Results 1 to 86 of 86
    Jan 2014
    Breaking the seal on tubeless ready rims.
    Breaking the seal on tubeless ready rims.-20151124_210948_resized.jpgBreaking the seal on tubeless ready rims.-20151124_211819_resized.jpg
    Finally had success with breaking the seal on the Mulefuts. Have tried several methods with lots of aggravation. This one came to me tonight after trying several others.
    I didn't even break a sweat to break the seal. Smooth as slicks on ice.
    Step 1. Inflate tire to 12 to 15 psi.
    Step 2. Use metal C-clamps just above the rim about 5 to 6" apart. Start closing the C-clamps in equal increments till the bead lock opens up.
    Step 3. Use tire lever to complete the breaking of the seal.
    Step 4. Carefully pour out the Stans into a container. (Saved most of the stans in the tire)
    Interesting part of this was even when the bead lock was broken, the tire was still holding air.
    As a side note, I have used the stretch wrap method of tubeless. When I removed the stretch wrap, not a single drop of stans had migrated to the rim strip indicating that it works just as well as any tape method. If interested in stretch wrap you can find the process here.
    Tubeless With Stretch Wrap by Bumpyride69 | Photobucket
    Attached Thumbnails Attached Thumbnails Breaking the seal on tubeless ready rims.-20151124_210858_resized.jpg
    Dash Pt. State Park (Tacoma), Big Sky Montana during Snowboard Season, Duluth Mn, a couple of times of year incl. Xmas.
    Feb 2005
    Or just lay the wheel on it's side, slap on a pair of shoes/boots with a nice firm sole. Get your heel right up to the edge of the rim, and jam your weight downward.
    Worked every time with my LB's, but yes, they are surprisingly tenacious, it's true!
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Feb 2006
    Quote Originally Posted by MendonCycleSmith View Post
    I do something very similar.
    1. place the tire on a step with the rim barely hanging off the edge of the step.
    2. Put one foot on the tire on the step, and push down on the rim with the other foot.
    Has worked with four different tires on mulefuts.
    Jan 2014
    I weigh 138 lbs.. Tried several methods including stepping on the tire with both methods listed above. Can't generate enough force, though Thanksgiving is tomorrow and perhaps I can eat enough to gain the weight necessary.
    There are a bunch of us on fatbikes that really don't weigh all that much, or perhaps don't have the skill necessary to effect other methods to break the bead. This was meant to be a help for anyone who has tried the previously mentioned methods without success. I estimate that if you can lift your bike, you can break the bead without breaking a sweat. You can also do this on a bike stand without doing any damage to the rim/cassette/rotors. The second tire I did (not including time to put the bike on a stand nor pumping up to 12 to 15 lbs) took me 1 1/2 minutes to break the seal.
    Feb 2006
    Quote Originally Posted by Bumpyride View Post
    I weigh 145 lbs and had good luck with the method I presented. It is entirely possible that your tires fit tighter. I think your C clamp method sounds reasonable.
    Jan 2014
    Quote Originally Posted by blizzard_mk View Post
    My Floaters came of easily, and the step method worked on those. The Mission Commands did not, even immediately after putting them on the Mulefuts without Stans.
    Decided to try something else with a better mechanical advantage to do the work for me for the 2nd run at removing the tires.
    Calculate the mechanical advantage of the screw by dividing the circumference of the screw by the pitch of the screw. Using the previous examples, a screw with a pitch of 1/8 and a circumference of 0.79 inches would produce a mechanical advantage of 6.3 (0.79 inches/ 0.125 = 6.3).
    It was necessary to keep the tires inflated in order for them not to fold around the C-clamps and to use 2 C-clamps which spread the bead wider.
    I'm a builder, and have found that mechanical advantage saves me much grief. I can lift a 500 lb. beam in place by myself using leverage. Can't budge it just trying to pick it up.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    I know when I set up my LB rims I spent about half a day trying to break the bead from the tires I had set up with a tube the day before to set the rim strip. I tried all kinds of hard and soft boots until I put my SPD boots on and the bead popped relatively easy. I felt stupid for working so hard before. No matter what, it's good you found an easy method.
    Reputation: AthleticAL's Avatar
    Feb 2015
    I think it's genius. Or resourceful at least. If you put a short piece of a 1x board or something similar, you might be able to break the bead with a single C-clamp. And it may be a little easier on the tire sidewall too since it'll spread the pressure out over a broader area.
