Results 1 to 25 of 25
    Reputation: FatBike&SlenderWoman's Avatar
    Apr 2016
    DIY Stud Pockets (so you can avoid using those expensive screw in studs)
    Standard 1/8" Rotozip bit ground down to create a tip similar to a keyhole router bit. The smooth skinny (1mm) part acts as a guide to create stud pocket.
    NOTE: Updated bit details at post #14 of this thread
    DYI Stud Pockets (so you can avoid using those expensive screw in studs)-bit.jpg
    Zip-tie stick-on mounting base. Grind plastic top flat on a belt sander.
    DYI Stud Pockets (so you can avoid using those expensive screw in studs)-mountingbase.jpg
    Peel adhesive backing and attach flattened zip-tie base to bottom of Rotozip to create a depth stop for drilling lugs.
    DYI Stud Pockets (so you can avoid using those expensive screw in studs)-rotozipplate.jpg
    Set cutting depth to match stud body.
    (4.3mm for bikestud.com studs)
    DYI Stud Pockets (so you can avoid using those expensive screw in studs)-stud_bit.jpg
    Mount tire on bike, inflate to 15psi, mark stud locations with a white Sharpie, seat yourself along with bright work light at eye level with top of tire so you can acquire your target. Wear goggles...those little chunks of rubber get hot!
    With Rotozip set to fastest speed, plunge tool into tire lug. With tool bottomed out in the lug, rotate the tool 360º in the horizontal plane to create stud pocket. Remove tool from lug by quickly lifting straight up.
    Note: DO NOT cut a pocket into any lug that is not at least 5mm tall. Trust me on this for I now own a Jumbo Jim TLE that is no longer 'TubeLess Easy'
    DYI Stud Pockets (so you can avoid using those expensive screw in studs)-drillinglou.jpg
    Insert studs and ride.
    DYI Stud Pockets (so you can avoid using those expensive screw in studs)-studdinglou.jpg
    Feb 2018
    Thanks for posting this. I’ve been unsuccessful in trying to create stud pockets for some 45 north studs. I tried custom grinding the head of a nail and ended up drilling it right through the case on a MAXXIS minion. I tried the YouTube method of just drilling a 1/8” hole but the stud will not seat. I think I’ve got a rotozip somewhere and will have to try this.
    Apr 2016
    You can do this to your winter boots as well. (Link below)
    Installing studs in boots
    Reputation: Kirkerik's Avatar
    Apr 2016
    Very nice. I love using off the shelf stuff to mod more off the shelf stuff! Great!
    Thanks for sharing!
    The tires are the things on your bike that make contact with the trail.
    Apr 2016
    Motivated by the glare ice forcast for the Bike Across Bago last week, I studded a Jumbo Jim (photo below) and a Hüsker Dü as guinea pigs to test my DIY stud pockets. The event consisted of three miles of mixed snow covered asphalt along with 17 miles of Zamboni grade lake ice with an ongoing dusting of fresh snow.
    (Mile 5)
    DYI Stud Pockets (so you can avoid using those expensive screw in studs)-bago2018mile5.jpg
    These were utilized as rear tires on a Blackborow and a Mukluk. The next day, I discovered one stud missing from the Jumbo Jim. It was one of the stud pockets that did not get cut deep enough during my initial experimenting with the Rotozip. I injected a little black Shoe Goo® into the pocket and after it cured, I recut the pocket at the proper depth and have been commuting all week with no more stud loss.
    The JJ and HüDü are good candidates for studding but I am now embarking on the Surly Lou which I have found to have deeper sipes and the much softer lugs which could present a challenge for stud retention.
    I fabricated a new tool from a 9/64” standard 135º drill bit in order to get a wider pocket at the bottom of the stud. I will post results with photos next week.
    The Jumbo Jim pictured below has 96 studs (two rows of 48) for use as a rear tire. The inner three rows are too shallow to stud.
    For use as a front tire, I would recommend studding the outer two rows as well for a total of 192 studs.
    DYI Stud Pockets (so you can avoid using those expensive screw in studs)-jumbojim.jpg
    Sep 2015
    I'm confused how you're getting a pocket at the bottom. When you say rotate, do you mean keeping keeping the vertical axis of the bit in the same place and spinning the tool? Or do you mean moving the axis off center and using the skinny part of the bit against the initial insertion hole and then making a small circle around the initial hole?
