in a 6" tyre is going to make high speeds too exciting.
    Latitude: 5736' Highlands, Scotland
    Reputation: vikb's Avatar
    If I was QBP and I had the desire for bigger tires than the current 5" rubber options I would make it as incompatible with other companies' bikes as possible.
    Quote Originally Posted by Velobike View Post
    Presumably the reason for going down the 6" tires route would be for ultra soft conditions and for street cred when cruising to get a latte - both would be slow speed missions.
    Safe riding,
    Vik
    www.vikapproved.com
    Reputation: Lone Desert Walker's Avatar
    Time will tell. When did the first pugsley with endos arrive on the market? If its not too late the ten year anniversary would be a great time to release a 6 inch "Super Pug."
    Quote Originally Posted by Lone Desert Walker View Post
    I've had my Pug 5yrs and I want to say they came out around 3yrs before I got mine.
    Safe riding,
    Vik
    www.vikapproved.com
    Perpetual n00b
    Reputation: dgw2jr's Avatar
    Extremely rough non-scientific calculation for fat tire weights, assuming same carcass composition as Surly Bud:
    Surly Bud = 1630g (26 x 4.8 x 3.14 x 4.15 = 1626) 3.6 pounds
    Surly Larry = 1370g (26 x 4 x 3.14 x 4.15 = 1360) 3 pounds
    Imaginary 24x6 tire = (24 x 6 x 3.14 x 4.15 = 1876) 4.13 pounds!
    Imaginary 26x5 tire = (26 x 5 x 3.14 x 4.15 = 1694) 3.73 pounds
    The law of diminishing returns has to kick in at some point right?
    The leg bone's connected to the Cash Bone!
    Fat & Single
    Reputation: ozzybmx's Avatar
    Yeah, pug was released 2005 i read somewhere.
    To make a tyre shape 6 wide and 4 high means extra weight to make it hold its shape, radial wires shaping the carcas or other similar technologies and also more reinforcing rubber are needed to stop the tyre taking its natural balloon shape.
    Evil Following
    Trek 9.9 Superfly SL
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
    Quote Originally Posted by vikb View Post
    I never worry about top speed. Strangely my Nates come out faster over distance than Racing Ralphs on my 29er even though they feel slower.
    bigger than you.
    Reputation: Gigantic's Avatar
    I really don't understand why you guys want bigger tires. 4.8" seems more than enough to me; I rather prefer the 3.8 standard to be honest.
    aka bOb
    Reputation: bdundee's Avatar
    Quote Originally Posted by Gigantic View Post
    Cuz it looks and rides fricking amazing!! Or maybe we all are just overcompensating for something
    Attached Thumbnails Attached Thumbnails getting fatter and taller-imag0421-1.jpg
    Perpetual n00b
    I'm with stupid on this one. Nate 3.8 was more than enough float and traction for me.
    aka bOb
    Quote Originally Posted by dgw2jr View Post
    I really am as well but would still love to see an aggressive light 4.25.
    bigger than you.
    Quote Originally Posted by bdundee View Post
    ok.
    Mar 2013
    Re: getting fatter and taller
    me too something in between
    Sent from my GT-N7100 using Tapatalk 2
    Jan 2011
    Quote Originally Posted by ozzybmx View Post
    I think this could be bypassed by simply using a rim that is wider than the tyre. Ex. back in the days when Endomorph (94mm) was only tyre people where running it on a 100 rims, making it articially wider and flatter.
    However the same could be done with a wider tyre as well. Ex. if we would like to use the same ratio for our imaginary tyre, we could form two equations:
    (1) EndoFlatteningRatio = EndomorphWidth / EndoRimWidth
    (2) ImgTyreRatio = ImaginaryTyreWidth / ImaginaryRimWidth
    And set eq's (1) and (2) equal, therefore coming into:
    EndomorphWidth / EndoRimWidth = ImaginaryTyreWidth / ImaginaryRimWidth
    And make ImaginaryRimWidth as a function of ImaginaryTyreWidth:
    ImaginaryRimWidth = ImaginaryTyreWidth*EndoRimWidth / EndomorphWidth
    Ex. use 94mm (3.7"), 100mm and 152.4mm (6") to find out that ImaginaryRimWidth for an imaginary 6" tyre would be around 162mm.
    This model is of course inaccurate and non-scientific because it doesn't include geometry or material deformation, but didn't want to use whole day and make this not understandable for those not familiar with mathematics.
    One car less.
    Perpetual n00b
    Ok so what kind of rear spacing are we looking at with 6 inch wide rims? BB width? What would the Q-factor/stance width be like? Those cranks have to clear the chainstays somehow...
    Agree, I've been looking for 24" or even 20" fat tires too.
    bigger than you.
