Results 1 to 64 of 64
    Reputation: E6roller's Avatar
    Apr 2013
    FATTY TUBELESS-ACTUAL WEIGHTS? and method?
    ANyone who has had excellent to perfect results with fatbike tubeless methods please respond.... Thank You!
    please, can we get some HONEST weights of tape, foam, weatherstripping, sealant, valve stems, ribbon, ribbon etc. ('honest weight' could be defined as "...I weighed this stuff on a digital postal scale reading out in grams...."...or some such real-world measurement that is not a guess or estimate).
    Also, what tubeless method or process did you use?
    Again, Thank You to those of you who've put in the effort to make this work.
    I would like to correlate the method and weight for future reference.
    PS...I'd like to stay on topic on this thread and keep it to weights and methods.......NOT a discussion of pros and cons of tube versus tubeless....if we possibly can
    aka bOb
    Reputation: bdundee's Avatar
    NO weights but Uma 90's, Stans fat tape and sealant. Two winters now and not a bit of problems down to 3-4psi. Tires used where BFl's and Bud.
    Sup
    Reputation: Burnt-Orange's Avatar
    Dec 2008
    its like your bike cant get any higher bdundee
    I am slow therefore I am
    Apr 2013
    Quote Originally Posted by bdundee View Post
    Thanks. We know what the 90's weigh. Your hub, spoke, and nipple choices...and brake disc choices, etc. retracted from the overall weight.....minus the published and/or real world weights of the BFL and Bud.....would net us a weight for stans prod...
    How much sealant are you using? That is likely the pertinent question if Stan's fat tape and sealant is all that is inside your BFL and Bud?!! No rim ribbon? no foam? Thanks for the answers! Cool to hear you've had zero problems down to 3-4!
    Nov 2008
    I converted my front wheel to tubeless on my 2013 Mukluk. Stock weight with Larry, Toob, rim strip, Custom 1 3/8" drilled Darryl, and 203 mm rotor was 3695 grams. For tubeless, I added one layer of colored duct tape, two layers of packing tape over that, and a double wide layer of 2" Gorilla tape. I had two rolls of Gorilla tape and I prelaminated the double wide with about a half inch overlap before laying on the rim. This helped mitigate wrinkles and when it did wrinkle its less likely to leak since it wrinkles in unison. I didn't use any foam. I mounted a Larry with a toob and pumped up to 20 psi and let sit for 10 minutes to make sure tape was seated well and to also seat one side of the bead. I broke one side of the bead, removed tube leaving other side of tire beaded. I then put in a tubeless valve stem with the core removed. I sprayed about a half second of starting fluid into the tire and lit it with a match. The resulting explosion beaded the one side of the tire that wasn't previously. Now with both sides beaded up, I added 6 oz of homemade tubeless sealnt (WSS1). Aired right up with no leaks or adverse affects. Weight after conversion was 3460 grams, so I saved 235 grams. 6 oz of goo was 190 grams, and the tape was a little over 100 grams.
    Reputation: BoogieMang's Avatar
    Mar 2011
    I have not weighed my Large Marge wheelset, but I did three wraps of gorilla tape, a Stan's valve with removable core, and about 4 scoops of Stan's sealant...
    I started with 3 scoops, but they needed to be pumped up pretty frequently. A fourth scoop seemed to do the trick, as they're holding well now. I could have put 10 wraps of gorilla tape around those rims, and 8 scoops of Stan's, and I bet it still would have weighed less than the stock Surly fat tube.
    Weatherstripping, foam, etc. do not seem to be necessary in my opinion. I can get the bead seated up pretty easily with an air compressor and a ratchet strap on the tire. If I flat with a tubeless setup on the trail, I'm putting a tube in anyways, so I don't think it's necessary to build up the center channel.
    I'm building up some new wheels and will convert them to tubeless. I'll weigh everything before I do and report some actual numbers.
    Apr 2013
    Sasquatch....Thank You! Great description.
    The missing data would be: inner tube size/weight/brand? and also Rim Strip type/weight?.
    Those key data points would be very helpful. Cool!!
    Apr 2013
    BoogieMang.....it'd be great to hear how the "materials" add up in your new wheelset build.
    Thanks for the info.
    oh...what tires on your LargeM. wheelset????