    In any case, thanks for sharing your solution
    There is a season, turn, turn, turn
    And a time for every wheel to turn through it
    Great solution, Thx for posting. I had to go bare foot to get a toe grip on the tire to get it off the mulefut.
    Can only imagine how much fun I would have if i had a flat and had to remove the tire this way on a remote, cold, deep snow ride. Now I can carry a c-clamp with me I see a market for titanium or carbon c-clamps!!!
    The foot method also excerts s lot of lateral force on the wheel that might have some negative affects on trueness, etc. This method eliminates that.
    Urmb
    since 4/10/2009
    Reputation: Harold's Avatar
    I was in a local shop that was trying to change out a tube on a bike of theirs they were building for stock, that came with a flat tube out of the box. It was the first tire change they had done on a Mulefut rim and they were having an awful time of it. Called Salsa twice (I think the bike was a 2016 Mukluk) for tips and they were still fighting with it.
    I left after doing my own business there, thinking to myself that I was glad that wasn't me building that bike and fighting with that tire. In a way, though, that tenacious bead lock does mean for a more reliable tubeless setup, so it's not all bad.
    beer thief
    Reputation: radair's Avatar
    Dec 2002
    Quote Originally Posted by AthleticAL View Post
    This is my thought as well. I would not put a C-clamp on without a block to spread the point load out a bit. Actually i would not use a C-clamp at all since standing on it works well for me (different rims though).
    urmb, the standing method does not exert a lot of lateral force on the rim. Very little, actually, as your weight is on the tire if you're doing it right.
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    What's the best seatpost bag for carrying c-clamps on a ride?
    Not trying to be smarmy, because your solution gets full points for creativity and using what you have on hand. Just pointing out that eventually you'll need to do this on the trail, and c-clamps are often hard to find out there. At least on my backyard trails.
    Feb 2006
    Quote Originally Posted by mikesee View Post
    ..and this C-clamp method relies on there being some air pressure in the tire.
    Jul 2015
    I can remove, and install on both my Mulefuts by foot and hand. I really don't know where all this aggravation is coming from, did they update the bead to be even stronger? Maybe the first run of Mulefuts is different?
    since 4/10/2009
    Quote Originally Posted by l3eaudacious View Post
    good question. all I know is that at a shop that does a good bit of fatbike business, the employee was having a problem with stepping on the tire to remove it from the rim. He put a 2x4 underneath the rim to prop it up a little and get more room to press down and the tire was holding firm. I left before he got it off the rim.
    I also know that quite a few people have had trouble with Nexties. I have always been able to pry my tires off of the Nexties by hand. I usually have to work at it, and I'd hate to have to do that in the cold woods in January. My first thoughts watching the employee fight with those tires/rims were that I wouldn't want to have that much trouble with them when trying to fix a flat in the woods, which goes back to what mikesee said.
    Jan 2014
    10. “May I say that I have not thoroughly enjoyed serving with humans? I find their illogic and foolish emotions a constant irritant.” - Star Trek, season 3, episode 7 (“Day of the Dove,” 1968) Spock quotes.
    This is a shop fix. I certainly didn't think anyone would be carrying the paraphernalia on their bike. There are times when folks would like to do maintenance themselves, but their physicality limits what they can do. This is just another way to use mechanical advantage to solve a problem. When your changing over to winter/summer tires this would be appropriate. The trail is another matter. You need to choose your tires wisely, especially in the winter time. I had a heck of a time breaking the bead on the trail in the summer with a Floater, but did manage. I just installed a pair of Nates. I put those on by hand without levers, and have broken the bead by standing on them. This is partially determining what tires I will use in the winter. I want a tire I can slip a tube in on the trail without losing my fingers to frostbite.
    I would urge anyone that is going on a long primitive ride (especially in winter), to become well acquainted with slipping in/changing a tube for their particular tire, and whether or not it is feasible.
    Generalizations in certain situations can be way off base, so if you expect someone to be as good as you, you're probably in for a bit of a surprise. YMMV depending how much you weigh, how strong you are, your technique, the rims you run and (importantly) which tires you use.
    Different tires are just that--different tires. If all I rode was Nates year round, I wouldn't worry about it because they are running loose (for me). The Mission Commands are a different story. Can't do it. From what I've heard Snowshoes are not particularly easy to break the bead lock.
