Page 4 of 5 FirstFirst 12345 LastLast
Results 151 to 200 of 232
  1. #151
    Yeah 24.5 as pictured. Weighed on a park tool scale. I love everything but the XX brakes. Sounds like I ran over a turkey.
    It was 22.5 before the pedals, Garmin mount and bottle cage.
    15 Yeti ASR-c
    14 Yeti ARC
    16 Bianchi Specialissima
    15 Echo Big Deal
    15 Roubaix S-Works
  2. #152
    Reputation: thecanoe's Avatar
    Borealis Picture and Specs Thread
    In the brake forum you'll find a mile lot thread about the Avid Turkey warble and peoples solutions. Mine was organic pads.
    Santa Cruz Tallboy
    Moonlander
  3. #153
    Quote Originally Posted by irishpitbull View Post
    Finally got mine on Friday night.
    Took it out for 35 mile quckie. Pretty awesome.
    Attachment 939320
    Attachment 939321
    What rims are those?
    Santa Cruz Tallboy
    Moonlander
  4. #154
    Feb 2006
    I just ordered one with the new Guides, and I have already tried them on a different bike and they were a huge step up from normal XX brakes. Very Shimanoesque.
    I got mine with 2 Bud's though, so I'm gonna pay a small penalty on those.
  5. #155
    Reputation: mnyquist's Avatar
    Great looking bike, Irishpitbull! were you at Maybury today (Sunday?) I saw a Borealis rolling through the parking lot when I was loading up after my ride.
  6. #156
    Quote Originally Posted by mnyquist View Post
    Yeah that was me. Finished up 3 laps. 1st 2 were good the 3rd was muddy.
    The wheels are HED Big Deal. Unbelievably light.
    15 Yeti ASR-c
    14 Yeti ARC
    15 Echo Big Deal
    15 Roubaix S-Works
  7. #157
    Feb 2006
    Giving thanks for a new fat bike on this fine Thanksgiving day.
    Mine is the Echo. 28lbs with pedals, cages, and 4oz sealant in each Bud.
    Borealis Picture and Specs Thread-20141126_200251.jpgBorealis Picture and Specs Thread-20141126_200545.jpgAttachment 942198
  8. #158
    Beautiful bike, safe to say that's about as light as you're going to see with a Bluto and HED wheelset running the big tires.
    What does the Yampa weigh w Nexties?
  9. #159
    Quote Originally Posted by TankD View Post
    Issues? Do two broken frames count as an issue?
    I'd be curious to know how you managed to break two frames? Where were the breaks? How much do you weigh?
  10. #160
    Feb 2006
    Quote Originally Posted by RickyB View Post
    I did have the steel axle installed in the rear hub, versus the aluminum one, and had wheels built with brass nipps, so it would have been in the 27.??? range but was happy to give that weight up in exahcange for the extra durability.
    The Yampa with the Nexties weighs 26.2lbs with cages, pedals, sealant, and two small lights mounted on it.....and some dirt.
  11. #161
    Reputation: ForNow's Avatar
    Nov 2014
    On my Yampa the front through axle is a real fight to get in and out with the stock hub and wheel set.
    Anybody else have to struggle with the through axle?
    I pull the front wheel off when I take my bike to the trails.
    It is the only way to get the bike in my VW Jetta GLI.
    Advice Please.
    Todd
    ______________________________
    Farley 9.8.5
  12. #162
    If it's like mine was it probably is the tube that separates the bearings in the hub, when you pull out the axle the tube falls down, this makes it difficult to insert the axle due to hitting the tube, next time you remove the axle look thru the hub and you will see... Essentially the bearings are pressed in the hub and then hold the tube in place. What I did was had the bike shop align the tube correctly and then re-press the bearings into place, it has held pretty good but my guess it's going to fail again.. Very poor design in my opinion..
  13. #163
    Nov 2014
    Quote Originally Posted by co_biker View Post
    Thanks for the reply. My first bike with a through axle.
    Farley 9.8.5
  14. #164
    Reputation: TahoeBC's Avatar
    I have the same problem with my front hub, Borealis told me it happens some times and to take it by my shop and have what co_biker describes done. Yes not a great design, my Hope hubs have been flawless.
  15. #165
    Jun 2014
    I found the through axle hard to get in and out as you describe, but I found there was a little o ring on the inside that was the problem. Took it out and is fine now. Still havnt worked out what it was for. Thought maybe to keep water out? But I havnt had any issues. You can put lube on the axle so it slides through the o ring but it's a pain.
  16. #166
    beer thief
    Reputation: radair's Avatar
    Dec 2002
    Quote Originally Posted by Aidsfromoz View Post
    That O-ring might be from the end caps on the hub. I have the same issue with my front hub, those little tubes are a PITA. I'm not sure I understand the pressed in bearing fix but will take a closer look next time my wheel is off.
