IE fork air pressure
tyres and air pressure
your bike
your weight
your regular riding terrain
how much rebound dialed in
Currently got mine set up
forks 100psi
floater tyres 15 psi rear 12 front
bike OO Fatty and Puffin
weight 200 + lbs
terrain Road / mud / rocks / roots no beaches
rebound 5 clicks from fastest but not sure if that is right as was how they arrived from bikeshop
2014 Borealis Echo
Surly 26"x4.8" Bud in front, ~13psi
Surly 26"x4.8" Lou out back, ~8psi
Shock air pressure ~120psi
Rider weight: ~172lbs. depending on beer intake the night before the weigh-in
Terrain consists of loose/rocky/gravelly/off-camber/steep/rock-gardeny/dirty singletrack and fire roads
Rebound is 2 clicks away from the little rabbit graphic
I’m not confident that this is the best setup for the terrain I am riding, however, don’t want to waste time dicking around with configurations whilst on a ride– I just want to RIDE! :band:
120mm BLUE-Toe on a 2014 Mukluk Ti, size small
100mm clownshoe front rim/80mm Holy Rolling Darryl rear rim
Hope Fatsno hubs - 135mm front with Hauck conversion caps, 170mm rear
3.8" 120tpi Knards set at ah-boot 10psi
Fork set at 110psi
Rebound - I dunno, maybe 5-6 clicks in from slowest
Lockout lever on the bars
I clock in at over 200#
Terrain is a Northeastern Canadian mix of rooty, rocky loamy single track and gravel doubletrack with some sand patches
So the specs list 200psi max pressure. Does anyone know what the max weight limit is or what the math would be for someone that has an owners manual in front of them?
2013 Mukluk + Bluto 80mm
95 psi
rebound= 4 clicks in from the rabbit
rider weight= 160lbs
dual buds on holy rollers @ 11psi front- 8-9 psi rear
terrain is mixed, a little of everything. Still fine tuning
MD 2014 Carbon Beargrease w Hed carbon Wheels (24 1/2 #s)
150 pounds wet
Dillanger front 11 psi, Hudu rear 12 psi
75 PSI
One token per side
Three clicks out w lock out
100 MM Travel (full range)
A rider XC
Does anyone know whether a SID XX damper (the one with the hydraulic remote) would work in a Bluto? It looks like it should be fine. I quite like this damper, much nicer lockout action than the cable ones.
Large Motobecane Boris
4.5 juggernaut pro 9 psi front, 4.5 snowshoe 120tpi 11psi rear
0 tokens
90psi air pressure
4 clicks out from fully slow
120 mm travel
Weight 141
I ride a mix of local free ride/ Enduro trails. Jumps, drops,log rides etc. I live in NY, so roots and rocks are everwhere. I need to add a token or two though because I bottom out on one of my favorite drops (4'). I don't go much bigger than 4' on this bike though. I save that for my trail bike.
Example of the terrain:
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