    My Nates are on for the winter.
    Oct 2012
    I spend couple hours yesterday trying to remove the Vee Snowshoe off these Mulefuts with no luck. Perhaps being 160lb is just not enough weight. I was so aggravated and mad I was about to take knife to them and cut them off. I never ever had so much trouble getting a tire off a rim. Yes, a nice seal is all good for tubeless but this is beyond ridicules. There is absolutely no way in hell one gets a tire off on the trail. There is no other way but to run these rims tubeless as you are not changing a tube on trail.
    Luckily another thread pointed me at this one and the c-clamp method finally did it. It took a few trails with varies air pressures. I tried putting two wood boards between the tire and the clamps but after one of the boards shot up in the air next to my head I decided its not a good idea. I really worried I will damage the tire but at this point I no longer cared. Even with clamps I had to use two screw drivers to pray the seal enough to fit a tire lever in. Then with 3 levers it took quite a bit of work to finally pray one side off the rim. My hands are scratched up and I can't feel my fingers.
    I plan on putting on Snowshoe XL with studs and hopefully these are stretched a bit (second season) and will not be so tight. I also tend to change my tires with Vee H-Billie depending on the trail conditions and if I have same trouble with these two tires then no way I can keep these rims. Only option would be to get a second set of rims (cassette, rotors) and maybe use them with the other set of tires. Well I guess I can move the cassette and rotors between the wheel sets as well...
    I was very excited to get a new fat bike with these rims but now I don't think it was such a good idea.
    Jul 2015
    Maybe there's money in LBS classes; How to change a FatTire with tight beads? Sounds like a porno.
    Jan 2014
    Quote Originally Posted by dariusf View Post
    The C-clamps I used were pretty large with large pads and spaced them about 6 inches apart. No damage to the casings. The tire pressure was crucial to making sure that only the area around the C-clamps was pulled away from the tubeless bead, and then the tire lever pretty much freed the rest of the rim. Soap and water helps.
    Glad you were able to get the tires off without destroying them. I saw your post and was hoping that you didn't have to cut the tires. Different tires have slightly different circumferences and different bead locks. Seems like the Surly tires are a little looser, easier to break the bead lock. Happy snowshoeing.
    Oct 2012
    lol that was good
    Oct 2012
    My clamps also have large plastic covered pads and looks like no damage to the tire. I was not able to get the tire lever in but had to use two screw drivers. Was worried I would damage the rim or tires but worked out ok. Once I pulled the bead out I was able to push in the tire lever and go from there. What a major pain. Thanks for your post and the details, really helped me to get this tire off. I did inject some soapy water with a syringe in to the edge there but not sure if it helped at all.
    Oct 2012
    I also have the Park Tool TL-1 levers and they are not that good for this. I might gt maybe something like this
    BikeMaster Three Piece Tire Iron Set | 246-266 | J&P Cycles
    and this looks interesting
    J&P Cycles® Tire Bead Breaker
    J&P Cycles® Tire Bead Breaker | 2170080 | J&P Cycles
    also just found this video
    https://www.youtube.com/watch?v=Qaom3dHtVNU
    Oct 2012
    here are the instructions for the Bead Barker
    http://img.jpcycles.com/staticwebfil...df/2170080.pdf
    It's really hard to believe that a tire could be so stuck to a rim that it would require such heroics. I've been working on cars, bikes, cycles for decades and your struggle is unique. Personally, I'd love to have a tire so stuck, it would allow super low tire pressure.
    Jan 2014
    Oct 2012
    Here is a tool that I think would work very well. Its for motorcycle tires and the long handles gives plenty of leverage and are much more convenient then the screw based ones. Although the screw based ones would be more "convenient" to take along on the trail
    Motocentric Bead Breaker Motorcycle Tire Accessories | eBay
    Laramie, Wyoming
    Reputation: alphazz's Avatar
    Oct 2012
    Quote Originally Posted by Nurse Ben View Post
    I'm with Ben on this one.
    Reputation: JDYMTB's Avatar
    ive had best luck laying the wheel on some 2x4 pieces of wood to protect cassette/hub/rotor and put another longer 2x4 on the bead and then step on it. the leverage pops it off like a champ each time. if you are in the woods and need to put a tube in.... goodluck?!?! its truly a beast to get off the rim!