  17. #167
    Dec 2013
    Borealis Picture and Specs Thread-image.jpg Borealis Picture and Specs Thread-image.jpgBorealis Picture and Specs Thread-image.jpgBorealis Picture and Specs Thread-image.jpgBorealis Picture and Specs Thread-image.jpg
    amazing bike
  18. #168
    Sv: Borealis Picture and Specs Thread
    So finaly I've built up my Echo. Very pleased with this bike. I'm missing a few sticker-details, but are having it made. Not the best presentation pic, but for shure in its right environment.
    Spec:
    - Medium Echo frame
    - Bluto RCT3 built to 120mm
    - Borealis hubs with nextie Wilddragon rims and db(2-1.7-2) spokes
    - Snowshoe XL or Bud/Lou
    - X0 trail WC brakes
    - 180mm ubercompoents discs
    - X01 gears
    - Reverb Stealth with Fabric scoop saddle
    - Turbine stem and next bars with Lizard skins grips
    - next sl cranks
    - Hope purple goodies
    All with XT pedals and tubeless weigh in at 13.1 kg (28.8lbs).
  19. #169
    Nov 2014
    Great week of diverse riding
    Riding Spec X01. Have BD/I 9 wheel set on order
    Attached Thumbnails Attached Thumbnails Borealis Picture and Specs Thread-20141205_122305.jpg
  20. #170
    74 & 29 pilot
    Reputation: MTB Pilot's Avatar
    Oct 2010
    Quote Originally Posted by tri-tele View Post
    Pic is with my old stem and bars but here is the current spec:
    -Large Echo Frame
    -Bluto Fork 100mm travel
    -Cane Creek 11 headset
    -Thomson -10 degree 80mm X4stem
    -Thomson XC 730mm flat carbon bar with ESI Chunky grips
    -Thomson Masterpiece seatpost
    -Cobb Cycling SHC DRT Saddle
    -Race Face Next SL Crnak 32tooth ring 175 arms and Race Face BB
    -Avid XX1 Brakes 180 rotor front /160 rotor rear
    -XX1 trigger shifter, rear derailleur, and 11-42 cassette
    -Nextie-Bike Jungle FOx rims laced to Industry Nine Classic Fat Hubs
    -Knard 29x3 120 tpi tires tubeless
    -Time ATAC carbon pedals.
    LOVE this ride!
    Attachment 938506Attachment 938508
    Hey Tri,
    Looking to do the same to replace my Gnarvester; What weight is that thing coming in at?
    MTBP
    "GIVE ME LIBERTY OR GIVE ME DEATH!"
    Turn on the truth: http://www.ronpaulchannel.com/
  21. #171
    24.66 pounds with the current setup and an arundel sport cage mounted.
  22. #172
    Dec 2014
    Got this about a month ago. XX1 build except the crank (RF turbine). Set up tubeless with Marge Lites and 120 tpi Hudus. XTR pedals, Elite polycarbonate cage, Fizik Antares VS. 24.5 lbs. Rolls like it's on butter.
    Attached Thumbnails Attached Thumbnails Borealis Picture and Specs Thread-bike-pic.jpg
  23. #173
    Reputation: alshead's Avatar
    Oct 2007
    Anyone have weights on the Turnagain FR80 rims laced to the Borealis hubs/ original/ stock wheelset? I skimmed through here and didn't see anything
    "There are two kinds of mountain bikers in the world: those who are faster than me, and me."
  24. #174
    Dec 2014
    Quote Originally Posted by alshead View Post
    Roughly 3000 grams. Hubs are 560 gm, rims are 1800, spokes are probably 450.
    I saved roughly a pound by going with Marge Lites. Will be having the wheels rebuilt using Sapim CX-Ray spokes to save close to a half pound.
    Rotational weight and a new perfect build are my motivation!
  25. #175
    Jan 2013
    1x10, 30t narrow wide, 11-40 one up Shimano Xt. Nextie 65mm rims with Snowshoes set up tubeless.
  26. #176
    Feb 2006
    Twice the fun!!!
    Echo on right is about a week old, one on left is about 2 months old. But the 6 pack was brand new that day Borealis Picture and Specs Thread-20150124_133526-large-.jpg(yesterday), unfortunately, it didn't survive.
  27. #177
    Oct 2007
    Can anyone with an echo AND race face next sl cranks in a 170 spindle share a shot of the frame clearance at the chain stays?
    There are two types of mountain bikers. Those who are faster than me, and me.
  28. #178
    Really I am that slow
    Reputation: SlowerThenSnot's Avatar
    I'll try and get you a shot at work
    Read my BLOG!
    just a guy who loves bikes and exploring
  29. #179
    Feb 2006
    Both of the Echo's you see in the pic posted above have 170 spindles and the clearance is plenty, but if the gentleman who said he'd try to get you a pic at work today is unable to do so I will see what I can do if it will help you out.
  30. #180
    Oct 2007
    Quote Originally Posted by SlowerThenSnot View Post
    As always, Dave: You = the man.
