Results 1 to 34 of 34
    New question here. Fat-specific Cycle Computer?
    Well, I'll be the latest to grumble about my success with the search function...
    I need to get get a cycle computer for the 9zero7 and I'm wondering if there are any fat-specific cycle computer considerations.
    I would think that wireless would be the way to go, but would welcome anyone's pics of their setups.
    I know some of you don't even bother with them on the Fat bike
    The problem I have with an existing computer is that the distance between the fork and the spokes is too far away for the sensor to pick up the signal.
    Yeah, I was wondering if that wouldn't be an issue... I suppose the dished wheels put spokes closer to a sensor on the one side than symmetrically laced wheels do on either side - and I have a symmetrical front.
    A garmin edge at about $125 solves the issue--ok, I know, a bit more expensive than bike computers, but it does eliminate the whole "wheel sensor" issue, and can be used on multiple bikes . I move mine with me between my hard tail, fat, and I take it when I XC ski.
    Reputation: Bethany1's Avatar
    No problems with my cheapie Specialized wireless computer.
    Reputation: Velobike's Avatar
    Quote Originally Posted by orind View Post
    +1
    I went through the same process. Plus whatever tyre pressure you use can radically change the effective diameter of the tyre, so you'd have to reset an ordinary speedo for tyre pressure changes.
    The disadvantage of the Garmin is it can lose signal and needs frequent recharges.
    Latitude: 57º36' Highlands, Scotland
    Fat & Single
    Reputation: ozzybmx's Avatar
    If you dont mind spending some $$$
    I have just bought the new Garmin 810 with the topo maps package, have yet to use the HRM and will never use the cadence sensor but as far a fatbiking goes, the topo maps on the big screen is awesome for exploring, it shows roads and tracks that i would have found otherwise, you can also download other peoples rides/tracks from Strava, Garmin connect ect then start navigation turn by turn like using your car GPS.
    Awesome unit but a bit on the exy side.
    Evil Following
    Trek 9.9 Superfly SL
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
    dvn
    dvn is offline
    Reputation: dvn's Avatar
    I run CatEye Strada Wireless CC-RD300W on all my bikes including the fat bike. No problems at all.
    Attached Thumbnails Attached Thumbnails Fat-specific Cycle Computer?-img_20130528_144654_435-800x451-.jpg
    "Either way it doesn't really matter, I just got back from a bike ride."
    > dbhammercycle
    Reputation: gcappy's Avatar
    I am with the Garmin crowd, Edge 500. I snap it on whatever bike I am ridding that day, go home and download all the data on my pc.
    Human Test Subject
    Reputation: Volsung's Avatar
    I use a planet bike computer with a ton of spacers on the fork so the sensor can read the magnet. It gets in the way every time I have to change my tire but it has a thermometer which is rad for winter.
    Reputation: mtuck1's Avatar
    Garmin... No magnets, no wires, no problem.
    Reputation: duggus's Avatar
    Quote Originally Posted by Volsung View Post
    I second this... use them on all my bikes. Lots of info on one screen, and the temp is nice. Wireless. Reliable. Cheap. Accurate. (sorry but GPS isn't anywhere near as accurate as a wheel mounted computer).
    Another nice design feature is that the entire computer is the button... it does a little click on it's base. Definitely a must-have design for winter fatbiking with gloves.
    PROTEGÉ 9.0 WIRELESS
    ...Be careful what you're looking at because it might be looking back...
    Reputation: Schott's Avatar
    Nov 2012
    These computers you speak of have a setting large enough for the diameter of a fatty? Even a bud?
    "You're like a Ferrari engine driving a dump truck"
    Quote Originally Posted by Schott View Post
    These computers you speak of have a setting large enough for the diameter of a fatty? Even a bud?...
    You don't need to set that with the GPS versions.
    Reputation: vikb's Avatar
    You enter the roll out in MM usually so you can measure it and enter whatever you need.
    As VB notes if you are changing your tire pressure a lot the speed/distance won't be accurate.
    One way around the tire size changing with pressure is that some computers have 2 wheel sizes you can program in so you can switch the computer between bikes. You could use this to enter a higher and a lower pressure roll out as long as you are willing to manually toggle the computer between these modes.
    Safe riding,
    Vik
    www.vikapproved.com
    Levi Early
    Reputation: Levi707's Avatar
    Ive been using a bontrager node 2 on mine. I calculated the rollout myself but do realize that I am off slightly with different air pressures. Comparing my distance covered to my friends other computers, I am usually off only .10/mile so I can live with that.
