Page 3 of 3 FirstFirst 123
Results 101 to 108 of 108
  1. #101
    Nov 2008
    Having the same problems with an older (24 POE) 170mm Fatsno hub. I've broken two aluminum freehub shells, exploded two inner freehub bearings, and replaced two main drive side bearings after they got very gritty. All have been stock hope bearings. I'm 300+ lbs.
    I had an older steel freehub from a past hope hub but the bearing ID is too small to fit on the Fatsno axle. I thought all hope freehubs were the same?
    There is some confusion on what bearing are required for the freehub. Is it just two 17287's or is it two 6803's and one 17287?
  2. #102
    No, the Fatsno hub and the Pro 2 EVO use a thicker axle, so the freehub body is different too. You need a freehub for a Pro 2 EVO hub
  3. #103
    Jan 2017
    Ugg, just stumbled upon this thread. Decided to check my rear hub, lo and behold the bearings are crunchy. Also the aluminum freehub body is all chewed up. Front bearings still feel good though. 3500 km.
  4. #104
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Bearings are pretty cheap, easy to get, and easy to replace. I repacked some after 2 seasons, put brand new ones in others (I have 4 hope hubs).
  5. #105
    Jayem....this is a interwebz forum.
    You should only post negative things. That's the rulez!
    But , yes....I agree with you.
    Oddly ( or not so oddly)....the Fatsno rear I have that is only used during winter is a little rough after 3 seasons. While the Fatsno rear that is used all year , for 3 years, with thousands of miles on it....is rolling smooth ( but is going to get new bearings for the reasons you stated)
  6. #106
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Crazy, I've had 4 sets (still have 3, sold one with old fatty), first one that is over 10 years old. All on original bearings.
    Had a couple pawl springs break on the oldest one but that's it.
  7. #107
    Went from fatsno to dt Swiss 350 & will never go back. Hope- broken bearings & cracked hub bodies, Hope should have had monthly direct withdrawal from bank account it was costing a lot.
    Sent from my iPhone using Tapatalk Pro
  8. #108
    Jan 2017
    Well I only checked my bearings because I came upon this thread. A lot of people have had problems apparently. But thanks for the positive news. It seems like it's just the two 6903's that need replacing on mine. Just had to replace the bearings in my RaceFace BB30 last week, hence the disappointment. I'm about to embark on a 4000km fatbike tour so I need things to be reliable.
  1. Replies: 36
    Last Post: 01-31-2016, 11:00 AM
  2. Replies: 5
    Last Post: 08-16-2014, 07:58 PM
  3. 170mm Rear Wheel Build, Muk 2 or Hope FatSno hub?
    By nitrousjunky in forum Fat bikes
    Last Post: 08-21-2013, 01:38 PM
  4. Rear Cassette Is Hungry For Hope Fatsno
    By jonshonda in forum Fat bikes
    Last Post: 01-27-2013, 08:12 AM
  5. Rear Cassette Is Eating Hope PRO 2 Fatsno
    By jonshonda in forum Wheels and Tires
    Last Post: 01-25-2013, 06:45 AM