    I rode a bike with a ClownShoe/Bud/Lou combo today. I stand by my preference for 4 inch tires; I don't understand why anyone would want anything wider than 5"... you reach a point of diminishing returns, going beyond 5", the weight detracts from any benefit of flotation.
    NMBP
    Reputation: crashtestdummy's Avatar
    Jun 2005
    Did you ride the bike across a sand dune, or through 6" deep unpacked snow? Did you also notice how all the young, good looking women flock to the guy with the fattest tires?
    Riding Fat and still just as fast as I never was.
    Perpetual n00b
    Quote Originally Posted by crashtestdummy View Post
    Are you implying Bud/Lou on Clown Shoes is still not enough float for those situations? Because he didn't say that it was too wide, he said he didn't see any need to go wider than that. And while that may be 'to each his own', it still doesn't answer the engineering issues in getting a bike with wider than 5" tires to fit a rider comfortably. I guess if you guys don't mind Walgoose-type chainstays, because I'm sure that is what it will take to get 6" wide tires on a bike. Of course someone will say "But that is what they said about 4" tires and alas they were wrong!". Well a 100mm BB isn't that much of a jump from 68/73mm, but the jump to 152mm from 100mm is probably more than most people can handle.
    NMBP
    Jun 2005
    He said that he prefered 4" tires, BFL's and Bud and Lou are 4.7" and 4.8", therefore larger than 4".
    Besides, when people start verbally masturbating over "what if", I like to stir things up.
    I often found myself dreaming of a bud/lou/clown combo this winter, as even at 4-5psi on RD's I needed more float. MORE...MORE...MORE.
    I would love to have a bike the could have two wheelsets. RD/hudu/knard for everything but winter time, Clown/BUD/LOU for winter.
    Quote Originally Posted by jonshonda View Post
    ...I would love to have a bike the could have two wheelsets. RD/hudu/knard for everything but winter time, Clown/BUD/LOU for winter.
    I'm with you. I can't see the point (for me) of 29er wheels on a fatbike because I'm still happy to ride fat in summer. So a set of 4" on 80mm rims for summer gives enough float for most things and much fatter set for winter.
    bigger than you.
    It was mostly the middle-aged women with the inane questions and sagging faces flocking to the guy with the biggest tires. "What's those fat tires for?" gets irritating after a while...
    Fat & Single
    It was mostly the middle-aged men with the inane questions and sagging faces flocking to the guy with the biggest tires. "What's those fat tires for?" gets irritating after a while...
    Fixed it for you
    Evil Following
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
    bigger than you.
    that too! I enjoyed relative anonymity with my marge lites and Larrys.
    Fat & Single
    I don't get much anonymity with margelites dressed in Buds
    Evil Following
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
    We need higher performance 4" tires with reliable ready made tubeless compatibility, not 6" tires.
    Diminishing returns folks, diminishing returns.
    Oct 2012
    I wasn't trying to push the 6" tire Idea, but I'm sure someone will. I am happy with my 4" tires on 65mm rims.
    I was just trying to contemplate a way to make it usable when they do it. I think a 29" OD tire is about the biggest that can fit a majority of riders with a little tweaking here or there to get crotch clearance, handlebar height, and be able to turn the front wheel while pedaling.
    I am sure some will want the extra width for soft conditions, be it sand, snow, or mud, or just to have the look of the fattest tires around. To make the bikes ridable, and perform well, we need to try and keep that diameter about the same, so smaller wheels, or lower profile tires would be a couple of solutions to consider.
    As far as Q-factor, I would say it would be best to stick with the 100mm Bottom bracket, or maybe a little bit wider 30mm press fit type equivalent, with cranks no wider than the Moonlander currently uses, but chainstays will need to be moved around(elevated) to get away from interfering with the tire, and the cranks, while not increasing the chainstay length. It will help if the cranks have thin arms too. If the chainstays are elevated out of the way of the cranks, then the cranks only have to be wide enough to clear the tire.
  1. Fatter than Moonlander?
    By Murphy1976 in forum Fat bikes
    Last Post: 08-11-2013, 02:58 PM
  2. get our fattys fatter in uk
    By stesteste in forum Fat bikes
    Last Post: 04-13-2013, 04:22 AM
  3. Sandman gets fatter
    By Andy FitzGibbon in forum Fat bikes
    Last Post: 02-28-2012, 12:35 PM
  4. Fatter still - Moonie beater!
    By druidh in forum Fat bikes
    Last Post: 02-24-2012, 07:14 AM
  5. Why is my Tallboy fatter than most????
    By dapozer in forum Santa Cruz
    Last Post: 05-20-2011, 11:55 AM
