Results 1 to 12 of 12
    Reputation: thesilversurfer's Avatar
    Oct 2011
    Easy swap from Mechanical to Hydraulic brakes and still use cables
    I saw these today. Cable operated hydraulic brakes. They were being fitted to a cyclocross bike. Can be used with any cable brake lever and they have huge power. Much more than cable brakes. TRP HY/RD. Hydraulic power off season and in winter just swap your BB7's over using the same cable and lever. Simples.
    https://www.trpbrakes.com/category.p...d=206&subcat=0
    They are new to me but maybe not new to others.
    <a href="http://www.flickr.com/photos/74469747@N06/10112145466/" title="IMG_2515 by Fatbackrider, on Flickr"><img src="http://farm8.staticflickr.com/7315/10112145466_ba9db3830a.jpg" width="374" height="500" alt="IMG_2515"></a>
    <a href="http://www.flickr.com/photos/74469747@N06/10112081543/" title="photo 1 by Fatbackrider, on Flickr"><img src="http://farm3.staticflickr.com/2827/10112081543_911951309e.jpg" width="374" height="500" alt="photo 1"></a>
    <a href="http://www.flickr.com/photos/74469747@N06/10112001275/" title="photo 2 by Fatbackrider, on Flickr"><img src="http://farm3.staticflickr.com/2850/10112001275_b4361c49a2.jpg" width="374" height="500" alt="photo 2"></a>
    <a href="http://www.flickr.com/photos/74469747@N06/10112039656/" title="photo 2 by Fatbackrider, on Flickr"><img src="http://farm6.staticflickr.com/5532/10112039656_38ceb4dc68.jpg" width="374" height="500" alt="photo 2"></a>
    <a href="http://www.flickr.com/photos/74469747@N06/10112043086/" title="photo 1 by Fatbackrider, on Flickr"><img src="http://farm4.staticflickr.com/3680/10112043086_e18dae8224.jpg" width="374" height="500" alt="photo 1"></a>
    <a href="http://www.flickr.com/photos/74469747@N06/10112054706/" title="photo 3 by Fatbackrider, on Flickr"><img src="http://farm4.staticflickr.com/3687/10112054706_14843169be.jpg" width="374" height="500" alt="photo 3"></a>
    I have them fitted to my cyclocross, cheaper than an upgrade to the new roadie styled hydro brake combos and work pretty well so far, a few pro CX riders are using them as well at the moment. A good upgrade if you don't want the hassle of fitting a full hydro set up. Or you have a long frame that needs a long hydro line ('12 Mukluk for starters)
    Feb 2005
    Kinda cool, and I'm sure my concerns are unfounded, but having the whole system, so close to the heat source, and so little oil volume, thermal expansion being what it is, I'd worry about seal failure in longer braking situations.
    I obviously know less than the good folks at TRP, but it still begs the question....
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Reputation: Velobike's Avatar
    My concern is of getting the worst of both worlds with that setup.
    Latitude: 57º36' Highlands, Scotland
    aka bOb
    Reputation: bdundee's Avatar
    Quote Originally Posted by Velobike View Post
    ^^^This^^^
    Feb 2012
    I think for fatbikes the bigger issue is lever pull ratio. Those are designed to work with road/cantilever pulls, unless you are running BB7R on your fatbike, your levers are a V-brake pull. That lever will work with road, but it's not ideal, I found it to be pretty grabby when using Paul Single Finger levers and BB7Rs.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Anchoring the cable on the "short" side of the arm may alter the leverage enough to make them workable with flat bar brake levers.
    Nemophilist
    Reputation: TrailMaker's Avatar
    ROFLMAO!
    I don't want to seem redundant in my commentary (elsewhere), but I can't imagine looking to ADD a cable to anything. Not if I wanted it to work better. Hose = install it and forget it. Cable means maintenance - PERIOD. That means diminished performance at some point. I absolutely fail to see the point, or the advantage.
    Most people ply the Well Trodden Path. A few seek a different way, and leave a Trail behind.
    - John Hajny, a.k.a. TrailMaker
    Dec 2010
    From what I've heard about those, that's what you get...however I'm still curious to see where that technology may go.
    Cane Creek Flat Top levers will give the pull ratio you need, but by the time you buy those, plus $300 in TRP brakes, you can easily get a very good set of hydros. Or just go with BB7's.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Hey, I remember those. Welcome to 20 years ago.
    Easy swap from Mechanical to Hydraulic brakes and still use cables-gtltsdisc.jpg
    Reputation: shiggy's Avatar
    Dec 1998
    Yup. Those were known for locking up from heat expansion on long descents. Could only sit and wait for them to cool down until the wheels would turn again.
    mtbtires.com
  1. Mechanical disc brake cables
    By TheeSuperUberV in forum Beginner's Corner
    Last Post: 10-07-2013, 11:00 AM
  2. Got XT hydro brakes!!...easy to shorten cables??
    By ROG30Y in forum Brake Time
    Last Post: 05-13-2012, 03:25 PM
  3. hydraulic vs. mechanical
    By HumboldtBrad in forum Brake Time
    Last Post: 05-04-2012, 07:29 AM
  4. Hydraulic disc brakes Vs mechanical.
    By Sky1ne in forum Brake Time
    Last Post: 02-25-2012, 10:01 PM
  5. Best cables for mechanical disc bb7's
    By Realslowww in forum 29er Bikes
    Last Post: 05-25-2011, 08:53 PM
