Page 29 of 30 FirstFirst ... 19252627282930 LastLast
Results 2,801 to 2,900 of 2933
  1. #2801
    May 2017
    Hi!
    This is my first post.
    I just got this bike off ebay (germany) for 225Ä. It seems to be pretty identical to the mongoose dolomite, but it has an alloy frame, stem, handlebar, seatpost and crank! The front and rear hub and headset bearings were too tight. Fork is a little bent. Weld looks solid. I will keep you updated, as soon as i put some miles on it. 3x9-speed is intended. May take some weeks, though.
    Awesome thread so far!
    Lots of great ideas and intructions.
    Attached Thumbnails Attached Thumbnails The Dolo in the (semi) wild - Mongoose Dolomite-s-l1600.jpg
  2. #2802
    Mar 2016
    Sorry if this a noob question, but is a cassette part of the freewheel or are they two different systems? I tried to read up on the internet but I've come across conflicting info.
    I just bought a megarange for my Malus but haven't installed it yet. I'm considering returning it and going the 8 speed 11-32 route instead.
  3. #2803
    Aug 2016
    Quote Originally Posted by spf808 View Post
    The Dolomite, Hitch and Malus use a freewheel style and not a cassette style.
  4. #2804
    Nov 2016
    Cassette and Freewheel are completely different systems
    and they are not interchangeable
    freewheels do not come in 11-32. the 11tooth high gear is simply too small to physically fit on a freewheel. 15 is the usual limit on these.
    Additionally they are Usually only 7 speed, a few are 8 but these are unusual and may not fit.
    Cassettes are definitely better, both for durability and gear options.
    But since the systems are integrated into the wheel hub, upgrading is extremely costly.
    learn more here: https://www.sheldonbrown.com/free-k7.html
  5. #2805
    Mar 2016
    Thanks, that was helpful guys. Sometimes I need things spelled out for me. I don't have the luxury to buy parts that might .ot fit or work with my setup.
  6. #2806
    Jun 2017
    Hey guys! I just owed my first bike/dolomite. Im currently in the process of painting the bike to my like and comfort. Im in a tight spot now trying to choose a different handle bar and seating for the bike. I had me mind to have a hydraulic seat pole for a smoother ride even though the tires will issues that sort of help but I'm looking to advance the bike to my liking. I will upload photos one day to shout you all I'm getting my hands into.
  7. #2807
    Jun 2017
    Where did you manage to get your seat post?
  8. #2808
    Reputation: watts888's Avatar
    Oct 2012
    Quote Originally Posted by elpuru View Post
    I got a Kalloy one off ebay for $18. It worked OK, and was better than some I've used. Just came across this earlier today when looking for my kid's bike. Cheap $10 gamble. If anybody gets one, post how it is.
    https://smile.amazon.com/gp/product/B071CPBLLW
    "a hundred travel books isn't worth one real trip"
  9. #2809
    May 2014
    I'd recommend buying a cheap stem and upgrading to 31.8mm handlebars. I waited for a sale on Nashbar and bought these:
    Nashbar Black Ops Flat Mountain Handlebar
    and used this cheap but durable stem:
    Mountain Bicycle Road Bike Handlebar Stem Aluminum Alloy 1 1/8" 31.8mm Black | eBay
  10. #2810
    Found this bottom bracket in my Costco version. It had sealed bearings. I was going to install the YST kit, but wouldn't sticking with this be better? If not, I'm going to have to try harder at pulling the axle out.
    https://imgur.com/a/zGsiQ
  11. #2811
    Mar 2012
    Quote Originally Posted by Guapo613 View Post
    The Malus has a 110mm bottom bracket I believe. If that is the case, this is what you need: https://ru.aliexpress.com/item/Fat-B...08.4.33.fWRLLH
    So the 110x167 from this link is confirmed to fit on Malus? Planning to add Vuelta crankset too.
    2018 RSD Middlechild
    2016 Norco Sasquatch 6.1
    2010 Giant STP SS
  12. #2812
    Mar 2012
    Quote Originally Posted by kryten View Post
    Ordered 110x167 bottom bracket and Vuelta 175mm crankset for Biggity DLX (Malus). Will see what happens.
    What bottom bracket tool do I need to do this job?
    2010 Giant STP SS
  13. #2813
    It has been a long time, but I'm finally riding my bike again. Today was the first ride as an electric bike. The 203mm disc brakes harder than before, but I want more with less travel and effort, so I'll order hydraulic brakes. I could have had an accident on today's trial ride when the rear tire came off the bead. I'm hoping that's due to poor installation on my part rather than poor quality of the wheel or tire because that's something I can address before the weekend.
    It looks like you'd need a tool like this to remove the bottom bracket.
    https://www.amazon.com/BIKEHAND-Bicy...dp/B00811WQJS/
    Have you removed your pedals? Those use another tool. I bought mine from a lbs, but I think this would work too. One of the reviewers said it worked on his Dolomite.
    https://www.amazon.com/Park-Tool-Pul...dp/B001VS1M20/
  14. #2814
    Mar 2012
    Quote Originally Posted by leaftye View Post
    I do have pedal wrench, just not crank puller, bb lockring wrench and bb removal tool yet.
    Also curious if this has a chance to work on these bikes with Vuelta crankset. E type LX mech?
    Shimano LX Front Mech E-Type 9sp M580 | Chain Reaction Cycles
    2010 Giant STP SS
  15. #2815
    Mar 2012
    Got the Vuelta mounted on the stock BB, still waiting for the 110x167 bb to arrive.
