• 07-24-2012
    gravelrd
    30.5 measured?
    Originally Posted by pierre meux View Post
    OD = 30.5" ... Thanks BoogieMang.
    Was the 30.5 " OD arrived at by using a tape measure or adding the 622mm+....?
    For instance, an ExiWolf 29" x 2.3" on Salsa gordo is 28.5" OD. 723.9mm OD. If you add the numbers it appears it should be 738mm (622mm + 116.84).
    15-20mm will make a big difference in terms of clearance.
    thanks.
  • 07-24-2012
    ward
    thanks.
    Ya, have to wait and see actual results. The "2.3"" stamped of the side of a tire often doesn't measure exactly 2.3"... sometimes one brands 2.3 will fit and another's won't. Plus you don't know who or how they measured them. Have to take the tire size thing with a grain of salt 'till you get the goods in hand.
  • 07-24-2012
    GrayJay
    thanks.
    Take the sideview picture at;
    http://24.media.tumblr.com/tumblr_m7...9plo2_1280.jpg
    Open it in a photo program (I use gimp) and measure the # of pixels for the overall outside diameter of the rim at the lip (know deminsion is 633mm, NOT the 622 bead seat specificaiton which is not visible in the picture). Now measure the pixel count of the OD of the tire on same rim and do the math to get tire diameter in mm. I get 765mm (30.1") for knard, basically the exact same outside diameter as a big fat larry so any frame that can use a BFL should do fine with diameter of the knard. Very likely that whatever maximum size limit of the tire manufacturing machinery that limits diameter of BFL to 4.8" is also identically involved in limiting OD of the knard thus they are same OD.
    I also found a good front shot of the knard tire, scaled from pixel measurement of the 44mm headtube and measue the knard tread width as 81mm / 3.2" .
  • 07-24-2012
    gravelrd
    Makes sense
    Open it in a photo program (I use gimp) and measure the # of pixels for the overall outside diameter of the rim at the lip (know deminsion is 633mm, NOT the 622 bead seat specificaiton which is not visible in the picture). .......outside diameter as a big fat larry so any frame that can use a BFL should do fine with diameter of the knard. .....
    Thanks for doing the work. Makes sense.
  • 07-24-2012
    El Train
  • 07-24-2012
    gregg
    Just added a video to my article here:
    New Surly Krampus (Not a 29er, Not a Fat Bike – 29+) | Mountain Bike Review
    <iframe width="560" height="315" src="http://www.youtube.com/embed/_3HHldATIno" frameborder="0" allowfullscreen></iframe>
  • 07-24-2012
    sanjuanswan
    Anybody know what the seat tube diameter is? I can't tell from the photos. It would be nice to put a dropper post on it.
  • 07-24-2012
    Drew Diller
    If it is a typical Surly 27.2 ID tube, you can always run a KindShock post, they go down to 27.2. I haven't had any troubles with mine, an i7 remote version.
  • 07-25-2012
    byknuts
    Originally Posted by byknuts View Post
    they've got a line on special order IGH's, ultra-low torque ones with some weirdo cog offset that'll clear a nate on a centered 135mm frame, maybe a 73mm bb to avoid 100mm bb q-factor induced knee pains?
    that's all the "they say it can't be done" I can think of in one bike that's still a rigid. (as per Surly's MO)
    could be a travel coupled bike, but that's hardly "can't be done" stuff...
    just realized, i was right about centered 135 and 73mm bb! LMAO!
    what do i win?
  • 07-25-2012
    ward
    Originally Posted by ward View Post
    At work right now so I'll check again when I get home, but my ALU Fatback (first generation) is too short for 30.5, as per the CS brace and the derailleur cable. So is my custom FB... as far as the tape mesure shows. I'll have to wait 'till I have a tire/rim in hand to mesure myself. 30.2 or 30.3 might barely fit, but 30.5 just doesn't look feasable for the shorter CS'd bikes. Might fit on the 907... they're quite a bit longer. It's all good! I like my short CS's. And I love my FB's just like they are. If the Krampus works out to be the cat's meow for certain purpose's, just have to go w/ a complete bike... and, like I said, curious to see how this new format evolves... the 50mm rim is spot-on for all around riding w/ a 3" tire (IMO), but a 65mm rim would bring those beads out closer to the width of the tread and increase it's floatation by leaps & bounds (all around dirt handling being the trade-off). I'm guessing we'll also see some ALU and TI offerings from other builders as well... FUN STUFF!:thumbsup:
    Re-measured last night; On the Fatback I'll rub the derailleur arm and cable at 30" almost exactly; On my custom it will touch the CS brace and the cable at 30 1/4" so if it turns out that they're 30.1 they might fit on that one.