    I have the same setup, and will echo the "no problems" comment. The bead lock ridge on the UMA rims is what makes the setup work well at low pressures. Don't have any weights, sorry. I think I used 2.5 or 3 scoops of Stans sealant. The 27 tpi tires will hold air without sealant, so I only put enough in to help seal the bead and valve areas.
    Nov 2008
    Surly Toob - 450 grams
    Surly Black Rim Strip - 85 grams.
    I realize that my weights dont add up perfectly, but some were approximated. Looks like there is about 10 grams that got sucked into a black hole somewhere.
    Feb 2012
    Here is a method I have been using and have had better success than the other method I have tried spilt tube, duct tape. Also I think they weight a lot less and I use no liquid seal, but I have not did an actual weight.
    1. I use a foam tape that you use to seal metal roof panels with. I stick it at a 45% angle on the bead and the flat of the rim the 2 ends I glue together with a drop of super glue
    2. I use shrink wrap that comes in 6” wide rolls. It needs to wrap over the bead of the rim about 8 wraps works well but make sure they all are over the bead or up may have a slow leak.
    3. install a valve stem I use one I cut out of a motorcycle tube with the treaded stem so you can tighten it down. Yes it is a standard type valve I like them better, but I think either would work fine.
    4. Install the tire and pressurize it I have had great success getting them to fill with ease because the shrink wrap seals against the tire bead.
    FATTY TUBELESS Summary of methods & ACTUAL WEIGHTS?-img-20130322-00081.jpgFATTY TUBELESS Summary of methods & ACTUAL WEIGHTS?-img-20130322-00083.jpgFATTY TUBELESS Summary of methods & ACTUAL WEIGHTS?-img-20130323-00084.jpg
    Feb 2012
    I have ran this tubeless at 3 or 4 pounds of pressure with no problems. I have a few hundred miles on them in all type of conditions and have had no failures.
    Apr 2013
    Thanks exp18 (a/c reference?? I think we met.
    I tried what you describe but I thought the glazing tape went against the tire rubber..
    In your photos I see I was not doing as you said to. Thanks. I will do this again.
    Any issues with tire-carcass porosity/pinholes?
    Thanks again. Your method is the lightest. I weighed the materials!
    Mar 2011
    Quote Originally Posted by E6roller View Post
    One is a Larry, one HuDu
    Smash Mode: ON
    Reputation: Dustin Mustangs's Avatar
    Lots of responses to this thread but not many answers to the OP's question!
    I am running RD's with gorrilla tape tubeless. Ribbon as a rim strip (14g), one layer of extra wide extra tough GT down the middle, followed by two layers of standard GT about 1 1/2" wide on each bead shelf and down onto the middle layer. Side note: without the bead shelf layers four separate tires leaked at the bead with these rims. Presta valve cut from old tube attached with ~4" of standard GT.
    Not including the decorative rim strip, the GT and valve comes out to around 200g doing it this way. I have successfully run as little as 6 fl oz of sealant in a 4" tire but imo 8-10 is more appropriate (10-12 for 5") and stans is about 30g per fl oz.
    Soooooo, GT tubeless at 200g + 8 fl oz of stans at 240g = 440g. Same scale has the stock surly tube at 480g, Qtubes superlight 2.4-2.7 at 243g, and surly rim strip at 88g.
    I don't want to take this thread off-course, but I think it is worth mentioning here that sealant (especially when used in excess) should not be considered rotational weight.
    Whatever floats your bike, dude
    Nov 2012
    Wait a minute...
    The OP wants everyone that did a tubeless conversion to go to a good bit of trouble to compile and repost the info that he wants to see. There are quite a few threads where people have gone into detail about what they have done, how well it worked, and very often what everything weighed.
    Has the OP spent any time looking for and reading that info? If so, maybe he could do everyone else a service and summarize what he has found for the benefit of all. If he hasn't, well...
    I go into great detail about my tubeless setup here: On-One Fatty Wheelset and Floater Tire Tubeless Setup (How To) I don't feel obligated to provide a Cliff notes version for those that don't want to spend the time reading what I wrote!
    Smash Mode: ON
    Maybe I am mistaken, but it seems to me like he is specifically asking about the, and I quote, ACTUAL WEIGHTS involved in these different techniques and only one post other than my own gives that info.