    (silly litesepeedaddict called you a "gentleman"- lulz)
  31. #181
    Feb 2006
    Borealis Picture and Specs Thread-drive-side.jpgBorealis Picture and Specs Thread-non-drive-side.jpg
  32. #182
    Oct 2007
    ^Awesome- thanks litespeed!
  33. #183
    Y'all beat me to it 😃
    Read my BLOG!
  34. #184
    Must build all the wheels
    Reputation: chriskmurray's Avatar
    Dec 2013
    Quote Originally Posted by litespeedaddict View Post
    First time flipping through here in a while. I was actually the one who built your wheels and I remember them specifically because a steel axle and brass nipples on HED rims sounds like something I would do as I am still having a tough time letting some of my curmudgeon like tendencies go. Bike looks awesome by the way!
  35. #185
    Feb 2006
    Quote Originally Posted by chriskmurray View Post
    Very cool, thanks for dropping by and introducing yourself. The bike is awesome, I wouldn't change a thing. It also inspired a few more Borealis purchases in town after everyone saw this one.
  36. #186
    Dec 2013
    For sure, I always love seeing where my wheels end up!
    Glad you are enjoying the bike so much, bias aside, these bikes are incredibly fun and addictive!
    Might as well add to the thread while at it.
    This is my Echo with the new 100mm Turnagain tubeless rims.
  37. #187
    Need more stopping power, already run a 200 rotor in the front, thinking about going 180 the back, looks like it could be tight fit adding an adapter. Anyone try this yet? Large frame BTW.
  38. #188
    Out for a ride on the local snomo trails...
  39. #189
    Reputation: TankD's Avatar
    Jan 2014
    Quote Originally Posted by TahoeBC View Post
    Fits with ease, both Yampa and Echo large frame.
  40. #190
    Jan 2015
    Ups just delivered my yampa
    The hed are not holding air
    I'm hoping the tubes are damaged and nothing else
    Really excited to get her dialed in and ride
    Lbs opens at 10 and I'll be waiting
    Attached Thumbnails Attached Thumbnails Borealis Picture and Specs Thread-image.jpg
  41. #191
    The tires are on tubed and not holding air? Sounds like a tube problem and not a rim issue.
  42. #192
    Jan 2015
    I am hoping it the tubes
    Im hoping the LBS has time to help me go tubeless tomorrow so i can ride with my buddy in the afternoon
    it weighs just under 25 (luggage scale) which is mind blowing
  43. #193
    beer thief
    Dec 2002
    Quote Originally Posted by blidner View Post
    Come on man, certainly you know how to fix a flat!? Tubeless can wait for another day, get out there and ride.
  44. #194
    Jan 2015
    Yes of course I can change a flat!
    But I don't have a torque wrench (yet)
    Did some excellent riding and she rides strong
  45. #195
    Reputation: skiahh's Avatar
    Wait.. you got a bike with HED rims??
    I ordered (and paid for!) my Echo with HED rims back in January, but the HEDs were back ordered. The gave me a great deal on a set of Turnagains, so I could ride, but so far, nothing on the HEDs. That I paid for. If they're shipping them, I'm a bit torqued that they haven't shipped mine out yet.
  46. #196
    Jan 2015
    I pm you
    I picked mine up in the secondary market
    Is anyone else having trouble with their front release? My handles spins right off
  47. #197
    I pm you
    Ah, OK.
    Not torqued, then. Just impatient!
  48. #198
    Reputation: jackdz's Avatar
    Aug 2010
    Quote Originally Posted by skiahh View Post
    My HED's have been on order since December the 10th when I bought my Yampa. Borealis sold me a set of Turnagains pretty cheap...but they are POS. I pulled the rims off the hubs and replaced them with a set of Stans Hugos.
  49. #199
    Jan 2015
    I'm sorry to hear that, I hope your carbon hoops arrive soon
    I don't see that package on the website anymore
    I can say it's worth the wait
    Nice and light rotational weight
  50. #200
    Aug 2010
    Yeah, the funny part is, I bought the bike, actually 2 Yampas…from my LBS. Both were suppose to come with HED wheels. I hate to think that I'd still be waiting for my bike from Borealis (since December 10th) if I had not bought another set of wheels. Now I have two sets of Turnagain FR80's that are worthless to me. I have utilized the hubs in my Hugo build, but the rims are worthless.
  1. CDT picture Thread: Foo & Fam
    By Mtn. Biker123 in forum New Mexico
    Last Post: 10-31-2012, 03:30 PM
  2. Procaliber picture thread
    By indianadave in forum Gary Fisher
    Last Post: 09-09-2012, 11:12 PM
  3. Then and now picture thread.
    By jeff in forum Vintage, Retro, Classic
    Last Post: 10-02-2011, 02:30 AM
  4. thread lock? torque specs
    By brightsky in forum Niner Bikes
    Last Post: 03-20-2011, 09:53 AM
