Results 1 to 2 of 2
    Feb 2012
    Chainrings for my Raceface Chester cranks. ( 10 speed )
    Am I limited to Raceface chainrings ( Turbine ) for my Chester cranks??
    In the parts bin I have a shimano 10 speed outer 42 tooth ring and a middleburn inner ring.
    Could these be used in combination with with a new middle ring? Can other brands be used with
    raceface cranks? Suggestions? Options? Thanks.
    Feb 2012
    The biggest problem with mismatched chainrings is shifting performance,
    Spacing even if correct, (which is very possible) may not result in shifts at your earliest convenience.
    If all you want to do is see if that ratio is good for you - go for it, it's just a few mins to swap rings.
    If they shift poorly you still can remain in the appropriate gear and see if they give you the correct range.
    Cheaper than buying new rings only to find out they are too tall or too short in the ratio's
  1. Why 10-speed chainrings sell at much higher than 9-speed chainrings
    By solitone in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-03-2014, 05:49 PM
  2. 10 speed cranks, 9 speed chainrings?
    By Hoban in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-26-2012, 02:39 PM
  3. New RaceFace cranks?
    By hatake in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-19-2011, 11:03 AM
  4. Replies: 12
    Last Post: 08-28-2011, 07:19 PM
  5. Chainrings: Blackspire, Truvativ, FSA, RaceFace?
    By TwoHeadsBrewing in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-29-2011, 09:14 AM
