• 12-02-2012
    MartinS
    Which chain lube for winter riding?
    So I've got my first fatbike and done a couple of snow rides and am starting to wonder what chainlube to run. My Fatback's chain seems to have come very well greased, I'm guessing that it is still the packing lube on the chain but seems to be working fairly well (I've never run an FSA chain before, maybe they just throw a lot more lube on it at the factory). I personally will be riding between 5C (41F) down to -10C (14F) in fairly humid snowy conditions, but I'd also like to hear recommendations for colder, drier conditions too.
    My current lube collection is pretty wide thanks to trips to IB as well as trail finds. Here's a list;
    Boeshield T9 (my fave)
    Prolink Gold (heard good things but haven't used due to issues with plastic bashguards)
    Squirt
    Pedro's Chainj
    Pedro's Icewax
    Finishline Krytech
    Finishline Crosscountry
    White Lightning Epic, and Cleanride.
    I'm going to test out what I've got, but any input/experiences from those of you with a few seasons under their belt would be appreciated!
  • 12-02-2012
    SRALPH
    I've had good luck with Rock'n Roll blue, which is a PTFE lube.
  • 12-02-2012
    JoeG
    I use squirt, myself and like it a lot. I normally apply it at the end of my ride (or right after washing the bike) so that it dries before I ride it. You have to keep it indoors or it will freeze.
    I've used Prolink in the past, but didn't like the black gunk that it left on the chain. I also used Icewax many years ago, but found that it wore off quickly, often mid-ride. Squirt is much better IMO.
    I think that I have used Finish Line wet a few times when riding in wet conditions. I don't ride much in the wet as it just tears up the trails here.
  • 12-02-2012
    OntarioMTBMama
    Also a big fan of Rock'n roll blue all conditions use year round.
  • 12-02-2012
    Soupboy
    Fresh baby seal blubber if you can source it.
    If you're not down with the club scene, Rock N Roll works too.
  • 12-02-2012
    RockyRider
    I used to use Finish Line Cross Country and loved it until I found Chain L. I wouldn't use it in dry but in wet and snow and cold I haven't found anything better. I only have to lube my chain once or twice during the winter and it simply does not wash off when riding in snow like all other lubes (including cross country) I've tried
  • 12-03-2012
    Luthar
    2nd Chain-L
  • 12-03-2012
    mavicrider
    Big fan of DuMonde Tech (the dark green one)
  • 12-03-2012
    MendonCycleSmith
    Hot DOG we have a weiner! :D
    Me too, love the stuff.
  • 12-03-2012
    Mr.Magura
    Bar oil.
    Cheap as chips, very high performance, inhibits rust, and does fine till minus 25C.
    Magura :)
  • 12-03-2012
    Shark
    Originally Posted by Mr.Magura View Post
    Bar oil.
    Magura :)
    I use this mixed with about 1/4 motor oil to thin it out a bit. Works fantastic & I get to make fun of the guys with squeaky chains after 20 miles when I haven't lubed in a month.
  • 12-03-2012
    grendalfly
    +1 love this lube for everything.
  • 12-03-2012
    thesilversurfer
    White Lightening Wet Ride has worked for me. I've tried it up to -25C. All good
  • 12-03-2012
    JAGI410
    The tears of roadies on indoor trainers.
    Or Gnar Lube Wet.
  • 12-03-2012
    patineto
    Bar oil.
    Magura :)
    What is "bar oil"... :confused:
  • 12-03-2012
    Mr.Magura
    The stuff also called chain saw chain oil.
    It's available at every second street corner, like gas stations, home depot (for the ones on the wrong side of the pond), around here you can even find it in the big supermarkets.
    1 liter of bar oil, is roughly 15-20$, and will last for the next decade of lubricating bikes.
    In fact I think that if I didn't have a chainsaw, it would get too old before I would get rid of the entire bottle ;)
    Magura :)
  • 12-03-2012
    patineto
    Magura :)
    Great, I have no idea about this oil but it makes perfect sense if it works on chainsaws..
  • 12-03-2012
    GTscoob
    Originally Posted by JoeG View Post
    I've used Prolink in the past, but didn't like the black gunk that it left on the chain..
    The black gunk is the remains of the stock grease coming out. ProLink has a solvent base that eats through previous lube. If you thoroughly clean your chain ahead of time in some mineral spirits, then the ProLink goes on clear and stays that way throughout its use. Only downside of ProLink is that it's thin and doesnt last long, and it eats through rubber and plastic.
