Results 1 to 11 of 11
    Reputation: blown240's Avatar
    Brake Studs on the Chain Stays?
    Other than the obvious issues with chain line and chain slap, are there any reasons why V-brakes on a chain stay wouldn't work. Seems like it would be exactly the same except for chain issues.
    Jan 2011
    My guess is that you could make it work on a single speed. Or 1x system.....but why?
    Moderator Moderator
    Reputation: Walt's Avatar
    A) Why do you want rim brakes?
    B) Why do you want to mount them on the chainstays?
    Plenty of late 80s/early 90s mountain bikes used chainstay mounted u-brakes. BMX bikes still do on occasion. There's really not much reason to do it in the era of linear pull and disc brakes, imo.
    -Walt
    My buddies and I have a challenge - to buy/build a fat-bike that is trail worthy and the goal is to keep as cheap as possible. Parts I have do not count towards the cost.
    We both started with a Mongoose beast. Its a mess in its stock form. So, to keep costs down, I am doing the rear brakes as V or canti. I have a junky donor frame with brake studs and I already have V and canti brakes. Thats why I want to do post mount brakes. Front brakes will be a BB7 with a 203mm rotor, all stuff I have already.
    The reason for talking about putting them on the chain stay is because I MAY convert it to FS. I have almost all the parts, to do it. The dropout will be solid with the chain stays, and there will be a pivot between the seat stay and the dropout.
    There really isn't too much mud around here. Sand yes, mud no. My main backup bike has a front disc and rear V and it works pretty good...
    Moderator Moderator
    V-brakes will not work with fat (ie ~3-4") tires. Period. You're going to get tire/cable noodle or tire/arm interference no matter what you do, pretty much.
    -Walt
    Walt - Thank you very much for the constructive comments! Have you seen or used the "long arm" V-brakes? They are supposedly for bikes with fenders. I was thinking of trying them, even though they may not work.
    Tires are 26x4.0
    Heres a link to the brakes I saw. Only $12
    V-Brake Extra Long BLK Front - Cycles U.S. LLC/Choppers U.S.
    I was thinking I could mount the studs where the brake pads are as close as possible to the stud, this should give me more tire clearance...
    Reputation: Eric Malcolm's Avatar
    Dec 2011
    Are the side walls of the rim capable, that is have a machined face for brake pads, for this application?
    They appear to me to be Disc suitable only. I have only limited info on Fat wheel rims though.
    Eric
    If I don't make an attempt, how will I know if it will work?
    Several people are using rim brakes without issue on these bikes. So ya, it should be fine...
    I doubt that even the longer V-brakes will work with fat tires, the tire/noodle interference is severe. Some cantilivers can be setup to work fine with fat tires however.
    The wal-mart fat rims should work fine for rim-braking.
    Chainstay mounted brakes accumulate more snow/mud/sand/spray than seatstay brakes.
    If you are even mildly contemplating a modification to add rear suspension, just start with a decent frame (even a non-fat frame). Really no reason to start such a project with such a junky frame.
  1. Need 90's Cannondale Brake studs
    By asoduk in forum Cannondale
    Last Post: 05-06-2016, 09:19 AM
  2. Removing Monocog brake studs?
    By AmericanTemplar in forum Brake Time
    Last Post: 06-20-2013, 08:26 AM
  3. Frame brake studs thread specs ?
    By David C in forum Brake Time
    Last Post: 04-17-2013, 02:24 PM
  4. Taping Chain Stays
    By missingno in forum Beginner's Corner
    Last Post: 02-02-2012, 10:28 PM
  5. 29er suspension forks with v-brake studs?
    By febikes in forum Shocks and Suspension
    Last Post: 01-03-2012, 10:45 PM
