Page 5 of 6 FirstFirst 123456 LastLast
Results 201 to 250 of 261
  1. #201
    Reputation: watts888's Avatar
    Oct 2012
    Quote Originally Posted by aredemann View Post
    Anything I could do to seal it better from the get go?
    Everyone will have a different method. My method is using an old tube (make sure it has a removable valve core). Cut it out of the tube and leave a 1" diameter circle. Use a piece of gorilla or electrical tape to seal the edge of the old tube material to the inside of the rim's tape. I don't trust using the valve stem nut to hold the seal tight. I've also had to remove a tubeless valve on the trail, and if the nut is on too tight, it's a bear to get off.
    "a hundred travel books isn't worth one real trip"
  2. #202
    SimonsJ
    Valve leaks are by far the most common source of any leaks when using the FattyStripper bands. Here is a check list that may help...
    1) When installing the bands, be sure to put the valves through the latex before putting the latex onto the rims. If you try to insert after putting on the rims, often the valve will pull the latex down between the valve and the rim's hole and bind. Often... this can cut the latex at the valve hole, which by itself isn't the end of the world, but I do recommend putting some tape under the cut to reinforce the latex and re-doing it properly.
    2) After putting the latex on the rim, look to make sure that the latex is not stretched at the valve hole or pulling the valve to any one side. Basically, relax the latex at the valve, then put on the plastic spacer, lock nut and tighten.
    Another trick? I put sealant on all of the valve's threads (dip the valve) before putting on the lock nut. The latex in the sealant makes a perfect loctite to keep the nut from working loose... yet can easily be removed with your fingers if you want to take it off.
    3) The main reason for the extra piece of tube to make a "gasket" is to help build up the valve's base so that it doesn't pull through the single wall rim as far. When the valve pulls through the rim, it causes the lock washer to run out of threads before it gets sufficiently tight. The plastic spacer helps achieve this goal too while it also lifts the metal lock nut up off of the flat rim's surface, making it much easier to get your fingers on.
    If the latex is relaxed and the valve fully tightened... you shouldn't get any leakage via the valve stem's hole.
    I have done three fatboy wheels by now with little problems. However, I always get a bit of leaking around the valve. It will seal eventually, once I add Stans. I use a double layer of cut up tire between the valve and the stripper. Anything I could do to seal it better from the get go?
  3. #203
    Sep 2004
    Has anyone been able to reuse a fattystripper? When I attempted to remove one that was supposed to be glued to the rim, it was actually bonded to the tire with no way to remove it without destroying it.
  4. #204
    Reputation: Jeff_G's Avatar
    Oct 2015
    I had a large stick go through my tire and then poke through the latex and bling strip. I plugged the tire but didn't notice the hole in the rim strip. It was a very small hole that the sealant filled, until I flicked it with my finger.
    I had to break one bead down to fix it. It came off with the FS still held to the rim. And I was able to reseat and it's held.
    When I installed it originally I used the Elmer's glue on the rim then some petroleum lube on the tire.
    "At least I'm enjoying the ride"
    16' Trek 8.4 DS
    16' Farley 7
    and I'm OK admitting..
    16' Sturgis
    Minneapolis MN
  5. #205
    Quote Originally Posted by watts888 View Post
    Using regular valve stems, i couldn't get the stem to seal, in part because I had torn the strip a little bit before I started. Instead, I drilled the rims out for shraeder, installed the 949 Racing stems, and added a rubber gasket to help seal the hole. now it works great, the valve is super secure and there are no leaks. Presta valve stems just aren't that great IMHO - the 949 stuff is great.
  6. #206
    Oct 2015
    Quote Originally Posted by alexkraemer View Post
    What happens if you go back to a tube?
    16' Trek 8.4 DS
    16' Farley 7
    16' Sturgis
    Minneapolis MN
  7. #207
    Reputation: Swerny's Avatar
    Quote Originally Posted by Jeff_G View Post
    he would have to run Schraeder
    Mike
    Toronto, Canada
    2016 Trek Farley 7
    2015 RSD Mayor Bluto (sold)
    2014 Giant TCX SLR1
    2012 Giant TCR Advanced SL3
  8. #208
    Reputation: watermonkey's Avatar
    I've run the 949 valves too. They're awesome. The only reason I don't use them on all my fatbikes is because my low pressure gauge and CO2 inflators are presta. If you drill out for schrader, you can still use presta valved tubes, you just need an adapter - its a little aluminum sleeve that takes up the gap. Work great - even going from schrader to presta ghetto tubeless - tool lazy to look for a pic or link, but they're readily available. BTW, the 949 valves weigh less than my Stan's valves.
    I would advise not taking my advice.