    If I get an 8 speed shifter, as long as I correctly set rear derailleur limit screws, I can use it without issue and have one unused click on the shifter, correct? If that is true, might as well get an 8 speed shifter in case I want to get 8 speed freewheel down the road.
    2010 Giant STP SS
  16. #2816
    What 8 speed freewheel are you planning on? I have a DNP Epoch that I'm planning to install tonight.
  17. #2817
    Mar 2012
    Not sure yet, as it won't be in this round of upgrades. Was considering either 13-32 Sunrace or 13-34 Sunrace (not Alpine) whichever I can get here. Was just on their web and they do have 9 and 10 speed freewheels available. Would these still work with proper shifter and derailleur on this bike?
    I noticed DNP Epoch freewheels, I was not sure if 11T would work on these bikes. If it does that would be awesome, more expensive than Sunrace but would go that route for sure.
    2010 Giant STP SS
  18. #2818
    The DNP Epoch freewheel works in all gears. I just took it for a very brief test ride. Right now it seems to shift less fluidly than the original freewheel, and I'm going to try more adjustments to improve shift quality. It gets close to the tire, so those with wider tires and wheels may not be able to use this freewheel.
    The low gear works pretty well as a granny gear now. I'll need to wait until later today to test the 11T gear at 30mph.
    I have it paired with the Shimano ST-EF51. I was looking for a brake/shifter combo to free up space on the handlebar. I really need to post some pictures.
  19. #2819
    I did about 25 miles today with the DNP Epoch freewheel. It performed nearly flawlessly. There were a couple times where it took a few teeth to go up a gear somewhere in the mid gears, but it did go. I'm sure that's due to my adjustments. The highest 34T gear still feels a little slower, but that could be all in my head.
    Bottom line is that it did what I wanted. The 34T is the granny gear I've been wanting, and I can still spin at 40mph with the 11T.
    The only bummer is that the shifter doesn't quite clear my throttle, so I had to move the shifter a half inch to the left instead of butting against the throttle. I'm going to get a left handed throttle anyway because downshifting is tough to manage while staying on the throttle. It's doable, but I still want the shifter closer to the grip.
    Here's how the bike is currently sitting.
  20. #2820
    Do any of you guys know how to disassemble the kickstand? The shaft on mine bent, and I want to get it fixed.
  21. #2821
    Oh well, kickstand came off. I still like having a kickstand for commuting and doing errands, so I'll try Luna's fat bike kickstand.
    I installed hydraulic brakes on 203mm discs up front, and screwed that up. It was spaced out too far, and wore out the lower part of the pads. I've lowered them, but I may have to get new pads and disc to get it to 100%.
    The rear caliper and disc was replaced today with a Shimano mechanical caliper and 180mm disc. The old ones had plenty of power, but I couldn't get them to stop squealing. Because replacement pads were nearly as much as new calipers, I sprung for the upgrade. The new calipers uses less expensive pads with roughly twice the surface area.
    I'm having a hell of a time finding a good way to mount a rear light. The combination of rear rack and fat tire are limiting options. Seat post mount doesn't work because the rack hides it. Rear rack mount doesn't work because the adapter hits the tire. For now I've mounted a light on the left seat stay, but that won't work when I use both panniers.
    Mounting the front tire is still giving me issues. I used the zip tie trick, which improved things greatly, but it still isn't perfect. These tires are almost done, and hopefully this issue goes away with new tires.
  22. #2822
    May 2017
    Dolomite, the remix.
    I present to you, my Dolomite.
    Frame: Dolomite
    Fork: Vinson
    Bars: Generic carbon fiber 660mm
    Stem: Wake BMX style
    Headset: AEST sealed bearing
    Seat: Gav1n
    Seatpost: EVO 400mm
    Wheels: Vinson
    Tires: Chaoyang 26x4.9
    Tubes: QTubes 2.3 superlight
    Cassette: Sunrace 8spd 11-42t
    Crankset: Vuelta MTB comp 175, setup for 1x with Snail 30t narrow-wide, k-pedc alloy pedals
    BB: AliExpress no-name 100x177 sealed
    Rear Derailleur: cheapo Tourney TY300, extended range with Chinese no-name tailhook
    Shifter: Sunlite 8spd/brake lever combo
    Brakes: Front, Avid Elixir 1 and G3 203mm rotor. Back Avid BB7 and G3 203mm rotor
    Weighed in at 39lbs in full trim. I had to slightly manipulate the chainstays for the 4.9 tires. My buddy Mike @ Capital Region Customs (upstate NY) powdercoated the frame/fork for me in prismatic powders H.D. teal over heavy silver. I couldn't be happier.
  23. #2823
    Aug 2014
    Sweet bike, I like everything about it! Just researched that BB that you posted, I might order that one before winter gets here, does it change the Q-factor at all or are your feet just as far apart as the stock BB.
    Nice work.
  24. #2824
    May 2017
    Quote Originally Posted by momikey View Post
    Nice work.
    Thanks man! I've put some serious work into this thing and a bit of money, but I'm still happy I did.
    Spindle width is very close to stock. It spins very smooth, too. I'd definitely recommend it. I think I paid around ~$20 shipped and it arrived in about 15 days.
    -JD
  25. #2825
    Jul 2015
    Quote Originally Posted by TheRealJonnyD View Post
    -JD
    Nice bike! I've been looking at a few parts from AliExpress... which party's would you order again? How do you like the Wake stem? I've thought about aluminum bars from AE, but I think I'll go carbon from XMCarbonspeed instead.
  26. #2826
    Aug 2014
    Looking at this bike again this morning and I'm tempted to ask one of the guys in the Vinson thread to sell me their stock set of wheels if they've upgraded. Also did you notice a difference with the fork, I kinda love my Dolo in the snow so I never thought about a fork swap.
