Results 1 to 11 of 11
    Mar 2006
    Does waterproofness of rim strip material make a difference when running tubeless?
    Planning to convert Fatboy rims to tubeless. Given the fact that the rimstrip/ribbon/duct tape will be exposed to snow/water, is there a functional difference in the types of materials listed, or others that you use?
    Your Best Friend
    Reputation: Silentfoe's Avatar
    Use Gorilla tape. Easy to find and relatively cheap. Works great.
    I'm a mountain bike guide in southwest Utah
    Mar 2006
    Right. That seems to be the consensus. I wonder how the satin tape, ribbon and other materials people use for style hold up to water.
    is buachail foighneach me
    Reputation: sean salach's Avatar
    If they're thin, and backed by gorilla tape or stan's tape, they might pick up a little ice, but will otherwise be fine. If you use shag or faux fur, expect icicles.
    Fat & Single
    Reputation: ozzybmx's Avatar
    If your outside strip is not waterproof then it can get stained with dirt/salt and take on water.
    Personally i wouldn't want the strip saturating with sea water and it constantly being wet on the inside of the rim next to my nipples.
    I use a strip of clear "table covering", its a thin film used to protect a table top... its directly over the black foam so my strip looks shiny black.
    Evil Following
    Trek 9.9 Superfly SL
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
    I am guessing you wouldn't want anything that would let water in, which would allow water to find its way between the rim and the rimstrip.
    Mar 2006
    At this point I am leaning toward Gorilla tape, smooth side out.
    Air pressure against the gorilla tape and ribbon will effectively seal off the edges of the holes. As long as there aren't any wrinkles it'll be fine.
    Reputation: duggus's Avatar
    They have tons of colored duct tape too if you are just talking rim strips. Look on Zoro tools .com if you want interesting reflective tape.
    ...Be careful what you're looking at because it might be looking back...
    Feb 2012
    Quote Originally Posted by sean salach View Post
    Nice, very nice.
    To date I have not seen fur rim strip, but i haven't checked out the fat bike scene in Miami lately.
    Reputation: Ramjm_2000's Avatar
    Jan 2005
    Quote Originally Posted by Silentfoe View Post
    +1 on Gorilla Tape
  1. Going tubeless with rim tape instead of the rubber rim-strip???
    By Damitletsride! in forum 29er Components
    Last Post: 05-09-2013, 02:23 PM
  2. Bontrager Tubeless Rim Strip Help
    By LFJ in forum Wheels and Tires
    Last Post: 01-20-2012, 09:10 AM
  3. Stan's Tubeless Without Rim Strip...
    By dirtdan in forum General Discussion
    Last Post: 09-21-2011, 06:20 PM
  4. Electrical Tape as Tubeless Rim Strip?
    By onepivot in forum Wheels and Tires
    Last Post: 07-18-2011, 12:16 AM
  5. Laserdisc rims-tubeless without a rim strip?
    By fat_weasel in forum 29er Bikes
    Last Post: 06-11-2011, 07:32 PM