    Dec 2005
    Quote Originally Posted by FatBike&SlenderWoman View Post
    It's OK not to drill the hole to the full depth of the stud body. The stud will protrude more, which can actually be helpful in some situations. This may theoretically make it easier for them to fall out, but I haven't lost any yet from a worn-down Nate I studded despite a lot of road riding.
    Reputation: BlueCheesehead's Avatar
    Quote Originally Posted by Cerpss View Post
    ...moving the axis off center and using the skinny part of the bit against the initial insertion hole and then making a small circle around the initial hole
    ^^^ This
    Apr 2016
    Quote Originally Posted by Seggybop View Post
    It's OK not to drill the hole to the full depth of the stud body. The stud will protrude more, which can actually be helpful in some situations...
    The beauty of using a Rotozip is that you can easily adjust the pocket depth. A lot of these tires have pretty soft compounds so when milling pockets, you need to be consistant with the amount of pressure that is applied to the top of the lug while drilling. I try to insert the tool until the Rotozip plate just makes contact with the top of the lug because applying pressure here can compress the lug resulting in a stud pocket deeper than desired. If you screw one up, you can always fill the hole with Shoe Goo and redrill it after it cures.
    DYI Stud Pockets (so you can avoid using those expensive screw in studs)-shoegoo.jpg
    How do you control the diameter of the hole?
    Latitude 61
    Apr 2016
    Quote Originally Posted by sryanak View Post
    The diameter of the bit head matches the diameter of the stud and cuts a 3.5mm diameter hole when you insert it into the lug.
    When bit is fully inserted, the 1mm diameter smooth shaft of the bit acts as a guide enabling you to rotate the Rotozip a couple laps around the edge of the hole which results in a 1mm high, 6mm diameter pocket.
    The picture below is a cutaway rendering of the bit (RED) cutting a pocket in a 7mm tall tire lug.
    NOTE: See post #14 on this thread for latest bit details.
    DYI Stud Pockets (so you can avoid using those expensive screw in studs)-bit135.jpg
    When bit is fully inserted, the 1mm diameter smooth shaft of the bit acts as a guide enabling you to rotate the Rotozip one revolution around the inside edge of the hole which results in a 1mm high, 6mm diameter pocket.
    Attachment 1182247
    Latitude 61
    Reputation: dudeist's Avatar
    Apr 2013
    This is the best, FB&SW, thanks so much.
    Apr 2016
    How to make a bike stud bit.
    I am making a 'new and improved' v1.1 bit for milling a Surly Lou.
    It is a standard 9/64" drill bit with a 135º point (not a 118º).
    https://www.fastenal.com/products/details/0345842
    A 9/64" bit will work with the 5/32" collet on a Rotozip. We're just milling soft rubber here so a plain steel bit will suffice. A fancy tungsten/carbide bit is not necessary and will only make it more difficult to machine down.
    If you have access to a lathe, it would be a lot easier to create an accurate rendering but if you are hacking like me, here is the ghetto method.
    Clamp a power drill into a vice with bit in chuck.
    Set the power drill in REVERSE rotation at full speed.
    Chuck up a Dremel cutoff disk (I used two disks together) in your hand grinder of choice and grind bit per video below. Make sure to wear safety goggles because those little shards of metal can shoot right through your eyelids!
    https://youtu.be/n5nBUKyps0w
    AutoCAD rendering below is the objective but hey, we're working with a power drill and a hand grinder here...not a CNC lathe so get as close as you can. Oh, and buy some extra bits so you have a few to screw up.
    Apr 2016
    The Jumbo Jim as pictured above is giving you enough bite in glare ice?
    I was running a partially studded wrathchild in the rear in a similar fashion as your JJ set up. When climbing a hill on glare ice I noticed it would ride a bit on the center knobs which were unstudded and would slip a bit.
    I have it fully studded now with good traction.
    Apr 2016
    Quote Originally Posted by Kirkerik View Post
    The Jumbo Jim as pictured above is giving you enough bite in glare ice?...
