Results 1 to 10 of 10
    Reputation: woodyak's Avatar
    Frozen Lev Dropper
    So I just had the internal cable replaced on my Lev Dropper. Works perfect above freezing. When I ride below freezing it seems like the internal cable gets locked in the open position. I had to pop the cover and force the cable to the closed position to keep the dropper from dropping. Anybody have a solution for this? Grease? WD-40 the heck out of everything? Different dropper for cold weather?
    Thanks in advance!
    Come stay and play at da Kingdom Trails! - http://www.homeaway.com/vacation-rental/p3486813
    is buachail foighneach me
    Reputation: sean salach's Avatar
    Gravity Dropper, if you can stand the inhumanity of external cable routing.
    Reputation: rollertoaster's Avatar
    Most likely there is water in your outer cable which is freezing and not allowing the internal cable to get enough slack. I recently had that happen to mine. New outer actuator cable and housing fixed the problem
    Sent from my SAMSUNG-SM-T337A using Tapatalk
    Team _________
    Reputation: traditiionalist's Avatar
    May 2014
    Never had a problem with my gravity dropper. 6 degrees and still works fine.
    bigger than you.
    Reputation: Gigantic's Avatar
    Quote Originally Posted by rollertoaster View Post
    This, or it's incorrectly assembled. after I replaced the seat clamps, my KS LEV has been trouble free for 2 years.
    bigger than you.
    perhaps I spoke too soon... My last ride, it was about 23 and i encountered this problem...
    OP, have you resolved the issue yet?
    Quote Originally Posted by Gigantic View Post
    All fixed. I popped the red cap off and sprayed the crap out of the cables while actuating the dropper up and down. No problems on my very next ride. Rode today in 7 degrees and worked like a champ. Still much slower than when not cold but that's normal for the Kindshock stuff.
    BTW,
    It was definitely the inner cable because when it was frozen I was able to manually push and pull the outer cable.
    bigger than you.
    What did you spray it with?
    WD-40. Tons of it!
  1. why is my for frozen?
    By hookydoo in forum Shocks and Suspension
    Last Post: 06-03-2014, 10:32 AM
  2. Frozen Fat
    By vack in forum Pennsylvania
    Last Post: 02-09-2014, 06:25 PM
  3. Frozen passion 'eh?
    By noot in forum Passion
    Last Post: 04-06-2012, 11:28 AM
  4. Frozen hands. What do you do?
    By thuren in forum Oregon
    Last Post: 10-11-2011, 06:52 PM
  5. Frozen Dirt
    By Dave_schuldt in forum Passion
    Last Post: 01-02-2011, 10:45 PM