  • 07-25-2012
    Cloxxki
    Always shop for bikes with the Fatties Fit Fine decal :-)
    Oh well, another bike then!
  • 07-25-2012
    Burnt-Orange
    after looking at the numbers its almost like surly designed the bike around XX1
    Sj
  • 07-25-2012
    vikb
    Sj
    Doesn't XX1 cost nearly the MSRP of a Krampus?...:eekster:
  • 07-25-2012
    woodi2259
    I reckon so.... Hopefully it'll trickle down and we'll see an X71 or X91 in the not too distant future.
  • 07-25-2012
    byknuts
    don't take this to the bank or anything, but when I take my gazzi'd wheel out of the Niner's fork dropouts and slide it up the legs a couple inches, it looks like the tire will still clear.
    40mm rim.
  • 07-26-2012
    Cloxxki
    40mm rim.
    Surely you mean a steel fork? Not that the carbon should not fit, it might as well.
  • 07-26-2012
    coastkid71
    I just blogged about the Krampus from a Scottish owners point of and use (want!) for this bike:
    coastrider: Another new bike coming from Surly Pt2 - The Krampus 29+
    Mentioned is the tyre clearance/ low gearing options needed for riding here in UK conditions, compatibility of 2x9 cranks/mech for builds from present bikes etc...
    Feel free to pop over and leave your view, thanks :thumbsup:
  • 07-26-2012
    GrayJay
    Changing crankset to a MWOD, or using a adjustable chainline Profile crankset with a wide spindle, or adapting a 148mm wide ISIS spindle to the 73mm shell could likely allow a Krampus owner to widen the crank chainline enough to get tire clearance for an inner 22T chainring and have a useable middle chainring 2X setup.
  • 07-26-2012
    Dr Feelygood !
    Or using a 83mm by 133mm long FSA ISIS BB and spacing it over if you need too ?
    Did this on the Fat Klein and it allows granny ring with enough clearance for Larrys on Trailtec 47mm wide rims.
    Should work fine with RH's and Knards :)
  • 07-26-2012
    coastkid71
    Looks like a few options then for the crankset :thumbsup:
  • 07-26-2012
    El Train
    can someone please merge this thread with the Surly Krampus thread in the 29er forum?? this is getting bothersome...
  • 07-26-2012
    byknuts
    yeah delete the one in the 29er forum, this thread's been active since day one and is 17 pages long.
  • 07-26-2012
    Sand Rat
    You mean there is a 29er forum?
    If it going to be deleated...perhaps the least I/we can do is go and pay our respects?
  • 07-26-2012
    Rabies010
    I think the 29er forum should now be called the 29- forum.
  • 07-26-2012
    byknuts
    just convince Boogiemang to change the title of this thread to "The Official Surly Krampus Thread" and we're golden! :D
    seriously though, nothing about the Krampus screams "29er" but everything about it screams "what fatbikers have been asking for as a summer bike for years now"
  • 07-26-2012
    modifier
    Not all Fat bike fans and 29er fans cross over. Having 2 threads going makes more sense.
  • 07-26-2012
    El Train
    just a thought. i am just so lazy i don't like checking both for updates...or pressing the shift key.
  • 07-26-2012
    Yoreskillz
    That's a genuine problem there.
  • 07-27-2012
    Velobike
    ...seriously though, nothing about the Krampus screams "29er" but everything about it screams "what fatbikers have been asking for as a summer bike for years now"
    +1
    Can't remember when I last looked at the 29er thread.
  • 07-27-2012
    Sand Rat
    CK
    I know this is a little off topic, but as per your blog and your thoughts on XX1, are the XX1 style
    chainrings really required for operation? Yes I understand that chain rentention may suffer, but
    required? If nothing else, run a rear cog as a chainring, would take some work, but seems very
    doable? A 26T would give something like 77.0-18.7gi with a BFL
    I think SRAM missed the boat with their choice of BCD and dedicated cranks.
  • 07-27-2012
    Sand Rat
    Hey guys...
    U'all waiting for CK to post? Carry on!
    My question was not important enough to start a new thread.
    Just asking to see if he or anyone had thought about breaking the rules with XX1.
  • 07-27-2012
    BoogieMang
    It won't let me edit the first post :madman:
  • 07-28-2012
    Guitar Ted
    You might check this out. North Shore Billet makes a spider for SRAM cranks in the standard 104/64BCD for the 2X cranks with the proprietary SRAM BCD
    Drivetrain Components « North Shore Billet
  • 07-28-2012
    modifier
    CK
    Not necessary but performance will likely suffer going with standard rings. Haven't tried it yet but it seems like a good idea to me.