    Just sayin!
    Darryl rims with 1 3/8 holes cut in. Surly rim strip. Basically JoeG method above but 3" gorilla tape fits the Darryl rim perfectly so a wrap of 3" tape and your good to go. This alone holes air pretty well but I add 1 to 1 1/2 scope of Stan's to ensure eve thing seals up. I normally run 5-7psi but have run down to 2 lbs in heavy snow conditions. Sorry no weights but JoeG outlines it very well.
    Apr 2013
    Thanks for any and all information posted and shared in this thread.
    I apologize if my initial post/request was not clear enough.
    I am, as Dustin has defended me for, asking specifically for actual, real world, measured weights of any method of tubeless a person has made work reliably. I also am asking for a summary of the method. If someone includes more info. in a reply, or if I ask what tire they tried, please accept my apology for use of the extra bandwidth.
    ...Can we take 'er easy? Maybe we oughtta all "..just shut up and ride...", as my wife often says.
    Thanks. Peace.
    Anchorage, AK
    Reputation: Lars_D's Avatar
    Just for comparison my tube setup only weighs about 212 grams--190 for the tube (Schwalbe SV13F Extra Lights, 26 x 2.10-3.00) and 22 for single strip of regular duck tape (with some talcum powder to keep it from sticking to the tube). I doubt any tubeless setup will get anywhere near as light and even if it did the weight savings would be very minimal. There may be ride quality or puncture resistance benefits to tubeless setups, but I doubt there is any meaningful weight benefits.
    --Peace
    Quote Originally Posted by Lars_D View Post
    This is why I didn't bother to weigh mine when I switched them over. I was more interested in the improved traction and ride quality (which is significant) than the possible weight savings.
    aka bOb
    Quote Originally Posted by Andy FitzGibbon View Post
    ^^^This^^^
    Apr 2013
    Thanks to all.
    In this thread, I really was hoping to summarize, or group, or list the various tubeless methods, their effectivity and longevity, and actual measured weights. It is a summary
    I asked this as a way to conveniently elucidate myself and the community in response to the mention on the carbon fiber fat-wheel thread that a tubeless setup would save weight.
    I am new to this forum. I apologize again to the long-standing members who feel I may have breached site-etiquette.
    Apr 2013
    I will search for a summary of the benefits of tubed versus tubeless fatties!
    Any links to pertinent data would be appreciated.
    JoeG, nice job on the tutorial of your method. Thanks for the link!
    Mar 2013
    i recently had purchaced one of the Schwalbe SV13F Extra Lights, 26 x 2.10-3.00 as recommended what i did notice about this tube is it doesnt fill the tyre completly because my rim tape was bulged out at a 15psi with the one one fatty tube, but the Schwalbe SV13F didnt even come close i could put my finger in the rim tape(you might not notice this and i wouldnt of because the tyre felt good and only noticed due to having rim drilled ,it even looked loose) so before going to bed i thought i would pump it up to 20psi to stretch abit ,,AND THEN BANG tube popped glad i wasnt going down hill trail ,the Schwalbe SV13F dont even look like they should pump up 4 inch tyres ,,wheels was all clean didnt do it with my other tube ,,
    i am not saying there not ok just a warning dont want anyone to have an accident
    Anchorage, AK
    Quote Originally Posted by stesteste View Post
    Stesteste,
    I have not had one pop on me but I did have one tube that I couldn't get to fill the tire. I'd say that the SV13Fs are about a thin as you can go on a fat bike and as a result, a certain percentage of the tubes won't work (those on the thinner end of the manufacturing tolerance). That said, on those tubes that I have gotten to fill the tire I have had great success. I have about 2,000 miles the one in my front tire, and about 1500 on the one in my rear with no ruptures, no flats, and almost no air loss. Of course, your results may vary and there is always some risk that one of them will burst in service.
    --Peace
    Feb 2012
    Hi E6roller we did meet a while back at the LBS very cool rims love to see you are getting them out there. I did change a little how I am doing my tubeless the way I showed is easier and gets a better seal. Sometime in the near future I will put the materials on a scale for kicks and see what it weights. The lack of having to put sealer in is a big savings that cannot be over looked. When you put sealer in that weight is at the farthest point from center which is the worst possible place to add weight. That would defeat the propose of carbon rims.
