Results 1 to 44 of 44
Thread: Fat Chariot
    Fat Chariot
    i tried a few experiments and this is the monster i ended up with.
    there are definitely better ways to accomplish this, but this cost me
    less than twenty dollars. canadain.
    started with a cross laced double rim set up. tricky because the
    Chariot hubs are 24 spoke. so, twelve spokes per rim. the new rim is a
    48 hole too, so just skipped some holes. then gorilla taped the inside
    and ran a regular 2.35 tire with a tube. everything worked and ran
    safely, so it passed the first test.
    next i found some 20 x 4 1/4" tires. the casing is super stiff.
    getting one bead over and on one sidewall was a chore. then i had to
    push it over into the second rim. ok. had to wrestle the second bead.
    had to get it about halfway seated, hold one side with my elbow, then
    the other side with a tire lever, then use my free hand to pry the
    rest on. first one started with a 20" tube. after the second battle,
    and aired up, the fist one went flat. 24" tube crammed in. so a 20"
    tube in one and a 24" in the other. both are holding fine right now.
    this should be fun in the snow, sand, and especially when i get my
    moonlander!
    Smash Mode: ON
    Reputation: Dustin Mustangs's Avatar
    Where did you find that 4.25 tire? I've got some 2.3's on my sons trailer and those just barely cut the mustard on sand. Haven't tried them in snow yet.
    Whatever floats your bike, dude
    the tires are Duro Boomerangs. they are for choppers, or stingrays. a distributor here in canada has some in stock. i think they are made for a 100mm rim, and would sit more square. they may move to a bike when she gets bigger
    Harrumph
    Reputation: G-reg's Avatar
    Very nice! I've really wanted to try this but I haven't managed to get around to it. I what is stalling my fat Burley is the sweet Mag wheels. I've got to find some of those hubs and was going to use some trials rims.
    Slowly slipping to retrogrouchyness
    Reputation: Velobike's Avatar
    Ingenious.
    Latitude: 57º36' Highlands, Scotland
    not FAT free
    Reputation: RFX big foot's Avatar
    Mar 2011
    i like Your project,
    i did similar thing but i bought two schwinn 20"rear chopper wheels 4" wide ! of ebay for $60 and than bought KORE front track hubs for $15 each ( very smooth rolling)
    i was lucky because spokes were just 3mm too long so they were trimmed after wheel was trued
    i had to modify front hub axles to fit my trailer so that way i could have two sets of wheels and keep my original wheels for paved trail
    trailer runs much smoother on uneven ground so it's more comfy for my kid and also does 80% better in a sand than original wheels
    i wish those tires could be more flat and with softer sidewalls so could run them at lower pressure but i'm very happy with current results
    cheers to all modifiers !!
    so awesome RFX big foot! i would love some wide rims, but i think the chariot system needs the chariot hubs. and 24 spokes in a 36 hole rim hurts my head for spoke calculating
    PRETENDURO
    WOW!!! Wish I’d thought of that back when we had our Burley D’lite. Nice work!
    QUOTE from MTBR.COM: You have given Brewtality too much Reputation in the last 24 hours, try again later.
    Mar 2011
    Fat just got fatter
    Fat Friends-
    Just finished this Chariot SideCarrier setup. I studied the instructions above and thought I would give it a shot. The only snag that I ran into was that the chariot hub has 24 spokes and the schwinn rim has 36 holes. My brain stopped working for a minute so my wife stepped in and helped with the configuration. I didn't have to modify the spokes at all and I went ahead and used the ones that came on the schwinn wheel but added some new nipples. Then I went to lacing it up and truing it up. Everything came together just right and I'm itchin to take the boy out on a ride....(he's 3.5 months old). I took it out yesterday and it rode like a dream!! Thanks again for the forum ideas and all those that contribute to it! Awesome project.
    Wow, those are fantastic.
    I've had great success just using the Chariot XCski kit, which we own already, but it's tempting to tinker with building some fatter wheels.
