Results 1 to 5 of 5
Thread: Bottom bracket
    Dec 2011
    Bottom bracket
    Question on Sram/Truvativ BB, I have an offset frame and a Howitzer triple crankset. I have to replace the BB bearings. Will the replacement cups for GXP 68/73 bottom brackets work with the 100mm spindle for my cranks?
    Thingamejigger
    Reputation: Flying_Scotsman's Avatar
    Correct GXP will work, copied from another thread on the UK Fatbike forum, these are what you want - 37mmx22mm:
    OUTBOARD BB UPGRADE KIT FOR GXP - 23.99 : mbbearings.co.uk, Frame Hub Bearings
    Oct 2012
    Quote Originally Posted by Flying_Scotsman View Post
    That looks like just a bearing replacement kit for GXP.
    I am pretty sure the Howitzer uses wider bearings than GXP. If the spindle size is the same, you might be able to use the whole cups from a GXP though, which would save some weight.
    Dec 2011
    Should I be looking for a the Howitzer BB that is described as "100 + E 66mm chain line?" I assume the "E" is for the e type derailleur? Are the puglseys a 66mm chain line?
    Oct 2012
    Yes, that is the one you need if you have Holzfeller or Husselfelt cranks made 2006 and up. the chainline on a 135mm offset by 17.5mm(pugsly) or a 170mm centered bike is ideally about 66mm.
    before that, I think they were ISIS splined, so you would need an ISIS BB from any manufacturer. I think these cranks say ISIS on them. I don't theink the Howitzer ones say anything, but the Bottom bracket cups have it written on them.
  1. Bottom Bracket
    By Markleo in forum Beginner's Corner
    Last Post: 08-04-2012, 06:12 AM
  2. Bottom Bracket
    By TurnerRick in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-20-2012, 04:42 PM
  3. Jet 9 bottom bracket
    By ThinBlueLine in forum Niner Bikes
    Last Post: 04-19-2012, 10:40 AM
  4. Which bottom bracket do I need?
    By smartytime in forum 29er Bikes
    Last Post: 01-15-2012, 08:14 AM
  5. Do I need a new Bottom Bracket
    By Lope in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-25-2011, 04:44 PM
