Results 1 to 39 of 39
    Jun 2013
    DIY bikestand for fatbike
    Don' t know if this has been posted here before but decided to make my own fatbike bikestand.. Total cost, $12.. The only initial problem was the stand was light, it would tip when bike is placed.. That was quickly remedied by placing grout sand inside the tube for added weight..
    Oct 2013
    Just made 2 of these, 1 for my Fuel and 1 for my road bike.
    Reputation: gcappy's Avatar
    Way ahead of you.
Size:  51.1 KBName:  image.jpg
Size:  37.7 KBName:  image.jpg
    since 4/10/2009
    Reputation: Harold's Avatar
    I'm going to have to do something like one of these. I have 3 rack slots and 4 bikes, with a 5th (fatbike) on the way. I think I'll need to be a bit more modular than my current rack to be able to modify it as tire widths in the family stable change.
    I like yours, gcappy.
    Quote Originally Posted by NateHawk View Post
    Easy to modify, just get the glue!
    Sep 2014
    I'm kind of torn about whether to make one of these stands. Most of my bikes are mounted on the garage walls to save space.
    On one hand, I like these type of ground stands for easy access. On the other hand, it takes up way too much room in a two car garage compared to wall mounts.
    DIY bikestand for fatbike-image.jpgMy walls are all taken by cabinets and the bay the bikes are in is too short for a car. When the house was built (not by me), a four foot entry room was built sticking out into the garage bay.
    Too many bikes for the walls anyway.
    Heheh yeah there are currently 14 ready to ride bikes in my basement and a bunch more in pieces scattered about my man cave/work space. I got a plan though ...
    They have PVC compression fittings that don't require glue, just unscrew and change lengths. Obviously not for every joint, but used strategically, might help.
    Quote Originally Posted by rjedoaks View Post
    Yeah, I found those after I got mine built. I should get some because I have a couple mods to make. The Nate slot now needs to fit a Bud on a RD. Wider than Nate on a CS.
    Sep 2014
    Quote Originally Posted by gcappy View Post
ID:	937661My walls are all taken by cabinets and the bay the bikes are in is too short for a car. When the house was built (not by me), a four foot entry room was built sticking out into the garage bay.
    lol yeah that's also another aspect of it. I kind of want to put up some tool shelves on the walls instead of having bikes take up all the space.
    hmm I just thought of something. From the looks of it, perhaps I can build the stand to hold bikes more at an angle so that it doesn't stick out into the main garage area as much. I'll have to do some measurements.
    I have one that is real similar to gcappy's. The PVC fittings were tight enough that I did not even use glue. I pounded the fittings on with a rubber mallet and they are not going anywhere.
    Minnesota Off Road Cyclists www.morcmtb.org
    Quote Originally Posted by av8or View Post
    Your seat angle! Ouch!
    aka bOb
    Reputation: bdundee's Avatar
    This is how I do it.
    Attached Thumbnails Attached Thumbnails DIY bikestand for fatbike-cycle-guide-install-6020-square.jpg
    Reputation: bcriverjunky's Avatar
    Jul 2014
    Quote Originally Posted by bdundee View Post
    How do you keep the oil from leaking out?
    Marin Bobcat Trail 29er - Trek Farley 8
    Jul 2014
    Your poor bikes are going to be smashed if the car falls on them....
    How did u u mount your suv to ceiling?
    Looks good but my garage ceiling is 12.5' high.
    Lone Wolf
    Reputation: Osco's Avatar
    Apr 2013
    Cars go in the driveway,
    Bicycles go in the Garage,,,,
    “I seek only the Flow”,
    Climbing Is Supposed To Be Hard,
    Shut Up Legs :P
    Oct 2013
    I thought bikes went in the dining room.
    since 4/10/2009
    Quote Originally Posted by tedsti View Post
    Yep, this is how I need to do it when I build a new one. The one I have currently is glued super tight (it was built for the back of a pickup, so it's probably better to glue it in that case). I even painted it, to boot. Painting PVC is NOT easy.
    Dec 2013
    I don't have a photo with the fatty in it right now, but you get the idea. 2x4, steel pipe and fittings, metal rings and "husky hang alls" from home depot. You can squeeze a lot of bike in a little space, and still have some floor space to boot..
    since 4/10/2009
    was talking to the wife last night about our bike storage in the basement. she really likes the idea of a hanging system like above. should maximize floor space a bit better for us.
    aka bOb
    Perfect then you shouldn't hit your head on the car.
