Results 1 to 23 of 23
    Fat Bike Rim Weights - 26"
    Like many things, I was comparing things switching from page to page wondering if there was something I was missing. So similar idea to the Tire Width Thread, maybe we could use this for what is available for 26" Fat bike rims.
    Here is my quick list, we can add/update as products and information become available.
    Aluminum Rim Weights
    Make Model Width
    Claimed(g)
    Actual(g)
    Bontrager Jackalope TLR 26 80mm
    870g
    DT Swiss BR710 80mm
    675g
    HED Big Deal Alloy 80mm
    760g
    640g
    Fatlab 26 X 80 80mm
    798g
    920g
    Sunringle MuleFut 80SL 80mm
    830g
    Surly MOBD 80mm
    710g
    Surly Rolling Darryl 80mm
    860g
    Surly Marge Lite 65mm
    690g
    Surly Clown Shoe 100mm
    960g
    Surly Rabbit Hole 50mm
    600g
    Velocity Dually-26 45mm
    610g
    Weinmann DHL80 80mm
    1040g
    Framed Pro Z 80mm
    ???g
    Framed Pro Z Wide 100mm
    ???g
    Carbon Rim Weights
    Make Model Width
    Claimed(g)
    Actual(g)
    Nextie Kylin 100mm
    680g
    Nextie Snow Dragon 80mm
    630g
    650g
    Nextie Black Eagle II 65mm
    550g
    Nextie Wild Dragon II 90mm
    650g
    Nextie Xiphias 85mm
    520g
    524g
    Light Bicycle RSNOW02 90mm
    650g
    Light Bicycle RSNOW03 65mm
    500g
    Atomik Phatty 85mm
    580g
    HED Big Deal 85mm
    445g
    HED B.F.D. 100mm
    500g
    Kuroshiro ensō685 85mm
    415g
    454g
    Kuroshiro ensō6105 105mm
    525g
    Sarma Naran 80 80mm
    650g
    679g
    Sarma Naran 100 100mm
    750g
    Whisky No.9 70mm
    575g
    Framed Carbon rim 80mm
    600g
    Rocking on a Rocky
    Reputation: RockyJo1's Avatar
    DT swiss is 675 according to their website.
    It doesn't matter what I ride as long as I ride it Rubber Side Down●~●.
    Quote Originally Posted by RockyJo1 View Post
    Thanks, updated
    Rocking on a Rocky
    Jun 2013
    Weinmann DHL80 with factory cut-outs. 80mm, Aluminum, 1040g. According to my (no-name/generic) shop scale.
    sluice box
    Reputation: Co-opski's Avatar
    Oct 2013
    Velocity Dually-26 45mm Al 610g
    ptarmigan hardcore
    Sep 2012
    My Nextie Snow Dragons weighed at 645 and 650g.
    Trek Stache 7
    9:Zero:7 Whiteout
    Ibis Ripley LS
    Santa Cruz Bronson
    Reputation: wetpaint's Avatar
    My 80mm Sarma's were 669g and 689g
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    This should have claimed weight and actual weight columns.
    Nov 2015
    This is a nice list about the bike rim weight.
    Oct 2011
    FatLab 26 x 80 rims. Claimed 798g. Actual 920g. That is according to my Park scale.
    Jul 2017
    Quote Originally Posted by 2LO4U2C View Post
    Very helpful post, thanks 2lo4u2c
    you should add MOBD (my other brother darryl)
    Rims | Parts and Accessories | Surly Bikes
    claimed = 710 (symmetric hub / non-double drilled)
    Music & Bikes
    Reputation: fokof's Avatar
    Nextie Xiphias 85mm : 524g (claimed 520g)
    "There is a big difference between kneeling down and bending over" -FZ
    Jul 2017
    Quote Originally Posted by neons97 View Post
    very interesting - that is a full 8oz EACH lighter than claimed 1294g
    Weinmann Metal Products Co., LTD
    Just to double check - you have the 26" x80mm version, not the 24" x80mm version? The 24" claims a much closer number to your figure of 1040g.
    I really wish that dhl80 was from a more-Quality less-UltraBudget focused manufacturer; I need a nuke-proof rear wheel and would gladly pay 8oz penalty if i felt confident it was great quality, not just a cheaper-metal, cheaper-tolerance extrusion.
    Quote Originally Posted by fokof View Post
    If you don't mind me asking... will you be riding the Xiphias' mostly in winter - or in the other seasons as well? I wonder how well they'd hold up for year-round riding. Do they seem pretty stout to you?
    Quote Originally Posted by high_desert_mud View Post
    The 1040 has big holes drilled in it. The 1294 does not.
    Latitude 61
    Jul 2017
    Quote Originally Posted by sryanak View Post
    You drilled those custom, correct ? (Have not seen any factory with cuttouts.
    What is your impression of the rims? How much do you stress them / system weight / what type of riding? I'm considering them for a very heavy MTB cargo bike, concerned whether the weight would give much more strength.
    Apr 2017
    better clear if its double wall or single wall, of course double wall rim is heavier. but stronger.
    Go further go faster.
    https://www.iubike.com/
    Dec 2016
    Where is the tire width thread?
    You need to talk to Neons97 about that, see post #5.
    Latitude 61
    Quote Originally Posted by Jackfair View Post
    ........... of course double wall rim is heavier. but stronger.
    Not necessarily, if the double walls are each half as thick as the single wall they will weigh the same. Well maybe wall thickness needs to be a bit less to make up for internal stiffining.
    If the walls in the double wall are made too thin they may not be as strong as a well engineered single wall. Likely why they are typically heavier.
    Latitude 61
    Jul 2017
    I missed that you said "factory cutouts" (thanks sryanak) ... any chance you have a link? I haven't found any for sale (or spec)
    Music & Bikes
    Quote Originally Posted by ToastR View Post
    I ride year long.
    I have them for a month or so , but made a couple of tough ride and they hold up well. So far so good.
    EDIT: I'm 175 Pounds
  1. 24" tire weights
    By Fargo1 in forum Families and Riding with Kids
    Last Post: 07-29-2015, 08:25 AM
  2. The "Specialized 2014 actual weights"-thread
    By rularn in forum Specialized
    Last Post: 01-14-2015, 10:12 PM
  3. Stock wheel weights for 24" bikes
    By ToSloTrk in forum Families and Riding with Kids
    Last Post: 12-29-2014, 11:38 AM
  4. Air 9 RDO "True" build weights.
    By Gutch in forum Niner Bikes
    Last Post: 11-29-2012, 06:08 PM
  5. Fox F100 1.125" and 1.5" taper weights
    By rockyuphill in forum Weight Weenies
    Last Post: 03-07-2011, 12:44 PM
Members who have read this thread: 93