    Reputation: Gizzard75's Avatar
    Aug 2013
    I use my Garmin watch... Forerunner 405, I can take it anywhere!
    Quote Originally Posted by vikb View Post
    Yup... this.
    I actually put my "usual" pressure in the tires and marked a spot on the garage floor and then got on and put some weight on the front and slowly pedaled until I had one rotation. It has been accurate if I ride a set distance on a street and then check with my car and GPS.
    This is very helpful! I don't know that I'll go the GPS route yet, but will check on the Specialized, CatEye, Bontrager, and Planet Bike (I like the button feature) options.
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Garmin edge 605 here....love it. Not only for the no-sensors-wires etc, but uploading my rides & keeping track of distance, climbing, hours etc. Plus uploading other routes when you are in a new area helps with spider-web type trails. Find a route you like & send it to your device.
    Reputation: smthgfshy's Avatar
    Garmin foretrex 301 for me. Runs on AAA lithiums. I can move it easily from bike to car to backpack, no issues with recharging. Is more accurate, no wires or sensors, and I don't get lost.
    Reputation: kyttyra's Avatar
    Mar 2012
    Quote Originally Posted by Bethany1 View Post
    No problems w/my cheap Sigma wireless computed either...except that its sensor now lies somewhere in the woods...meaning that the small rubber band that kept the sensor in its place broke :/
    Dec 2016
    Sorry to dredge up an old thread. I am trying to mount a wireless on my rigid fatty. As noted by others the spokes are a long way from the fork. I appear the have the option of angling the sensor in towards the spokes or trying to mount the sensor down nearer the hub. In both cases with the fork being round and tapered I am not over confident that it will stay in place and not end up getting mashed in my spokes. It's been so long since I last mounted a computer on a bike it more or less pre-dates wireless (affordable at least) but I don't recall having any concerns on MTB or a roadie in terms of secure sensor mounting. Any flashes of brilliance would be much appreciated.
    Mar 2015
    Wouldn't something like Strava get you the same info and be bike agnostic?
    Reputation: foresterLV's Avatar
    Dec 2016
    Yep, just launch phone tracking app, put it in pocket, and then review speeds/times/records back at home. Not sure why speedometer thing is really needed on the bike these times.
    Sent from my SM-G900F
    since 4/10/2009
    Reputation: Harold's Avatar
    Quote Originally Posted by MozFat View Post
    Either is fine.
    Nov 2016
    garmin 305 | eBay
    Dirt cheap these days.
    Pastafarian
    Reputation: TavisB's Avatar
    I decided to go the phone route. Galaxy S5 in a RAM mount.
    Jan 2016
    Which app did you choose to use with your phone?
    Pastafarian
    Strava, map my ride, ride with GPS, osmand+, MTB project, Wahoo fitness. That's the cool part, lots of options.
    Sent from my Pixel XL using Tapatalk
    Feb 2012
    For rigid forks, maybe you can epoxy a magnet to the side of the rim to bridge a sensor gap.
    Haven't tried myself since I just use Mapmyride app.
    Totem KDS-D fatbike, Brompton M2L-X Ti, 6kg Dahon Dove, 1998 GT Forte Ti road bike
    Dec 2016
    Maybe powerful magnet will do the work too. I have seen Scwalbe selling valve cap with a magnet (for computers), because its not close to the fork too I guess its covering the gap with a power. But fat bike gap might be too much for that magnet.
    Reputation: system_weight's Avatar
    May 2016
    Quote Originally Posted by ozzybmx View Post
    I have just bought the new Garmin 810.
    +1 for the Garmin 810
    I have 3 bikes with three mounts and just take the Garmin from bike to bike. So the price tag compares to 3 regular computers.
    It can record the heart rate even from a (Garmin) fitness watch. You get really interesting data showing speed, altitude, heartrate etc. in the same diagram.
    friendly greetings
    Frank
    Dec 2016
    Thanks all. Plenty to go with
  1. Cycle computer then to a droid and now to gps
    By wellcraft in forum GPS, HRM and Bike Computer
    Last Post: 05-21-2013, 04:14 AM
  2. Need a Lefty-friendly cycle computer
    By epl108 in forum 29er Components
    Last Post: 04-25-2012, 09:46 AM
  3. Cycle computer in winter?
    By Spikes in forum Fat bikes
    Last Post: 08-23-2011, 10:53 AM
  4. Iphone for cycle computer?
    By stephanmoll in forum General Discussion
    Last Post: 07-29-2011, 11:37 AM
  5. Cycle computer
    By cypee in forum Cannondale
    Last Post: 04-11-2011, 05:12 PM
