Wheels just off the ground, so I guess it counts. Day 4 of 4 and about 10 minutes away from the finish of the Cape to Cape in Western Australia, can you see that I am looking forward to stopping!! And yes it has a nice soft beach section where I picked up loads of places and copped a fair bit of (good natured) heckling. 2 Fatbacks and 2 pugs this year.
what pressures do you usually run when doing all of this crazy stuff???
Hmmmm, I'm really not sure. I do have a digital pressure gauge, but I rarely have it, and use it even less. I think it's around 10-12psi, but I guess I should find out. I have never hit rim to rock, but I try to unweight if possible. Also, if I find that it's squirmy going around turns, I'll stop to pump it up a little bit.
I run 7-8psi for snow and dirt, usually. I've run it down to ~5 based on feel if it's a really technical trail. This is on the Big Fat Larry's, your 4" experience may vary.
