Results 1 to 38 of 38
    mtbr noob
    Reputation: roxo56's Avatar
    Dec 2010
    Full suspension fatty design with Surly Nate sized tires ( more boredom )
    So, having still a bit of time I have been screwing around with geometries, tire clearances, shock travel - wheel travel ratios, chain line clearances and lastly O.D. Crank - swingarm bend clearances. This is not easy to design with so many variables !!!
    Specs:
    Steel tubing frame assemblies
    80mm front travel max
    135mm front hub, 82mm rim and Nate tire
    160mm rotor
    75mm rear travel max
    30mm shock arm travel
    2.5 : 1 ratio
    170mm hub, shimano 10 speed cassette, 11-36t
    82mm rim and Nate rear tire
    160mm rotor
    Full suspension fatty design with Surly Nate sized tires ( more boredom )-underside-swingarm-assembly-solid-modeling-mode.jpgFull suspension fatty design with Surly Nate sized tires ( more boredom )-close-up-sliding-drop-outs-solid-modeling-mode.jpgFull suspension fatty design with Surly Nate sized tires ( more boredom )-left-side-nates-layers-turned-.jpgFull suspension fatty design with Surly Nate sized tires ( more boredom )-left-side-xray-w-o-tires.jpgFull suspension fatty design with Surly Nate sized tires ( more boredom )-right-side-xray-w-o-tires.jpgFull suspension fatty design with Surly Nate sized tires ( more boredom )-shock-mtd-xray.jpg
    roxo56
    Surly Troll
    SC Butcher
    Reputation: liquidboarder2k4's Avatar
    Jul 2013
    Will the Tires have clearance when compressed?
    bigger than you.
    Reputation: Gigantic's Avatar
    you're gonna wanna put a linkage in there. Pedal bob is going to be terrible with that setup.
    not necessarily. Single pivot can work quite well without a linkage if done right. I recently had a Santa Cruz Superlight29 and was blown away by how well it pedaled for a "cheap" and "simple" bike. Not sure if it was because they've got all the geo and pivot loctions dialed perfect, or because shocks are better these days or what, but it worked.
    Bend, OR
    Quote Originally Posted by Gigantic View Post
    How would the linkage reduce pedal bob?
    mtbr noob
    Dec 2010
    That was the first thing I worked on...they fit with about 10mm clearance at full 75mm .
    travel
    Quote Originally Posted by liquidboarder2k4 View Post
    roxo56
    Surly Troll
    SC Butcher
    mtbr noob
    Dec 2010
    I had a SC Butcher and consider the SC single pivots to be my ideal.
    I studied other systems too ( Yeti, Ventana, Niner, etc..) but the simplicity and weight savings of a single pivot system like the Heckler and Butcher was my logical selection.
    I'm lazy and don't like all of the extra linkage disassembly and regreasing involved with levered linkages. Plus, I have had this crazy idea after getting into this design that FS fatties of the future (and I think they will be hugely popular, forgive the pun)
    are going to probably be used for more radical terrain and will evolve into a much lighter and much more widely ranged machine than the current snowbike that gets used for trail "sometimes". The reason I'm thinking that is because I read constantly on this forum of many of you who now leave the FS skinny tired bikes at home and use the fatty for trail.
    Why have two bikes to take care of if one can reasonably do both ? Keyword there is reasonably !
    Anyways, I now have a good acad block library in 3d if anyone needs some for design. Just PM me...
    I'm working on a HT 190mm version and will try a 190mm Bud tired FS too now that I have a component library.
    Quote Originally Posted by TroyS600 View Post
    roxo56
    Surly Troll
    SC Butcher
    I think the linkage mention was meant as a Swing Link, to stiffen up the rear when it's actuated.
    I remember AMP bikes had a similar shock/strut interface early on that got complaints of being flexy. They added a swing link...flex problem solved.
    Sup
    Reputation: Burnt-Orange's Avatar
    Dec 2008
    the pivot is too high
    the chain is going to pull the wheel down
    if you have any sag it will bob all the way down the trail
    the ideal single pivot location is at the top of the chain ring
    with more than one chainring it will always be a compromise
    look at all the trek's and cannondale's ignore all the fancy monkey motion links because they are all single pivot
    should get you in the right area
    good luck ....cool project
    I am slow therefore I am
    mtbr noob
    Dec 2010
    Quote Originally Posted by Burnt-Orange View Post
    Thanks for that critique. I will rework it to move pivot. Do you agree that a link pivot is a better system or will a SC single pivot concept work if I relocate pivot ?
    roxo56
    Surly Troll
    SC Butcher
    Unless you're Dave Weagle or Joe Graney, i would not try to invent anything suspension wise. I think your first idea of copying a santa cruz single pivot as closely as possible is the right idea. Trek and cannondale have other parts that are not present in your design. I believe that all they do is modify the linkage ratio as the swingarm moves through its travel, but i don't know enough about it to be certain there aren't other effects as well.