  27. #2827
    Mar 2012
    Ok, so I have AliExpress 110x167 bottom bracket here for the Malus and a brand new Deore LX E-type derailleur for $5. It was listed as dual pull when I ordered, but the packaging it came in has bottom pull on it. I also picked up Altus SL-M310 front shifter as well. Already have Vuelta crankset installed on the stock BB for the time being.
    I'm assuming derailleur will mount to the frame as pictured, correct? What else is needed to make this work? I was looking at some problem solvers cable guides and cable stops etc. What would be the best way and most economical to get this done? I can still return unopened Altus shifter if this is gonna turn into a nightmare and too much expense and be out $5 for the mech. I will put in sealed BB in either way.
    2010 Giant STP SS
  28. #2828
    May 2017
    The vinson fork is quite a bit lighter and has slightly more axle to crown height, so the tire clearance is better. These Chaoyang 26 x 4.9s are F'n massive, so the clearance is appreciated. I didn't really notice too much difference in handling, but it's not very stiff. If a carbon fork pops up for cheap I'll likely swap it out.
    All in all, out of my random assortment of 15 or so bikes -- this one is my favorite. It started as a stock, $125 Craigslist special and turned into something great (to me lol).
  29. #2829
    Jul 2017
    Frame: Dolomite
    Fork: Vinson
    Seat: Gav1n
    Seatpost: EVO 400mm
    Wheels: Vinson
    Nice bike. How did you manipulate the chainstays for the bigger tires?
  30. #2830
    That is a good looking bike. Is that weight a typo? Everything is lighter than stock and it only saved 6 lbs.
  31. #2831
    Reputation: pathfinder67's Avatar
    Nov 2016
    What's up Fatboys?
    Haven't posted since back in March. The Malus is still riding like new and haven't made any upgrades since my last post due to finances. But it is still shifting smoothly and I am still rocking those stock Chinese tires. I don't know if I will change them. They seem to perform really well in deep sand and climbing as well. Those are my two biggest obstacle in this area. Weight of the tires has not been an issue at all. Also control has never been an issue either. Don't ask me how many miles are on it, because I just get on and ride. Not a strava or gps guy. Been real busy lately but still find time to ride the local trails. Mostly pavement thru the summer due to ticks here in the pines. Still loving this bike after 8 months and a lot of miles. I am not a jumper when I ride so I can't give you any advice on that. But I ride a lot of hilly trails with endless stumps for some fast bumpy rides. The bike has held up well. Rear axle still holding up too. About to start hitting the trails again. Will keep you posted and pics to come soon. Ride fat my friends.
  32. #2832
    Nov 2016
    and btw. RealJohnny. Great job Looks Awesome!!!
  33. #2833
    The Dolo in the (semi) wild - Mongoose Dolomite-img_0085.jpgHas anybody converted a hitch to single speed? Just thinking about it.
  34. #2834
    Reputation: Luis_fx35's Avatar
    Aug 2015
    Can someone confirm which bottom bracket from AliExpress works with the malus? The last few pages mention a 100x177 sealed bottom bracket which seems too wide for the malus and then someone else bought a 110x167 sealed bottom bracket but he never posted pics with everything installed. I replaced my huffy frame with a 2017 malus frame and I love it, just need that bb replaced. Thanks.
  35. #2835
    Jun 2016
    Quote Originally Posted by Luis_fx35 View Post
    I was told this 110mm here: https://www.aliexpress.com/item/Fat-...311.0.0.8WZ3yb
  36. #2836
    Reputation: DirtyHun's Avatar
    Jan 2011
    This is a very cool thread.
    2016 El Oso Grande
    2018 Stolen Zeke
    90's Skykomish
  37. #2837
    Aug 2015
    Thanks, I'll post some pics later today
  38. #2838
    Reputation: highspeedgt's Avatar
    Oct 2017
    I just joined the forum, however I remember looking at this post YEARS ago when I was looking to buy my fat bike. Ended up with a Mongoose Hitch, which has gone through some major changes since it's initial purchase!
    I actually recently started a YouTube page, and the first few videos featured my Hitch. If you're interested, have a look and let me know what you think.
    https://www.youtube.com/channel/UCHH...g4AsBkDzdr2Djg
    I just got some new camera gear, and am almost done revamping my workshop so that I can make higher quality videos. If anyone wants to see a "How to" video of upgrades I've done, or any other videos, feel free to let me know.
    Anyways... Here's my beauty!
  39. #2839
    Mar 2012
    Quote Originally Posted by highspeedgt View Post
Name:	Mongoose Hitch.jpg
    That is a great looking bike. I'm just finishing building up Malus for my brother for winter. Should be right around $350CAD all finished. Very similar upgrades to yours so far.
    Subscribed to your channel. Funny, was just helping my friend paint garage floor in his new house a day before you posted that video.
    2010 Giant STP SS
  40. #2840
    Oct 2017
    Awesome, and thanks for the sub! I was initially looking for a Malus, but I could never seem to catch one at a good price. I actually snagged this Hitch on Black Friday for $135!!!
    The weather here has been a bit crummy the past week or so, so I figured I'd revamp my workshop. Just finished it up yesterday and did a review of my CO-OP hardtail in the new workspace.
  41. #2841
    Aug 2015
    Hey guys, wondering if anyone knows if the Dolomiteís headtube is capable to take the cane creak EC 44/40 conversion headset to accept Tapered forks?
