Page 5 of 5 FirstFirst 12345
Results 201 to 232 of 232
  1. #201
    Anchorage, AK
    Reputation: Lars_D's Avatar
    Borealis Picture and Specs Thread
    If anyone has a Yampa with a quick release frame, I thought I'd let you know that a number 58 derailleur hanger fits it.
    --Peace
  2. #202
    Reputation: TahoeBC's Avatar
    ^^ good to know as I already bent 4 this winter
    Anyone else with a Yampa quick release have issues with the rear end getting loose sometimes, always crank mine down pretty hard, but sometimes it just seems to work it's way loose. Wish I had the though axle model....
  3. #203
    beer thief
    Reputation: radair's Avatar
    Dec 2002
    Quote Originally Posted by TahoeBC View Post
    I have not had this problem, but the hangers are certainly soft. Very easy to bend them.
    Lars, I assume this is the one you are referring to? Wheels Manufacturing Derailleur Hanger 58
  4. #204
    Anchorage, AK
    Quote Originally Posted by radair View Post
    Yes, that is the one. By the way, I have had no issues with the quick release getting loose, even in very rough riding.
    --Peace
  5. #205
    Reputation: jackdz's Avatar
    Aug 2010
    I have had the same issue. The last time was during the latest gravel road race here in NE Ohio. 3 of us approached the last climb together (really difficult) and I went off the front and got a gap. The climb kicks in a turn and I stood up to really go and the rear wheel popped out of the drop outs. Needless to say, I had to stop to put it back in.
  6. #206
    Feb 2006
    I never experienced it, but my riding partner did. Entire wheel would pop out of the frame under hard acceleration. I think it only happened twice??? But he sold it, and got an Echo, and the QR rear end was the main reason. Fat bikes with 190, or even 170 rear spacing, need TA. Not saying a QR is going to implode at the end of your driveway, but it's an inferior design and for the life of me I don't get why anyone would buy that now, with all the options out there.
  7. #207
    PRETENDURO
    I had the skewer on my 9:zero:7 slip under extreme load recently, tire submarined into the left-side chainstay. I was going up a hill roughly 30% in grade, I was out of the saddle on my 32x18 singlespeed. I then tightened the skewer extra tight, so tight that it hurts my hand to disengage. Hasn’t happened again, but I am now leery to stand and mash up such steep climbs anymore on the bike. I think my next singlespeed fatbike will have to be something with a thru-axle, perhaps a Yampa or another Echo (I already own one Echo with gears, would one more be so bad? Nah!). Haven’t had this happen on my Echo with the thru-axle, have mashed up some steep stuff out of the saddle, but not in such a big gear (I think biggest I was in was 30x20 up the steep stuff).
    QUOTE from MTBR.COM: You have given Brewtality too much Reputation in the last 24 hours, try again later.
  8. #208
    Yep hard acceleration and just a couple weeks ago climbing hard out of the saddle with all my might it popped right out. Sounds like the new Yampa has a swappable rear dropout so you can run quick release or a though axle.
  9. #209
    Nov 2008
    For giggles and grins I raced my Yampa in a cross race. I hopped the little barriers and on the third my wheel popped out.
    I wonder if anyone makes a 190 bolt on skewer?
  10. #210
    Anchorage, AK
    Current build
    In another thread someone asked me about my set-up so, I thought I'd post my current build:
    Front Rim--85mm HED Carbon Rims
    Front Spoke set--DT Swiss Aerolite (272 Brake Side; 274 Drive side)
    Front Hub --SP hub dynamo (dynohub) PD-8x 32h
    Front Skewer--Carbon-Ti X-Lock QR15
    203mm Rotor--Rav X SL
    Front Innertube--Schwalbe SV13F Extra Lights, 26x2.10-3.00
    100mm Rear Rim--Sarma 100mm
    Rear Spoke set--DT Aerolite 256
    Rear Hub--Borealis 190mm QR
    Rear Skewer--Old Man Mountain
    160 mm rear disk--Origin8 Torq-Lite
    Cassette--XX-1 10-42
    Rear Innertube--Q-lite 2.7
    Frame--Borealis Yampa
    Front fork--Custom Carver Titanium Snow Fork 485mm thru axle
    Bottom Bracket--Phil Wood (100mm/155spindle w 5mm offset)
    Crank--Middleburn crank
    Front Chainwheel--Absolute black28T oval 64bcd chainring
    Pedals--Ritchey Pro Mountain V5
    Rear Derailleur--xx1
    Rear brake caliper--Avid BB7
    Front brake caliper--Avid BB7
    Front break IS Adapter--203
    Front light--Busch + Müller
    Rear light--Busch + Müller Toplight Line Plus
    Bar grips--Crank Brothers Handlebar Grips
    Brake Levers--AEST levers
    Shifters Rear--grip shifters XX1
    Chain--KMC x11
    Seat --Brooks Cambium c17s
    Seat post--Thompson Seatpost
    Kickstand--Upstand
    Rear Rack--Blackburn Blackburn XR-1
    Pannier--Arkle Dry-Lite
    Aero Bar--Profile Design T1 Aerobar and 1 AEST Brake Lever
    --Peace
  11. #211
    Here is the current spec:
    -Large Echo Frame
    -Bluto Fork 100mm travel
    -Cane Creek 11 headset
    -Thomson -10 degree 80mm X4stem
    -Thomson XC 730mm flat carbon bar with ESI Chunky grips
    -Thomson Masterpiece seatpost
    -Cobb Cycling SHC Saddle
    -Race Face Next SL Crnak 32tooth ring 175 arms and Race Face BB
    -Avid XX1 Brakes 180 rotor front /160 rotor rear
    -XX1 trigger shifter, rear derailleur, and 11-42 cassette
    -Nextie-Bike Wild Dragon 90mm rims laced to Industry Nine Classic Fat Hubs
    -Knard 26x4.8 120 tpi tires tubeless
    -Time ATAC carbon pedals.