    Apr 2013
    Thanks 18
    Will try it soon.
    Got the glazing tape at Speedy Glass, but not sure it is the product you have used to good effect.
    Feb 2012
    Glazing tape should work fine
    Shameless Plug!
    I set up my Front Bud on a Marge Lite using just a Clown Shoe Rim Strip and some slime pro. For the rear, Nate on a Marge Lite, I used gorilla tape over the Marge Lite strip and Stan's.
    The first methods lost air for the first ride or two but then set up fine and hasn't lost air in weeks and many rides. The rear set right up but I did get an odd overnight flat one time in between rides.
    I think a wrap of Gorilla tape is 90g and you need 2 wraps. I want to say the CS strip is 145g or something and the ML strip is a bit more than half that. I used about 3-6oz of sealant in each.
    Apr 2013
    Thanks for the report, BearSpleen.
    I'd love to hear of others' who have tried EXP18's method.
    It is lightwieght! and also shouldn't make a mess! ..in other wise...if it worked for him, it oughtta be a good experiement for the rest of us.
    I weighed the plastic and glazing tape that I removed after I incorrectly attempted his method.
    It was like 54 grams total or something. I'll be trying it again!!
    Mar 2013
    Re: FATTY TUBELESS Summary of methods & ACTUAL WEIGHTS?
    Quote Originally Posted by exp18 View Post
    xo you have a lclose up view of the faom sitti g on tbe rim bead, not sure exactly where it is also a close up of the foam or link so i can source it thanks good job
ID:	787354Click image for larger version.
ID:	787355Click image for larger version.
    Sent from my GT-N7100 using Tapatalk 2
    Fat & Single
    Reputation: ozzybmx's Avatar
    Do a search with "tubeless" in the Fat Bike forum, my search threw up 47 results, have a look through there as we have done quite a bit of tubeless chat prior to you joining 3 days ago.
    Evil Following
    Trek 9.9 Superfly SL
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
    I recently switched to tubeless on my new 907. I don't know wheel+tire weights but i weighed everything that came out and everything that went in. I did a foam-in-the-valley style with stuff I had laying around. The foam seems unworthwhile. It seated great (with a hand pump and no strap) the first time, but after a few days with pressure the foam had deformed and didn't do much anymore. Holy RD + BFL lites. Out Came: surly rim strip, non surly tube (standard butyl, not sure brand or size) and
    In Went: 1 wrap lightweight tape sticky side in to cover holes,
    some foam weather stripping, enough to make nice tight fit to tire bead for seating,
    1 double wide wrap of gorilla tape plus about 6 inches over valve stem (presta cut out of old tube),
    and about a scoop and a half-2 scoops of stans.
    been working great so far (not very long yet)
    saved 200g per tire. next time I'll omit the foam altogether and save another 20-30 per tire
    Apr 2013
    Quote Originally Posted by ozzybmx View Post
    Ozzy...please accept my apology. I'm pretty new to the web forum "thing".
    Again, my goal was to summarize tubeless methods and correllate ACTUAL WEIGHTS in one thread if that is possible. A "fresh" thread seemed like a reasonable way to attempt that goal.
    PS My wife has been a member of this forum for some years.
    Fat & Single
    No need to apologize. The advance search function here is pretty good and can find most stuff, all I'm saying is theres been a lot of discussion in the past year since I got fat and long before I arrived here. Ive spent a lot of time here reading all different threads and I have found MTBR to the best source of info (and links) anywhere.... get reading
    Evil Following
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
    Apr 2013
    Okay.
    So I will post what I learn in my research for weights.
    Anyone who knows this stuff offhand, consider this a second invitation to add your knowledge now.
    Anyone who has a moment to weight your goo and tape and valve stems,,,,, please do!
    Apr 2013
    Tough searching on the site here. No results. Probably operator error....me.
    Ozzy's link to 47 hits was a dead link, or whatever you call it.
    Will try again soon.
    I weighed the materials in the "EXP18"-method. only 29 grams total!!!!
    The foam tape on the sides weighs less than 2 grams.
    The plastic "wrap" weighs 21 grams.
    The valve stem weighs 6 grams.