    Let me know when your kids get bigger and you put together a fatified trail-a-bike.
    It's on my to do list, but hasn't reached the point of being a priority yet, I'd love to have some outside input.
    old skool newbie
    Reputation: goldenboy's Avatar
    just having a chariot brand trailer is cool enough, these modified fun rides are awesome!!
    Reputation: alaskairhog's Avatar
    I ordered a couple stingray rims, I'm going fat on my chariot too after seeing these! Benjo Clark: any issues at all lacing up that 24h hub to the 36 hold rim? I've never laced a wheel before so this will be my first! Any clearance issues with the frame of the chariot? I have a cougar cts1, and it looks like similar frame overall.
    Mar 2011
    @alaskairhog. I thought it went pretty smooth as far as lacing up the 24 hole hub to 36 rim. Obviously, you do end up skipping 12 spokes but the strength seems to be sufficient for the load. I did have to throw it into the truing stand and work out a couple kinks. The tire clearance is close (1/2 inch or so) but it doesn't rub. Once the boy is riding in it I'm going to keep an eye on that area.
    I ordered my rim off of ebay and it arrived on a Thursday, I unlaced both wheels on Friday afternoon, and then laced it up on Saturday and test drove it. It was a really fun project and I don't really consider myself a great mechanic so I'd say if you have a basic understanding of wheelbuilding you should do just fine. Have fun with it.
    Dinner for wolves
    Reputation: buddhak's Avatar
    Badass Chariots! Especially the side hack!
    I did a similar, but much more mechanically straightforward (tire swap and chain lengthening) to my Weehoo Igo trailer. No rides, yet.
    Oy - photo fail. Basically, you can shoe horn a 20" x 3" Kenda (Sunline) Flame into a Wee Igo if you add a link to the chain.
    Responds to gravity
    Mar 2011
    Let me clarify the Chariot Sidecarrier since I've gotten a few emails about this and am unable to respond to you since I don't have more than 5 posts on MTBR??? Odd regulation. Anyway, the Chariot Sidecarrier was produced for a short time and it is based on the sidecar design. I've been in the bike industry for some time now and have never seen a company take on the sidecar concept until I bumped into Chariot. I called the company since there weren't any dealers close by and they told me the news that they were discontinuing the Sidecarrier and that my best option would be to find it online somewhere. They didn't give a reason for stopping production but I "heard" they were being bought by Thule...don't quote me on that. So I ended up finding one on REI and it was on clearance so I pulled the trigger and snatched it up. Soon thereafter they were all gone and that was that. So in other words I cannot take responsibility or credit for making the Sidecarrier but you'll be hard pressed to find another company willing to take on the sidecar concept. There ya go.
    i love the side carrier! i didn't know they were discontinued. where are you guys getting the stingray rims? i really need a wider rim. the tire sits so round right now, its a pretty small footprint. the only ones i have found are some weinmann's in a 36 hole. also today i found clearance issues on the q/r handles for the rear basket. doesn't really bother me too much, and i could dish it over if i needed to.
    Mar 2011
    I bought my stingray wheel on ebay and I waited around to find a complete wheel, tire, and tube combo so I wouldn't have to piece it together. You can also find them on craigslist on the Schwinn OC Chopper bikes that everybody is trying to unload. Mine ran around $50 without shipping.
    Saw
    Saw is offline
    Mar 2012
    Choppersus.com would be another source.
    Nov 2012
    The sidecars are still available on ebay:
    New - Chariot Side Carrier | eBay
    Used - Chariot Sidecarrier or Bike "Side Car" Complete with Rain Fly and Mesh Cover | eBay
    Edit - they're not cheap, though!
    Mar 2011
    I'd say the one on ebay for 200 is a pretty good deal. I was really blown away by the design features, the heavy duty material used for the carriage, tons of reflective material is used throughout, and it's fairly lightweight.
    hey, where did all my pictures go?
