Results 1 to 21 of 21
Thread: Fat CO2
    Reputation: OFFcourse's Avatar
    Fat CO2
    I had a look at a few of the other threads but didn't really see a clear winner for a dispenser, have a race coming up that finishes with 20km of road and buggered if I'm going to stop and hand pump that or ride it at 8psi ;-)
    Probably go from 8psi up to around 15psi (will have to see how new tires run on road when they arrive).
    How many canisters am I likely to need?
    Reputation: liquidboarder2k4's Avatar
    Jul 2013
    get a 9 0z paintball co2 tank... you can build a presta adaptor for it
    SILCA 30.0 Presta / Schrader Brass Bicycle Air Pump Adaptor Head Hose Chuck on eBay!
    Spyder 9 OZ Paintball High Pressure Cylinder | eBay
    and some fittings
    Thingamejigger
    Reputation: Flying_Scotsman's Avatar
    Lezyne do large 25g cartridges, take a few and you should be fine.
    Or you could put some stan's juice in the tubes.
    Fat & Single
    Reputation: ozzybmx's Avatar
    I would say 1 for each tyre would do it. The biggest loss on Co2'ing a fat tyre is the initial fill, you could bust 2 into a flat tube without even getting any pressure. Once you have some pressure they will bring it up nicely, on a 4.8" I would say 8psi to 12psi per cartridge.
    I have a Genuine innovations ProFlate that takes threaded or non threaded 16g cartridges, been using it for a few years now.
    The 16g cartridges can be picked up in "lots" from ebay for $1 each or less.
    Evil Following
    Trek 9.9 Superfly SL
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
    Jun 2013
    Use this cartridges:
    nvphatty
    Guest
    Quote Originally Posted by ozzybmx View Post
    they also make 20g carts which i believe fit the same dispenser.
    Mountain
    Nov 2007
    This will do the job. One cartridge will fill a 4" fat tire to 15psi in seconds.
    Big Air! 40 Gram Propane - 1 Pack With Hang Tab
    Oct 2012
    don't forget about the inflate as you ride system from adaptrac, although it doesn't look like they ever got the Fat bike hubs ready for the market yet.
    Are you sure it wouldn't cost you less time to just find a compromise pressure for the whole race than getting off the bike and inflating the tires, even with a CO2 inflator?
    If you ride hard enough, maybe you can get the tire temperature up enough to where the pressure is good enough.
    Have you thought about going tubeless? Setup is a slight hassle, but it is really well worth it.
    Quote Originally Posted by autodoctor911 View Post
    Yeah that's another idea I was considering, exploring options ATM.
    Quote Originally Posted by sgtstretch View Post
    I don't see how running tubeless or not relates in anyway to the OP, have you had your coffee yet?
    I run tubeless anyway FWIW.
    Nov 2007
    Wouldn't you just try it out before the race (for just the cost of a few CO2 bulbs)... should never try anything untested in a race. Do it a week or two before and you'll have your definitive answer. Let us know what you found.
    Cheers
    FatMuz
    2017 Nicolai G13
    2017 Trek Fuel EX 9.9
    2018 Kona Honzo CR Trail
    2018 Kona Honzo ST
    2018 Whyte 905
    Three 16g cartridges barely touch a BFL- they bring it up to maybe 5 PSI, not nearly enough to ride. To be safe, a couple of "Big Air" containers and a good frame pump (which weigh less than the two canisters) would be the minimum for me.
    Quote Originally Posted by OFFcourse View Post
    I switched my Moonlander to tubeless immediately after I bought because I didn't ever want to have to deal with inflating a fat tire on a ride. I don't see and never will see CO2 as a respectable option for fat tires. Either it doesn't reach the necessary PSI or I have to carry an extra 4 pounds of CO2 canisters.
    I run tubeless and carry a mini mountain morph pump. And yes, I can get it to a decent PSI from dead flat in a very reasonable time. I had to on a recent bike race.
    nvphatty
    Guest
    well we know it's an option and frankly a very effective one which far exceeds what a mini pump can do.
    D peple even read the P these days?
    Nov 2007
    N
    nvphatty
    Guest
    whats that?
    Feb 2013
    Good point! I've used the 40 Gram Big Air and it works great for fat tires. If you are looking for a race solution it will be the quickest way to air up as you can likely use just one cartridge for both tires and the container appears lighter than a typical CO2 cartridge. I think the Big Air can is aluminum instead of steel.
    I use the 40g Big Air cans. They are filled with propane...great fire blower if needed
    Damn those big airs ain't cheap, tho I suppose it doesn't really matter for a one off race use CO2 Refill | CO2 Cartridge | Threaded CO2 Cartridge | CO2 Cylinder
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    It's not about inflating after a flat.
    It's about bringing the pressure from 8 psi to 15 psi quickly when the final part of the course starts - 20 km of road.
    I would definitely use CO2 for that, even though otherwise I steer clear from it. I also ride a Moonlander tubeless.