    This is by far (!) the lightest tubeless method I have heard about.
    Smash Mode: ON
    A little search help for you... Go to the fatbike forum, click the search forum button on the grey bar in the upper right. Click advanced search. Put in keyword tubeless and directly to the right make sure to select search titles only. That should keep you busy for a while.
    Oh, and something about using plastic wrap for this makes my palms sweaty.
    Apr 2013
    ..ps. that is 8 times around the rim.
    plastic wide enough for an 80mm rim.
    exp18 has fiddled with several different ghetto tubeless methods.
    .....sounds like this one works.
    Feb 2012
    Cool I have done several tire changes had good sucess takes a few tries to get a good system and a few tricks but i have never had it fail after you get it sealed. Sorry i have been hard to contact. Been busy at work and riding after work.
    Apr 2013
    Okay, I've been using the search function and am not really satisfied that the search results have been either consistent or complete. (the problem might still be me, so I will keep trying)
    Anyway....I do not feel like asking a question that has been previously answered in some old thread is a reason to not simply answer the question the newbie (me) asked. If you've been on here for a couple of years, please give the newbie some grace and help him out. (it should be "...the more, the merrier...", otherwise, all you have is a collection of old discussions)
    So....please, keep the data coming. Thank You.
    NMBP
    Reputation: crashtestdummy's Avatar
    Jun 2005
    Don't despair, any moron can say "use the search". It takes a little bit of intelligence to actually help somebody out. I have found the search functions to be mostly useless. Just like this post, threads get bogged down with a lot of meaningless crap that makes them difficult to navigate. I wish someone would take the help threads, then dissect the garbage out, then post them somewhere safe.
    The other issue I have found is the change in technology and the available parts. Tubeless help for a 2.5" tire doesn't necessarily equal tubeless for a fat tire, or even 3.8 vs 4.8.
    This post has several tubeless links to more recent tubeless posts. What happened to all of the tubeless posts?
    Reputation: cujarrett's Avatar
    I recently converted my fat wheels to tubeless. My setup was Surly Holy Rolling Darryls, Knard 120 TPI, Big Fat Larry 120 TPI, Gorilla Tape, Stans valves, Stans sealant.
    I documented the conversion on my blog: Cycles In Life
    Shameless Plug!
    Little update, I have moved to the Marge Rim w/ Clown Shoe rim strip for all tubeless setups now, and am down to about 5 minutes per setup.
    Simply replace the marge rim strip with the clown shoe rim strip, taking care to tuck the strip under the bead.
    Pump up the tire to 30psi with a tube in it to seat the bead.
    Unseat one side, remove the tube.
    Put in a tubeless valve, replace the tire, add sealant (I use 4-6oz now)
    Place the wheel on a trash can, seated side up, and hit it with a compressor. Gravity should take care of the rest. Spin and bounce several times and you're good to go.
    Nov 2008
    Quote Originally Posted by Bear Spleen View Post
    Lovin this idea. I don't run foam and use gorilla tape to make a rim strip. After about 4 months of tubeless the sealant is starting to weep in between gorilla layers. You know how much a clown shoe strip weighs?
    Shameless Plug!
    Quote Originally Posted by Sasquatch1413 View Post
    95g
    Dec 2011
    So are you only using the clown Shoe rim strip, no foam, no nothing?
    Feb 2012
    Quote Originally Posted by cujarrett View Post
    Ha! I was just about to come here and share your blog. Great job, Matt, cheers!
    Shameless Plug!
    Just the clown shoe strip and sealant, nothing else. It's been a little under a year with this setup and the only "negative" is that the pvc bulges from the rim cutouts quite a bit after a while. Hasn't caused an issue yet.
    Quote Originally Posted by Raul34 View Post
    Thanks sir!
    Team Captain
    If weight isn't a concern, I bet you could run a Marge Lite strip under the clownshoe strip to cut down on some of the excess bulge.
    Reputation: kyttyra's Avatar
    Mar 2012
    Nice! My current setup is 50 mm satin tape reinforced with duct tape (≈35 g/wheel) with Schwalbe tubes (≈200 g). If I did my math correctly, a Clown shoe rim strip + satin tape (with only a small strip of duct tape to keep it together) + sealant + valve should have a unsignificant weight penalty (20-30 g per wheel: I know, I'm a weight weenie ) but hopefully with significant benefits
    I will have to try this method as soon as I have the time.