    If your design only has one part (like a Superlight) then use the superlight pivot location. If you have swing links and that other business, then use the pivot location of bikes like that.
    I think my Superlight had less pedal bob than a Fuel EX that i rode a couple years ago.
    All that said, i think Burnt Orange is right, if you compare your pivot location to that of the Superlight, you can see yours is much higher. The superlight pivot is about even with the big ring.
    Full suspension fatty design with Surly Nate sized tires ( more boredom )-santa-cruz-superlight-29-dxc.jpg
    Bend, OR
    The new Heckler's pivot looks to be placed exactly the same also.
    I think it's great that you're working on this design. Have you built bikes before? Do you intend to actually build this?
    As mentioned by someone else, rear end flex is an issue with this type of design, but it's not horribly important i don't think, especially on a fat bike. Sure stiffer is better, but that adds cost and complexity. You have to choose your own compromise. Is the stiffer frame enough more FUN to justify the cost and complexity? Up to you.
    In any case, you'll want to use large bearings and a carefully designed interface for that pivot, to make it as stiff as possible. Santa cruz sells rebuild kits for their pivots, you could use their hardware and design your frame to suit.
    Full suspension fatty design with Surly Nate sized tires ( more boredom )-heckler_profile_blue.jpg
    Bend, OR
    mtbr noob
    Dec 2010
    Full suspension fatty design with Surly Nate sized tires ( more boredom )-juneau3.jpgFull suspension fatty design with Surly Nate sized tires ( more boredom )-juneau1.jpgFull suspension fatty design with Surly Nate sized tires ( more boredom )-juneau2.jpgTroy,
    I admire the Heckler too for it's simplicity and also realize that it probably enjoys greater stiffness due to it's aluminum frame. It should be possible to increase rear swingarm rigidity thru the use of thicker tubing selections or perhaps even the use of an aluminum swingarm. Does anyone know of a website where Heckler type suspension bearings are spec'd ? Or any larger bearings that could be used are spec'd ?
    In the meantime, I've reworked the main pivot fulcrum to just above the larger chainring. Also, I've reworked the CS and SS curves so that a Surly Lou will easily fit and added upper and lower stay braces that will allow full suspension travel. Might add a DT mtd rubber bumper to maintain/limit max swingarm travel ?
    roxo56
    Surly Troll
    SC Butcher
    Reputation: BoogieMang's Avatar
    Mar 2011
    Looking good. I've found that the closer you can get the pivot to the bottom bracket , the less you'll have to worry about chain growth through travel. Not sure if you intend to run a FD, but your pivot location may interfere with an FD if that's your intent. Personally, I'd just run XX0 or XX1 and eliminate the FD. Also, may want to consider putting the kink in the seat tube a little lower. You'll have to tweak the front triangle a bit to maintain your geometry, but having that much seat tube sticking out seems like it would be kind of limiting for different riding styles.
    As for the Heckler bearings, they sell bearing/linkage kits through the SC website. Information is probably pretty limited, but you could always just order a set to base your design around.
    I really like this design.Why not just build a wide swingarm for a superlight or do you plan to produce frames?
    Most linkage designs are no better than a single pivot design. The wheel arc is the same.
    If you're interested, read Ken Kasaki's dissertation on it here:
    Index
    In it he shows that the ideal pivot point is between the bottom bracket axle and the chain line, i.e. the vertical chainline. Meaning, a pivot point somewhere around the top of the granny ring or middle ring. Given that it's a fat bike, and you may spend more time in the granny gear, that points towards a lower pivot point, maybe 30 to 50 mm above the bottom bracket center. (Chainrings have a radius about 2 X # of teeth +3, so 24 tooth ring is 51mm radius). Within this range, it probably doesn't matter much, but it will be much better than a pivot point at the top of the big ring. Well, better, maybe not much better.
    If you look at the top Specialized, Cannondale, and Trek bikes, after all these years, they all have basically a mono pivot design with the pivot somewhere around what I just said.