  42. #2842
    Oct 2017
    Waiting on my hitch to arrive Iíve already ordered some upgraded parts has anyone recently ordered from amazon and had any issues once it was received anything in particular I should be looking out for? Iíve read pretty much through all of this thread but things have changed over the years so Iím unsure on what to expect. Iím a real beginner havenít rode a bike since my early teens (bmx) days so this is going to be an adventure. I want to do some trails but most likely Iíll be rural riding street/woods depending on Wheather. I was on a pretty tight budget not wanting to dump too much money in until Iím sure Iím going to actually use whatever bike I picked up. Has anyone updated the suspension on the solo or hitch?
  43. #2843
    Aug 2015
    Donít ride it, re-adjust and re-grease the hubs or permanent damage will occur because the hubs and headset are over tighten from factory. If you donít have cone wrenches or the proper tools take it to a local bike shop and tell them to adjust the hubs and headset. Upgrade little by little to shed some weight over time. The Luna Lander suspension fork will fit because it is a straight steerer and has quick release dropouts which fit the bike hubs. You will fall in love with this bike, have fun and enjoy 👍😁.
  44. #2844
    Oct 2017
    Question which hyraulic brake system has been used is it the Shimano M315 800mm and rear 1450mm? Itís available on Amazon...
    Also thinking of getting a Shimano Altus or the SRAM X1 BB30 crankset.. any one have recommendations
  45. #2845
    Oct 2017
    Quote Originally Posted by SteeleRyder View Post
    Yes, I have the M315 800mm/1450mm on my Hitch, which I got off Amazon. You'll have to shorten the rear hose, because it's about 8 inches too long. You'll also need to find a way to secure it to the frame, because it won't fit inside the top tube cable stays.
  46. #2846
    Oct 2017
    This is an awesome bike to get back into riding! I agree with Luis_fx35 that the hubs, and in my case bottom bracket and headset need to be cleaned, greased, and adjusted before any riding occurs. They are poorly setup out of the box.
    I haven't done any suspension upgrades, and I ride this thing hard. I have done several other upgrades though. I cover them all in one of my recent videos. Have a look if you're interested.
    https://youtu.be/ytaJ3TRHlOU
  47. #2847
    Oct 2017
    Thanks Iím going to add those to my next order! I havenít assembled my hitch yet, just got it last night. Once I do Iíll have it ran through by my local shop cause I donít have everything I need. Or should I just order a basic bike mechanic tool kit and do it myself Iím pretty sure I can get mostly all the tools I need for what Iím going to pay someone to do a full run through. Whatís your thoughts? Is it worth having a professional run through it?
  48. #2848
    Oct 2017
    That depends on your confidence level and desire to work on the bike. I am a huge advocate of doing my own bike work, and having the tools is a huge bonus down the road for any additional repairs. I'm confident that you can get all the tools to make these adjustments for less (probably substantially less) than paying a bike mechanic.
  49. #2849
    Mar 2012
    Did anybody mount Snowshoe XL 4.8" tires on the Malus? Wondering if these fit.
    2010 Giant STP SS
  50. #2850
    Mar 2012
    Tried to install sealed 110x167mm bottom bracket on the Malus I got from AliExpress earlier this year and while it fits and both Vuelta crank arms (converted to bash guard/32/22T) clear chain stays without issue, spindle on the drive side sticks out less than on the non drive side meaning chain will rub tire in the easiest gear on freewheel and 22T up front. I'm guessing I can't install this bottom bracket from non drive side with the cup on drive side as it does not want to thread in...?
    Original axle is 175mm long, so what are my options at this point apart from ordering YST cup set?
    2010 Giant STP SS
  51. #2851
    Oct 2017
    Finally got everything assembled with a few upgrades and I must say... the hitch is a very nice ride! Everything came in as it should have upgraded to rapid fire shifter and mega range free wheel of course had to update the grips next upgrade is the seat cause itís killing me.... lol.. Iím a big guy 6í0 370 and itís rough... bike handles my weight great.. canít say itís a breeze uphill Iíve only had 3 short rides and well Iíve felt everyone of them afterwards. I ride motorcycles and for the most part Iím very athletic even at my weight so maneuvering is no big deal even did some jumps nonthing too much just seeing how it would up...
  52. #2852
    Mar 2012
    Reasembled everything with original unsealed bottom bracket cups, packed with tons of grease though. Will most likely get the YST sealed cup set especially as this is a winter snow bike if only I could find it somewhere for 'reasonable price'. Shipped to Canada from Amazon or ebay is over $40 CAD and on our own wonderful Amazon.ca it is $66 + shipping, wtf? That is just outrageous.
    2010 Giant STP SS
  53. #2853
    Sep 2004
    Resembled everything with original unsealed bottom bracket cups, packed with tons of grease though. Will most likely get the YST sealed cup set especially as this is a winter snow bike if only I could find it somewhere for 'reasonable price'. Shipped to Canada from Amazon or ebay is over $40 CAD and on our own wonderful Amazon.ca it is $66 + shipping, wtf? That is just outrageous.
    Where did you buy one of these bikes in Canada?
  54. #2854
    Mar 2012
    Quote Originally Posted by headwind View Post
    Kijiji for $150 slightly used. Canadian tire used to sell Ironhorse Dolomite (same as Mongoose Dolomite) and now Schwinn Biggity Dlx (same as Mongoose Malus).
    2010 Giant STP SS
  55. #2855
    Sep 2004
    I'd buy one just to thrash it!
  56. #2856
    Jul 2015
    @Kryten.
    Why not buy a RF BB and crank complete for $104usd? UniversalCycles has them at a decent price.
  57. #2857
    Mar 2012
    Quote Originally Posted by Pack66 View Post
    @Kryten.
