• 03-14-2013
    13 Attachment(s)
    DIY Fat bike rack tray/straps for 5" tires - write-up with photos
    Call me ghetto... but this turned out pretty decent and works great. Thought I'd share my little creation. This was on my Thule rack, may work differently on others.
    I had been strapping the tires down tight to the rack which worked for the most part, but any side wind would occasionally blow my tire sideways... not fun going 70 on the highway.
    So had to get creative to fix this...
    Attachment 780812
    2 - Polyethylene Internal Coupler, 5" or 4" depending on your tire size (get these at any hardware/home store... home depot, etc.).
    4 - 1/4" x 2" bolts.
    8 - 1/4" washers.
    4 - 1/4" wing nut bolts.
    2 - straps of your choice... or get some super cheap snowshoes with the ratched latch (which I used).
    You will also need a Dremel or other rotary tool and some zip ties help.
    Here are my parts per strap - the coupler, 2 bolts with washers and wingnuts, and the strap from my old snowshoes (cut down).
    Attachment 780814
    First I had to cut out the part shown here in green, so that it would fit snug with the tray. Just notched them out with the cutter.
    Attachment 780815
    Attachment 780816
    Next I cut the coupler in 2 pieces, leaving one slightly taller than the other.
    Attachment 780817
    Then I lightly zip tied the taller piece to the rack, threw my bike on top to find the position, and strapped it down tight so it wouldn't slide around.
    Attachment 780818
    Then lay the shorter half inside the other. I found having the two creates a stronger support.
    Attachment 780822
    I drilled two holes with a (bigger than 1/4") drill bit so that it went through the center channel of the thule aluminum tray. This won't effect anything on your thule tray if you want to put your old straps back on some day.
    Attachment 780824
    To help with drilling the second hole, I put the bolt in and lightly tightened. I arranged as bolt head on top with washer, and then bottom of thule tray the other washer and wingnut.
    Attachment 780825
    Once my holes were drilled I removed the inner coupler and layed down my strap. I didn't want to drill through the strap since it was hard rubber that might eventually stretch, so this is how I went about it. This ratchet strap from my old snowshoes fit perfect.
    Attachment 780826
    Then I just put the inner coupler over the top of the strap, put the two bolts in, and tightened it up. I also took the rotary tool and cut all corners nice and round, and got rid of any other sharp areas where things could catch.
    Attachment 780827
    Here is a front view with the two pieces and Bud. You can see the bolts going through underneath. It's a nice snug fit.
    Attachment 780828
    The finished front one strapped down. Side to side movement of the tire is now very minimal.
    Attachment 780829
    Then it's time to go inside and have another beer.
  • 03-14-2013
    Nice job!
  • 03-14-2013
    Dr Feelygood !
    A really great job :thumbsup:
  • 03-15-2013
    Really creative!!
    I can't tell from the pics, but you might want to add a lock washer to the bolt securing the coupler to the rack. Don't want anything coming loose.
  • 03-15-2013
    Originally Posted by jonshonda View Post
    Really creative!!
    You're probably right... thanks for the heads-up!
  • 11-21-2014
    Custom made fat bike adapter for Europe
    Attachment 940733Attachment 940734
    In Europe noone has made a bike carrier for Fat bikes! So we made our own, custom stainless steel adapter.
