Results 1 to 15 of 15
    Good job! Dillinger 5 on Rolling Darryl fits a Pugsley offset fork
    There are too many tire threads here and I can't find the one that had a bunch of fit questions. So if the mods find the thread I'm thinking about, and want to put the comments there, feel free.
    At 10-12psi a Dillinger 5 on a Rolling Darryl wheel fits with no problems on the old-style Pugsley offset fork. I'll grab a pic tomorrow. I currently have a tube in the tire to get it smoothed out from being folded in the packaging. I plan to go tubeless in the next few days with it.
    I'm also going to try stuffing it on the offset rear and see how close it is on my Pugsley (a medium size frame).
    One thing of note is that I have Avid mechanical brakes, and it is a pain to get the tire past the front brake caliper. I can deal with that though to see that big fat D5 on the bike.
    I also found that even 10psi seems MUCH stiffer than 10psi on my old Larry 3.8 tires. I'm thinking I'll definitely be running the D5 under 5psi.
    Andy B.
    Main Ride: 2016 Jekyll Carbon 2
    '11 Pugsley
    '97 Uber V conversion
    Here are some photos....
    This is the closest the D5 gets on the front. There is actually about 4-5mm at the closest point.
    Here's the D5 mounted in the rear. It's difficult to get a good photo of it, but again, this is the tightest spot and it's about 3-4mm of clearance.
    The knobs rub the corner of front derailleur. I just have a standard 3-ring crank installed, but thanks to a very kind offer from a fellow forum member, I purchased a Mr. Whirly crankset and I think it would allow me to run a D5 on the back if I wanted. There is plenty of space between the chainstays.
    '11 Pugsley
    turtles make me hot
    Reputation: NYrr496's Avatar
    Excellent. That's on Darryls?
    I like turtles
    Quote Originally Posted by NYrr496 View Post
    Yup, Darryls with the cutouts. I'm only around 150 all geared up so I don't think anything will flex enough to cause any rubbing to worry about. Plus, this is mainly a snow and sand bike. Although, I do run it in the summer on singletrack when I feel like it.
    '11 Pugsley
    Jan 2013
    andy b,
    Thanks for posting that. It's great to have info out there like this with so many Pugsleys floating around.
    sluice box
    Reputation: Co-opski's Avatar
    Oct 2013
    good info
    ptarmigan hardcore
    Reputation: [wahoo]'s Avatar
    This is great. I am wondering how the MWOD helped with rear clearance. I currently have and OD crank on my Pug and was quite curious if a 5in tire was possible.
    "Those who wander are not always lost"
    Quote Originally Posted by [wahoo] View Post
    If you're asking me, I have the MWOD, but haven't installed it yet. My Nate should be here tomorrow and I'm going to mount it up on a Rolling Darryl wheel. I probably won't put the MWOD crank on for at least a few weeks, well, unless the Nate has clearance issues. Then it will be installed in days.
    Once I do put the MWOD crank on, I'll put the D5 in the rear to see what kind of clearance I have. I'll report my findings.
    '11 Pugsley
    dillinger 5 on rear of pugsley
    Dillinger 5, on rolling darryl at 20psi (overnight), seat-stay clearance
    Dillinger 5 on Rolling Darryl fits a Pugsley offset fork-img_20150213_070913.jpg
    chainstay clearance
    Dillinger 5 on Rolling Darryl fits a Pugsley offset fork-img_20150213_070929.jpg
    sorry for the crappy cellphone pics.
    I have a Bud up front, and this particular Dillinger 5 doesn't compare in size. Its bigger than the 127 tpi Nate i had on previously. I'll probably have to drop a gear from the cassette in back. currently setup 1x10
    Reputation: 69tr6r's Avatar
    When you say drop a gear in back. Do you mean space the cassette for tire clearance?
    Thanks.
    Quote Originally Posted by 69tr6r View Post
    Thanks.
    yep
    Quote Originally Posted by hotwater View Post
    yep
    Cool. I would have no problem doing that for a D5 on my pugs.
    Thx.
    Thx.
    no problem. the only reason i have them is because I won them at post race raffle last weekend. I tried to sell them for a few days, but no offers came in. figured i'll keep them around for those times when it gets icy out (since these are studded).
    An update on my front D5. I went tubeless yesterday (split tube) and had a good 13 mile ride. I aired the tire back up to a little over 10psi (I run lower out on the snow), and it definitely expanded overnight. On the front offset Pugs fork I am down to about 2-3mm clearance. I don't think it will expand much more, but I don't think it will work on the back of my Pugs because before it expanded I had only 3-4mm of clearance, this will put me down to around 0-1mm clearance. That is too tight. I'll try it to see, but I don't think it will work in my case.
    '11 Pugsley
    turtles make me hot
    It's gonna go BRAAAAAP.
    I like turtles
  1. Dillinger 5 on Darryl fit a Pugsley?
    By eastman115 in forum Fat bikes
    Last Post: 02-05-2017, 05:56 PM
  2. Replies: 5
    Last Post: 01-28-2015, 05:44 PM
  3. Rolling Darryl offset to non-offset
    By drmayer in forum Fat bikes
    Last Post: 01-13-2014, 09:42 PM
  4. Replies: 0
    Last Post: 07-14-2013, 08:19 PM
  5. Replies: 0
    Last Post: 10-23-2011, 11:25 AM