    MisFitPsycles DiSSent, ALc - BLINGLESPEED
    Rocky Mountain Altitude
    Surly Ice Cream Truck
    Oct 2012
    I went ahead and ordered that Motocentric Bead Breaker tool. As for the trails, I think best is to go tubeless and not to worry about removing the tire in the field.
    Tubeless is great, but what if you tear a sidewall and need to put in a tube to get home? It's one thing to use tools, 2x4s, or trash cans (my favorite) to unseat the bead, but how do we do it trailside? While it's nice not to worry, it's important to know how to deal with the "what ifs".
    Jason
    Disclaimer: www.paramountsports.net
    Quote Originally Posted by JAGI410 View Post
    Once the tire has been on there for a little while, it's FAR easier to remove and reset. It's that initial set that was a PITA, before the tire was stretched. Putting my studded 5" tire on this winter was a breeze, compared to last year.
    I'm not sure if I can describe this well but I've had good luck with this method on my Mule Futs. I sit down and anchors my left palm on the outside of the rim. I then place my left elbow up against my left thigh. I then use my right palm and all my body weight against the right side of the tire. I push until I see the bead move then I rotate two or three inches and apply pressure again. On about the third or fourth rotation the head will pop as long as I notice some movement at each push. Oh and make sure you do your Lamaze breathing during each push!
    Oct 2012
    Quote Originally Posted by SHowley2003 View Post
    Also plenty of cursing helps
    Oct 2012
    The tool has finally arrived. Looks very solid and while I have not tested it yet, it looks like it will do the job and make the whole tire changing much simpler, hopefully
    Feb 2014
    Believe it.
    I've done a number of tubeless setups including one Mulefut. That was with a Van Helga and I had to do the boot-step on the bead to break the bead, but overall no problem.
    I offered to convert a friend's MF with 2016 Snowshoe to tubeless. Breaking the bead required boards, C-clamps, and cursing. Even with C-clamps, one bead would break but the other wouldn't and more wresting was required. Getting the tire off was another challenge.
    I'm sure that the bead will loosen with time, but as you've said, as they are when new, the tires ain't coming off, even when flat, without some heroics or tricks. If you have tricks from the motorcycle world for breaking the bead, I for one would like to learn rather than struggle.
    I'd say the tubeless setup has evolved and we have our wishes granted for a good tire bead / bead seat interface. But it may now mean just like moto and car tires, we'll need bead breaker tools (or other inventive measures)
    And lastly - on the Mulefuts - as others have noted: There are holes in the beadseat from the manufacturing process and a seam / joint that is not welded. If these aren't covered with tape or other means (I use latex caulk before tape) then an airtight seal is much more difficult if not impossible.
    Reputation: solarplex's Avatar
    Apr 2014
    If you can climb a hill you can take a tire off. You dont "step" like a little ***** foot, you stomp. 120 tpi tires need a bit of air in them my 60tpi hodags dont. I put the wheel on blocks and stomp stepping even over 200 lbs does nothing
    Fatbike, XC bike, Gravel Bike....
    Feb 2014
    Quote Originally Posted by solarplex View Post
    I'll try it!
    Quote Originally Posted by Oldens Lowe View Post
    I'll try it!
    Thanks all for this great advice. I just got a Sturgis bullet and wanted to mount my surly Nates from a previous bike. I could not believe how difficult it was to get the Vee snow shoes off the mule fut! i've worked on thousands of tires and done dozens of tubeless conversions but never seen anything like this. I was minutes from cutting the tire off when I did a quick search and found your thread.
    I tried stairs and boots, 2x4s and leverage. Nothing would break it. In the end I used a vice and 2 C-clamps to get enough space in the bead to insert an old metal tire lever. It was then patience and swearing to work the bead off. My Nates went on with no problem and fit great!
    I will never use these Vee tires and plan to give them away. What a nightmare!
    Oct 2012
    Quote Originally Posted by tbone627 View Post
    I don't think its specifically the Vee tires but the combination of new tires on these rims. I remember having very hard time getting some new Neo-Moto 650b tires on WTB i23 rims and then off again after a few rides. Once the tires stretched a bit it was far easier the fallowing times. I'm about to mount Vee H-Billie tires on the mule rims over the weekend. These tires are about a year old so will see how it goes. I did arm myself with a nice long (good leverage) metal tire lever and the motorcycle bead breaker tool pictured in my earlier post
    Still can't fool gravity
    Reputation: woulde's Avatar
    +1 for laying the wheel down and stepping on the tire close to the bead. You're going to fix your equipment with the tools you bring, best to know you can put a tube in a tire trail side when it is 10 degrees and blowing 20 than the try and figure it out when faced with those conditions.
