Results 1 to 5 of 5
    Sep 2013
    DT Swiss 177 axle
    A buddy was telling me his DT Swiss rear axle snapped on him at a bevel where the threads start and that it was a common problem. I have a Ventana El Gordo that I run 29+ that has a 177mm rear with the DT axle. I checked mine and didn't see a bevel, was thinking maybe it was an earlier axle (mine is a 2014, his is a few years newer) or maybe where mine is a 177 (his was 148) that maybe mine was made a bit stronger. Any ideas or heard of this happening?
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Quote Originally Posted by kendunn View Post
    There are no threads in/on the DT 170/177 axle.
    Regardless of that, I've built literally hundreds of DT 177 hubs and thousands of DT 135/142/148/157 hubs. I have yet to see a broken axle on any of these.
    Sep 2013
    Quote Originally Posted by mikesee View Post
    It certainly is a DT Swiss, threaded, and in a Hope 177 Fatsno hub. Not sure if its something special or what.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    These axles come with the bike and as such, may or may not be speced by DT Swiss, in this case, that is definitely a DT Swiss axle. My Pivot and my Turner both come with a DT Swiss rear axle too. The axle comes with the frame, not the hub.
    Aug 2003
    Ah -- we're having a terminology problem.
    Technically the axle is part of the hub. The axles on DT Swiss 177 hubs don't have threads.
    What you've shown a picture of is the thru-axle, and you are correct that is a DT Swiss RWS.
    Certainly not a common problem -- not sure I've ever heard of a failure before this one.
  1. Replies: 2
    Last Post: 09-21-2017, 12:56 PM
  2. Replies: 10
    Last Post: 01-28-2017, 05:24 PM
  3. 10mm thru-axle skewer for 170 or 190mm hubs?
    By awai04 in forum Fat bikes
    Last Post: 12-02-2015, 02:38 PM
  4. Replies: 37
    Last Post: 10-30-2015, 09:40 AM
  5. Replies: 0
    Last Post: 04-05-2006, 09:52 PM
Members who have read this thread: 65