  9. #209
    Quote Originally Posted by BIke N Gear View Post
    I would re-use the fatty stripper with the same tire and pair a new strip with the new tire.
  10. #210
    Oct 2015
    Quote Originally Posted by coldbike View Post
    The valve stem would be a pesky problem......
    16' Trek 8.4 DS
    16' Farley 7
    16' Sturgis
    Minneapolis MN
  11. #211
    You would want to keep it with the strip I suspect. I have done this with split tube, which has the valve built in, but it should be feasible with the strippers. The hole probably stretches enough to pull it out, but it would be a high tear risk
  12. #212
    Quote Originally Posted by Swerny View Post
    Outside of an emergency scenario, I can't imagine having to put a tube in, but now I will add a presta-shraeder adapter to my frame bag in case I have to make a swap to my back-up tubes.
  13. #213
    [QUOTE=SimonsJ;12616510]Valve leaks are by far the most common source of any leaks when using the FattyStripper bands. Here is a check list that may help...
    Do you mean to put tape between the rim around the whole, below the latex tape?
  14. #214
    SimonsJ
    [QUOTE=aredemann;12618402]
    Quote Originally Posted by SimonsJ View Post
    No tape reinforcing is necessary unless you damage the hole punched in the latex to the point where it doesn't fit snugly onto the valve. My suggestion was to put a piece of tape directly onto the latex, over the hole, on the non-sealant exposed side to reinforce the hole (after it got damaged). You can just re-poke a clean hole through the tape where the hole in the latex is. This will just make a clean hole for the valve to push against & create a solid seal.
  15. #215
    Not the fake Jay Leno
    Reputation: Chinman's Avatar
    Dec 2014
    So I finally got my 26x4 Fat b Nimbles setup tubeless on Marge Lites on my Pugsley. FBNs have to be some of the toughest tires to setup tubeless. I tried pretty much everything, but I eventually got it to work with the Fattystripper. I tried the foam backer rods and they did not help. What finally worked was setting the beads with the fattystripper and a tube installed. I then broke the bead on one side, installed the valve, put a strap around the tire, sprayed lots of soapy water on the bead, set the tire on a bucket with the loose bead down, and aired up with my Joe Blow floor pump. I rode the FBNs on my Fatboy last summer and liked the lower weight, but didn't like the drop in the BB. These are great summer tires on the Pug with Marge Lites. The traction feels better than the knards and they roll great. I ran the front tire at 4.5 psi with the fattystripper installed. That was probably a bit lower than I should have, but it worked fine on the trail with no self steer or burping.
  16. #216
    because GIANT
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    26 inch Hodags on MuleFut 80 did fattystripper last night.
    crazy how easy it is. holds air all night no sealant whatsoever. but i put
    in 4 oz each a blend of 2oz orange seal and the 2oz fattyspooge they send with the
    fattystripper 'kit'
    for bead lube I use a dab of laundry detergent in a bowl of water, so much more slippery than dishsoap
    anyhow, ridiculous how easy this is, and seals tight
    floorpumped it up with core removed,
  17. #217
    Oct 2012
    Is this the same/similar backer rod? And do the backer rods shrink down in time eliminating any bead retaining capability? Any other easily obtainable foams that don't collapse in time?
    Frost King E/O 3/8 in. x 20 ft. Caulk Saver-C21H - The Home Depot
    MD Building Products 3/8 in. x 240 in. Backer Rod-71464 - The Home Depot
  18. #218
    Oct 2012
  19. #219
    Has anyone been able to contact them?
    I had something that needed straightening out on an order and have not recieved replies to multiple emails
  20. #220
    Jon BALER
    Quote Originally Posted by Ohfugit View Post
    Yes, exchanged emails with them more than once. Never had an issue.
  21. #221
    ok good.
    Maybe it's getting blocked or something. Nothing in the spam folder.
  22. #222
    Norđwegr
    Reputation: Vegard's Avatar
    I prefer the stans tlr valve as it's threaded all the way. Removes the need to build up the valve.
    I got prompt replies aswell.
  23. #223
    figured it out. thanks.
  24. #224
    Are the strippers now black instead of red?
  25. #225
    Quote Originally Posted by cdn11 View Post
    Guess I should word that better.
    After looking on the fatty stripper site, I noticed that the pictures are of black material instead of the original red colour.
  26. #226
    Nov 2015
    Yes, the last ones I ordered were black.
    MiTT
    Denver Metro (Front Range), Colorado
    '15 Speciaized Fatboy Expert
    '00 Yeti ARC
    '12 Novara Buzz
  27. #227
    Reputation: baltobrewer's Avatar
    Apr 2015
    Yes, black. My guess is that it's to make the little bits that are left once you trim the outside latex less noticeable. As an aside, I had a sidewall rupture and had to replace a tire, Used the FS's again, and again, sealed up like a champ. Great product!