    Feb 2012
    LOL this description reminds me of that old Milton Bradley game Twister where people are climbing/falling over each other.
    Haven't tried it outside but was playing around with what was already on the bike. Removed the post/seat, flipped it upside down and put the back of the saddle over the bead. Stood on it and pulled on the post for extra leverage.
    It worked.
    Sometimes Rickety, not a turd
    Jul 2014
    It sounds as though many have come close, but have any of you had a tire that could not be removed non-destructively?
    Nov 2015
    Attempting this at the moment and was able to break beads free stepping near the rim. However, I can barely get the tire irons under the bead sitting on the rim strip, and when I do they're threatening to break as I try to pry upwards. Are people using metal irons on these? I've always shied away for fear of bending a rim or tearing a tube, but maybe I'll have to track some down (like those mentioned earlier in the thread). Thanks for all the info.
    Reputation: Dilligaff's Avatar
    Nov 2015
    After reading this thread, I am glad I have a motorcycle bead breaker in the barn, along with manual tire changing tools.
    Nothing to see here, move along folks.
    Nov 2015
    Well I got the sucker, nearly broken lever...mine are just too old and a bit too bendy for this, apparently. I've put on some tough tires, usually on the road bike, but I've never had this much trouble getting one off.
    Metal levers
    Quote Originally Posted by dayooper View Post
    Yes, I happened to have a set of metal levers from the 80s kicking around. I used them to pry and not slide around the rim. Painstakingly slow to use three of them an inch apart around the wheel. I didn't want to scratch by sliding like we do witha plastic lever. The good news is they didnt break. I agree though, the tight bead is beyond ridiculous.
    Oct 2012
    Yes my old Park tool blue levers did not work too well for the task. Had to use screw drivers
    I just purchased these two. Like the longer handles for better leverage and grip. Did not try them out yet to see how they work.
    MileWideSports Solo Bicycle Tire Lever
    IceToolz DH Nylon-Coated Tire Lever
    Reputation: jddjirikian's Avatar
    Last night I was working with my LBS putting together a new Heller Bloodhound. Wheels case tubed. Front wheel, no problem. Rear wheel? Whole nother story. It was as if the fat bike deities made a tubular fat bike wheel. Couldn't get the rear tire off to save our lives.
    Today, my mechanic was told by QBP to ride the bike for a little bit and then bring it back in as riding it should loosen the tire up enough to remove it. Crazy.
    "Ride what you love, love what you ride"
    Oct 2012
    Today I took off Vee H-Billie off the wheels on my other fat bike, generic rims that came with Framed Minnesota 3.0 No issues and came off super easy. Then I mounted the Snowshoe tires that I could not get off the Mulefuts. These tires have been laying in garage for maybe a week after I managed to get them off so they did not have any chance to stretch. They went on very easy, no issues at all. So its not the Vee tires its the Mulefuts rims that are the issue. Tomorrow I will be mounting the H-Billie tires on the Mulefuts. Will see hot that goes
    Nov 2015
    I just setup one of my tires tubeless tonight but I honestly don't see what the fuss was about. I was able to break the tire beads by hand, with about 5 minutes each time, and it came off just fine. I did use 2 tire levers to start the tire off the rim but once 10" was over the lip it came right off. I needed nothing for the other side. I even used the plastic tire levers rather than the steel to avoid scratching the wheel. I just used the palms of my hand and worked one spot at a time towards my chest.
    I set it up using a SunRingle rim strip, which saved 90g over the stock rim strip, then the Zip Tape, which added back 30g. That stuff is the Bomb! I had to cut it to width since it's too wide. I then mounted my Nates until the snow flies when I'll switch to the studded Dillinger 5's. The Nates are 30g heavier than the Snowshoes.
    I ended up using a vise.
    That was really rough. I'm assuming some of these are tighter than others because no amount of stepping on it (used 3 different pair of shoes plus barefoot) was working. I tried the c-clamp method but I was getting a little nervous with the way it was stretching the sidewall, it may have worked but I chickened out. I was about ready to give up until spring because I didn't want to screw up the tire or rim just as fat season is beginning.