    Mar 2011
    I am curious where my other pictures went too. Strange???
    not FAT free
    Mar 2011
    same thing here ! i see just 2 of 5 photos
    Mar 2011
    Here's another perspective.
    Mountain biking fanatic!
    Reputation: Uncle_Mike's Avatar
    I love those designs - thanks, awesome! Hopefully I'll come up with something this Spring to bring my two year old along on rides. In the Winter, I can't believe how well the ski kit works behind a fat bike. Check this recent short vid out:
    Fat Biking with a Trailer - YouTube
    Happy riding all!
    Mar 2011
    That's pretty slick!
    Here's mine: I copied an earlier poster and bought the stingray wheels from ebay and also tires. I basically de-laced a wheel then re-used the spokes and used the stock chariot wheel as a template to copy the lacing pattern to lace up the chariot hub to the new rim. I then took them to "The Bike Shop" here in Anchorage and they did an awesome job truing the wheels and they work and fit perfect!
    my little passenger!
    great way to warm up before a race!
    works great as a stroller as well!
    Mar 2011
    Man, that turned out great! Some good times are going to be had with that thing. We have the infant accessory on the way for our Chariot Fat Sidecarrier so I can take our 5 mo. old son for ride next weekend. Super excited! Now someone needs fatify a trail a bike and we'll be set. Who's going to do it???
    PRETENDURO
    Quote Originally Posted by BenjoClark View Post
    Someone’s got to have a welder and some skill handy for this one…
    Fat!Drunk!Slow!
    Reputation: JordyB's Avatar
    Oct 2007
    I borrowed airhogs wheels over the weekend, put them to work on my Chariot, my son had a blast. My wheelset is still a work in progress. These fat wheels turn heads on the local trails, everyone wanted to know how it was done and thought it was the coolest idea! They do add weight, and since the tire casing is short had thick, it rides a bit rough even at pressures below 10psi. I would like to find a softer tire.
    Those wheels look great! I haven't been able to try mine out yet in the snow which is now very wet and too soft. Did you get to try out the float of them in the untracked stuff? The skis do work extremely well but we had to bring the (stock) wheels for the road sections.
    Reputation: Skywalker22's Avatar
    BenjoClark, That has got to be on of the coolest things I have ever seen on a bike!
    Mar 2011
    Thanks skywalker! I'm with you and I think it's one of the coolest things i've ever seen on bike too. I looked around and kept my eyes peeled for a sidecar for a quite a long while so it's been a long time coming. We're waiting on the infant kit to arrive so we can strap our boy in and go for a joyride.
    Mar 2011
    and....lift off!!!!!!
    Reputation: WhiskeyJr's Avatar
    Jul 2014
    Sorry for this resurrection, and very long post.....
    I found a second burley on ebay, picked it up pretty cheap. I also bought three stingrays off craigslist at $60 each.
    The new burleys, featuring the 1/2" quick release wheelchair style axles, come from the factory with 20h 20" hubs and integral hub-mounted parking brake. I was planning to put the stingray wheels on the burley hubs, but I fear the 20h hubs and 36h rims are incompatible.
    I called burley and ordered a spare set of axles so I can just switch out my stingray wheels for the rougher terrain, and back again so my wife and I can hit the local bike trail.
    I spent a bunch of time looking on the internet for some burley-esque 1/2" bearing compatible 36h trike hubs, but have been unable to find anything that isn't 5/8". This hub, Trike Hollow Hub 36 Spoke Heavy Duty ,looks pretty close to the dimensions of the burley hub, but features 5/8" bearings.
    Can the 5/8" cartridge bearings be pulled and swapped with 1/2" bearings? Or does anybody have any suggestions for a different hub?
    Jul 2014
    Fat Chariot
    I went over to the LBS, and after a long talk with the expert wheelbuilder in residence, have ordered the 5/8" hubs. Once they come in, I will swap bearings, install new axles, and spoke the hub to the rim.
    I will put pictures on when they seem appropriate.
    Edit: I have just received my axles from Burley, waiting now for the hubs to come in the mail.
