Go Back   Mtbr Forums > Classic Mountain Bike Forums > Fat Bikes
Reply
LinkBack Thread Tools Display Modes
Old 11-06-2010   #1
A Surly Maverick
Dr Feelygood !'s Avatar
Rep: Dr Feelygood ! is just really niceDr Feelygood ! is just really niceDr Feelygood ! is just really niceDr Feelygood ! is just really nice
user gallery
Idea! Fattening up a Pony..... The quest for a Fat RS begins !
I`ve given this project a lot of consideration; and decided that it is time to have `a go`.
So I put an add on Single Track World, and managed to get a Klein Palomino frame here in the UK.
It`s a Palomino XV frame in a kind of grey/green, not that that is important as it won`t be staying that colour.
Paint was scruffy (as you would expect for the vintage), but no structural issues.
First job was a bit of measuring , the rear triangle has a max width of 80mm (not bad!).
Using a 26" wheel with a Mavic D321 rim, the max tyre height was 61mm.
I had a play around, an Endo on a D321 rim wouldn`t fit
A Gazzaloddi 3" on the same rim would fit (just) but wouldn`t rotate as it rubbed the Palomino shock body.
I disassembled the rear triangle and stripped the paint, gave it a quick polish and reassembled !
So back to the drawing board (literally).
I`m an old fashioned Mech Eng so no computers, just pencils, rulers and rubbers.
Full scale drawings indicated that widening the rear from 135mm to 165mm would give 110mm rear tyre clearance as a minimum.
Additionally, it would be necessary the lengthen the chain stays by 40mm, which would give approx 25mm mud clearance.
I contacted BETD regarding a custom 165mm rear Draco hub and they said they could do that ok.
Next decision was how best to go about the widening and lengthening without compromising the rear triangle structure too much.
The current chain stays have a solid pivot block welded to the tubular stays in one place.
I thought about simply welding a in a 40mm extension but this increases the welded areas from 1 to 2, increasing risk of failure.
On balance, it would seem best to produce two new pivot blocks with the extra 40mm already attatched (from solid aluminium) and then simply re-weld the existing chain stay (tubular section) back on (having first cut it off the original smaller pivot blocks).
So I`ve got a nice block of Al off Ebay and that`s what I plan to do.
I will also have to make a new upper seat stay yoke to allow for the re-positioning of the seat stays.
Will this work ? Theoretically , YES !
Stay tuned for success/failure/fettling and bodging to follow.
here are some Pix to reward your patience
Cheers,
Dr FG
__________________
Green,not mean
and Floating in a Floatilla :)
Dr Feelygood ! is online now   Reply With Quote
Old 11-06-2010   #2
How much does it weigh?
Borgschulze's Avatar
Rep: Borgschulze is on a distinguished road
user gallery
Awesome, been waiting to see this for some time now.
Borgschulze is offline   Reply With Quote
Old 11-06-2010   #3
Velobike's Avatar
Rep: Velobike is just really niceVelobike is just really niceVelobike is just really niceVelobike is just really nice
user gallery
That looks ideal for a conversion
__________________
Latitude: 57º36' Highlands, Scotland
Velobike is offline   Reply With Quote
Old 11-06-2010   #4
Just Ride!
Pigtire's Avatar
Rep: Pigtire is on a distinguished road
user gallery
Can't wait to see the finished product.
Pigtire is offline   Reply With Quote
Old 11-06-2010   #5
bighit's Avatar
Rep: bighit is on a distinguished road
user gallery
it's go time
__________________
Cycling's Kustom Kulture
http://undergroundvelo.proboards.com/
and NSFW blog
http://undergroundvelo.com/
bighit is offline   Reply With Quote
Old 11-06-2010   #6
ThreeD's Avatar
Rep: ThreeD is on a distinguished road
user gallery
I'm going to watch this one.
ThreeD is offline   Reply With Quote
Old 11-06-2010   #7
Rep: sryanak will become famous soon enoughsryanak will become famous soon enough
user gallery
Now you've gone and messed with my status quo. I've always had a soft spot for Kleins and may have to try to do one of these too. I'll have to wait til next season as I'm putting a Fatback together for my wife for Christmas. That just gives me time to find a good deal on a palomino. Have you thought about customizing up a Maverick fork so an 80mm rim would fit? And finally did you consider going to 170 in the rear to allow a bit more clearance with wide rims?
sryanak is offline   Reply With Quote
Old 11-06-2010   #8
a lazy pedaler
Rep: martinsillo is on a distinguished road
user gallery
in!
