Results 1 to 14 of 14
    Reputation: SteveF's Avatar
    Fork for my Mukluk-ti, aluminum or carbon fiber or ???
    I'd like to put a lighter fork on my fat bike, a 2012 Mukluk. I'm considering the Carver carbon and ti forks because they seem to offer a lot for the money. Open to other options, though. I weigh around 165 geared up and ride the fat bike fairly aggressively, mainly in the winter/on snow but sometimes on sandy trails or just for fun and a change of pace on summer singletrack. I like to bash it around, over rock piles and logs and enjoy it's tractor-like stability and "roll over anything" capability. I've ridden this thing over stuff I've never had the nerve to even try before!
    I'll admit I'm a carbon doubter--just can't wrap my head around the stuff durability-wise. (no need to cite the endless studies and tests--I've seen them all and remain unconvinced) All my road bikes are steel w/ steel forks, my mtb's all have suspension forks except the Mukluk. Is the ti fork really so flexible that it would be an issue for me? I'd feel safer going that route, or aluminum, but I'm almost seriously considering the Carver CF fork just because it's so darn light...
    Reputation: duggus's Avatar
    No fear with your weight and carbon. Lots have posted their weights being over 200 and beat the crap out of the Carver. I have a friend who is running one on his 9zero7 with Bud in front and he is about 225... running it for 2 years now and he is aggressive.
    ...Be careful what you're looking at because it might be looking back...
    get down!
    Reputation: appleSSeed's Avatar
    Selling my Carver carbon fork to get a tapered version if you or anyone is interested.
    Rudy Projects look ridiculous
    visit my blog, BEATS, BIKES & LIFE
    Feb 2005
    Just a heads up on this; I e-mailed Salsa last month about running a 2013 aluminum Beargrease fork on a 2014 Mukluk. I wanted to run a Bud up front and didn't want the geometry to change. I didn't see axle to crown on the 2014 fork, so I asked. This was their reply:
    "You cannot use a 2013 Beargrease fork on a 2014 Mukluk. The 2013 A-C is 468mm, mimicking an 80mm travel fork at 20% sag. The 2014 Mukluk and Beargrease are designed to use a fork thatís corrected to 100mm of travel or 483mm A-C. That 20mm [sic - it's 15mm] will change the ride characteristics in a negative way, and also put stress on your 14 Muk frame that it was never designed to handle. At first blush it looks like you could do it, but it simply wonít work and will void your frameís warranty. You can still run a Bud up front as the fork clears up to a 4.8 tire on a 100mm rim, but will need super low pressure to squeeze past the caliper. Hope this helps out!
    -Zach"
    This seems a bit more cautious compared to what they said about the 2013 Mukluk: Salsa Cycles
    "Another new feature for our aluminum Mukluks is a 44mm headtube. The primary reason for this change is to allow for the use of both straight 1-1/8" forks and tapered 1.5" forks. There are several new fatbike forks out there (including our new Beargrease fork) that come in tapered form. Additionally, since the Mukluk is also compatible with 29er wheels (135mm front and 170mm rear spacing needed), it keeps the option open to use the latest and greatest suspension forks."
    I wonder what the use of any aftermarket fork, let alone a suspension fork, will do to your warranty.
    Jason
    Disclaimer: www.paramountsports.net
    Black Sheep rising
    Reputation: utabintarbo's Avatar
    Ti > * </thread>
    FWIW, I love my Ti fork. It has just enough flex to take the bite out of small bumps yet doesn't feel "noodly".
    Let the market decide!
    N42.58 W83.06
    Run a full carbon Carver on my 2012 Muk2 with a Bud/Marge lites. I bought it solely for a bit more 'forgiveness' in the front compared to the steel Enabler fork. A really nice byproduct was the lightness achieved in the front end. So much easier to manage on tight single track. And I can pull that front up with little effort.
    Appreciate the replies, folks. appleSSead, thanks but I'll probably buy new if I go carbon.
    Quote Originally Posted by utabintarbo View Post
    Ti > * </thread>
    Which one do you have? The Carver or the $1,000 (yikes!) "YOLO" Jones truss model? Or something else?
    drev-il, not Dr. Evil!
    Reputation: Drevil's Avatar
    Quote Originally Posted by SteveF View Post
    I currently have a Black Sheep titanium 29er unicrown fork (I had two, but one broke), a Black Sheep Faith titanium fat fork, and a Jones Truss titanium fat fork. The Jones is the least flexy, followed by the Faith, then the unicrown.
    For my style of riding, which involves riding on a lot of rocks, and catching bits of air, I won't use the ti Unicrown anymore. The remaining one serves as gravel grinder at worst. YMMV.
    "Keep your burgers lean and your tires fat." -h.d. | ssoft | flickr
    Outcast
    Reputation: Renegade's Avatar
    Hi Drevil. Looking at your photos, it looks like the black sheep truss fork has a longer A/C measurement than the jones, and perhaps a significantly different offset?
    Quote Originally Posted by Drevil View Post
    Quote Originally Posted by Renegade View Post
    The offset/rake is the same. The Jones is 435mm A-C, while the BS is 460mm.
    Outcast
    Thanks Drevil. Looking at pics of the jones fork on several bikes, it looks like spacers can be placed between the fork crown race and the bottom of the frame head tude, increasing the A/C slightly. Is this correct?
    Correct. It's one of the coolest things about dual clamp forks with a "floating" steerer.
    Here's a pic of the Vertigo with spacers at the bottom:
    Vertigo Cycles Fat Bike | Flickr - Photo Sharing!
    Here's a pic of the fork unattached to a frame. There is no solidly mounted race like there is on conventional forks. It's basically like two top halves of a headset, and the bottom is flipped:
    Black Sheep Faith Fork for Vertigo | Flickr - Photo Sharing!
    Jeff Jones has a good explanation here:
    http://www.jonesbikes.com/?option=co...1818&Itemid=58
    Anchorage, AK
    Reputation: anortherncrazy's Avatar
    Just bought a Carver for for my Fatback about a week ago. I dig the weight savings and I'm 165 pounds as well. Beat it up on a 20 mile ride today and had no problems so far. I tend to be pretty hard on stuff so I was a little hesitant about carbon, but what the hell, may as well give it a try right? I have a 16 inch, 1X9 setup with a carbon bar and a carbon seat post rig weighing in at just under 29 pounds.
    two wheel livin'..
  1. Carbon fiber frame vs Titanum vs Aluminum
    By Nakkoush in forum Beginner's Corner
    Last Post: 12-09-2012, 04:27 PM
  2. Can't decide Aluminum 29'er or Carbon Fiber 29'er
    By Ice Cold in forum 29er Bikes
    Last Post: 04-07-2012, 05:59 PM
  3. Adhering carbon fiber to painted aluminum
    By rdhfreethought in forum Frame Building
    Last Post: 04-03-2012, 09:00 PM
  4. carbon fiber fork..aluminum vs carbon steering column
    By shackleton47 in forum Shocks and Suspension
    Last Post: 03-01-2012, 10:29 PM
  5. Anyone like Aluminum better than Carbon Fiber?
    By Joe Schmoe in forum Beginner's Corner
    Last Post: 01-11-2011, 10:24 AM
Members who have read this thread: 4