    Mar 2006
    Sorry for the thread bump, but I think I'm about to pull the trigger on this.
    We had am absolutely brutal winter this year and I didnt get out at all with my girls. I thought about the XC conversion for the Chariot Cougar 2 but cant justify the price plus its limited to groomed trails which I cant snowshoe or bike on.
    So I'm putting together my parts list for this and am hoping that others would be interested as well.
    Rims: Origin8 80mm 36h rims $51
    Hubs: Sun Bicycle Cartridge bearing hubs 36h $17
    Bearings: 24mm$9
    Axel: Push Pin Quick Release axle for wheelchair $20
    Spacers and other hardware: $10
    So I'm thinking I could build these for about $100-ish a wheel, plus rim strips and whatever tire is appropriate.
    Anyone interested in a pair?
    Aug 2015
    I need a set for our Wike special needs trailer.
    But in addition to two 20in wheels, I'll need a 16" wheel for the front jogging wheel (to push on sand!)
    Reputation: Jabrnet's Avatar
    Oct 2016
    So I'd love to do this bit can't afford to really.. so I have 2 options... Making a diy ski kit from.old skies laying around, or, getting wider tires on the existing rims for my chariot cougar. I'm debating between a 2.0 mountain bike tread I can buy locally, or a 2.125 I can order in, or a 2.3 with a more hybrid style tread... Any opinions? Better to go as wide as I can? Can I even fit the 2.3 on the existing rims? Or better to go a bit wider and have the mtb tread at 2.125 rather than the 2,3 road style tread? First photo is the 2.125, second is the 2.3, and third is the 2.0.
    Sent from my SM-G930W8 using Tapatalk
    Fat!Drunk!Slow!
    Oct 2007
    This might make a great option! I am running these on my kids bike, but they should fit on just about any 20" rim.
    20x2.8 Big Roller: https://www.specialized.com/us/en/co...-roller/117678
    I have a chariot cougar, fit 2.3" gisset pimp tires (or pimp gussets? I dunno) easily.
    I also found a 4" CST tire, and tried that (back when I also had the Chariot Sidecarrier). I think those goofy cruiser tires are terrible, the sidewalls feel way too stiff for a trailer that weighs 30 something pounds and a kid that's 40 something.
    The big rollers should be a great option, supple casing, the trailer doesn't lean over so no real worries about it peeling off a narrow rim under sideload, you'll get air volume and cush, and they roll well.
    If steel is real then aluminium is supercallafragiliniun!
    Oct 2016
    Finding a truly wide tire is tough.. the 2.125 local tire turned out to be 1.75 when inflated... It's wider than the 1.50 of the stock tire but not wide enough..
    Jan 2014
    Fat Chariot Wheel Revival
    Reviving a long ago post. Really inspired from above posts. Wanted to see if I could build a set of Chariot wheels from newer kits fat bike parts that are readily available. Went on a mission for 20" wider rims as I knew there are 20" x 4" fat tires available. Found myself corresponding on Alibaba with suppliers in China for great rims with the minimum requirement of 100 units. Not in the business. So I ran into some Drift Trike rims that would suite the purpose. Found a set that had 36 holes and therefore could be laced up with the standard Chariot Hub.
    Went on to find some tubes from the Walmart Mongoose kids fat bikes and some tires that would work. Lots of finicky re-spoking but they turned out pretty good.
    The Kids had a blast the other day while out for a fat bike near our house. I asked my wife to see if there was float, but she was concentrated on staying upright as she has not been out much. Anyways whole build was fun and the kids love it.
    More to come.
    Mar 2015
    I love seeing these builds. I like your final results there. looks super sharp. I was looking for some extra cushion for my daughter in her burley ended up with two different options. i found some 2.6x20 kinda slant 6 tires for the stock rims and then came across some hubs that i laced to some 700c rims. i am running schwalbe big one 2.35 tires on those. both give the trailer a lift to mach my 29+ fat bike.
Members who have read this thread: 34