  28. #228
    Good to hear they are now black. Maybe I'll try them out!
  29. #229
    Sep 2004
    Quote Originally Posted by baltobrewer View Post
    How were you able to re-use the FS? Every one I have removed has been bonded to the tire, whether glued to the rim or not.
  30. #230
    thought it meant Mt. Beer
    Reputation: bbender785's Avatar
    Sep 2015
    to follow up on this:
    Quote Originally Posted by Chinman View Post
    I have to say, after doing 2 sets of Fatboy SE rims with this system I'm very impressed. The latex band and valve only adds about 100 g to the rim, which is hard to beat. The wire bead Ground Control tires required a strap around the tire to seat them, but my folding bead Ground Control tires did not and aired up with a floor pump. I didn't use the petro jelly. I just spayed soapy water, which worked awesome. You'll need the soapy water anyway to check for leaks along the bead edge. The red bling strips look killer on the stealth Fatboy SE too.
    the same way i did my Sport GC's on my Fatboy SE, but didn't go quite as smoothly. as said elsewhere the nice thing about using soap as a lube is it shows you leaks when aired up... well i found a few:
    the sidewall pinholes were aplenty and the beads leaked all the way around on both sides of both tires. these tires had 400 miles of tubed use before this and are wire bead for what it's worth. I also was not able to get a bead "pop" from any of the four beads, even when using an air compressor with valve stem cores removed. this was October 27, and as of this weekend i still get a little bubbling at the bead here and there (2oz Stans front, 3oz rear). they've been fine, and i'll probably run 4oz in both to be safe, but i would recommend and use the system again, as the bike came ALIVE with the conversion.
    VILLAGE RACING
  31. #231
    Nov 2016
    Looking at ordering a pack of these from the state's after Xmas. How do you bond the foam backing rods to your rims? Pretty sure I'm going to have issues with my wheels.
  32. #232
    Oct 2012
    Quote Originally Posted by dahedd View Post
    The instructions from FS says to glue down the latex band to the rim. I'd try to glue them down, and if that doesn't work, a few strips of electrical tape will hold them in place until the fatty stripper strip is installed.
  33. #233
    Sep 2015
    the revised instructions that come with the bands actually go back on the recommendation of using glue; he basically says don't bother. but in the case of tubing you could try it.
    VILLAGE RACING
  34. #234
    Have been using the FS now for a while and also always get leaking along the valve. I have only used 2-3 layers of cut tubing inside the tire between stem and FS but not on the rim side. So to recap: put a 1-2 pieces of 1inch tubing on the valve facing the rim and another piece on the inside, so the FS is surrounded by the rubber tubing acting as a gasket?
  35. #235
    Oct 2012
    Yea, I'll still tape it. It's not like you're getting any stretching of the fatty stripper once you get it installed, so the tape will stay where you put it. Just have to make sure it's sealed well around the valve.
  36. #236
    Nov 2016
    Source of frustration for me atm. USPS shows a bad adress was used (name of billing address, but street etc of delivery adress). Paypal receipt shows the delivery adress was correct. Despite USPS telling me it was using no trackable service, it still shows in tracking and is stuck in the target country airport since Dec 7. Handover, local delivery for USPS (DHL) has nothing in the database and jim does not respond to my half a dozen emails since
  37. #237
    Dec 2016
    he is out for a month
  38. #238
    Reputation: Teton29er's Avatar
    HI Guys,
    Thought I'd contribute some experiences with 4 different rims and 4 different valve stems.
    1) Specialized 20 kids fat bike. Tedious to get the small band installed, but I finally got it. Tire required cam strap and strong compresser to seat. Leaked quite a bit and when it lost pressure overnite fell off the rim shoulder requiring starting over again. Finally doing ok after some baby sitting and adding air.
    2) Farley 24 fatbike. Used the adult size stripper band it was super easy to put on. Required cam strap and strong compresser. Had slow leaks for 3 days, but now set up fine.
    3) Clownshoe with D5's. Again, cam strap and compresser needed to seat. Held air very well right away.
    4) Mulefut 80's and D4's. Easiest yet. No cam strap required to set tire. Inflated quickly and held air without a leak right away. When air was let out to add sealant, bead stayed fully locked in.
    Now, on to the subject of valve stems. The ones Fatty stripper sells work fine with a thick tire patch and the included spacer. Stans and another lookalike brand work fine with store bought o-ring or tire patch. But here's my favorite yet: Doesn't need anything else--comes with nice o-rings and I like the red color to help find the stem quickly:
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Fatty stripper is by far the best tubeless method I"ve used. Now if we could only convince all rim makers to stop making it so dang hard to go tubeless so we don't need the product at all. (such as my trek jackalops which came from the factory taped and ready to inflate tubeless with a HAND PUMP).