    Lacking studs near the center, the JJ can be a challenge to get rolling on glare ice because the studs do not bite the ice until you are actually on the saddle. As compensation, I milled a couple studs pockets into the toes of my Wölvhammer boots so I can push off to get rolling. Installing studs in boots
    If I stand on the pedals in lower gears, I can easily spin the tire but it is good enough to cruise across the flat ice on a lake without washing out.
    If you want to do wheelies or climb icy hills, a fully studded Wrathchild is the way to go.
    See post #20 in this thread for details on studding a Surly Lou.
    Apr 2016
    ^^ pretty cool that you have got standard studs in some of the coolest non studded tires available!
    Oct 2017
    This is fantastic, thank you for sharing. I currently have Bud/Lou and am running into confidence issues while commuting due to our local freeze/thaw cycles that create lots of ice patches on pavement.
    I am in the market for some JJs for summer, and also have Big Fat Larrys (that came w/ the bike) that I could experiment with.
    I feel like studded Bud/Lou would be the best 'easy' solution that would offer traction and commutability on a single set of tires, but studded Big Fat Larrys are attractive too for my day-to-day riding over ice and snow (and if I screw them up, I still have my nice bud/lous to fall back on).
    I didn't quite understand this process until you posted the graphical cut-outs. Thank you! Any chance you're selling these bits? :P I have a drill but not any tooling for griding down drill bits.
    Apr 2016
    Quote Originally Posted by blaineb View Post
    ...I currently have Bud/Lou and am running into confidence issues while commuting due to our local freeze/thaw cycles that create lots of ice patches on pavement.
    I am in the market for some JJs for summer, and also have Big Fat Larrys (that came w/ the bike) that I could experiment with...
    If the knobs on the BFLs are at least 5mm tall, I would stud those up and save Bud/Lou for those school closing snow storms.
    My bike came with a Lou on both wheels so I immediately replaced the front with a Bud. I purchased the JJ 5 to try out as a fast fair weather tire but ended up doing 2.8 x 29 slicks instead so the JJ and the extra Lou have been gathering dust for the past two years.
    A couple weeks ago, the freeze thaw cycle was turning our annual 20 mile lake ride into a Zamboni ice event so I picked up a fully studded D5 for the front. Then, in an attempt to remain somewhat frugal, I planted $37 worth of studs into the JJ 5 for use as a rear tire to help keep the bike vertical.
    The JJ 5 was adequate but I think that a fully studded Lou would make a better mate for the D5. If this studded Lou thing works out, I am going to unstud the JJ 5 and repurpose it for use as a rear beach/street cruiser with a Vee Apache Fatty Slick up front.
    Apr 2016
    Tackling the ice with Lou
    First the math... A Surly Lou has eight rows of studable knobs with 38 knobs per row. If you were to stud all eight rows you would end up with 304 studs. That is approaching Ice Spiker density!
    To aid in acquiring the target for milling the pockets, I marked all of the stud locations with a white Sharpie.
    DYI Stud Pockets (so you can avoid using those expensive screw in studs)-lousharpie.jpg
    A couple of concerns came to the forefront during the milling process.
    1. The rubber compound in this tire is the most soft and supple that I have ever encountered. After milling 4-6 consecutive holes, the bit temperature would rise to the point that it was melting rubber so I would have to stop and clean the deposits off of the bit with a brass wire brush.
    2. The sipes is these lugs are 3mm deep which leaves a lot of the aluminum stud body exposed with only 1mm of very soft rubber to captivate the stud.
    DYI Stud Pockets (so you can avoid using those expensive screw in studs)-lousipes.jpg
    Lou is not a 45NRTH tire with firm, fully formed stud pockets so in order to turn this sticky, aggresive snow tire into a weapons grade ice spiker, these lugs need to be reinforced.
    I grabbed a tube of black Shoe Goo, loaded up a syringe and injected copious amounts of Shoe Goo into each stud pocket prior to inserting the stud. The excess goo that oozed out got packed into the sipe around the stud body to create a firm footing for the stud. It ain't pretty but after curing for 24 hours, they do not come out willingly.
    The nice thing about the Shoe Goo is that the stud can still be cleanly removed with the stud tool although it does require more torque than removing a stud from a D5.
