Results 1 to 7 of 7
    Fork disc mount - front or rear standard?
    One of the questions which has come up in the development of the Singular Puffin is that of fork disc standards. For the protos I specified rear standard as I knew I would be using Hope hubs and that is what they use. However a few people have asked whether it would be possible to change to front standard so as to use Jones or Paul 135mm front hubs. This would still allow the use of a rear hub but would require the use of a 4mm spacer behind the disc caliper adaptor or the rotor. Any thoughts?
    Yes - I do own Singular Cycles
    Oslo, Norway
    Feb 2012
    I would go go front standard. That is what is being used on all the new developments from KT, Joytech, etc. including their upcoming sub 220g models. Looks like that will become the industry standard.
    Espen Wethe
    www.kindernay.com
    Kindernay on BikeRumor: https://goo.gl/iQtWxu
    Reputation: Velobike's Avatar
    On the other hand the rear standard allows the use of a lower priced rear hub.
    I use DMR singlespeed hubs. They are light, cheap, and no "fat" tax.
    Latitude: 5736' Highlands, Scotland
    Front hub. If buyers want to use a rear hub, let them space it. It's simple and works perfectly.
    Jason
    Disclaimer: www.paramountsports.net
    Oslo, Norway
    Feb 2012
    Inexpensive 135mm front hubs are becoming available now.
    Espen Wethe
    www.kindernay.com
    Thanks for the feedback guys - sounds like front spacing does make sense. I may just get some 4mm washers and suppply them with the frames to save any hassles.
    Jan 2011
    Hi Sam.
    About the washers mentioned above... Have You decided to include them on the Puffin frameset?
  1. Replies: 4
    Last Post: 09-13-2012, 01:33 AM
  2. Standard Fork Front Spacing
    By spielnicht in forum Shocks and Suspension
    Last Post: 04-23-2012, 04:56 PM
  3. Post Mount Disc Brake Standard
    By Moff in forum Frame Building
    Last Post: 11-08-2011, 12:45 PM
  4. OS 28 front hub / standard fork compatibility?
    By el-cid in forum Specialized
    Last Post: 08-22-2011, 04:09 AM
  5. Replies: 2
    Last Post: 06-18-2011, 07:31 AM
