Results 1 to 6 of 6
Thread: Chain Catcher
    Mr Snitch
    Chain Catcher
    Hello!
    I have a 2012 Surly Necromancer that I converted to a 24 tooth single ring up front. Unfortunately, the chain has a tendency to slip inwards off the chainring. I am looking for a chain catcher that is compatible with the 100mm of the surly as well as the 24 tooth chain ring....suggestions?
    Feb 2012
    Isn't that what the wolf tooth front rings are for?
    Mr Snitch
    Maybe, but I have the Mr Whirly cranks still on with their ludicrous bolt center diameter that Wolf Tooth don't make a size for.
    Reputation: duggus's Avatar
    Have a local metal shop cut you a piece of aluminum with a hole in it and bent to fit up next to the chain. I had this made for my full suspension and just converted to 1x up front tonight on my Moonlander. This swapped right over from my other bike. It works more as a chain guide though than a chain catcher... but it definitely doesn't allow the chain to fall off.
    I mocked the size up with a piece of cardboard first, then traced it on paper.
    ...Be careful what you're looking at because it might be looking back...
    Reputation: Teton29er's Avatar
    I have the same bike and used a Pauls Guide.
    Needed to grind a touch off to clear the crank. Never have had a the slightest problem with chain or guide since the day it was put on. Needed to order the long arm option.
    If I was to do it again I'd try a wolf chainring, but what I have works fine.
    Dec 2010
    This is a less beefy option, but worth a mention. On an old bike, long ago (running 1x7) I had this issue and used a spoke as a chain catcher. I bent one end into a round hole that was attached on the seat tube bottle cage mounts with a washer and bent the rest of the spoke over to get very close to the chain and then down and around the bb shell for support. I don't have any pictures, and it wasn't super strong, but it worked well and had a simple look...and it was free.
  1. Chain catcher, Third Eye, etc
    By neverdnf in forum XC Racing and Training
    Last Post: 08-24-2013, 10:52 AM
  2. ISCG 05 Chain Catcher?
    By SManZ in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-07-2013, 07:07 PM
  3. Chain Catcher for Jet 9 RDO
    By WoodstockMTB in forum Niner Bikes
    Last Post: 03-22-2013, 07:07 AM
  4. Replies: 4
    Last Post: 03-02-2012, 09:08 PM
  5. Homemade chain catcher
    By skankingbiker in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-30-2011, 11:02 AM