  • 12-03-2012
    Mr.Magura
    As posted above, it works very well for bikes. Better than any of "bike oils", especially in harsh conditions.
    That it's an industrial product just means you'll have to find a fancy bottle yourself, and write "bike oil" on the bottle ;)
    Magura :)
  • 12-03-2012
    ferday
    Magura :)
    you can buy bio-degradable chainsaw bar oil as well, which is a big plus. i've switched to bar oil diluted with either motor oil or ATF (slight amounts) and experimenting with vegetable oils for diluting, and as you said, $10 will last longer than the bike.
  • 12-03-2012
    Mr.Magura
    LOL!
    Around here you can only buy bio-degradable bar oil, and it's been like that for quite some time.
    I have never found a reason to dilute it though, why are you doing that?
    Magura :)
  • 12-03-2012
    EPcycles
    Amsoil Semi-Synthetic Bar and Chain Oil. Should work good in the cold plus the price is right a less than $6 per quart.
  • 12-03-2012
    FishMan473
    There are summer and winter grade bar oils. I would guess people are diluting the summer grade oil which gets thick and stringy when its cold. Winter grade should work without diluting. The other great thing about the bio-degradable bar oil (other than it is slightly more environmentally friendly) is that it works well both in winter and summer.
    Phil Wood Tenacious Oil is basically summer grade bar oil.
    I prefer Tri-flow most of the time since I like to clean the salt off of my chain a lot in the winter. If I think its going to be wet or a long ride I might use Pedro's Syn Lube. These lubes can easily be applied when the bike is outdoors, wet and cold. I think most fancy bike lube apply best indoors when its warm and with a little more care.... with that said, I bet T-9 would be great for winter, I miss that stuff.
  • 12-03-2012
    Mr.Magura
    Ahh, that would be the reason I have never understood the point in diluting bar oil. I have simply never had anything but the bio version.
    Thanks :thumbsup:
    Magura :)
  • 12-03-2012
    JoeG
    Not in my experience. The chain was degreased with carb or brake cleaner. Black gunk appeared throughout the life of the chain when using ProLink. YMMV.
  • 12-03-2012
    GTscoob
    Strange, I did a full mineral spirits soak and shake until the chain ran clear then used nothing but ProLink and it dried clear and dry. Worked great but I've moved on from ProLink as it just doesnt last long enough.
  • 12-03-2012
    wrcRS
    ProLink for me.
    I found T-9 to work great till it gets cold (15deg or cooler.)
  • 12-03-2012
    MartinS
    That stuff looks pretty interesting, very different in it's description - "liquid plastic through polymerization" - unless they mean PTFE. Wonder if there is a Canadian distributor...
  • 12-03-2012
    blockphi
    I like bacon fat. Gives the chain a nice scent and if I get hungry mid-ride, well you know...
    Actually I currently use ProLink. Seems okay. Not sure that I am completely sold on it though. It does seem to require application more often than others I have tried.
  • 12-03-2012
    MartinS
    Hmmm, main prob with bacon fat around here is the potential for waking sleeping Grizzlies. Although wouldn't be as bad as this past summer when a buddy spilled the oil from a can of sardines on himself on a high alpine bike ride...
    Had to explain to him that it wasn't the wisest food choice.
  • 12-03-2012
    VanSyncro
    You must ride a FatBack!
    That must force you to keep the cadence up so you can stay ahead of the circus parade.
  • 12-03-2012
    G-reg
    I've been a fan of Rock and Roll, and it works well at low temps. The problem I've found with wax based lubes is that you can't reapply while the chain or lube is cold. After slushy rides or things like the Arrowhead 135 I've found the chain unhappy and I have to bring the bike (or at least the chain) indoors to warm up before lubing.
    I might test out the AmsOil+thinner of some kind for a lube that could be applied at below zero...
  • 12-04-2012
    dan0
    +1
    I use it as well, its a bit dirtier but my drivetrain now lasts a whole season ( chain 6 mos.)
  • 12-04-2012
    dan0
    [QUOTE=FishMan473;9932112]There are summer and winter grade bar oils. I would guess people are diluting the summer grade oil which gets thick and stringy when its cold.
    actually the stringyness is on purpose, it draws the oil back into the cracks and crevases instead of letting it fling off into the air
  • 12-04-2012
    Davesnhere
    Originally Posted by soupboy View Post
    fresh baby seal blubber if you can source it.
