Results 1 to 10 of 10
    Jan 2013
    Filling those unused spoke holes in rims
    I found and used color coordinated (w the rim tape) plugs to fill all the unused spoke holes in clownshoe rims. I use shrader valved innertubes and run the 4.9 TS tires.
    Looks neat...and cheap. Cheap super fast shipping
    Hole Plugs/Hole Covers/Hole-Caps ? by Pro-Dec
    I LOVE ORANGE keep them coming, if I wanted to change I would have done it 50-60 years ago....
    Reputation: OFFcourse's Avatar
    Pic or it didn't happen...
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    So you added weight and it cost you money, to fix a problem that isn't really even a problem....?...ok cool ,
    Filling those unused spoke holes in rims-mtbr-response-time.jpgDamn near unusable.
    Jan 2013
    I agree adding a couple of GRAINS of weight is bad (hahaha) and some always have a hard time getting it in the hole.
    Now I want to know what they weight per wheel!
    Jan 2013
    Quote Originally Posted by OFFcourse View Post
    Buy some and weigh them on your grain weight measuring device.
    Reputation: kyttyra's Avatar
    Mar 2012
    My guess would be about 5 g, as 64 veloplugs weigh 10 g (I bought a set when I last suffered from weight weenieism)
    nvphatty
    Guest
    Quote Originally Posted by Shark View Post
    pretty much sums it up..LOL
    Reputation: Velobike's Avatar
    Quote Originally Posted by kyttyra View Post
    I can relate to that.
    But I discovered that carefully cut patches of duct tape were even lighter. (But I wouldn't want to try that on a high pressure tyre)
    Latitude: 5736' Highlands, Scotland
    dvn
    dvn is offline
    Reputation: dvn's Avatar
    Quote Originally Posted by Harvie View Post
    Nice! Looks good. I certainly wouldn't worry about a few extra grams of weight on a fat bike.
    Were you having problems with stuff getting in the unused holes? I think they look great, and it's a creative, cheap bling (compared to Ti bolts and stuff like that), but it seems like a solution looking for a problem.
    Dr Gadget is IN
    Reputation: wadester's Avatar
    For clownshoes and other holey, singlewall (at least where all the holes are) this is not that big of deal. The big holes will gather whatever, whether the spoke holes are filled or not. I like the contrasting colors, so it's all good.
    If you're running double walled rims, OTOH - where debris will fall thru the holes and accumulate inside the rim, this is a very good idea. I found these plugs at the local hardware store - black only - and filled the 18 spare spoke holes after I drilled 18 new ones in the other side to build a Moonlander offset wheel. Red wheel with black plugs is good enough.
    This isn't a "you're doing it wrong" topic.
    WSS/OSS: Open Source Sealant
  1. stans ztr crest rims filling up with water
    By Gabe3 in forum Wheels and Tires
    Last Post: 09-17-2012, 05:07 PM
  2. Sealing Spoke Holes
    By luvdabeach2001 in forum Wheels and Tires
    Last Post: 06-28-2012, 05:30 PM
  3. Leaking Spoke Holes
    Last Post: 04-22-2012, 07:46 PM
  4. Filling the holes in the seat stays
    By drMP in forum Frame Building
    Last Post: 04-29-2011, 12:47 PM
  5. Solution for unused Fargo holes?
    By DogpawSlim in forum Salsa
    Last Post: 01-16-2011, 04:12 PM