    If you're really interested in the suspension design, download the software "Linkage" and play around with it.
    You'll also want to think about heel clearance with the shape of your chainstays.
    mtbr noob
    Dec 2010
    A wider swingarm on a superlight would only address tire clearance thru the swingarm. It would not solve chainline-BB issues that "Lou" brings with him ?
    roxo56
    Surly Troll
    SC Butcher
    mtbr noob
    Dec 2010
    I will study that dissertation. Thanks for that link and your summary of pivot locations based upon his remarks.
    You make an excellent point by noting that much time will be spent in granny gear up front. That would likely be because this FS fatty will be at least 40 lbs ?
    In fact, I have pondered going 1x10 (half granny) with an OD crankset to aid with chain tire clearance. Not that that is currently an issue. Does anyone know offhand what is the smallest tooth count cog possible (outboard) on the Moonlander crank ? 28 teeth would be perfect if it fits.
    Quote Originally Posted by Godlikedog View Post
    Index
    roxo56
    Surly Troll
    SC Butcher
    This was easy and I now have over 3k miles of road, off road and up north down hill riding on it and it's still riding just like the day I built it.
    Another Full Suspension Phatty
    Quote Originally Posted by Look Out Below View Post
    That looks good and not overly difficult to mod.As mendon posted lenz is looking to build a fatty fs and i see the risse racing lassen is gonna be an option also.
    Roxo,i apologize for the thread derail.
    Quote Originally Posted by roxo56 View Post
    It looks like FSA makes a 29 tooth 94mm BCD ring, and surly makes a spider for the Mr Whirly cranks that would make that work.
    mtbr noob
    Dec 2010
    no prob. nice conversion. tire size ? how'd you fix bb ?
    roxo56
    Surly Troll
    SC Butcher
    mtbr noob
    Dec 2010
    Sold my 2-stroke dirtbike today to make room in my garage for a new fatbike. I'm getting close to having this design ready to turn over to a custom frame builder and need a recommendation. Many seem to be so busy they don't bother to return emails. I'm not looking for the absolute best welder. Just someone who can build my design and check me for missing items like cable guides, brake post locations, water bottle cage mts, etc...
    Thanks to those who have suggested geometry mods and suspension advice.
    Steel frame
    1x10 drive train
    Bud/Lou tires
    29 tooth FSA ring
    13-36 cassette
    100mm BB
    MWOD crank w/ spider ring
    XT brakes
    3" rear travel (with 4" possible later)
    190mm rear hub, 135mm front
    203mm rear rotor, 180 front
    80mm front suspension suspension corrected
    neutral single pivot link (cnc'd)
    flanged & inset ball bearings (Lily)
    8-10mm hardware at pivot links
    6.5" x 1.5" Fox CTD shock
    Check it out:
    roxo56
    Surly Troll
    SC Butcher
    bigger than you.
    Try Lenz or Ventana. Looks good.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    2nd design would be far stiffer laterally and should pedal much better. First one would have fairly extreme chain-tension due to the high pivot, which means bumps interfere with pedaling, and pedaling interferes with bumps, it will stiffen under power and lose traction as you try to pedal up stuff, as bumps won't be absorbed as well, but transferred to your feet, opposing your direction of travel. This won't work well with a short or possibly even medium cage derailleur, as it won't have enough length to take up the slack.
    A simple way to say it is that the distance between the top of the chainring and top of the cassette is going to increase dramatically though the travel, these are fixed and somewhat immovable, one is connected to your feet going one direction, the other end is connected to the ground. Forcing them apart radically(increasing distance) as the suspension goes through it's travel is going to have bad effects.
    2nd bike looks real nice though. I'm not sure how fatbike FS bikes will evolve, so that will be neat to see.
    Reputation: duggus's Avatar
    Re: Full suspension fatty design with Surly Nate sized tires ( more boredom )
    Bigger rotor usually goes in front. Better stopping power.
    ...Be careful what you're looking at because it might be looking back...
    What fork are you planning to use? Is there a rear pivot near the axle?
    You have a really wide screen. I like to move taskbars and toolbars to the sides of the workspace instead of the top/bottom, that gives more usable viewing space for working. But that's me and i'm weird. I notice that pretty much nobody else does that.
    You should post a link to this thread over in the frame building section if you haven't already. There are some very knowledgeable and experienced people over there.
