Results 1 to 6 of 6
    Wig
    Wig is offline
    Aug 2014
    Dillinger on 19mm
    No real reason other than I had the time and was swapping tires. I just wish I had something they would fit onDillinger on 19mm-image.jpgDillinger on 19mm-image.jpg
    Dec 2013
    Re: Dillinger on 19mm
    19 is ok but I prefer 17 for the rounder profile and fewer pinch flats.
    Reputation: ADKMTNBIKER's Avatar
    Nov 2014
    skinny little wheels.
    Feb 2012
    I had a 2.4 tire with tube blow off the front rim coming down on some off camber stuff, not a lot of fun, came up missing some skin in a few places and pretty well shaken. I would be careful with them, it all fun and game until itís not and those look scary just to air up!
    Wig
    Wig is offline
    Aug 2014
    Like I said, I had nothing to try them on but I'm sure they would be rolly-polly. I had 2.4 on the same rim and that was pushing it - tubeless and all it never burped or anything but it took some getting used to the sidewall roll
    Did you use a road tube?
  1. 19mm rim 26" what Stan's kit
    By krshome in forum Wheels and Tires
    Last Post: 05-26-2014, 07:51 AM
  2. 2.4" tire on 19mm rim?
    By Noclutch in forum 29er Components
    Last Post: 06-17-2012, 11:21 AM
  3. Superfly 100 with 19mm shorter shock ??
    By Menzo in forum 29er Bikes
    Last Post: 11-01-2011, 06:10 AM
  4. 94mm BCD Spider for 19mm spindle
    By j306 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-24-2011, 09:03 AM
  5. Fork-hub stiffness (std QR, 19mm vs OS 28mm)
    By whtdel in forum Wheels and Tires
    Last Post: 03-18-2011, 10:23 AM
