    Oct 2013
    Fattystripper vs stretched latex ultra light tube
    I've been reading a bit on the current means of getting tubeless and found that the Fattystripper system seems like the way to go nowadays. I also read in a skinny tire forum that some people are favoring ultralight latex tubes instead, which made me search and find there is apparently no such tubes available for 4+ fatty dimensions.
    Seeing that a good part of the seal in the Fattystriper way is achieved by this thin latex film I was wondering if a lightweight, (kinda stretched out) latex tube like this: https://www.ebay.com/itm/Vittoria-MT...IAAOSwHMJYEO2U
    made for 1.7/2.3 tires wouldn't do the same job with less sweat and Stan's for a 4.25?
    Jan 2014
    Working on 2 bikes with this stretch wrap. Have not had to do anything, but will need to refill the fluid on the 2014 bike. Still have no regrets on the stretch wrap.
    Using STRETCH WRAP for tubeless. Mulefut rims, Floater/Larry 3.8 tires. Pictures
    Have also used this on Nates and Mission Commands.
    Dash Pt. State Park (Tacoma), Big Sky Montana during Snowboard Season, Duluth Mn, a couple of times of year incl. Xmas.
    Loud hubs save lives!
    Reputation: 43st's Avatar
    Jan 2013
    The problem with stretching out a tube, latex or other, is that once punctured the hole will naturally enlarge.
    Reputation: BlueCheesehead's Avatar
    Quote Originally Posted by 43st View Post
    I presume the OP is expecting to use the latex tube in a split tube application as the intention is to be "tubeless".
    The if one could find a latex tube for a 24x2.75" tire, like you can do for rubber tubes, a latex split tube setup would be nice.
    (note: latex, whether fattystripper or tube, is more permeable than rubber and will require pumping up more frequently)
  1. Replies: 7
    Last Post: 04-20-2017, 08:41 PM
  2. Big Bear Lake Ultra & Ultra Lite (WV) - August 1, 2015
    By BigBearLake - WV in forum Endurance XC Racing
    Last Post: 07-09-2015, 04:48 AM
  3. 29er latex tube
    By rydbyk in forum 29er Components
    Last Post: 02-23-2012, 08:11 AM
  4. stretched tire casings
    By stiingya in forum Wheels and Tires
    Last Post: 08-06-2011, 01:43 PM
  5. chain stretched out after 200 miles
    By ihaveagibsonsg in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-08-2011, 10:16 PM