    EDIT and I did. 25 g weight penalty, and the rim strip bulges quite much but the air seems to stay in And in any case, it is unlikely that I will need that much air pressure, probably max 1 bar.
    At 1.2 bar the rim strip looks like this. Should I be worried o_O
    EDIT2 ...I could not watch that bulging. So, wash, rinse, repeat - but this time I put a DIY rim strip (satin tape+duct tape) under the clownshoe rim strip . So far everything looks good.
    Jun 2010
    I'm planning to set up a set of Marge Lites tubeless using the Clownshoe rim strip as suggested here.
    I'm hoping that I won't suffer the bulging seen above if running <10 psi. If it becomes a problem, I suppose I can add reinforcement on the inside of the rim tape (to retain the color through cutouts).
    Can anyone shed more light on longevity of rimstrip with or without reinforcement when run tubeless?
    Shameless Plug!
    Hi, it's been about 500 miles and I haven't lost any air, nor have the bulges grown or been a nuisance in any way. Pretty golden setup, if you ask me. If you're worried, just use the marge lite strip underneath the clown shoe one as a backup.
    Dec 2011
    I run a ML strip under the Clown Shoe strip and have none of the bulging as is the pictures. Looks just like it did with a tube. I've been using this set up for 4 months with no problems.
    Jun 2010
    Quote Originally Posted by slabber View Post
    Set up a pair of Vee Snowshoe tires on Marge Lites using Clownshoe rim strips - one took less than 30 secs to seat/seal, the other took a bit longer, but less than 2 minutes.
    Overall, very easy to do and satisfying. Currently running ~6psi. Will see if I drop it any further.
    As far as I'm concerned the bulging adds more volume of air which is good. Even better if the system isn't ridged as if gives a little more squish for the larger hits. I have never run the clownshoe so have no experience with what works on that setup. I have always left the Surly rim strip in as it has given me a level of confidence with the additional strength and flexibility with the larger cutouts. No science behind the bulge but it seems to make sense to me and when I set it up this way it always feels better?
    Aly
    Aly is offline
    Sep 2015
    Question :
    Do I need the stock rim strip for tubeless setup ?
    Can I simply go with a round of sealing rim tape (like Gorilla tape) ?
    Jun 2016
    Try This, It works great for me.
    1) Do the usual Gorilla Taping of interior rim.
    2) I then paint over the Gorilla Tape and rim sidewall with Rubber Cement or one
    could use Liquid Rubber or similar rubber paint. With Rubber Cement you need to
    powder the inside of rim with talcum powder cause it drys tacky.
    3) Mount both tire and tube onto rim, inflate and center rim.
    4) Place wheel horizontal on 5 gallon bucket.
    5) Release enough air so that tire bead is easily pushed away and down from rim.
    6) Here's the Good part! With a caulking gun, Run a continuous 1/8-1/4" bead of Seal
    and Peel Temporary Caulking Compound into bead groove on tire. One side only!
    7) Inflate tire to full inflation. Use a blade or caulk removal tool to scrape away excess
    caulking compound.
    8) Wait 20-30 minutes. Flip wheel over so Caulking side is down. Deflate tire.
    9) Without disturbing bead that is "glued" remove tube from wheel.
    10) Insert Tubeless Stem using Seal and Peel Compound to help seal stem.
    11) Reinsert tire bead into rim. Make sure it is centered.
    12) Run a similar 1/8-1/4" continuous bead of Seal and Peel around tire bead groove.
    13) Flip wheel over on bucket to let gravity help stick bead to rim.
    14) Inflate with floor pump or compressor. (I have been able to ride on my wheels
    even without tire sealant.)
    15) Wait 20-30 min. I don't wait that long. Deflate tire.
    16) If you have not removed valve core, do so now.
    17) Inject your desired amount of sealant. Re-inflate and marvel at how much sealant
    is not leaking out of your tire and rim.
    18) Re-insert valve core.
