Results 1 to 20 of 20
    Jan 2014
    Dropper Post for Fatty for cold Weather Conditions
    So I would like to install a dropper on my fatty and I am considering two options (I don't want to consider an expensive dropper):
    1 - a no name TMA dropr from EBay (~$120 US) - purely mechanical
    2- a giant contact from my LBS ~ $200 CAN - mechanical with some oil (I think)
    only concern is live in Canada where the winter temps can get low as -25c.
    any thoughts or recommendations for a budget dropper for cold weather?
    Mar 2012
    I'm also in Canada. Last year went through 2 Reverbs on my FS trail bike that I ride spring to fall. In fall with temperatures around 7-8C, it was very slow, below 4-5C if was not functional. Replaced with 2016 Giant Contact Switch and so far this season 100% without issue. I don't think I rode colder than about 7 or 8C this year, but Reverb was already on its last leg at that point. I got mine for $239CAD.
    For my fat bike, I bought a slightly used Gravity Dropper Turbo LP that is yet to be installed and tested this winter. Since bike lives in the shed always cold, I figured this proven simple mechanical design will be my best bet. Will see how I like it, but so far I think even the Giant has potential to be a decent post for winter use. Hope this helps a bit.
    GD post was 90USD shipped from pinkbike just to give you an idea. As I said I have not used it yet, but decided to get it instead of an ebay Tmars etc for similar $.
    2018 RSD Middlechild
    2016 Norco Sasquatch 6.1
    2010 Giant STP SS
    sluice box
    Reputation: Co-opski's Avatar
    Oct 2013
    This should work eh!
    Dropper Post for Fatty for cold Weather Conditions-hite_rite_ad_from_fat_tire_flyer_vol_5_no_4_1985-1160x800.jpg
    ptarmigan hardcore
    Reputation: solarplex's Avatar
    Apr 2014
    Gravity dropper, or the new e thirteen. Fully mechanical.
    I use to have a dropper... Their a fad unless you ride all mountain.
    Fatbike, XC bike, Gravel Bike....
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Gravity dropper? It's all mechanical...
    MaxTheCyclist.com
    Reputation: mdilthey's Avatar
    Dec 2014
    My vote is for GravityDropper. Very nice piece of tech, if you can get past the look of the boot (the boot works and is 100% necessary).
    That said, I sold my GD post and bought a Thomson rigid. Can't really mess that up!
    Ultralight bikepacking and gear lists... MaxTheCyclist.com
    Reputation: brilleaux's Avatar
    May 2016
    9point8 fall line? They say it works cold conditions also.
    But what is cold? I ride -27celsius also so i don't use dropper post at winter.
    If Gravity Dropper does something to that rubberboot i might consider it.
    Life, Love & The Blues. And Fatbiking.
    bigger than you.
    Reputation: Gigantic's Avatar
    I've been riding a KS Lev for the past 2 years, in temps as low as 0f, never had a temperature related issue with it.
    Jan 2014
    while there are some solid recommendations in the above, unfortunatley for me they are all above my price point - guess it is the TMars for me.
    Reputation: ryguy79's Avatar
    Used Fox DOSS? Mine is going on 2 years with no issues. Its not nearly as smooth as my Reverb and only has 3 positions, but it works in the cold.
    Mar 2012
    I was deciding between new Tmars or used GD, and GD won based on great reputation and the ability to order any part in case you ever need to. Used ones can be found for the cost of new Tmars.
    2010 Giant STP SS
    is buachail foighneach me
    Reputation: sean salach's Avatar
    Gravity dropper has been great for me. No issues in cold weather.
    Reputation: OneTrustMan's Avatar
    Nov 2017
    I don't know if someone still reading this.
    I had the Tmars last winter, because I was sure that a mechanical one would work better in cold weather.
    Unfortunately -15C is its limit.
    After 1 hour it stoped working.
    Next winter I am trying the E13 dropper or somthing else I guess.
    Jan 2009
    Quote Originally Posted by OneTrustMan View Post
    The BikeYoke Revive looks compelling...
    [WTB] 1987 Cannondale SM800, 20", Pink with airbrushed graphics.
    Quote Originally Posted by J_Westy View Post
    I've used it in cool weather, 20F temps and above. I don't plan on using it in real cold weather, down to -F temps. Lots of stuff stops working at those temps, not to mention extended use of a hydraulic dropper at the cool temps (shortening seal life, etc.). A dropper on my fatty was kind of fun for a while, I used a Transfer at the end of the season, but I'd go mechanical and not give it a second thought for real winter riding.
    Mar 2012
    Had my Gravity Dropper Turbo LP without any issues for two winters on my fat bike. It did slow down very slightly in -20C but could just need a bit of cleanup and re greasing? Great post and the looks grew on me now, but man, their remote is the worst ever.
    Took my trail bike with Giant Contact Switch a few times out up to about -15C without any issues. Sold the bike since, but was super happy with this dropper and would have gotten one again, but could not beat the price of Brand X Ascend II post that will go on a plus bike I'm currently building. Will update this eventually of how it performs in cold weather.
    Had two Reverbs as my first droppers. Both were super slow or got stuck and did not return at all in +5C to +8C weather. Both were serviced professionally before they got sold.
    2010 Giant STP SS
    aka bOb
    Reputation: bdundee's Avatar
    I ran a Fox Transfer in WI all winter without any issues down to about -15f.
    Reputation: brentos's Avatar
    Crank Brothers Highline has been good to at least -15F for me.
    Reputation: Mr Horse's Avatar
    Having a X Fusion HiLo that is useless in the cold I decided to give Tmars a try since the cost/ risk ratio was relatively low.
    It's simple and does what expected. Construction seems well done.
    If you can't get past the rubber boot aesthetically, the 471 doe not have one. My only real gripe is that due to mechanism, the cable excess accumulates over the rear wheel when you drop the post.
    I wound up shimming it onto a FS bike that has a 30.0 diameter seat post where the cable routing is not an issue.
    I would probably buy a Gravity dropper if I had the money to do so, but the Tmars is a decent alternative.
    Like any dropper, gettting the seat post clamp tension just right is absolutely necessary in order to get it to function properly.
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    I have two Giant Contact SL's in service for our winter-use fatbikes. No change in performance noticeable from +20*f down to -20*f.
    Haven't had them in colder temps than that, yet. We use different bikes (on different trails) when temps are much warmer than +20*f.
  1. Onyx in COLD weather? Good cold weather hubs?
    By car bone in forum Wheels and Tires
    Last Post: 02-11-2016, 04:23 PM
  2. Dropper post for cold temperature?
    By A.P. in forum All Mountain
    Last Post: 01-07-2015, 07:34 PM
  3. Cold weather jacket for dry conditions?? Recommendations please.
    By Zac808 in forum Apparel and Protection
    Last Post: 12-23-2014, 09:39 AM
  4. Replies: 94
    Last Post: 11-28-2014, 07:00 PM
  5. Post your cold weather riding tips!
    By tburger in forum California - Norcal
    Last Post: 02-24-2011, 03:11 PM
Members who have read this thread: 84
