Results 1 to 38 of 38
    Sep 2013
    Challenge accepted- Mongoose Beast.
    So after seeing people playing around with these bikes I thought I'd have a go of it.
    I wanted to make it as light and reliable as I could afford to justify into this over weight pos.
    After hearing crank problems I knew I had to do something there. BB is 110mm and I started with a 100mm raceface. I turned a plug to press inside the crank spindle and then cut and widened the spindle about 18mm to make sure the crank arms clear the chain stays.
    Inserted, cut, welded, and pad welded.
    Welding up the new chain stay braces from the frame width change. Sitting about 180mm width now for the brake mount bracket and hub.
    Rough mock up. Sporting a Carver O'beast carbon fork. Brakes are Tektro Pros, wheels are Graceful Fat Shebas with Surly front hub and Salsa rear.
    Rim diet.
    And as of yesterday... House of Kolor candy tangerine. Also weld a seat post brace in for good measure.
    Reputation: FatBikeNoob's Avatar
    Aug 2013
    Nice work. Wish I had those welding & painting skills.
    Current bikes: 2010 Raleigh Talus 29er with Ergon GP5 grips, Shimano PD-T420 Click'R pedals, Topeak Explorer 29" Disc MTX Rear Rack and Topeak DXP bag.
    2013 Walmart Mongoose Beast blue
    "Put The Fun Between Your Legs"
    "26" isn't Dead, it just got FAT"
    "I Dream On Two Wheels"
    "Be The Motor, You Are The Engine"
    Heat treat on the BB spindle?
    Hi. Sorry I'm a bit of a dolt when it comes to this stuff, but what specifically did you do to the chain stays? I get your description, but the pic with the carver fork makes the chain stays appear as if they have been altered beyond just the brace. Is that just an optical illusion?
    Sep 2013
    Hardness of the bottom bracket are not that hard. It cut with a hack saw. Its most likely harder now then it was before.
    Sep 2013
    Quote Originally Posted by Slow Danger View Post
    I removed the old kick stand mount and top chain stay brace to make the width change. Lots of forming and bending and pulling to make it right. I then did a curved 1/2" top brace and a 5/8" bottom brace to tie it all back together. I also trimmed some off the drop out brackets to make them a little cleaner.
    Reputation: blown240's Avatar
    Thats awesome dude! Good Job! I love that these bikes are getting cut up and made better. Heres to an awesome build!
    Any reason you went 180mm in the rear? Or is that just how it ended up? Ive got an XT hub im going to widen and was planning on 190mm, but if 180 works....
    Quote Originally Posted by xtreamedrtbker View Post
    That may be a problem- see this thread:
    Shimano 100mm crank= Total Failure
    aka bOb
    Reputation: bdundee's Avatar
    Quote Originally Posted by Andy FitzGibbon View Post
    Man I hold my head in shame and my b@lls start to hurt when this thread gets resurrected. Maybe the OP will have better luck as the Shimano was very very hard to begin with but warning be very careful this almost got me killed literally. I believe it was 38 frameworks (?) that was trying to do the same thing but I haven't heard anything on that in a long time.
    Laramie, Wyoming
    Reputation: alphazz's Avatar
    Oct 2012
    Why not lace up the new Borealis Carbon rims for this build as well to go with the forks?
    Reputation: Velobike's Avatar
    Quote Originally Posted by bdundee View Post
    When I read about the BB extension I cringed too.
    Still, nothing ventured, nothing gained....
    And it's good to see folk experimenting.
    Latitude: 5736' Highlands, Scotland
    Sep 2013
    I have my worries on it also, but the metal was pretty soft, which should work in my favor in this. Worst thing that can happen is a failure of the shaft. If it does, then I will just machine a all new one.
    If I could justify a carbon wheel set, I would. Its a mongoose after all...
    I have my worries on it also, but the metal was pretty soft, which should work in my favor in this. Worst thing that can happen is a failure of the shaft. If it does, then I will just machine a all new one....
    I think it's we're worried about the consequence of the shaft failure on your future reproductive capacity. Perhaps if you put a BMX pad on your toptube it may be safer...
    nothing to see here
    Reputation: Stevob's Avatar
    Why didn't you just cut the bb shell down by 5mm each side?
    edit: I see why now, crank clearance, and I second what Craig said below.
    I see hills.
    I want to climb them.
    Feb 2005
    Pardoning the obvious answer of "because it was there", why on earth would you do this with all the skill and tooling you seem to possess?
    Just build yourself a sweet frame!
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Sep 2013
    A cup might have to be in order..
    I do have all the tooling to make a frame, except for a frame jig, which is on the wish list. I was trying to find out which one is the best for the money. The mongoose was just to see if I could pull it all off properly.
    I come from a big motorcycle back ground and I find bicycles to be a fun and exciting new outlet to play around with without breaking the bank.
    I started riding off road and doing a mtb race this summer (have a '13 specialized epic carbon comp and a hardrock) and found the excitement that I used to have when I raced motorcycles. So I found a roadie to train on (2003 Lemond Nevada City) and started riding to work everyday. Lets just say, I haven't put more then a 100 miles on a motorcycle this summer. Totally a new found passion.
    Laramie, Wyoming
    Oct 2012
    Quote Originally Posted by MendonCycleSmith View Post
    Exactly.
    aka bOb
    Quote Originally Posted by Velobike View Post
    Yes it is and I so miss the days of old where fabricating was required.
