Results 1 to 31 of 31
    Fat bike with helium filled tires
    Has anybody tried this?
    It sounds interesting considering the high air volume but what characteristics would it bring to the ride, positive or negative? and would there be any health risks i.e explosions etc.
    I've been saving my methane for weeks to fill my fat tires.
    Black Sheep rising
    Reputation: utabintarbo's Avatar
    Due to the small size of the helium molecule, you will likely have to keep filling the tire up. Consider a helium balloon after a day or so for an example.
    Besides, that small volume of helium would likely not be not be noticeably different in weight than the same volume of regular air, so you wouldn't see a real-world difference in bike or rotational weight.
    Sorry.
    Let the market decide!
    N42.58 W83.06
    It aint gonna ride itself
    Reputation: MauricioB's Avatar
    Oct 2007
    Hydrogen is cheaper and more readily available, just watch out for static electricity.
    poser Administrator
    Reputation: rockcrusher's Avatar
    Aug 2003
    best bet if an inert gas was desired would be nitrogen. A larger molecule than helium, and if properly done less variable due to temperatures and moisture. Of course that only really relates to automobiles and mostly high performance automobiles where variances in fractions of psi can cause handling changes.
    Best bet is to fill your tires with air. It is still a large proportion of nitrogen, there some nice helium and then oxygen to boot. Cheaper too, you can get it free from practically any pump. It might weight a little more than a comparable tire filled with helium but it will weigh less than a tire filled with pure nitrogen so you got that going for you.
    I only fill my tires with Neon, the trouble is staying fast enough for the front Dynamo to keep them lit.
    Aug 2010
    Had much the same wild idea, except the use of helium inside sealed frame/fork tubes to reduce weight. That lasted about 5 seconds when I realized that while helium is lighter than air, it also has weight. My next thought was to create a vacum inside the tubes...nothing in there...no weight!
    Then I did a search for the weight of air per volume...it ain't go'na fly! In fact, the bike weight would be increased due the the valves necessary to extract the air.
    Utabintarbo is correct; you can fill tour tires with helium, but it will not stay in them, in fact your party balloon, I wager, will stay afloat longer. A fun thought though!!!!
    Reputation: Soupboy's Avatar
    I fill my tires with the exhalations of lost children.
    Professional Amateur
    Black Sheep rising
    Quote Originally Posted by Soupboy
    Mildly creepy.
    N42.58 W83.06
    jmw
    jmw is offline
    Reputation: jmw's Avatar
    Feb 2005
    maybe take the hot air balloon approach and install little flamethrowers in the rims?
    traction might suffer though
    future nature
    You could always use Propane... run your stove in camp...
    Is dang happy!
    Reputation: Mr. Doom's Avatar
    Old school air is as light as air, probably not worth the trouble.
    The wheel is a extension of the foot
    Cool second post bro
    jmw
    jmw is offline
    Feb 2005
    yeah, don't get discouraged....some of us are just smart@sses
    future nature
    You'd need a lot of helium to lighten the bike, let alone lift it. http://science.howstuffworks.com/helium2.htm
    "0.5cubic ft of helium can lift 14 grams."
    Filling with Water is where it's at, the extra weight adds to the momentum effect, once you get them rolling they aren't going to stop.
    After all this isn't Weight Wennie this is fat bike!!
    I actually tried above for a laugh while BORED 1 weekend, but couldn't get enough water into the tube easily so gave up.
    PSYCHOLUST
    Reputation: scyule's Avatar
    I love that so many of us have these kinds of thoughts...... So many cyclists are closet engineers, spending so much time in that symbiotic relationship with one of the greatest machines ever made.
    As for lightening a FAT BIKE, I'd say the quick/cheap answer is tire tubes, and that is just so boring compared with exotic gas filled frames and tires.
    The VACUUM idea sounds pretty cool, but as one poster noted, the sealing and valving would add a TON of weight.
    YET ANOTHER alternative would be a skip a few cookies and potatoes and lose five pounds of ASS, which has always seemed to work for cyclists..
    keep thinking outside the box...........thats where crazy ideas like GEARS and disc brakes and CARBON came from in years past.
    Reputation: Velobike's Avatar
    I've got it! Hollow spokes.
    Now to find a long thin drill to drill out my spoke centres. I wonder if they make double butted drill bits
    Latitude: 57ļ36' Highlands, Scotland
    PSYCHOLUST
    Quote Originally Posted by Velobike
    This is very good....My only suggestion would be that you want have both elbows firmly on a table and one eye closed so you can be assured of a STRAIGHT drilling.
    Reputation: mikeetheviking's Avatar
    Jan 2015
    Ounces of ass in the morning equals pounds of ass at night.
    Who couldn't benefit from pounds of ass at night?
    Mikee Likes It!
    @gordosbicycleclub
    Quote Originally Posted by mikeetheviking View Post
    Thank god you resurrected a 5 year old thread to say this.
    Reputation: watts888's Avatar
    Oct 2012
    Quote Originally Posted by tfinator View Post
    It makes perfect sense. It had to be said. Nobody wants to admit it, but it had to be said.
    "a hundred travel books isn't worth one real trip"
    Reputation: Mr.Wizard's Avatar
    Feb 2015
    Central tire inflation system...
    Nitrous oxide with dual hoses...
    (One for the bike and one for ...)
    "Be what you is and not what you is not. Folks that is what they is, is the happiest lot."
    AK kid who LOVES bikes!
    Mar 2018
    Iím resurrecting an ancient thread, but I saw a post about water in the tires! We did this to my bosses fatbike and it weighed 19 pounds a wheel! The breaks did very little to slow it down! 😂
    Dec 2016
    Quote Originally Posted by AKRIDERK9 View Post
    Iím resurrecting an ancient thread, but I saw a post about water in the tires! We did this to my bosses fatbike and it weighed 19 pounds a wheel! The breaks did very little to slow it down! 
    This is comic gold!!!! Really had me LMAO, imagining a guy trying to pedal a bike more than twice its original weight
    In a similar vein. We used to bung rocks, or huge tinned fruit cakes, in guys packs in the military.... Always well appreciated
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Hiding rocks in backpacks, so mean but so funny.
    turtles make me hot
    Reputation: NYrr496's Avatar
    We have a guy here at work that carries his tool bag with him at all times because there are cameras everywhere. One day, he returns to the shop freaking out. He slams his bag down and pulls six Ridgid pipe wrenches, a lump hammer and all sorts of other crap out of his bag. Damn thing had to weigh 80 pounds. I was cryin'.
    I like turtles
    Mar 2018
    It was great, the fatbike weighed 75 pounds total and the darn thing was impossible to turn above 5 mph because of the rotating mass! My boss wasnít incredibly happy about that..... it was totally worth it though!
    Reputation: coke's Avatar
    Reminds me of the time some friends of mine were camping and riding 4wheelers / ATVs at the dunes. While one friend was sleeping, they swapped his paddle tires around. The next day he couldn't figure out why his 4wheeler was so slow
    Oct 2015
    take a dump before you ride...
    Reputation: campykid's Avatar
    Uhhh, weigh your wheel completely deflated, then weigh it fully inflated; the difference is the most you would save with helium or Hydrogen, i.e. non-measurable.
Members who have read this thread: 166