__________________
blog
I own:
La Pugsdozer
The BaroneSS
martinsillo is offline   Reply With Quote
Old 11-07-2010   #9
coastkid71's Avatar
Rep: coastkid71 has a spectacular aura aboutcoastkid71 has a spectacular aura aboutcoastkid71 has a spectacular aura about
user gallery
This is going to be a good thread Mike
good you can get a hub made up over here too
__________________
plan it...build it....ride it...love it....
http://coastkid.blogspot.com/
coastkid71 is online now   Reply With Quote
Old 11-07-2010   #10
A Surly Maverick
user gallery
Next go to work is checking the Palomino's Monolink with the TMS bb at 140mm wide will allow crank clearance of the widened rear chain stays , more drawings !
__________________
Green,not mean
Old 11-07-2010   #11
user gallery
I'm happy I could help find a BB suitable for such a project
Old 11-07-2010   #12
A Surly Maverick
user gallery
It IS appreciated
__________________
Green,not mean
Old 11-07-2010   #13
ratch's Avatar
Rep: ratch is on a distinguished road
user gallery
Really looking forward to this!!!!
Now get on with it!!!!
ratch is offline   Reply With Quote
Old 11-07-2010   #14
A Surly Maverick
user gallery
Crank clearance is not a problem.......
TMS BB ordered !
Now I`m thinking about how to adapt my Alfine to fit as well.......
__________________
Green,not mean
Old 11-07-2010   #15
is buachail foighneach me
sean salach's Avatar
Rep: sean salach is a glorious beacon of lightsean salach is a glorious beacon of lightsean salach is a glorious beacon of lightsean salach is a glorious beacon of lightsean salach is a glorious beacon of light
user gallery
Alfine is disk, right? There's gotta be a way to make an adapter that bolts into the disk flange, that would extend the shell and support a wide enough axle, maybe even have a second flange on it to widen the spoking as well.... Basically, the opposite of what Salsa's adapter does. They adapt the frame, this would adapt the hub.
sean salach is offline   Reply With Quote
Old 11-07-2010   #16
Velobike's Avatar
user gallery
Hope makes disk spacers.
I bought some because I'm going to use a rear hub on the front (once I've got the fork built).
__________________
Old 11-07-2010   #17
user gallery
Lathe, we need one now.
Such an adapter would be mega easy to make.
Old 11-09-2010   #18
A Surly Maverick
user gallery
Al block arrived in the post
Lots of measuring up later and new widened and extended pivot blocks marked up .
Bolt and pivot holes marked as well.
Will get the table saw out this week end and rough them out (hopefully!)
Will then need to have a word with the plant engineers at work about using their Pillar Drill.
IF that all goes ok, will then need to preform an `amputation` on the existing rear triangle followed by `transplantation` !
Pix
__________________
Green,not mean
Old 11-09-2010   #19
user gallery
This is a project I could tackle with a cheap MIG welder and steel instead of aluminum.
Almost makes me want to find a cheap Palomino frame as well.
Old 11-10-2010   #20
Rep: bme107 is on a distinguished road
user gallery
I'm not sure if you had considered it already, but it may be easier to drill the holes in the block before shaping it. Otherwise you'll have to find a way to hold the curvy piece and get the holes perfectly aligned and parallel.
bme107 is offline   Reply With Quote
Old 11-11-2010   #21
A Surly Maverick
user gallery
Good point, well made
__________________
Green,not mean
Old 11-13-2010   #22
Muskoka
BlackCanoeDog's Avatar
Rep: BlackCanoeDog is a glorious beacon of lightBlackCanoeDog is a glorious beacon of lightBlackCanoeDog is a glorious beacon of lightBlackCanoeDog is a glorious beacon of lightBlackCanoeDog is a glorious beacon of light
user gallery
wow!
That's very cool, Doc. Sure wish I had the skills for a project like this.
BlackCanoeDog is online now   Reply With Quote
Old 11-13-2010   #23
A Surly Maverick
user gallery
Only time will tell IF my skills ARE up to the job
__________________
Green,not mean
Old 11-13-2010   #24
modifier's Avatar
Rep: modifier is a jewel in the roughmodifier is a jewel in the roughmodifier is a jewel in the roughmodifier is a jewel in the rough
user gallery
Are you going to re-heat treat or just wing it?
__________________
No it never stops hurting, but you can go faster.
modifier is offline   Reply With Quote
Old 11-13-2010   #25
A Surly Maverick
user gallery
That will depend on who i can get to do the welding
__________________
Green,not mean
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Hot Deals
Latest Mountain Bike Articles
Latest Lights Shootout Articles
Press and News Articles
Interbike - Virtual Trade Show Booths
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2012, vBulletin Solutions, Inc.
Search Engine Friendly URLs by vBSEO 3.6.0