    -Arundel Sport Cages
    27.06 pounds as she sits.
  12. #212
    Feb 2006
    That 27.06 can't be with pedals, cages, and sealant can it?
  13. #213
    Yup. All of the above and the mount for my Garmin.
  14. #214
    Must build all the wheels
    Reputation: chriskmurray's Avatar
    Dec 2013
    Sorry to those who have had wheel slip issues. We have started shipping out Paul QR's to those who have had issues and it seems to be working well for us. Just shoot an email to Leah@Fatbike.com and she should be able to get you sorted out.
  15. #215
    aka bOb
    Reputation: bdundee's Avatar
    Quote Originally Posted by tri-tele View Post
    -Large Echo Frame
Name:	compressed echo fat.JPG
    That thing is bad @ss!!
  16. #216
    Feb 2006
    Awesome, I may have to be looking for some new rubber!! I have nearly the same build, but with Hed's, and I am at 27.6lbs. However, I am running Bud's and mine weight approx. 1800 grams each, which would esplain the diff. I have always loved running 2 Bud's, but now with all the choices we have, I may have to start at least considering a different tire.
  17. #217
    Feb 2006
    TRI, what do you think of the Knards????
  18. #218
    beer thief
    Dec 2002
    Quote Originally Posted by chriskmurray View Post
    How about front hub issues? Take the wheel off and the internal tube falls out of alignment, making it a royal pain to reinstall the front wheel. I emailed you guys months ago but got no response. Any suggestions? Right now I have a small stick in the frame bag to realign the funky tube so I can put the thru-axle back in.
  19. #219
    I've been pretty happy with the knards. Got a little self steer at 7 psi but am still playing with the pressure. They roll really nice though and all the soft rubber is nice and sticky.
  20. #220
    I was sent one of these awhile back and am happy to report I've had no slippage issues since installing, Thanks!
  21. #221
    I have the same issue, Borialis told me my shop could press the bearings back into it, been to lazy to drop it off for them to do, but they said they could probably do it and it's not an all to uncommon problem for many hubs, personally I've never had this issue but I've run King hubs for the last 15 years and my Hope hubes for my 29+ wheelset for this bike have been bomber so far also.
  22. #222
    Dec 2013
    Like mentioned above the trick is to re-seat the bearings to press a little tighter in the axle in the hub shell. You can also pop both bearings out, clean the outside of the bearing the best you can along with cleaning the axle and place a THIN layer of green (pressfit) loctite on the ends of the axle where it rests against the inner race on the bearing and press everything back together.
    The newer style (Turnagain) hubs no longer use floating end caps so this is no longer an issue.
  23. #223
    Dec 2013
    Good to hear!
  24. #224
    Reputation: in the trees's Avatar
    Mar 2005
    Loving this thing!
  25. #225
    Reputation: TankD's Avatar
    Jan 2014
    Some minor changes in the setup.
  26. #226
    Jan 2015
    Way cool!
  27. #227
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by TankD View Post
    That's hot.
  28. #228
    beer thief
    Dec 2002
    What about popping a bearing out and removing the tube completely. It can't be structural since it just floats in there. Or is it needed as an internal spacer for the bearings?
    TankD, that is smokin hot
  29. #229
    Laramie, Wyoming
    Reputation: alphazz's Avatar
    Oct 2012
    My wife would like TankD's bike although it might look nicer with pink bars instead of pink grips.
    As for all of the quick release issues, it's too bad that cheap has trumped quality. I had issues with my Yampa and switched the frame for an Echo. The through axle is more compatible with cheap. And though the frame switch didn't cost much, Borealis more than made up for it with the price of the new fork that didn't come with the frame.
  30. #230
    Jan 2014
    Where are all the gorgeous rides hiding? Let's not kill the thread.
  31. #231
    aka bOb
    I know a couple of mine are hiding out in the plastic recycling pile somewhere
  32. #232
    Quote Originally Posted by alshead View Post
    Anyone have weights on the Turnagain FR80 rims laced to the Borealis hubs/ original/ stock wheelset? I skimmed through here and didn't see anything
    I realize i'm dredging up an old thread and I'm sure alshead could care less at this point but I was searching for this info myself and could never find it so at least if someone is searching in the future they'll know!
    Turnagain FR80 tubeless ready wheels weighed bare, no rim strips, rotors, TA's etc
    Front wheel with 150 TA hub - 1296g
    Rear wheel with 197 TA hub and XD Driver - 1411g
  1. CDT picture Thread: Foo & Fam
    By Mtn. Biker123 in forum New Mexico
    Last Post: 10-31-2012, 02:30 PM
  2. Procaliber picture thread
    By indianadave in forum Gary Fisher
    Last Post: 09-09-2012, 10:12 PM
  3. Then and now picture thread.
    By jeff in forum Vintage, Retro, Classic
    Last Post: 10-02-2011, 01:30 AM
  4. thread lock? torque specs
    By brightsky in forum Niner Bikes
    Last Post: 03-20-2011, 08:53 AM
Members who have read this thread: 15
