Results 1 to 26 of 26
    Chris Bling
    Reputation: dustyduke22's Avatar
    New question here. Fatbikers chain of Choice
    Hey Everyone,
    Just been doing a lot of looking on the interweb and it seems that everyone has a different opinion about which chains rock and which chains suck. I am sure we will get some differing opinions here right quick, but its worth a shot.
    I have been running a PC 971 on my Pugs without much complaint. I was thinking about trying out the PC 991 cross step or the KMC X9.93 or X9.99.
    With all the different options out there, I figured they might be a common ring among fat bikers!
    The obsession of wheels fused with the passion of cycling
    Affordable Custom Wheels
    Its a chain. The technology is in the marketing. I use cheap X-level KMC's on all my bikes.
    Jason
    Disclaimer: www.paramountsports.net
    Reputation: Schott's Avatar
    Nov 2012
    I somewhat agree. I do run a more expensive (lighter) chain on my race bike, and a 991 on my fatty. Lube is more important than the chain itself. 45 north has some supposed winter chains, might be worth a look.
    "You're like a Ferrari engine driving a dump truck"
    Shimano Dura Ace/XTR 9 speed. Handles nasty conditions very well and I've never broken one. Serious neglect required to have one get rusty.
    KMC X10 and some wet lube.
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Cheap 9 speed KMC off amazon for like $12 a piece. they are great no issues, & come with a removable link.
    Reputation: OFFcourse's Avatar
    The one with the most ridiculous discount on CRC!
    Feb 2012
    All chains are not the same the cheap ones are soft metal the more expensive ones are steel. Take a link apart the cheap one you can bend the link like cheese. The more expensive link is tough to bend. I like KMC chains best
    Feb 2006
    The few chains I have broken in the past have all been SRAM, every single one. Including a powerlink.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    All shimano mountain chains now have mushroomed pins, which bulges the pin and keeps the link from sliding off under extreme conditions. This stated with XTR many years ago and has filtered down to all of em. The only caveat is that you install the supplied connecting pin correctly or a power-link works just fine too.
    For SRAM chains, you have to step up to "crosslink" to get the comparable level of technology. Obviously this is more expensive, so I think the lower end shimano chains are now a better bargain. A long time ago SRAM chains were actually Sachs, even still stamped as Sachs, and back then the shimano chains sucked comparably, but that put a bad taste in many mtbers mouths, which has lived on.
    Reputation: Velobike's Avatar
    Quote Originally Posted by Shark View Post
    Ditto
    Latitude: 5736' Highlands, Scotland
    I use a galvanized KMC chain, KMC Z99 Rust Buster.
    I hate rust, and I hate even more worrying about something rusting, so I'm happy with it.
    Reputation: Beard of Power's Avatar
    Although a bit pricey, the Shedon Brown Delux chain leaning kit is worth the investment if you really care about performance. The ShelBroCo Bicycle Chain Cleaning System
    __________________________________________________ __
    Bike is the New Black
    Reputation: duggus's Avatar
    ...Be careful what you're looking at because it might be looking back...
    Reputation: surlybugger's Avatar
    Jan 2013
    May I ask which chain lasts longer? In terms of the actual rollers wearing out. Not so much the links breaking, or the pins un-peening.
    Re: Fatbikers chain of Choice
    Ah, yet another advantage of internal gear hubs. I get to run burly 1/8th inch swingle speed chains.
    Jan 2013
    Quote Originally Posted by ultraspontane View Post
    Makes sense. We'll see what the future holds for my Moonlander.
    I wonder how them belt drives hold up?...
    bigger than you.
    Reputation: Gigantic's Avatar
    I've never had the rollers wear out; the links usually break long before that happens.
    Jan 2013
    Quote Originally Posted by Gigantic View Post
    Use a chain stretch checker when the chain is new, and then after the miles have been put on. You will see how much the rollers are wearing.
    bigger than you.
    I generally only get about 500 miles per chain.
    Anchorage, AK
    Reputation: Lars_D's Avatar
    Another vote for the gold KMC 9-speed chain. I got a 1,000 miles on my first one before hitting the wear limit and I have 900 on my current one and haven't yet hit the limit. I use dry lube every 100-150 miles and reverse the chain direction after I lube it.
    My next chain will be the 10-speed version. It's a little lighter and thinner, so it will be interesting to see how it holds up. My guess is that it will do just fine.
    --Peace
    In winter conditions, I assume?
    Quote Originally Posted by Schott View Post
    The 45 North chains are nice, light enough, and pretty cheap. I run a willful neglect 8 speed chain on my wife's ride with an IGH.
    I'm waiting for them to come out with a 10 speed version, though.
    Until then, the Shimano HG-54 does just fine, used with Wipperman quick link.
    Oh noes. I'm going to drink the Kool-Aid.
    ejj
    ejj is online now
    Don't spend much on your winter-bike chains. Assume they will be destroyed.
    bigger than you.
    Quote Originally Posted by johnlh View Post
    It doesn't seem to matter.
    Reputation: vikb's Avatar
    I buy $16 SRAM 8spd chains at my LBS. I don't recall the model #, but whatever is cheapest from SRAM in 8 spd gets my vote. I run an IGH on my fatbike so the chain just goes round and round. I do minimal maintenance and usually replace the chain every year or so when the rust and dirty gets too embarrassing.
    Safe riding,
    Vik
    www.vikapproved.com
  1. Any fatbikers in No Cal....
    By eredinger in forum Fat bikes
    Last Post: 05-06-2013, 03:31 PM
  2. Hey! Ontario fatbikers!!!!!!
    By angryx in forum Fat bikes
    Last Post: 10-02-2012, 02:22 PM
  3. OZ fatbikers
    By Velobike in forum Fat bikes
    Last Post: 04-18-2012, 02:45 PM
  4. Fatbikers in Germany?
    By Tibor in forum Fat bikes
    Last Post: 04-17-2012, 11:26 AM
  5. any fatbikers in UT
    By gregclimbs in forum Fat bikes
    Last Post: 10-16-2011, 07:43 AM