    Q. What do you get when you stud a Surly Lou á la 45NRTH?
    A. Louie Wrathchild
    DYI Stud Pockets (so you can avoid using those expensive screw in studs)-loustudded.jpg
    Since this is a rear tire where the outer rows (notice the casting hairs) have never come in contact with anything other than snow, I opted to do six rows for a total of 228 studs. I chose flat faced (full metal) studs for the center two rows because they are more durable and the most utilized. The other four rows are the taller, concave (hollow point) variety because I am told that they have more bite which would aid in limiting off camber washout.
    If I had to do this again, I would fill in the sipes with Shoe Goo and let it cure for a day prior to drilling.
    We had an ice storm today so I got to put my McGuyver stud job to the test. I am happy to report that after 10+ miles of bar hopping, all studs are present and accounted for.
    I have read a lot of complaints in these forums about stud retention with the longer 45NRTH XL style studs. Maybe injecting a little dab of Shoe Goo into the pocket prior to stud insertion would remedy that. hum-m-m
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Cool idea, I like DIY studded tires.
    How long did it take you? I pre-drill mine through the knob, and sheet metal screw from the inside out. a box of screws is only $3. Takes a couple hours for a set of tires.
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Quote Originally Posted by Shark View Post
    I like this idea since you can't rip them out like Kold Kutters. Any problems with leaking/seeping/flatting? Ever had to put in a tube?!!?
    Apr 2016
    ...How long did it take you?...
    I did not really keep track but I can tell you that the Jumbo Jim and the HüDü took half the time per stud compared to Lou. I would say that if I did another Lou with 228 studs, it would probably take at least a couple hours per tire.
    Honestly, if I did not have an extra Lou laying around to play with, I would have purchased a Wrathchild.
    ...I pre-drill mine through the knob, and sheet metal screw from the inside out. a box of screws is only $3....
    The 'studded' HüDü came on a used bike with three rows of screws in it which I did not realize until I removed it from the rim and discovered Gorilla tape on the inside of the casing to protect the inner tube. ARGH!!
    The cost and the simplicity of screws sounds attractive but carbide studs have a few distinct advantages that made the 20¢/stud a viable option for me...
    The carbide studs provide more traction on ice and last a LOT longer than steel screws.
    A #8 screw weighs 5x as much as a 6mm carbide stud. That translates to 340g per tire for screws as opposed to 64g for carbide studs -or- 228 carbide studs weigh the same as 50 screws.
    Screws through the casing makes going tubeless more of a challenge especially if you opt not to use a liquid sealant.
    Reputation: Jeff_G's Avatar
    Oct 2015
    Attachment 1182247
    Excellent. I was killing myself trying to figure out how that worked from your first post.
    "At least I'm enjoying the ride"
    16' Trek 8.4 DS
    16' Farley 7
    and I'm OK admitting..
    16' Sturgis
    Minneapolis MN
    Feb 2006
    Quote Originally Posted by mikesee View Post
    I've done a front/rear set of husker du that I ran 2 winters (including a handful of days with mixed exposed dirt and gravel) , and the dunder rear tire winter. Not a single drop of sealant on any of the screws.
    The kold kutters were OK for a while, but once they started to pull out, they were all ready to go. One ride I have 5! Lost. I resorted to broken toothpicks to plug the holes and keep riding/pumping.
    I have had to add a tube once, short term to get you back to the trailhead it was OK. Wouldn't want to put a lot of miles on I'm sure the screw heads would wear the tube quickly.
  1. To stud or not to stud..
    By caratunkgirl in forum Fat bikes
    Last Post: 01-04-2016, 07:34 PM
  2. Replies: 82
    Last Post: 11-28-2015, 10:19 PM
  3. To stud or not to stud?
    By circlesuponcircles in forum Fat bikes
    Last Post: 08-30-2014, 03:20 PM
  4. Gilets with chest pockets and hand pockets with zips
    By Rotund in forum Apparel and Protection
    Last Post: 04-28-2013, 04:51 PM
  5. DYI Truckbed rack
    By flatliner in forum Cars and Bike Racks
    Last Post: 09-06-2011, 08:25 PM
Members who have read this thread: 196
