Results 1 to 23 of 23
    Reputation: manchvegas's Avatar
    Mar 2011
    Chosen fat bike hubs
    Anyone have experience with these hubs? Any specs on them? POE? sealed bearings? etc.. ?
    determined to put the "mountain" back in "MOUNTAIN BIKING!!!" "HIT IT!"
    2012 MOJO HDeeeeeeee!!!!
    2010 scott CR1 comp
    I think that the 9:Zero:7 and On-One Fatty hubs are both made by Chosen. Those ones are 30 POE and have four sealed bearings. The 9:Zero:7s are listed at 368 grams and the On-One weighs around 450 grams (aluminum v. steel freehub body?).
    I have about 1000 miles on my Fatty hubs without any issues, but there are a few posts on MTBR by people who have had problems with them.
    Mar 2011
    Cool.. trying to.find.more info.on them.. have em.on ebay for 160 for both hubs.. pretty good deal.if they are quality..
    2010 scott CR1 comp
    Reputation: brankulo's Avatar
    Aug 2005
    i ordered mine from dengfu along with the frame and they were just $118.
    they do look like the ones on 9 zero 7 website, for 1/3 of the price .
    HuRa
    architecture and interior design
    website facebook
    Mar 2011
    Brankulo have you fitted them up to your FM190 yet? Vtmtber was mentioning in the carbon fatty page that he only used one spacer provided.. kinda concerned about that..
    2010 scott CR1 comp
    Aug 2005
    i saw that, someone else with fm190 and chosen hubs didnt have this issue, so not sure, dont have mine yet. not sure what was the deal with one spacer, dont think its a big deal, just dish the wheel to keep it centered
    HuRa
    website facebook
    turtles make me hot
    Reputation: NYrr496's Avatar
    I ran a pair of those hubs from last February til about three weeks ago.
    They were fine until one day a month ago the rear hub's pawls started skipping on a climb. I disassembled the hub, replaced the bearings and the freehub and hoped for the best. It was fine until a climb and more skipping. Upon closer inspection, I had flattened the teeth on the ratchet ring pretty badly.
    I relaced a Hope hub into my wheel and e mailed 9zero7. They sent me a new hub which I'll use on my son's bike he's getting for Christmas.
    Now... I'm 250 or so pounds and climb everything. I'm actually pretty surprised it lasted as long as it did. I bet if I had proactively changed the bearings, I may have prevented the minute amount of slop that probably allowed the axle to move slightly enough off center to cause the initial skipping.
    These hubs are probably better suited to lighter people.
    I like turtles
    Mar 2011
    Did you have chosen hubs or 907 hubs? Wondering if chosen has decent customer service..
    2010 scott CR1 comp
    turtles make me hot
    907. I emailed them and then called and left a message. Got no reply from either. They contacted the shop and told him they'd replace the hub after about two weeks. This is their busy season. I had already replaced the hub with a Hope and didn't care either way, but I'm pretty happy they replaced the hub.
    I like turtles
    Aug 2005
    anyone has spec/measurements for 135 front and 190 rear chosen hubs?
    i need to get spokes to have them ready for when the hubs arrive.
    HuRa
    website facebook
    turtles make me hot
    Quote Originally Posted by brankulo View Post
    Which rims are you using?
    I like turtles
    Aug 2005
    nextie, 90mm
    HuRa
    website facebook
    arc
    arc is offline
    Sep 2004
    Quote Originally Posted by NYrr496 View Post
    I have these hubs coming on a 190mm thru-axle wheel-set from Q2.
    Are the bearings hard to remove?
    Were the bearings decent quality or should a 230 pound rider should upgrade them right away?
    turtles make me hot
    Quote Originally Posted by arc View Post
    I have to say, the bearings in it were not horrible and were not crunchy or anything when I removed them. The non drive side came right out. The drive side fought me a little. I replaced them with Enduro bearings.
    I'm speculating that worn bearings caused the skipping. They never ever did it before, so what could have started to wear? Probably the bearings.
    I like turtles
    arc
    arc is offline
    Sep 2004
    I'm new to fatbikes and don't normally have hub problems. I picked Chosen hubs after reading reports of Hope and Novatec failures.
    That failure could be anything from misalignment under load, sticky pawls not retracting properly or crap heat treating. Guess I'll be keeping an eye on the bearings and finding a good low temperature grease for the pawls.
    turtles make me hot
    If no one gets back to you with this, I'll have a pair of these hubs in my hands in a few days. I'll measure em up for you.
    I like turtles
    Aug 2005
    all right great
    HuRa
    website facebook
    Aug 2014
    I did not see a set on E(vil)-Bay of a 150 front and 177 rear, only the 190 rear. Where else can you buy these hubs in red?
    ~Kevin
    I have a question for you all. I have the Night Train bullet 190mm rear bike from BD. I am building new wheels and would like to get these hubs.
    The sellers of these hubs always list them as 190/197mm. 190mm as I understand is the OLD, and 190 would be for a QR axle - but 197 is the same 190mm OLD but with a 12mm Thru axle. Does this make sense? I am trying to make sure I don't buy the wrong size and email communication with them has been... difficult.
    Quote Originally Posted by Destr0 View Post
    ~Kevin
    Not Ebay, but if you buy through AliExpress you can just specify which set you want - it's essentially one listing for the 135/150 - 170/190/197
    Free Shipping Chosen Fat Bike Bicycle Hub For Wheelset Dune Buggy Snow Bicycle Hubs Black Color 32 Holes Front 135/150mm -in Bicycle Hubs from Sports & Entertainment on Aliexpress.com | Alibaba Group
    Jul 2013
    Quote Originally Posted by tfinator View Post
    Just built-up some wheels today with a 9ZERO7 197 rear - the only difference between the 190 and the 197 is the push-on end caps. 190 is for a regular QR whereas 197 is for a 12mm through-axle - a 197 frame has a 3.5mm recess on the inside of the dropout to locate the ends of the hub.
    Re: Chosen fat bike hubs
    Quote Originally Posted by dovebiker View Post
    Got it. Mine is a12mm thru, so it's 197.
    Thank you!
    Aug 2005
    i have received my hubs. decent quality for $120. 30 poe. the rear one is 190 and comes with 2 3.5mm spacers for 12x197 rear
    HuRa
    website facebook
  1. New Cal Parks Director chosen
    By pliebenberg in forum California - Norcal
    Last Post: 05-27-2014, 09:36 PM
  2. Chosen Hubs Model POE question
    By bosbik in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-01-2013, 07:11 AM
  3. Chosen hubs, axle conversions
    By BXCc in forum Wheels and Tires
    Last Post: 02-16-2013, 07:13 PM
  4. Are these Chosen Hubs identical to Stan's 3.30
    By nbwallace in forum Wheels and Tires
    Last Post: 06-22-2012, 10:32 AM
  5. After a spinal injury - what have you chosen to ride?
    By farmerfrederico in forum 29er Bikes
    Last Post: 09-13-2011, 01:01 PM