  39. #239
    Sep 2004
    What advantage do these strips have over stretch wrap with Mulefuts?
    I wrap the rims, install stans valves and inflate with a floor pump.
    But the wrap cannot be reused if you want to swap tires. I guess the good point of the stretch wrap is no clean up.
    Can the fatty stripper be used again?
  40. #240
    Dec 2014
    Quote Originally Posted by headwind View Post
    I have had some success at reusing them. Because the strip stays glued to the tire, when swapping tires, you will need anther set of strips and valves for your second set of tires. Just carefully remove the tire from the rim and the strip should stay on.
  41. #241
    Sep 2004
    How do you clean out the sealant?
  42. #242
    Dec 2014
    You don't clean out the sealant. You just set the tire, attached strip, and valve aside until you remount the tire. The sealant will dry out eventually, but probably no faster than if you had a different set of wheels with the tires mounted. See the pics in post 203 above: Fatty Stripper tubeless solution? - Page 5- Mtbr.com
  43. #243
    I did not use glue but may do so next time. I'll not remove these tires till I want to swap them, since I may end up needed new strippers if I take them off for some reason.
  44. #244
    Dec 2014
    Quote Originally Posted by Flyer View Post
    If you want the tire to stay attached to the fattystripper, do not use the spray-on glue. The Stan's sealant is what "glues" the tire to the fattystripper. The spray-on glue will glue the fattystripper to the rim, which is not what you want if you want to remove the tire and fattystripper in one piece like a tubular tire.
  45. #245
    Jan 2017
    Quote Originally Posted by Montrealrider View Post
    Quote Originally Posted by voon View Post
    Well, that explains my situation as well. Ordered on December 26th and tracking says in in route. Have been trying to get a hold of Jim for 2 weeks now and need to order another set for a second set of wheels. Very frustrating since I have 2 sets of wheels sitting here and no FattyStrippers.
  46. #246
    Reputation: BlueCheesehead's Avatar
    Mulefuts set up quite nicely with a tubeless rim tape that stays in place. I have a friend that used the Orange Seal tape and I use the Zip flashing tape. Swapping tires is no issue and tape stays in place. No messing with stretch wrap or fatty strippers.
    I have tried the fatty strippers (on Rolling Daryls) and and they were a pain. Having to cut the excess off was time consuming and I was just waiting for the Exacto knife to gash the sidewall.
    For the couple extra grams I found a split tube to be more reliable than the fatty stripper and I found I could reuse it. To each his own, but I think there are better solutions.
  47. #247
    Quote Originally Posted by MioFatbike View Post
    Order some of these, go split tube and be done:
    https://www.excelcycle.com/products/...FUqewAod6QoHVA
  48. #248
    Ah good. I dd not use the glue so maybe it will stick. I wasn't thinking straight. So the fatty stripper is stuck to the tire, I bet. I'll stick with the Ground Controls till it is is time to swap tires and may need new strippers then. I was actually worried that the spray-on glue on the rim side would cause the stripper to shred up when I removed the tire.
  49. #249
    Jan 2017
    Quote Originally Posted by BlueCheesehead View Post
    Thanks for the link, just ordered those and sealant.
  50. #250
    Bikes with dogs
    Reputation: pocky's Avatar
    FattyStripper out of stock, but FattyStripper = TheraBand?
    I posted this on the Tubeless Tuesday thread but figured this might actually be the better thread to ask on:
    Since FattyStripper is out of stock on the normal fat strips right now and won't start shipping again till February 18th, can I just buy Thera-Band latex bands in the 150mmx6 yard roll? Are these, as I suspect, exactly what FattyStripper is using to make their strips anyway? Do I want the "red/medium" color assuming it's the exact same stuff and therefore the same color would be the exact same thickness, and is there an advantage to going with one of the thinner or thicker colors? Tubeless Tuesday. - Page 20- Mtbr.com
  1. Tape vs split tube for fatty tubeless
    By Dustin Mustangs in forum Fat bikes
    Last Post: 06-28-2016, 08:02 PM
  2. Replies: 55
    Last Post: 01-16-2015, 02:56 PM
  3. Tubeless Flat tyre solution yet to be tested
    By xcretro in forum General Discussion
    Last Post: 01-11-2014, 11:57 PM
  4. Replies: 46
    Last Post: 08-25-2012, 09:41 PM
  5. Best tubeless solution for 5.1d wheels
    By macming in forum Wheels and Tires
    Last Post: 03-16-2011, 05:31 AM