    I have been doing this on 29+ wheels and believe it will also be a great method for Fat Tires. Been on several bone shaking rides with roots and rocks everywhere and have yet to even get a slight burp, The tire beads are literally stuck to the rim. I have removed tires with this set up and the Seal and Peel is easily removed. Not so sure about its long term use with regards to removal. Good Luck!
    Merendon Junkie
    Reputation: abelfonseca's Avatar
    Dec 2011
    Mulefut 80sl with maxxis minions 4.8. They came stock on my BD Ti fatbike.
    Picked up a roll of gorilla clear repair tape from the supermarket. Its about 2 inches wide.
    One pass on each side of the rim with about a 5 inch overlap opposite of the valve hole. The tape will overlap about 1/2 and inch down the middle of the rim. I cleaned the rim and rim strip with IPA first.
    Inflated the tire with a tube. Broke the bead on one side to remove the tube and place a tubeless valve.
    I had to use a ratcheting strap to pull the bead to the side. I inflated the tire with a floor pump and the tire held air with no sealant. 10 minutes later I added sealent through the valve.
    Lost about 220 grams per wheel and they havent lost any air that I could notice. Already have two rides con the setup. Seems solid!
    Reputation: CrankAddictRich's Avatar
    Oct 2016
    Converted my 2016 Fatboy Comp 686 Edition last Sunday with the help of a friend. We used 2" wide Gorilla tape, Stan's 35mm valves, and Stan's sealant. Here's the process.
    1. Removed tires and tubes
    2. Taped the rim with 1 single strip down the center, starting 1 spoke hole away from the valve hole and ending 1 spoke beyond the valve hole after completing the wrap.
    3. We remounted the tire and tubes and pumped up to 15ish psi (maybe a little more, basically just enough to seat the beads on the tires).
    4. Broke the bead on one side and pulled the tube out, being careful not to break the bead on the other side.
    5. Poured about 3oz. of Stan's into the bottom of the open tire and began remounting the tire, slowly turning the wheel so the Stan's remind in the bottom of the now mounted tire.
    6. Once tire was fully mounted, used compressor on valve with core removed to pump up tire and reseat the bead.
    7. Put valve core back in and set the psi to 15 psi... rode the bike around the block for 10-15 minutes, swerving back and forth, trying to get the sealant inside to spread around as much as possible.
    8. The took the bikes to the beach and we did a 90 minute back ride at 8 psi.
    The tires held pressure for the rest of the day with no problem. I rode one mortise that afternoon.
    The next day, they were a little low, but i pumped them up and rode around some more and they've been good to go ever since.
    The biggest leaks came from the weld seams of the wheels. I'm wondering If we had done two overlapping wraps of the tape, moving each one further to the side so they overlapped in the middle of the wheel, if that would have helped seal the seams better, but they seem to be holding, so I'll leave as is for now.
    NMBP
    Jun 2005
    I tried the tape and Clownshoe rim strip method. First time it was OK. Second time the Clownshoe rim strip blew out (it's not elastic), and I had leaking tape issues. Also the Stans valves don't seal tight to a Clownshoe.
    I stripped everything down and started over using Fattystripper's rim strips, latex liner and valves. Everything worked great and no screwing around with a system that may or may not work.
    FattyStripper Tubeless Fat Bike Solution and SkinnyStripper Tubeless CX & DH Solution
    Don't google fatty stripper.
    Riding Fat and still just as fast as I never was.
    Buy bike with tubeless rims, 80 mm jackalopes. Take out tubes. Put in 1/2 cup stans, inflate with floor pump, go ride. Worked well with hodags and Spec. fast tracks. Both TLR tires.
  1. Nate 120tpi actual weights?
    By 69tr6r in forum Fat bikes
    Last Post: 05-08-2016, 11:27 AM
  2. Actual weights of 650b tires
    By OldManBike in forum 27.5
    Last Post: 05-18-2013, 02:23 PM
  3. creative methods of fixing tubeless tires on the trail
    By shackleton47 in forum Wheels and Tires
    Last Post: 12-15-2012, 05:45 PM
  4. Any actual weights of these two frames?
    By MarkyMarksXC in forum Weight Weenies
    Last Post: 09-08-2011, 04:19 PM
  5. 2012 actual weights shown at bikerumor
    By vizsladog in forum Specialized
    Last Post: 08-08-2011, 01:38 PM
Members who have read this thread: 14