    Making them proprietary is not such and issue since they have designed a full system to work together and to make it work the best having all of it is probably better. Plus like G-Ted said you can buy a different spider if you want to.
  • 07-28-2012
    Yogii
    A little off topic, but will Big Apple tires fit on the Rabbit Hole rims?
  • 07-28-2012
    modifier
    Does Big Apple make a 29" fat street tire or something? If so any 29er tire will fit on the rims. Even skinny ones. But fat ones (2.35+) will fit better.
  • 07-28-2012
    byknuts
    yeah BA;s would fit for sure.
    big apples are 2.3" slicks made by schwalbe, but they're VERY large air volume so they could spread out quite a bit on RH's.
    try searching for "hookworm on large marge" pics. hookworms are 2.5's but the visual effect of big apples on rabbit holes would look fairly similar. (since the rabbit holes are 50's and the LM's are 65's.)
  • 07-28-2012
    coastkid71
    Still no one has answered the question though; will a regular crankset with a granny ring (22t) have chain/tyre clearance on this bike? no 22t front ring capability with a 34t or more usefully a 36t ring will allow this bike to climb anywhere usefully, no matter how hairy your chest is :D
    When many people built their first 29ers they stripped a hardtail and bought a frameset/ rims and tyres. Once the wheels were laced they built the bike with remaining parts, so a cheaper build was possible.
    An expensive crankset like a 73mm MWOD makes this not a very cheap build then sadly.
    Guess that will be answered when folk get hold of one and ride them a bit.
    People have also commented on my FB page about the Krampus lack of 22t granny ring compatibility and lack of tyre clearance for mud...
    No one on here seems to want to address these issues folk are asking?
    Lets see some mud plugging low gearing pics please or film! :thumbsup:
  • 07-28-2012
    modifier
    I haven't seen the bike so I don't know but using a 68/73 BB and a 135 hub may make it so the wider tire won't fit but probably not. 3 inches is not that wide. With 3.8" tires using a 100mm BB and a 170mm hub makes enough room for a triple with no funny Pugsley type offset.
    On fat street tires. I wish they made a 2.5" Hookworm in 29" I used to run the 26er version on a commuter bike before it was stolen and they are great tires.
    Let's hope the fatter 29er tire revolution is on the way. The extinction of DH Dissents was quite a blow to the off road world imo.
    Here is my 29er DHer that I just built with Dissents.
  • 07-28-2012
    coastkid71
    Was unable to find 29er Dissents here in the UK, pity as looked a good tyre
  • 07-28-2012
    byknuts
    Well Coastkid, all I can say is that I don't have a CLEAN full gearing range on my middle ring with 3" gazzis.
    Orange patriot, 40mm rim, saint cranks, spaced as far out (all offset spacers to the drive side) as I can and the chain JUST rubs the tire in the granny rear.
    it's acting as a sand shave really... bollox for the chain.
    I'm expecting you'd need a longer than (current) standard bb axle. but only by 5 or 6mm, nothing crazy.
    some cranksets just have an inherently different chainline so if there were a better database for that sort of thing to point you in the right direction, that might be all you need.
    gazzis aren't knards though so take my "knowlegde" with a grain of salt.
  • 07-28-2012
    Yogii
    Thanks GT...this is what I found about the Big Albert, 28 x 2.35 or 60-622. Will they fit the Rabbit Hole?
    If so, this will open up a lot more interest.
    Big Apple HS 430 | Schwalbe North America
    cool project either way.....
  • 07-28-2012
    Guitar Ted
    Spreading a 2.35" tire across a 50mm rim is certainly possible. It may look like a low profile tire. and lower pressures may not be a good idea. Also, all of the previous depends upon a solid fit between the RH and the tire. A loose fit would be a bit sketchy, I think.
  • 07-29-2012
    Dr Feelygood !
    I don't think ANY Dissents made it to the UK :(
    Would have liked to try that.
    The cheapest chainline fix is the spaced 83mm ISIS BB as it will clear Larrys on 47mm rims.
  • 07-29-2012
    modifier
    Are you saying space it out on a 68/73mm bb shell? I've thought of that but didn't know if it would work. That's quite a bit of spacing.
  • 07-29-2012
    Dr Feelygood !
    Yes :D
    This is exactly what I ended up doing on the Fat Klein (73mm BB shell).