    Bend, OR
    mtbr noob
    Dec 2010
    Troy,
    I draw on a 37" diag flatscreen so my panning is at a min. Usually I do not use that toolbar pallete config. (3d modeling). I have my own slimmed down custom cui based loosely on acad classic. Not so much clutter and that gives me a lot more top to bottom as you say.
    But, those screen caps were taken in 3d.
    As far as fork choice...that remains to be seen. I've been listening closely to all of the rumors on here waiting for one of the "big three" to announce a new model. I'm hoping for an x-fusion "lou-worthy", but rockshox or fox would be great too. Doesn't matter to me who, but when. What is out right now is not to my liking, so much.
    I will delay the build until specs are publicly released so that i can tweak geom. a bit if needed. My guess of axle to crown so far has been predicated by 29+ specs that are available and there aren't many !
    I'm really liking the stuff 907 and salsa is producing and reckon that they'll be the first mainstream mfgs of FSF's, although hats off to the pioneers like sandman and carver...
    Surly will never do it. They lead, not chase.
    my $.02
    roxo56
    Surly Troll
    SC Butcher
    mtbr noob
    Dec 2010
    Yeah, i know about that. But being a dirtbiker who knows his own personal braking habits a smaller front is all i usually need in the woods. When I do get into major steep downhills I switch from front rotor use to heavy rear (right foot) and that will require a bigger rotor.
    I'll probably swap out the brake levers on the bars too so that my right hand controls the front brakes. Old habits die hard. My troll is set up normal and it sometimes freaks me on the steep stuff.
    roxo56
    Surly Troll
    SC Butcher
    very cool. Is that a standard front triangle with a modified rear end? Hydro-formed alum is typically not handmade. You gotta give us some details on that.
    Salsa?
    Looks like a salsa flexing pivotless rear end. Frame looks like a spearfish.
    Bend, OR
    Troy,
    my $.02
    Well, x-fusion DID show off their inverted fork at interbike. It's pricey, but with different travel options up to 160mm it would theoretically have the bushing support for at least 100-110mm of travel with a fat-bike. If one bought the shortest travel version and then installed spacers below the damping rods (I've done this before on marzocchi and stratos forks) you can effectively gain axle to crown distance, as long as the bushings and stanchions are the same as the longest travel version. They also are making a 29er version of the same fork, so that could be an option too.
    Are you saying you view it on a 3d tv and that 3d rendering is in 3d? (Does that make sense?) I mean, you put on the glasses and view that rendering in 3d?
    If so, that is waaaaayyyyy cool.
    Troy,
    my $.02
    Yeah, that's a salsa prototype; see:
    Salsa Cycles prototype FS fat bike
    Salsa?
    mtbr noob
    Dec 2010
    No, nothing so cool as that yet...
    I just meant that the screen caps were taken as I was in 3d ribbon mode, not my usual 2d. However, it is possible in 3d mode using polyline to draw CS and SS tubing in compound curves ! This takes concentration and ninja like skilz though. (dr evil mwuhaha laff here)...
    roxo56
    Surly Troll
    SC Butcher
    mtbr noob
    Dec 2010
    I made the mistake of going to a LBS the other day and riding an Origin8 Crawler equipped with a Nuvinci Planetary hub.
    I've got to have that...
    I came home and worked up a solution to my 135-170 chain line alignment problem much as 907 and Salsa have except mine is 4.8" tire capable and full suspension.
    But, I have a question about wheelbuilding and if it can even be done.
    Take a look at the hub placed in a custom spaced swingarm (top view is left side, rear view is right side) and tell me if a wheel can be built strong if it is that dished towards the drive side.
    roxo56
    Surly Troll
    SC Butcher
    You might want to check out this thread:
    Fat-Bike with an IGH: Is all this geometry necessary?
  1. Full Suspension Fatty!?!?!?
    By crazybeach in forum Fat bikes
    Last Post: 09-10-2013, 05:44 PM
  2. Open source full suspension design
    By 18bikes in forum Frame Building
    Last Post: 05-27-2013, 11:27 PM
  3. 29er Full Suspension vs Surly Pugsley
    By PaulRivers in forum Fat bikes
    Last Post: 10-03-2012, 10:27 AM
  4. Full Suspension Design Differences
    By junior1210 in forum Bike and Frame discussion
    Last Post: 04-12-2012, 10:04 PM
  5. Hmmm...Surly Full Squish Fatty???
    By Old Bag in forum Fat bikes
    Last Post: 01-18-2012, 08:16 AM