    That being said when my crank broke I was jumping out into vehicle traffic at the time and it almost took me down in front of a car. That is where my only concern is but hey have fun and go nuts. Oh and why didn't you weld disc brake tabs on the rear or did I miss something?
    bigger than you.
    Reputation: Gigantic's Avatar
    I work in the motorcycle industry- I've ridden +2500 miles on my bicycle in the past 15 months, 2 miles on a motorcycle. Pushbikes are more fun than even MC roadracing.
    Reputation: davesauvageau's Avatar
    Glad to see some process shots! Getting some good feedback and response too! Lets go shred MB Johnson sometime soon with Shaggy!
    My motorcycle runs on infant blood
    Sep 2013
    Quote Originally Posted by davesauvageau View Post
    For sure buddy! Thanks for all the help along the way.
    Made the chain tensioner today and did most of the final assembly. Still waiting on my front brakes and pedals. I'll have more detailed photos in the next few days.
    Attached Thumbnails Attached Thumbnails Challenge excepted - Mongoose Beast.-1381158_10200492641864451_576628069_n_zps383cfa90.jpg
    Anchorage, AK
    Reputation: Lars_D's Avatar
    Awesome.
    --Peace
    Laramie, Wyoming
    Oct 2012
    It does look good. Who says lipstick doesn't look good on a pig?
    Now, can we correct the wording in the thread title from "challenge excepted" to "challenge accepted"?
    Sep 2013
    Yeah I noticed that after making the post. Don't think I can change it from my account. Not the sharpest mind after a long day...
    Sep 2013
    Few detail shots. Did some riding on it and like how it feels.
    Attached Thumbnails Attached Thumbnails Challenge excepted - Mongoose Beast.-img_20130930_184826_zpsf60dee9e.jpg
    Great looking rear disc mount!
    surprised you didnt just weld a rear disc mount on when you did the seat stays
    although the one you have done is a neat job
    Sep 2013
    Quote Originally Posted by cozz View Post
    Thanks,
    Wanted something that would be adjustable for different gear ratios. Sitting with a 32-19 currently and have thought that I might go up to a 20 or 21
    Reputation: Finski's Avatar
    Question: What did you use for your rim strip? I'm looking for an orange one, and that's about the right color I need.
    NKAWTG
    Reputation: coastkid71's Avatar
    Exactly.
    +1
    Or for the cost of that carbon fork just buy an On One Fatty kit and eBay the needed parts
    plan it...build it....ride it...love it....
    http://coastkid.blogspot.com/
    Sep 2013
    Rim strips are orange surly's for a moonlander rim. Just fits below the bead on a fat sheba.
    I didn't build this bike to be a total answer to my cycling needs. I feel like my Epic does that for me in almost all situations. Just a fun project and not much money compared to throwing money at motorcycles. Planning on hitting the local trails on it Thursday if the weather holds out.
    Reputation: watts888's Avatar
    Oct 2012
    Noticed something about the holes in the rim. I was looking at the fatbikes bikesdirect put out recently, and it appears there are two holes side by side between each spoke instead of the larger hole offset beside each spoke. I can't help but wonder about the weight of your wheel before/after removing the discs. I think two holes per spoke would save more weight, but I'm afraid it might hurt the structural strength of the wheel. This would only apply to those making the wallyworld fatty better, but it looks like there's actually a couple people out there who think this is a good idea.
    Sep 2013
    Rear wheel without rim strip, rotor or sprocket was 1740g. May have been lighter if I would have done 1.5" holes in the centers vs the 1.25" holes offset, but its cool either way.
    I got my beast rim down to 899 grams. Thats just the bare rim with 1.5 inch holes (1 inch by the valve) and the paint stripped off. The paint is surprisingly heavy!
    nothing to see here
    to do that you need to edit the original post using the advanced mode
    I see hills.
    Sep 2013
    Quote Originally Posted by Stevob View Post
    Did that and it only changed the title of the first post.
    Got the front brakes and all the final details done. Stepped onto the scale tonight with it and it came in at about 36 pounds. So not the lightest, but about what I thought it would be. My guest was 34-35, but I'm happy with it at that weight. If the weather holds out, it should see some trail time tomorrow.
    ***Put it on a bike scale and it came in at 34lbs. Guess my bathroom scale is off a bit.
    Sep 2013
    Mb Johnson
    Rode mb johnson tonight. The bike turns surprisingly quick, I will be going to wider bars for more predictable control. I may try a longer stem if the bars don't totally do the trick. The single speed set up worked well. Climbed good, but top speed was a bit lower then I'd like on a few areas. I'm happy with it over all. I put it on a proper bike scale and it came in at 34 lbs.
    bigger than you.
    my lord, Myth Busters was right, you can spit-shine a turd! nice work!
  1. Mongoose Beast modifications
    By Larry Endomorph in forum Fat bikes
    Last Post: 03-15-2018, 11:20 AM
  2. Mongoose Beast Build
    By conniem in forum Fat bikes
    Last Post: 12-22-2013, 10:46 PM
  3. Mongoose Beast... cannot wait
    By 2silent in forum Fat bikes
    Last Post: 11-09-2013, 08:59 AM
  4. Mongoose Beast box size ?
    By NLSpruce3 in forum Fat bikes
    Last Post: 08-19-2013, 02:32 AM
  5. Getting a mongoose beast in the UK?
    By jamesabaldwin in forum Fat bikes
    Last Post: 08-14-2013, 01:37 PM