    I was contemplating getting the welder out and making my own bead breaker, but I ended up using a vice with a big plank of wood on one side of the wheel and a smaller piece of wood on the other side shaped to match the rim curve. This allowed me to get both sides off without any air pressure in the tire (did one side, then flipped around and did the other.
    Getting the tire off after the bead was broken wasn't as bad as I was expecting. It was tight, but not near as crazy tight as the bead connection was. I did have a Pedros Downhill tire lever that helped though.
    I did a tubeless conversion using the sunringle tape and rimstrip and stans valve. Since the bead was so tight, I decided to air it up without stan's sealant just to see if it holds pressure. I'll still plan on putting sealant in it.
    Attached Thumbnails Attached Thumbnails Breaking the seal on tubeless ready rims.-breaking-bead.jpg
    Warning: may contain sarcasm and/or crap made up in an attempt to feel important.
    Jan 2014
    2 C-clamps spread about 5 or 6" apart spread load. Several tires done with them, no problems with the tires.
    Vice looks like it would work also, but make sure there's no burrs or sharp edges, for those that use the vice the above the wood block would take care of that. Nice job.
    I forgot to mention that I rounded the edges/corners of the wood block to prevent any sharp edges pushing on the sidewall.
    Nov 2015
    I did the rear last night and it was a little tougher than the front but still not bad. I used the palms of my hands and walked around the rim a few times, looked to see where the bead started to move, then worked that area until it gave. It was still only 5-8 minutes.
    The front sealed without Stans but the rear didn't do so well. I did add Stans and then went for a ride to disperse it better. I dropped just shy of 2 pounds but the Nates are slightly heavier.
    Attached Thumbnails Attached Thumbnails Breaking the seal on tubeless ready rims.-image.jpg
    Jan 2014
    Quote Originally Posted by Dilligaff View Post
    I've found that all my tires have sealed, but the few that have had even small wrinkles along the beadset are the ones that required stans. I'm using the stretch wrap so your experience may be different.
    Jan 2015
    I'm in this trouble but with normal tubes, not tubeless. Rode about 300 km last winter with Showshoes, on Mulefuts, which is the factory setup in a Kona Wo fatty. This is the first time I've tried to remove the Snowshows and man is it difficult. I've even tried a vice but the rubber and fibers start to tear It's crazy. How can Kona sell this kind of shit solution?
    Tomorrow I'll buy a couple of C clamps, but I doubt even that will work. Maybe I have to cut the tyre off. Then maybe get some better rims?
    Reputation: Allamuchy Joe's Avatar
    I had a lot of trouble removing the Snowshoes from the rim, too. The trouble I had was not breaking the bead, it was removing the tire from the rim after the bead was broken. I was finally able to do it in the garage with a round tire lever I got for free years ago from the LBS. It was the only thing strong enough made of plastic. I am currently ordering some Park Tool Ti-6 coated steel levers to make it easier in the future.
    My main concern is if I get a flat in the woods. There is no way I can get these tires off the bike under less than ideal conditions. So, besides bringing along those new levers in my tool bag, I also bought these tubeless repair kits from Amazon. At least it might give me a chance to patch any larger holes in the tires so I can get out of the woods, with help from the Stans.
    2014 Giant Trance 27.5 1
    2015 Boris FS X9 Bluto Fatbike
    2016 Cannondale Bad Habit 2
    Dec 2011
    I'm new to fatbiking, but not tubeless. I just got a wednesday that came with 27tpi wirebead nates on the new surly tubeless ready rims. From what I've read, those nates need some time to stretch with tubes before they can be set up tubeless. Any idea how many rides or time that the tubes should be in there before they are ready?
    Quote Originally Posted by captnpenguin View Post
    I think this has more to do with the design of fat bike rims, specifically the Mulefut. Unlike regular mountain bike rims, the Mulefut has no "valley" to give the bead relief so you can get it up and over the rim. Therefore, the bead is always tight. Here are the cross sections of a Mulefut vs. a regular mountain bike rim:
Size:  16.4 KBName:  Pacenti-TL28-tubeless-mountain-bike-rim-cross-section.jpg
    Oct 2012
    If you want a rim with a good seal, you need to get hard core tools
    Attached Thumbnails Attached Thumbnails Breaking the seal on tubeless ready rims.-20151130_155927_resized.jpg
    Jan 2014
    Quote Originally Posted by haarald View Post
    Had same kind of problems, but the C-clamps worked fine. Just make sure you spread them at least 5" and maybe a little more apart. Work both clamps in small increments at the same time to prevent too much pressure on any one spot, and place them as close to the rim as possible.