    I already bought and installed Vuelta crankset and cheap sealed 110x167mm bottom bracket. That sealed bottom bracket would work if I was doing 1x, but for 2x with 22T granny gear it does not. I will try to do the garden hose O ring trick today and will be maintaining and regressing stock BB regularly I guess...
    2010 Giant STP SS
  58. #2858
    Jul 2015
    Shouldn't any external cup BSA BB work for this thing?
  59. #2859
    Mar 2012
    Test ride last night, perfect conditions.
    2010 Giant STP SS
  60. #2860
    Aug 2015
    Hey guys, I have a 2017 Malus with the red drilled wheels. My seat post keep moving even though I only weight 145 lbs. I purchased a better seat clamp but I noticed that the stock clamp is welded to the seat tube. Have anyone replaced the the seat clamp and encountered this problem on the Dolo, Hitch, or the old Malus? I donít know how to remove it without damaging the seat tube and the paint? Thanks
  61. #2861
    Mar 2012
    Did garden hose O ring mod to 'seal' the bottom bracket. I think it turned out ok and looks like it should keep out most of the grime from entering bb shell and wiping away grease.
    My first winter test ride went well apart from wiping out on ice less than a minute into my ride. (I'm used to my Dillingers)
    So today got bored and drilled holes and studded these Chaoyang 4.0 tires that come stock on the Malus with the 30 left over studs I had from studding my D5s last winter. Was planning to use Gorilla glue or some sort of silicone sealant but wanted to go for a ride already and did not. 30 is of course not enough to make much difference, mainly wanted to see if they would hold. Spent almost two hours on trails and some pavement riding commuting to trails and did not loose a single one.
    Unfortunately these tires, while probably half the weight of the original Dolo tires, are not adequate for any type of winter trail riding. Main issue is complete lack or corner knobs. Even in the rear they don't have much bite. I was planing to get some more studs, but now my dilemma is if it is even worth studding or should I just get better tires first.
    2010 Giant STP SS
  62. #2862
    Oct 2017
    So Iíve really been enjoying my hitch! So far Iíve upgraded the grips,freewheel, and shifters. I ran across a deal online looking for some new crank arms and got a race face turbine crankset for 40.00 bucks it was normally a whole lot more up to 280.00.. I also ordered bsa sealed bearings for the bottom bracket as I doubt the race face one will fit but I wanted bettter crank arms so it was a good deal. All thatís left is my bars and stem and brakes for now. At some point I might update the headset and forks but for now thatís the only plans I have. As far as the stem and bars Iím thinking about keeping it race face whatís your thoughts on their products... Iíve found a race face respond set for like 80.00 bucks bars are 785 stem is 45 degrees, feeling like this cheap fat bike will be a super nice ride when Its all said and done. It is heavy but I havenít upgraded the seat post are tubes and tires that will lighten it up at least 8 pounds from what I understand...
  63. #2863
    Jan 2011
    Hey, you wild and crazy Dolomiters. I just wanted to offer you various take-off parts from my Diamondback El Oso Grande. Chances are, they would be upgrades, so if you think you might want them, they're yours for the cost of shipping.
    I have a set of 31.8 mm bars, a seat (and a seatpost, but I think it is too thick for the Dolo), and a 1 1/8" stem up for grabs.
    Let me know if you want any of these items.
    2016 El Oso Grande
    2018 Stolen Zeke
    90's Skykomish
  64. #2864
    Dec 2017
    Just bought a 2017 Dolomite black with blue rims and over the last 3 weeks I have done some upgrades to it as well as tearing down all bearings and cleaning and regreasing them. After the initial rebuild, including adjustments to the brakes, I wasn't impressed with the braking (yeah, I know now that there is a break in period) so I swapped out the rotors for a set of 203mm Ice-Tech RT 86's. I used Shimano adapters and found that they were a direct fit for the rears, but for the front I had to go to the LBS to find an oversized bracket that I could machine to fit so that the adapter and caliper would fit. Just curious if anyone else has had this difficulty?
  65. #2865
    Aug 2014
    I use BB7 calipers with 160mm rotors so I'm not sure about a rotor that big if you are using stock calipers.
    -15 this weekend in VT.
  66. #2866
    Jan 2018
    So I just got my new Hitch and immediately went to work. Carbon bars, Avid brake levers, sun race trigger shifter, Kore lite seat post and seat, and a xt Mtb crank set. I'm surprised and disappointed that it still comes in at 43lbs. Will tires and tubes make that big of a reduction?
  67. #2867
    Jan 2011
    Quote Originally Posted by Gelthos View Post
    Tires alone can knock 3-5 pounds off.
    2016 El Oso Grande
    2018 Stolen Zeke
    90's Skykomish
  68. #2868
    Oct 2012
    At an absolute minimum, replace the tubes and rim strip. Throwing in something like a 27.5+ tube or a 26x2.7 DH tube will knock off at least a pound. replacing the rim strip with tape helps too. I think the stock tubes were from tractors or left overs from the 1930's. Stock tires aren't that far off.
  69. #2869
    Dec 2017
    Set your wheels up tubeless with stretch wrap and new, lighter tires if you can. This took over 8 lbs off of my GMC Yukon.
    See Tubeless Stretch Wrap Procedure
    Removing rotating weight is the first place you should start, it makes more difference than anywhere else on the bike.
  70. #2870
    Jan 2018
    Quote Originally Posted by Paul Fithian View Post
    I was wondering about going tubeless.
  71. #2871
    Aug 2014
    Bump in hopes everyone is riding and not posting!