    It is only 5mm each side, so two 2.5mm spacers on the drive side is all that is needed.
    FSA BB is 133mm long (ISIS).
    Works well :thumbsup:
  • 07-29-2012
    coastkid71
    I took a pic of the BB on your Fat Klein last summer Doc :thumbsup:
    UK Fatbike meet, 17 &amp; 18th September Northumberland, 2011 081 by coastkid71, on Flickr
  • 07-29-2012
    Dr Feelygood !
    Good stuff CK :D
    Looks a little different now :)
    I've also done a little bit of measuring and it WILL take RHs+Knards :thumbsup:
  • 07-29-2012
    El Train
    new pic on FB. I see two chainrings and a front derailleur.
  • 07-29-2012
    BoogieMang
    Good catch
  • 07-30-2012
    MauricioB
    Running 2.35 WTB Moto Raptors on a 26"x48mm trials rim worked fine for me and I think for lots of people on this forum. Some people were even putting Big Apples and Hookworms on 65mm Marge rims and claimed they worked fine.
    Still, it might benefit you to try before you buy if you have the opportunity...
  • 07-30-2012
    jfkbike2
    It appears my DeSalvo fatbike will take these 29+ with no issues. It has sliders with a Rohloff so I have to decide if I want to get a second Rohloff so I can switch back and forth or do I want to dismantle my current wheel.... I am leaning towards a new hub....
    I have been waiting for this combo since 2007... pumped.:D
  • 08-01-2012
    leadphinger
    Can anyone guess if these will fit on the back of a 1st generation Turner Sultan?
    Wondering if anyone measured this yet...
  • 08-01-2012
    jncarpenter
    No way they work on a sultan....barely ST clearance w/ a 2.4 Ardent at full compression.
  • 08-01-2012
    leadphinger
    I realize it's a no go on the DW Link Sultans but I'm talking about the first gen with a horst link. Those have crazy clearance...and the tire moves out and up as it progresses through its travel.
  • 08-01-2012
    byknuts
    hrmmm... coudl it handle a 4-6 susp. fork with 3" gazzi up front?
  • 08-01-2012
    leadphinger
    I just measured a buddies first gen. Sultan and it has 15 inches of clearance exactly at the chain stay yoke and 15.25 at the seat stay...no interference with seat tube that I could detect. It may fit but just barely...if the Knard wasn't so wide that is...the yoke at the chain stay is only 78mm. Seat stay has room to spare at 84mm.
    Close but no joy for the first generation Sultans with horst link rear end.
  • 08-17-2012
    Yoreskillz
    Your Rabbit Hole Looks Knardy
    "We've told you most of the pertinent details of the new 29x3.0 Surly Knard tire. It'll be about 820g for the 120tpi folding version and pretty close to that for the 27tpi. It's got blocks and whatnot for a tread pattern and it is 100% the best thing ever in the history of the universe and if you don't buy two you don't know anything about anything and you're a big jerk. It's also a very nice tire.
    So nice that we're going to make it in a 26x3.8" too.
    THE RABBIT HOLE
    It's a 50mm rim built for getting wide with 29ers. It will fit 29" tires down to about 2.4 or 2.5" and - of course - up to the Surly 29x3.0 Knard with which it was tandemly designed. It's got all of the nice features of our fat-bicycling rims - the cutouts for weight savings, the 64 spoke hole pattern for symmetric or asymmetric builds - but it's, you know, bigger in the circumference sort of way. It will weigh about 700grams and will help you be a better person.
    It's a single wall rim, but only mostly. There are actually internal spaces near the sidewall areas that make it a bit of a hybrid between single wall and double. Cut one in half and you'll see.
    This sucka is going to come in traditional light-sucking black or in fancy shiny silver. Oh yes.
    Here are some numbers that might help you decide if Knard or Rabbit Hole are right for you:
    The Knard 3.0 tire on a Rabbit Hole 50mm rim will be 75.8mm/77.7mm (casing/tread) wide and will have a diameter or 779.4mm (at 19psi).
    The Knard 3.0 tire on a Velocity P35 will be 72.6mm/76.7mm wide and have a diameter of 778.6mm.
    A Schwalbe Racing Ralph 2.4" tire will be 66.0mm/59.2mm wide and have a diameter of 752.2mm when mounted on a Rabbit Hole rim (at 35psi).
    A Continental Trail King 2.4" tire will be 65.5mm/57.1mm wide and have a diameter of 759.5mm when mounted on a Rabbit Hole rim (at 35psi).