    Aug 2014
    Quote Originally Posted by Fuzzwardo View Post
    This. My wife even said I can get rid of the dining room table - we never use it anyway. :-)
    Reputation: coke's Avatar
    I made these out of scrap wood. Tire size doesn't matter.
    Quote Originally Posted by lambeinator View Post
    This is so slick. With pedals removed and bars rotated this set-up looks like one of the best ways to compress your quiver storage. Probably best for me to just to sell a few bikes, but either way, I'm stealing this design. Cheers lambeinator!!
    Jun 2013
    Quote Originally Posted by smilinsteve View Post
    Not really.. Protects the jewels.. Plus when you're "grande", you gotta make room..
    Dec 2013
    cheers monkey. I found something somewhere on the net about this idea, just passing it on, not sure where I got it from... Hint: put more loops on than you think you will need then you will be ready for n+1 without disassembly...
    Re: DIY bikestand for fatbike
    Bad seat angle is bad seat angle. Fix it and your hands and wrists will thank you.
    Nice rack. I need something like this.
    Jun 2013
    Quote Originally Posted by ultraspontane View Post
    The angle is not that bad as the picture shows.. Been mtb for years now and my "balls" have been thanking me every ride.. Besides, they have that angle options for personal preference.. Like how some like to ride seat low? I ride seat high.. Won't tell them otherwise..
    Nov 2014
    DIY bikestand for fatbike-imageuploadedbytapatalk1417546654.570833.jpgDIY bikestand for fatbike-imageuploadedbytapatalk1417546677.455623.jpgDIY bikestand for fatbike-imageuploadedbytapatalk1417546703.926151.jpg
    Here my DIY rack. Easily reconfigured too.
    Some scrap wood and ten minutes work. Just sold 3 bikes so I am done to just the Fat bike atm.
    I know a little off topic but seeing these pictures, I have a Silly question but I have a MTN bike with hydraulic brakes and getting ready to purchase a fat bike with disc brakes as well and was told at one time that I could t hang them from the ceiling doing to the brakes leaking. Is that a real concern? What if I would hang them from the front wheel on the wall. Does this have the same effect on the brakes?
    '11 Specialized Crux Pink SS
    '15 Trek Farley 6 Fat Bike
    '15 Specialized Fatboy
    '12 Specialized Crux Skittles
    turtles make me hot
    Reputation: NYrr496's Avatar
    We have six bikes with disc brakes. They spend time upside down, hung up... Whatever. It's a closed system. It doesn't leak.
    I like turtles
    Reputation: SJEVO's Avatar
    Sep 2015
    DIY bikestand for fatbike-dsc08821.jpgDIY bikestand for fatbike-img_20160504_182141528.jpgDIY bikestand for fatbike-img_20160504_190630915.jpg
    Been using this homemade pvc rack for months now with no issues.
    17 Surly K-Monk
    16 NS Surge
    Jul 2017
    Well here is mine, definitely strong enough, 2x2's would have been better but the 2x4's and 2x6 I had along with the white trim paint so the cost was zero out of pocket.
    DIY bikestand for fatbike-img_1365.jpgDIY bikestand for fatbike-img_1366.jpg
    Reputation: kat71's Avatar
    likey likey
    Reputation: WhiskeyJr's Avatar
    Jul 2014
    Using the husky wraps from Home Depot, a piece of closet rail, four brackets and a piece of laminated shelf board. Worked great.
  1. Replies: 9
    Last Post: 12-03-2014, 01:37 PM
  2. Fatbike for the MDH 100?
    By RMcjd in forum Fat bikes
    Last Post: 07-28-2014, 11:40 AM
  3. New Fatbike Build (LBS or experienced FatBike shop)
    By synthesis in forum Fat bikes
    Last Post: 02-23-2013, 03:56 AM
  4. What do you use your fatbike for?
    By nelzbycks in forum Fat bikes
    Last Post: 05-15-2012, 05:32 AM
  5. Replies: 2
    Last Post: 06-06-2011, 05:12 AM