    The Dolo in the (semi) wild - Mongoose Dolomite-img_1310.jpgThe Dolo in the (semi) wild - Mongoose Dolomite-img_1311.jpg
  72. #2872
    Jul 2015
    I've gone tubeless with FBNs. Used the ghetto tubeless method with split tubes. Well worth the hassle for Arizona trails.
  73. #2873
    Dec 2017
    Dolomite black&blue version is back in stock at Wally World. For $179.99 again. https://www.walmart.com/ip/26-Mongoo...&wl13=&veh=sem
  74. #2874
    Dec 2017
    Got some miles on the 203's and they are working out great with the stock calipers. With me currently at 315lbs the bike around 50, I definitely need the extra braking. I'll be throwing on another 30-50 in gear to do some back country fishing. Hopefully by mid summer I'll be a lot lighter.
  75. #2875
    Oct 2012
    Possible upgrade time. Fat suspension
    Has anybody had any experience with the Whool or Pasak fat forks? I've seen a couple posts about the spring cartridge version with 28mm stanchions, but they seem to be the same as a suntour XCT. OK fork, but a little flexy under a clyde. There is a 32mm stanchion air cartridge version that I'm looking at. If you have one (or want to buy one and be a test dummy), speak up. Here's a link to one of them, but there are other sellers out there.
    https://www.aliexpress.com/item/Kalo...796974016.html
    https://smile.amazon.com/dp/B01N1JX29B
    cross posted to a couple of the other non-lbs fatbike discussions.
  76. #2876
    Mar 2018
    Two different quetions...
    A. Can anybody tell me if a Maxxis FBR or FBF 26 x 4.8 tire will fit on the back of a Mongoose Hitch? Info on the other Mongoose Fat Bikes would be helpful as well.
    B. What are the differences in the Hitch and Dolomite frames? Particularly when it comes to fitting a large rear tire...I know they are very similar but are they identical...would a wider tire fit on the rear of the Dolomite than the Hitch.
    Appreciate any help.
  77. #2877
    Quote Originally Posted by Bullfrog123 View Post
    ...B. What are the differences in the Hitch and Dolomite frames? Particularly when it comes to fitting a large rear tire...I know they are very similar but are they identical...would a wider tire fit on the rear of the Dolomite than the Hitch.
    Dolomites are not even identical.
    outside-outside spread of chain stays at inner rim
    • original Dolomite March 2014, 8 3/16"
    • late summer/fall 2014, 191mm (7.52")
    So are you getting a used one or a new one? Perhaps people with a new/newer frame can measure for you or post what fits theirs.
    Crazy on this ship of fools...
  78. #2878
    Mar 2018
    Quote Originally Posted by watts888 View Post
    I ordered a front wheel assembly (27.5 x 52mm internal width rim) for a Mongoose Terrex and it was less than $50 delivered to my door. I then bought a Suntour XCR fork (about $100) and replaced the front end on my Hitch...used a 2.8" wide Maxxis DHF tire.
    Steers a lot quicker and still rides very nice.
  79. #2879
    Mar 2018
    Quote Originally Posted by Canoe View Post
    Thanks Canoe...yea Mongoose tends to make changes along the way that is why it is important for everyone to record the model and date code on the bottom of the seat stay before it falls apart. I have two Mongoose Terrexs...one is 135mm rear spacing and the other one is 147mm (I think...it is wider).
  80. #2880
    Mar 2018
    Just measured my Hitch...it is the same as the later Dolomite...about 7.5".
    Dang just when Walmart gets the Dolomite back in stock too...oh well I have the 4.8 Maxxis FBR ordered and I am going to try it. My measurements indicate it is going to be really close on whether it fits or not.
    Thanks again for the info and the quick response.
  81. #2881
    Mar 2018
    Freewheels
    FWIW, anybody changing the Freewheel (some call it a cassette but the correct terminology is a Freewheel)....the DNP has a finer engagement (more teeth) than most Freewheels and works quite well IMO.
    It is possible to disassemble a DNP freewheel and the four smallest gears can be interchanged or exchanged for gears from a cassette. Not something I would recommend because the little nut that holds the gears on is very thin. The ID of the gears is a nine spline just like the gears on a cassette...the three big gears are different. Other brands of Freewheels are different and do not allow this mod.
  82. #2882
    ...It is possible to disassemble a DNP freewheel and the four smallest gears can be interchanged or exchanged for gears from a cassette. Not something I would recommend because the little nut that holds the gears on is very thin. The ID of the gears is a nine spline just like the gears on a cassette...the three big gears are different. Other brands of Freewheels are different and do not allow this mod.
    I don't believe I've heard of that before. Is it too late for you to post photos of that?
  83. #2883
    Mar 2018
    Yes, It is all back together and I am riding it now...actually have a BBSHD electric motor powering it. That is why I need to change the gearing around. Had to disassemble it with a punch and a hammer. One option for putting it back together is to leave off the smallest gear and find a nut with the correct threads. I couldn't find one...that is why I used blue loctite and the original nut.
    Even the two local bike shops I checked with didn't have a tool/spanner to fit the nut...I am sure DNP did not intend for anyone to take their Freewheel apart.
  84. #2884
    Photos of the end setup?
  85. #2885
    Mar 2018
    The pink nail polish is on the little nut...be careful, it is only about one thread thick.
    Attached Thumbnails Attached Thumbnails The Dolo in the (semi) wild - Mongoose Dolomite-1.jpg
  86. #2886
    That's one limited chainline off the front. Why the high tooth count? Not enough torque?