    Jan 2014
    My main concern is if I get a flat in the woods. There is no way I can get these tires off the bike under less than ideal conditions. So, besides bringing along those new levers in my tool bag, I also bought these tubeless repair kits from Amazon. At least it might give me a chance to patch any larger holes in the tires so I can get out of the woods, with help from the Stans.[/QUOTE]
    After having mounted 5 different tires on Mulefuts, I can pretty much say that the degree of difficulty is tire dependent. Nates, Floaters, Larrys were pretty easy, and Mission, Mission Commands were a bugger. I've pretty much decided to stick to Nates or Floaters from here on out. Also, I've used the Stretch Wrap to go tubeless and that may help a bit, but the new tight tires were worse than bad.
    Aug 2003
    Buy a new rack and bag too -- so that you can carry the c-clamps on the trail.
    Either that or have someone teach you the basic principles of tire removal. It is not as difficult as you're making it out to be.
    Jan 2014
    There are several people on this thread and in this forum that have had a miserable time removing certain tires from Mulefuts. Snowshoes are becoming a problem on the Mulefuts for many people. Tire selection becomes pretty crucial with this rim. Basic principals of tire removal don't necessarily apply to certain tires with this rim. If you're lucky enough not to have gone through the gyrations needed to remove the problem tires, consider yourself lucky.
    Aug 2003
    I understand completely the importance of tire selection with various rim designs. Arguably, I understand the concept and the nuances better than most, since my job depends on it.
    That said, there is nothing inherently difficult about the MuleFut/Snowshoe combo. They are both within design spec parameters, although the fact that they each hit the outer range of those parameters is what is catching people up. This is where proper technique comes in -- there is simply no substitute especially out on the trail.
  67. #67
    Nov 2015
    Well...what's everyone missing?
    There seems to be varied difficulty, even among the Mulefut/snowshoe combo. I removed four brand new snowshoes from mulefuts, and 2 were difficult to "pop", one was moderate, and one was extremely difficult. It's not rocket science, and all were much more difficult than any tire I've removed in the past 30 years. Normally it doesn't require stomping on, in my experience...though I don't do it for a living. So perhaps you could enlighten the board to the nuances?
  68. #68
    Aug 2003
    Can't begin to diagnose where people are going wrong from afar/online.
    Can only say that I do not possess special techniques or powers -- nor do any of the other wrenches out there that can install and remove Snowshoes from MuleFut's without c-clamps, or any other tool.
    If you need assistance with technique, stop by your favorite LBS where each mechanic installs/removes dozens to hundreds of tires per week, year round. They'll be able to spot whatever it is that you're missing.
    Cheers,
    MC
  69. #69
    Nov 2015
    Cheers,
    MC
    Fair enough, I guess. I just don't know what could be missed...push down as hard as you can to try to get the sucker to break! Also, I believe some have done just as you suggest, and even their LBS guys had much difficulty (may have been a different thread). That said, I don't doubt that removing tires every week one gains some helpful technique. I personally didn't use clamps as I didn't want to chance damage, and eventually got them off with my feet...but they were crazy tight, within spec or not.
  70. #70
    Jan 2014
    In fat tires there seems to be quite a variable difference in some weights. 50 to 60 grams worth, and as much as 100 grams in some of the Vee tires. That extra weight equates to additional rubber somewhere in the tires, which in turns means the different runs may fit differently which could account why some people are having more trouble than others. No need to chastise others when you're not riding in their snowshoes.
  71. #71
    Aug 2003
    If this is directed at me, and if my comments were taken as chastising, then I apologize. My intent was to help, both in the short and long run, by making people think more critically about their technique, and less about going to get a bigger hammer.
  72. #72
    Jan 2014
    I'm just trying to solve problems without ruffling feathers. I haven't had a new bike since 1996, so buying a Fat Bike was the same as being a newbie, but I have the time to do a lot of research which others don't because of work/family obligations. When new members come on asking questions, I just try to answer in the most benign way because words in jest or those that may be taken as critical can really affect people in the most unintended ways (I learned this the hard way, being a bit of an unintended jerk was I). I like this forum. It is given me much knowledge and it's much appreciated.
