Results 1 to 26 of 26
    Mar 2012
    Fat Bike on Roof Rack?
    I am getting a fatty in the morning (2012 Pugs)! SO excited... I have wanted one since they first came out... can't wait to join the fat club
    Anyways, I have a roof rack on top of my VW Passat with Yakima Raptor bike carriers. The rack tray hardly holds my mtn bike tires, let alone fat tires.
    Anyone have any ideas about how to best (most sturdily) put the fatty up top? Pics would be wonderful.
    Cheers!
    Heads up Flyboy!!
    Reputation: mountaingoatepics's Avatar
    I don't have any pics right now but I use Ball Bungees to strap the rear tire down in my Thule rack. I've not had a problem with this method.
    Levi Early
    Reputation: Levi707's Avatar
    I took out the qr on my yakima and put a threaded rod in its place. it is bolted to the rack itself and then i just bolt the fork to the threaded rod. I used 5/16ths rod. then i used a strap to secure the rear tire down since the yak strap does not fit across the wheel/tire combo. I can provide a picture if you would like of what I came up with
    Mar 2012
    Quote Originally Posted by Levi707 View Post
    a pic would be great. I need to figure out how to haul it home tomorrow... sounds like a good idea and secure
    Mar 2012
    Quote Originally Posted by mountaingoatepics View Post
    good idea. Thanks! What size did you use? 6"?
    Levi Early
    i used knurled nuts to secure the rod to the rack, then added 2 more on each side to double nut the rod to the rack so that it could not back out. all i do is set the bike up on the rack without the fork, hand tighten the outside bolts down then use a boxend wrench to tighten the outside nuts to the fork. then use a strap to hold the rear tire to the rack.
    Attached Thumbnails Attached Thumbnails Fat Bike on Roof Rack?-c360_2013-03-10-22-20-56.jpg
    Mar 2012
    I should have sent a pic of what my rack looks like... It isn't a fork mount but great idea... wishing i had a fork mount now
    this is the rack i have
    Levi Early
    then I would get some good straps that you can tighten down to secure both wheels. think of it like a motorcycle helmet style strap but larger. that is what i do. that would work for you since you can clamp to your downtube.
    btw, the total cost of my fork mount was $4.16
    drev-il, not Dr. Evil!
    Reputation: Drevil's Avatar
    I've used the following things:
    Redpoint Sport Wrap - Package of 2 at REI.com
    Amazon.com: Zefal Bicycle Toe Straps (Leather, 370mm): Sports & Outdoors
    Never tried 'em, but seems to me that dual toe straps would be even better?
    A few times I only had one extra toe strap and needed to do both my wife's bike and mine on our Yakima Steelhead or King Cobra, so I took off the regular strap that comes with the rack, then doubled up on the other. That was definitely the most secure.
    "Keep your burgers lean and your tires fat." -h.d. | ssoft | flickr
    Feb 2013
    We loaded my Moonlander on top of my sons car yesterday. Looked amazing up there. His rack is a Thule, just like your Yakima. The main brace held bike great. Obviously the wheel straps were too short so we used a small elastic strap with hooks on each wheel. Worked great. So a couple of elastics luggage straps will do until a more permanent solution is found. Should have taken a picture, it really did look great up there.
    Brian
    Mar 2011
    Check out my post in this thread. I use the 5/16 rod method and found a really nice ratchet lock at Rockler. The system doesn't need any tools and you can swap out your regular Yakima skewer in seconds. I just use a bungee in the rear and it works great.
    Racks (car) for fat bikes
    I u-bolted a junk rear hub to my rack to make it into a fork mount. then just use a bungee to hold the rear tire.
    Mar 2012
    Quote Originally Posted by c_m_shooter View Post
    interesting and easy idea... could you post some pics? thanks!
    Mar 2012
    Just an update. I finally am in the fat crowd! It fit on my roof rack but I didn't want to take it down the highway quite yet... It was on sturdy but i'm not sure if it was that sturdy...
    I think I am still looking for a way to make it more sturdy up top. maybe something as simple as adding another strap to the front tire would help. It was pretty sturdy but just don't want to dump it on the road quite yet...
    Surly junk straps are plenty long and securely strap down fat tires on roof rack trays.
    And they are SURLY!
    Just go to the home depot and get like two of these and cut them to a manageable length. Done. Your current rack is perfectly fine with the front and back wheels strapped down.
    '15 Specialized Fatboy
    '14 Kona Zone Two
    '13 Surly Big Dummy
    May 2012
    you need to carry a step ladder with you? how else would you mount the bike up there?
    Reputation: HAGASAN's Avatar
    Or wire ties.Fat Bike on Roof Rack?-imageuploadedbytapatalk1363120248.224207.jpgFat Bike on Roof Rack?-imageuploadedbytapatalk1363120285.985148.jpg
    Oh yeah step ladder or I can stand on the rear arm rest too.
    Thumper
    Reputation: WickedLite's Avatar
    As seen on TV wire ties...nice and simple.
    I don't use a roof rack myself but fork mount on tonneau cover setup.
    For rear tires, I use a basic nylon strap (for sleeping bags). It's held the tires down fine doing 140kmh on long road trips.
    Can't see why it wouldn't work for you roof rack guys.
    Reputation: duggus's Avatar
    Just posted this DIY, might work with your Yakima. DIY Fat bike rack tray/straps for 5" tires - write-up with photos
    Reputation: DavidJohn's Avatar
    May 2012
    Here's mine... My car roof mount mod.
    DJ
    I modified my rack with a "tray" from a newer "Thule" (I think)
    I thermoformed so it will fit the fatter tires.
    It works great, even on the freeways and big winds..
    Reputation: jddjirikian's Avatar
    Quote Originally Posted by tri-tele View Post
    And they are SURLY!
    "Ride what you love, love what you ride"
    Mar 2012
    Quote Originally Posted by duggus View Post
    Awesome stuff here. thanks. I might have to take a stop to my local home depot and pick some materials up
    Axe
    Axe is offline
    Custom User Title
    Reputation: Axe's Avatar
    1Up USA has a roof rack, and spacers for fatbikes.
  1. Best Thule (roof) bike rack
    By FoShizzle in forum General Discussion
    Last Post: 01-03-2013, 10:02 AM
  2. BMW M5 w/ roof rack and bike carrier
    By DKNewYork in forum Cars and Bike Racks
    Last Post: 09-24-2012, 04:43 PM
  3. Rhino-Rack Discovery Roof Rack Bike Carrier
    By Doug_ID in forum General Discussion
    Last Post: 04-18-2012, 07:54 AM
  4. Anyone have a bike rack for the roof rack of their FJ?
    By Mountain Cycle Shawn in forum Cars and Bike Racks
    Last Post: 06-02-2011, 07:49 AM
  5. Roof rack/Mountain bike help
    By o0adam0o in forum Cars and Bike Racks
    Last Post: 01-13-2011, 09:54 AM
Members who have read this thread: 16