  87. #2887
    Mar 2018
    I ride single track/off road only and I geared it to have the motor spinning full speed when the bike is going about 18 mph. I run a 28 tooth front on the bike pictured and on the rear I can use the cog the chain is on or one on either side of it and the chain line stays very straight.
    IMO, if anyone is building an electric bike and intends to ride off road...the only choice for a motor is the Bafang BBSHD. I started with a MAC IGH motor and tried everything possible to keep it from overheating with no luck.
    The BBSHD is about as simple as it gets as far as installation.
    I'd recommend a 14s battery as well...can't go over 60 volts or the BBSHD will throw an error and with the 14s you have a little more power than the 13s...8% more as a matter of fact.
  88. #2888
    Mar 2018
    So would a Dolomite off Craigslist be the cheap and fun introduction to fat biking that I think it would be?
    How do they fit a taller rider (6'2")?
  89. #2889
    Quote Originally Posted by 93EXCivic View Post
    I can't comment on fit.
    But, they're a very "budget" bike.
    To get any life out of them, before you ever ride it you need to check, clean, grease, the front & rear hubs, bottom bracket, sometimes others.
    If you're buying used, was that done, or what components are now trash on the bike you're looking at.
    It will take some bike knowledge to check it out and know if you're looking at replacing the rear or rear hubs, bottom bracket, etc..
  90. #2890
    Mar 2018
    I figured I would throw a few of the upgrades on here at it if I did buy one since honestly many of them are pretty cheap changes. Plus giving it a good once over.
  91. #2891
    Most people do, but one of the common issues out-of-the-box is incorrect hub bearing torque and/or dirt/metal in the grease. If that wasn't addressed, hubs & relacing can cost. And hard to resisting going for new spokes & nipples. And upgrade to cassette instead of freewheel. Starts to add up.
    Spindles are soft too, so not only BB bearings, but possibly replacing a bent or destroyed spindle. At 6'2" you're likely a Clyde too, so fairly common to end up with a bent spindle down the line. Look back through recent pages for the cartridge replacement that uses the out-swept crank arms. That cartridge is not a direct replacement, but with the correct crank arms people report it's working.
    Do consider the cost of a used Dolo PLUS all of the repairs and upgrades you'd need or want. Then compare that to the cost of a used better Fat Bike in good repair.
    That said, I'm not parting with my Dolo...
  92. #2892
    Mar 2018
    Here is my take on any of the Mongoose fat tire bikes...Hitch, Dolomite, Malus, etc.
    Fairly strong frame but all of the components on the bikes i.e. shifters, brakes (levers, calipers, and pads), derailleur, pedals and just about anything you can unbolt is on the cheap end of the scale...that is how you can buy it for less than $200. If you are just going to cruise around on the bike and not get too serious or rough with it the bike is great. All of the cheap components work, just not as efficiently as a $3,000 bike.
    You can slowly but surely upgrade components and still have a lot less in the bike than anything that will compete with it but it is going to take you some time and money.
    If anyone ever tries to disassemble the bottom bracket, I'd highly recommend you watch the video I am posting a link to at the bottom...I have had several Mongoose bikes that must have had a 1,000 lb gorilla on the assembly line tightening the cup that screws into the frame. I actually chipped a large craftsman crescent wrench attempting to disassemble the bottom bracket. Following the procedures in the video and soaking it with penetrating oil for a few days made it a piece of cake.
    Here you go: https://www.youtube.com/watch?v=P9oIUmdI5JU
  93. #2893
    ...You can slowly but surely upgrade components and still have a lot less in the bike than anything that will compete with it but it is going to take you some time and money...
    You can, but this is not necessarily true.
    It depends on what you upgrade, used or new parts, and the level/quality of parts, and paying for the work or DIY.
    In looking at the Total Cost of one's upgrades, a number of people have upgraded the Dolo to the point where they could have spent the same money - or less - and got a lot more bike, used and even new. It will depend on your choices (which are often determined by what is available in used parts where you are, and in your DIY skills).
    Plus the choice on replace/upgrade can be taken away from you if you're buying used and miss that something is trashed and must be replaced before you can safely ride.
  94. #2894
    Mar 2018
    Ok maybe it makes sense to spend the bit extra to get a new one? Either way, I figured on checking the hubs, repacking the bearings, new tubes and maybe YST bearing and cup before riding. I'd hit some of the lighter trails and see if I like a fat bike. I figure if I don't at all I could sell for some lose of money but not the end of the world. If I kind of liked I could hold on to a Dolomite and slowly do little upgrades and use it for those occasional time I want a fat bike. I really like modifying and tweaking things so it would be a fun project if nothing else. If I really liked fat biking, I'd sell the Dolomite and grab a nicer fat bike. As far as the Clyde, I am currently 215lb but trying to get down to 200-205 over the next few months. Not sure if that counts as a clyde or not.
  95. #2895
    Sounds like you're looking at it in the right way and have or can develop the skills for the work that make upgrades economical.
    Used Dolo is fine, IF you can determine the condition of what you're getting. You might even find one with key upgrades done.
    But buying new is the way to be as sure as one can. Just make sure you service everything before you ever ride it, or else you can be trashing the bearing surfaces.
    No one has chimed in yet, but a number of taller riders got longer seat posts. Some a longer tube and/or riser stem; some with riser bars (like BMX).
    Like fat
    Great idea to test 'fat bike', but ride a Dolo vs. ride a nice Fat Bike can be two different things. Some people have tried a Dolo as a first fat and had it turn them off of fat, then later rode a 'nice' Fat Bike and went wow. With the parts and skills, you can imitate nice for a good price; watch your costs.
