brake pad contamination
Printable View
  • 11-04-2012
    nvphatty
    This more or less is a general Q regarding pad contamination from fluid and my interest peaked mainly due to, well doing exactly that when bleeding them. I have read about it, heard people mention it and for the most part am aware however i did not heed the warning about pad removal before(dum chit) doing so hence pads were wet with fluid. I decided to clean them with isopropryl alcohol and give them a go...low and behold when they heated up the braking efficiency was pretty piss poor and upon further inspection something streaked on the disc face (i presume fluid oozing from the pad)
    Aside from pad replacement is there another method to save the contaminated pads? i.e. cleaner of some sort, heat of some form or fashion ??
  • 11-04-2012
    donny70
    I put a sheet of sand paper on my work top and ran the pads back and forth until I took off the top layer. Then I just ran them in again. They work just as good as before...
  • 11-04-2012
    dRjOn
    ive cooked xtr pads contaminated with mineral oil. backing plate down, on an old msr stove outside !...pads as good as new. cook until they stop smoking...
  • 11-04-2012
    bdundee
    I do the same on the outside stove. The last set I forgot about and they cooked for over 8hrs:nono:.
  • 11-04-2012
    Tone's
    like the posters have said above you can cook them in the oven untill they stop smoking, you can sand them with heavy grit wet n dry sandpaper which i find works ok, but you pads will imo never be the same again with any method, if they are really badly contaminated id buy a new set..
  • 11-04-2012
    Shark
    I cooked some pads, brought back stopping power, but pad life was shortened quite a bit .
  • 11-04-2012
    nvphatty
    Gents thank you all for the feedback and just for giggles i'll give the emery cloth / bake a try on the propane BBQ and keep them as spares but will replace with a new pr.
    In thinking about it if the pads can absorb fluids then yes perhaps 'bake a pad' would be a solution which some have confirmed :thumbsup:
    I cooked some pads.
    shark was this the main coarse and pray tell what was the side dish?;)
  • 11-04-2012
    Shark
    Lol there was beer involved, and maybe ice cream afterward ;)
  • 11-04-2012
    nvphatty
    not sure about the beer but fugg yea ice cream.........must ride 2hrs longer:)
    Well i did the deed and will make use of the pads until new ones arrive.
  • 11-04-2012
    Tone's
    Get some new pads and experiment with the contaminated ones, if they are organic they cam absorb the oil n fluid easier than some think so even baking n sanding will not do the job in some situations, if they are sintered you might stand a better chance, so give em the oven treatment n see how they go, then give them a sand and see how they go...
  • 11-04-2012
    donny70
    Mmmm yes thats true. Mine are sintered... ;)
  • 11-05-2012
    nvphatty
    yup thats what i was referring to in my last post, i sanded them then baked @ 550 and installed them...oh and yes they are sintered. New ones have been ordered.
  • 11-05-2012
    dRjOn
    i must admit, i was surprised mine worked so well...they were the finned resin xtr pads and i didnt expect them to come good. i wasnt too annoyed because generally i run the metal shimano pads which are a lot better for my conditions. however, at the time, there was a bit of a shortage in stock so i decided to give it a bash. hth....