    (The above numbers, as you may guess, will have some plus or minus to them when you mount up your own tires, because that's how the world works Ricky.)
    That's what you get for today. Thanks for hanging with our scribblings this week. Please let us know if you have questions about any of this, ok?
    Thanks,
    Skip"
  • 09-04-2012
    Bigggs
    I rode one this week... Not convinced.
    Is it a heavy and stable(slow) 29er or a sort of fat fat bike? Felt like a little bit of both and the bad parts of each. Is it fun? sort of, but I don't see me getting one anytime soon, I would get a 26" fat bike first.
  • 09-04-2012
    ward
    Interesting! Haven't had a chance to ride one yet. Had a friend (who also hadn't ridden one) tell me I "need a Krampus... it's the best of both worlds" (refering to 29er's and fat bike's). He was assuming of course that it couldn't be the worst of both. Sometimes mixing all the ingredients you have together DOESN"T make a tasty dish. Only time will tell. Going to have to "taste" this one for myself!! Cool that they're planning a 26 x 3.8 Knard. Can't wait to see that!
  • 09-04-2012
    damnitman
    ...I'd still prefer a 26x3.0 Knard...
  • 09-04-2012
    Guitar Ted
    I see the pre-production 26 X 3.8" Knards are being ridden. Saw a pic. Looks pretty flattish, not so rounded like the 29+ images I've seen. But it could have been on a hundy too, so it is hard to say. The rim was a wide one.
    I'd rather have the wider one myself, the 3.8"er. A 3.0 does me no good at all.
  • 09-05-2012
    druidh
    Agreed
  • 09-14-2012
    R n R Troll
    This looks like the surly limited edition new "Krampuss"
    There is a really great pic of it on Singlespeedcycle.nl or something like that.
  • 10-07-2012
    fer83
    what do you guys think about a conventional 26in fatbike back wheel and frame with a 29er+ front wheel? Will it work? no snow here, just thinking about a fun fatbike for slow technical riding and some singletrack
  • 10-07-2012
    Lars_D
    Should work fine with the right fork.
    --Lars
  • 10-07-2012
    IceBiker1972
    Yes, it works just fine :thumbsup: Mine is a Schwalbe RacingRalph 29x2.4" on a Salsa Gordo rim (35mm wide). This combo rolls as a front wheel of my good old Pugsley through the summer months, in pair with Endomorph on normal 80mm wide fatbike rear wheel.
    In fact, I prefer this set-up for the summer: less rolling drag, less wind resistance, no self-stirring of the front wheel (seems like dealing with "self-stirring" of the rear is much easier for me). Less weight also (could help for technical uphills)! The diameter of my 29" wheel is only 6mm bigger than the rear, so no problem at all for the geometry. Traction is excellent and floating is good enough for occasional beach riding and even for very sandy uphills. I normally keep air pressure in the front 29" 1.5 times that of a rear 26”.
    The only problem is an offset fork and so offset front wheel with non-offset rim. Spoke angles on both sides are fine with DMR single-speed hub, but I had to change front disc to 200mm one because of some minor interference of the spokes with brake caliper. Also modified the later (Avid BB7) a bit. ;) Now its fine. :thumbsup:
    P.S. Yes, now I see 29+ in your question. I’ve got no idea about fork clearance with this new Surly tire (never saw one), but I wouldn’t do this on Pugsley due to geometry change (slack top tube angle is not good for technical riding). Mukluk or anything else with longer fork could be a chance though, better with a change of the fork to somewhat shorter one.
    Greetings from Siberia.
  • 10-10-2012
    drofluf
    ^^Reported!
    EDIT not the post that is now above this but some spam that was there earlier.
  • 10-10-2012
    Velobike
    Originally Posted by drofluf View Post
    ^^Reported!
    You should probably have quoted a bit of the reported thread because now it's been removed, you look like you're pointing at another one. :)
  • 10-10-2012
    drofluf
    You've rumbled my cunning plan to chip this thread away post by post :D
    Edited my post for clarity.
  • 10-11-2012
    IceBiker1972
    Fortunately I've seen the deleted post, otherwise could be confused :)
  • 10-11-2012
    ozzybmx
    ^^Reported!
    The whole of MTBR is getting hit pretty bad by spambots at the moment. The mods usually delete the post and the spammers account.
  • 10-28-2012
    CdaleTony
    Rode the Krampus today......I think I dig it! Didnt have a whole lot of time though...I found it alot more nimble than my previous moonlander demo...
  • 11-01-2012
    dirtrider6
    Agreed!
    Would be an awesome Summer tire, hope someone is listening:D