    Clyde - BB
    The YST at no wiggle yet zero preload is amazing. Best BB I've ever had, even over Shimano XT and XTR (not on Dolo). The Dolo in the (semi) wild - Mongoose Dolomite - Page 12- Mtbr.com
    But rider weight or punching can bend the spindle. Hence the cartridge BB with the swept crank arms.
    Clyde - rear axle
    And its soft rear axle can get bent too. (Soft rod combined with freewheel hub: bearings are at freewheel locations, not cassette locations...)
    The Dolo in the (semi) wild - Mongoose Dolomite-freehub-vs.-freewheel-red-bearing.jpg
    So if you end up replacing the rear hub, a rider with some weight should be going freehub & cassette not freewheel hub.
  96. #2896
    Jul 2015
    I've got a 9 speed freewheel (generic Chinese I think) I picked up at a local co-op. Planning to put it and an old 9 speed shifter on fairly soon. Hopefully no adjustment needed to the chainline.
  97. #2897
    Oct 2012
    Being 6'4", I'll chime in on this. You'll need a crazy long seat post, and it will need to be decent quality. I bought a $15 one that was 450mm long, and it bent on the first ride, on asphalt and gravel. To me, the cost to get a good seat post plus common "little" upgrades justifies the upgrade cost to get one off bikesdirect.
    $400 bikesdirect fatbike; 8 speed, alloy handlebar and seatpost, alloy brake levers,
    $200 mongoose + $40 for basic 8-speed freewheel and shifter, $10 for grips, $10 for some brake levers, $25 for a seatpost, $15 for a handlebar. Lets call it $300. This still will have the 10 pound tubes, uncomfortable seat, heavy steel frame, freewheel rear hub, oversize front chainring (ok for road, not for trails, easily messed up bottom bracket and wheel bearings, and questionable quality brake calipers. All of which will need to be completely taken apart, re-greased, and reassembled. I guarantee they will not be good from the factory. I found metal shavings in every bearing plus the front wheel had a damaged bearing race from when they over tightened it during assembly.
    Not saying you wouldn't have problems with bikesdirect stuff, but at least it starts out a little better and is much easier to work on. If you don't plan on doing any upgrades or would heavily modify any bike you get anyway, the dolomite (and it's family of fat) will work.
  98. #2898
    omi
    omi is offline
    Omi
    May 2018
    Hey all, just grabbed a used dolo (appears lightly used, almost zero usage really). One thing I searched for here is weight tolerance and I can't come up with a solid answer.
    The guy stated it was about a year old, figuring 2016/2017 model (common blue/red). When I ride it, the front has a random squealing sound (not brakes). It appears more aggressive when I pedal. It's definitely only when I ride on it, otherwise makes no noise when I roll it around.
    I can't tell if it's the headset or front wheel axel/bearings. The rear which has most of the weight does not make the random squeal. It is a random but often occuring squeal, each lasting a 1~3 seconds. No specific pattern or riding style changes the random sound, except a bit more while pedaling.
    Since I have stock (need to change) far forward handlebars, I'm leaning a bit hard forward on the headset. It kinda hurts my hands. And the sound is really hard to target, headset or wheel. It almost sounds in between them. Very odd!
    Ideas? Thanks!
  99. #2899
    Mar 2018
    watts888...what are you going to do to tension your chain? I just installed a Surly "Singleator" on my single speed Hitch which is really just a red Dolomite and it works great.
    omi...I think you are on the right track i.e. a bearing. My first guess would be the front wheel bearings. Mongoose is notorious for over tightening them. But it could be the headset. Pull the front wheel and grease the wheel bearings then check the preload on the bearings. Make sure that the preload doesn't change when you are installing the wheel and tightening the nuts on the axle. I think you'll need a 17mm cone wrench...I bought a set of cone wrenches from Jensonusa not long: Foundation Cone Wrench Tool Set | Jenson USA
  100. #2900
    Not odd at all.
    Very typical for bikes at this price point (and seen in the Dolo) to arrive as new with debris in any/all of the bearings, including bits of metal shavings.
    As new, before ever riding this bike (or others of similar quality) you need to clean out and degrease the bearings, regrease and take care when setting the torque (don't over torque and damage the low quality bearings), as the threads at this price point are sloppy and it may take a few tries to get it right.
    As your bike was obviously driven, likely before the above servicing was done, inspect for damage, replace as necessary. You may need to replace the hub.
    Do this servicing for the front, rear, bottom bracket and steering.
    Rear axle and the pedal spindle are known to be of soft material and prone to bending. If you're a clyde, expect this; pedal gently, avoid bumps.
    • Or get a better spindle (source?) or get the replacement cartridge and swept crank arms that has been used successfully as documented in more recent posts in this thread.
    • If you need to replace the rear hub or axle, remember that freewheel hubs have an inboard load on the drive side that tends to bend the axle. Seriously consider a freehub and cassette replacement, instead of another freewheel hub.
  1. Rolf Dolomite Wheel set for sale
    By Wiplash in forum Wheels and Tires
    Last Post: 07-13-2013, 03:38 PM
  2. Semi-rad.com took a jab at us!
    By jmmUT in forum Off Camber (off topic)
    Last Post: 02-15-2013, 10:30 PM
  3. Rolf Dolomite Disc cracked rear rim?! WTF?
    By Wasmachineman NL in forum Wheels and Tires
    Last Post: 12-01-2012, 01:09 AM
  4. Replies: 1
    Last Post: 08-02-2012, 10:57 PM
  5. Semi OT
    By pisgahproductions in forum North & South Carolina
    Last Post: 08-11-2011, 02:48 PM
Members who have read this thread: 98