    If you're not down with the club scene, rock n roll works too.
    lmao....
  • 12-04-2012
    Schott
    I found myself without a bottle of lube this summer and a bike that had been ridden hard and put away wet, but I did have my chainsaw in the van. I pillaged it for some bar lube, it worked fan-freaking-tastic. I was not aware that it was a common practice. I just bought a heap of rock and roll, but glad to hear that people use bar lube regularly.....good work. Eat food, chop wood, ride bike.
  • 12-04-2012
    zeek29er
    Any tips on how you apply bar oil from the quart container without making a huge mess? Thanks.
  • 12-04-2012
    Schott
    Put some in a smaller bottle?
  • 12-04-2012
    pastorgarret
    Squirt
    Pedro's Chainj
    Pedro's Icewax
    Finishline Krytech
    I use Pro Gold ProLink Chain Lube.
    It keeps dirt out of the drive-chain and helps to keep rust away. It's a lube and cleaner. Waterproof formula and removes all other lubricants; prevents dirt and grit from sticking to the chain, and doesn't wash off in wet conditions. I have found it never freezes and I actually use it to cleanly chain too.
    -Garret
    I'm so Fat!
  • 12-05-2012
    EPcycles
    I have found it never freezes.
    -Garret
    I'm so Fat!
    Not at all true. I left my bottle outside the other day. It was 25F and the bottle was frozen solid. No dice.
  • 12-05-2012
    GTscoob
    You can pour it off into a dropper bottle. When I used to use bar oil on my fixed gear, I would pull the chain off and let it soak in a bottle of bar oil, then pull it out and wipe it off.
    I know guys that soak a rag in bar oil and just wipe it over their chains to lube, seems really messy but I guess its no worse than a drop on each roller.
    Guess the beltdrive bandwagon has broken down? This seems like the perfect thread for someone to jump in and chime on the allweather readiness of a beltdrive setup.
  • 12-05-2012
    dan0
    -Garret
    I'm so Fat!
    sounds like an impossibility, if it removes other lubricants and is waterproof it must be solvent based and as such it would also clean itself off , so while it may leave a small amount behind as it evaporates it would be a very small amount. Wd40 does the same thing, but is too thin to be of much value.
    there is a study done by one of the universities that tested all chain lubes ( in a lab) and they found that none of them did any better friction wise than no lube at all. they deducted that chain lubes value was in filling in the hollows and voids in chains so that dirt and water wouldnt get in and acumulate, also an oil based lube will also offer some rust protection
  • 12-05-2012
    pastorgarret
    I meant on my chain. Not in the bottle. There is less on your chain and maybe if the chain is moving there is enough fiction to keep it from freezing. Most of the other oils I have used froze at low temperatures. Just my experience. :D
  • 12-05-2012
    pastorgarret
    lmao!!!
    OK I am going to try this. Best advice I have ever heard. ;-)
  • 12-05-2012
    dan0
    no real friction going on with a bike chain, especially not enough to melt water
    any solvent based oil will not freeze in temps. that most people ride in. they will get thicker but you have to get well below zero to freeze
  • 12-06-2012
    Nothing's impossible
    I'm fan of wax, now using squirt, but i also liked other brands!
  • 12-06-2012
    Jay P
    If you ride in negative temps and are looking for reliability in all your moving parts, especially your hubs you should be using -
    Morning Star Free Hub Soup - FreeHub Soup (Lube) / Morningstar Tools
    I personally use this on ALL my moving parts. Headset, BB, hubs, pulleys etc
    As for chain, definitely, its like you do it once at the beginning of the year and call it good.. Massage it in and I will guarantee you over a thousand miles. It has worked for us every time crossing AK. Been using it on all my winter bikes for the past 5 years and the one time I didnt treat (Tracey's) hub it froze up at a very bad time...resulted in, well lets just say I boiled the grease and the seals right off the hub and then it worked again.
  • 12-06-2012
    GTR2ebike
    Freezes really easy.
  • 12-10-2012
    Once the water is evaporated it works really well and doesn't freeze anymore then other stuff.
    But if you have no chance of letting the squirt dry, or if you applicate it in low temperatures, you better look for something with a solvent that evaporates quicker or at low temperatures!