  73. #73
    Aug 2003
    You are doing (and have done) an admirable job of it.
  74. #74
    Jan 2014
    Thank you sir, it means a lot.
  75. #75
    Feb 2014
    Thanks very much for taking that position. As I said in an earlier post, I'd rather learn than struggle. I have a lot of bikes and take tires on and off many more times than I'd prefer. I do at times get lazy and use levers etc. when I probably don't need to. But again, the Snowshoe Mulefut combo I dealt with was really tough.
    So with that - if you have any tips for techniques in dealing with these difficult fat tires, I for one am all ears.
    And BTW - ya, the lack of a center well on the Mulefuts can make some parts of changing tires tougher. I just did tubeless on a set of BR 710s that have deep center wells. It's not unexpected how the difference in rim profile makes some parts of the job a breeze while other parts more challenging.
  76. #76
    Reputation: Ofroad'bent's Avatar
    I have a Ranger 2.8 on a 40mm carbon rim that's stuck on there but good.
    I'm thinking of trying this vice I have lying around. It looks like it would give more even pressure than C clamps.
  77. #77
    Jan 2014
    Quote Originally Posted by Ofroad'bent View Post
    Looks like an excellent idea. Once broken they're usually much easier to work with. If it doesn't quite make it on it's own, a little soapy water and tire lever should help. Leave some air in it to help.
  78. #78
    Got the tire off but it was quite a fight. I ended up clamping it in a wooden Workmate vice and heaving back and forth after using warm soapy water. Whew. Thanks for the help, guys.
  79. #79
    Reputation: Jeff_G's Avatar
    Oct 2015
    I haven't followed this thread so this may have been mentioned. The Barbi/Mulefut combination is a bear.
    Letting almost all the air out and putting the valve core back in so there is some pressure (1 psi?) holds the structure of the tire makes the bead break easier.
    "At least I'm enjoying the ride"
    16' Trek 8.4 DS
    16' Farley 7
    and I'm OK admitting..
    16' Sturgis
    Minneapolis MN
  80. #80
    Flying Sasquatch
    Reputation: KTMNealio's Avatar
    Jun 2016
    Mulefut + almost any tire I've used is a PITA to get off. Luckily I weigh 265 so I deflate the tube as far as I can and then just heel stomp the bead to pop it off.
  81. #81
    Jan 2014
    Workmate! Another good idea. Hope this helps anyone else who's having a problem.
  82. #82
    Reputation: Misterg's Avatar
    Jul 2014
    Quote Originally Posted by KTMNealio View Post
    I weigh 150, and that works for me, too.
    Gotta get all the air our, and wear a decent pair of boots, though
  83. #83
    Aug 2014
    Next time you have to change that problem tire, warm it up. Use a hair dryer. No need to get it really hot, just nice & warm to the touch.
  84. #84
    Reputation: foresterLV's Avatar
    Dec 2016
    In my experience removing tubeless tire is no harder than removing motocross/enduro tires, actually easier (less force to apply)... Viewing few motorcycle tire removal videos should definitely help IMO.
    I am using my motorcycle levers to remove tire quickly, rim protection plate for two-lever first pull. Second side typically goes off without levers.
    Sent from my SM-G900F using Tapatalk
  85. #85
    Jul 2014
    Quote Originally Posted by foresterLV View Post
    You carry all that stuff with you when you ride?
  86. #86
    Dec 2016
    Quote Originally Posted by andytiedye View Post
    For tubeless I am OK with hand pump and sealant inside, it should be major/uncommon damage to tire to not able to pump it back.
    But my point is with levers its kind of easy. Need to brake bead first though, first step is still there.
  1. Replies: 11
    Last Post: 09-01-2015, 09:50 AM
  2. Giant Rims are they Tubeless ready?
    By DaveOb in forum Wheels and Tires
    Last Post: 07-14-2014, 04:45 PM
  3. Non UST Tires (but Tubeless Ready) with UST Rims.......???
    By greenerob in forum Wheels and Tires
    Last Post: 11-29-2012, 12:16 PM
  4. Tubeless ready rims?
    By Tim2103 in forum Wheels and Tires
    Last Post: 07-08-2012, 06:43 PM
  5. Tubeless Ready tires on UST Rims
    By TwoPumpChump in forum 29er Bikes
    Last Post: 01-17-2011, 12:13 AM
Members who have read this thread: 17
