Page 1 of 7 12345 ... LastLast
Results 1 to 100 of 670
    Reputation: alshead's Avatar
    Oct 2007
    Bluto Tuning Thread
    I know this is a more limited group, but for any/ all Bluto adopters, where are you running your fork? I am having to drop my pressure way below recommended to get any good action out of the fork and get full travel. Even at 75psi, I get 15% sag and the fork feels super stiction-ey. Dropped it down to 65 to try later today. I'm 165- 170 all kitted up, so should be 100+ psi.
    "There are two kinds of mountain bikers in the world: those who are faster than me, and me."
    Loser
    Reputation: Jisch's Avatar
    Sure, now that I have the thing on order someone posts something negative. I'll be able to join in on this discussion on Saturday (maybe).
    Oct 2007
    Ha! Not negative- I've been super happy with it, but I am pretty picky about how my suspension feels. I've still only had it on maybe 4 rides (busy summer plus 2 other bikes that I regularly ride), but it feels stiffer than I want it to, and it looks like I'm only getting about 2/3 of my stroke. I'm going to put some slick honey on the stanchions and have it on a few more rides with lower pressure before I decide to tear it apart. Maybe it just needs to be broken in?
    What kind of trails and riding were you doing that required a lower than recommended type of pressure? Do you consider yourself to a casual rider who prefers soft suspension or an aggressive rider who prefers stiff suspension?
    I rode my bluto for the first time last night, but just around the block a few times.
    It seemed stictiony, but only like a new fork normally does. In my experience, it takes a few rides for fork bushings to loosen.
    Also, turning the compression knob made a surprisingly huge difference in the typical push down on the bars test. Unfortunately I threw away the manual and can't find it online so it isn't clear exactly what that knob does within the fork.
    I had to use slightly more pressure than recommended to get the desired stiffness. Instead of worrying about sag, I normally aim for a pressure that prevents bottoming except when something extreme happens. As the fork breaks in, it'll need some tweaking for sure. But for a starting point, I'm running 105psi for 160 pounds of rider and gear.
    Loser
    My normal method of setting up a fork is like yours dfiler, I want to use all the travel when I am riding aggressively and don't want excessive bob when I'm pedaling. I'll start with the recommended psi and work my way to the right spot.
    Oct 2007
    dfiler- I'm a pretty aggressive rider. The trails I ride are chunky and techy, dry, Colorado front-range trails. I am pretty savvy to suspension, but this felt more stictiony than I thought- it very well could be that it just needs to break in, but with the fork at recommended PSI and the compression all the way open, it's tough to even compress the fork very far, and, like I said, I am only getting about 60% of my stroke.
    The blue knob is your compression damper. Typically, the damper has oil flowing through it- either in an "open bath" or enclosed "bladder." Either way, the oil/ fluid is flowing through the damper assembly and through various ports. When the blue knob is all the way open (counter clockwise), it's allowing as much fluid to pass through those ports as possible. As you turn the knob clockwise, you are, in essence, closing off those ports, making it harder for the fluid to flow through and thus harder to compress the fork. All the way clockwise is "locked out" (though it will blow through if it needs to on a bigger hit to prevent damage to the fork). FixieDave hypothesized that it could be that some of these ports are clogged, but, again, I'll probably give it a bunch more rides before I take it apart- just wanted to see if anyone else was experiencing similar stuff.
    That's how I would describe compression damping as well. I'm interested in the specific type of valving but not enough to break the fork down before it needs service.
    It will be interesting to see if your fork breaks in at all. I'll report back with my findings as well.
    Reputation: OCDKV's Avatar
    Jul 2014
    Quote Originally Posted by dfiler View Post
    https://www.sram.com/sites/default/f...to_reba_sm.pdf
    One 2015 Bluto manual
    Loser
    if you let all the air out of the fork, can you compress it all the way? It could be overfilled with oil I've had this happen before where a fork is hyrdo-locked by too much fluid - after getting it back from a rebuild.
    Good suggestions Jisch.
    I'd seen the service manual but was hoping that a user manual might contain additional info on damping/lockout. That service manual also depicts a gate valve which only applies to the Reba.
    The reason for the interest is that there can be a big difference between forks. For example my manitou circus can be run with the compression knob set to lockout without fear of damaging the fork. It has blow off valving. The same is not true for the fox floats I've owned. I destroyed the lockout on a float by forgetting to unlock before sending a medium sized drop.
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Sounds like you're running too much air.
    Recommended psi's are just that--recommended.
    I weigh 15# more than you and I'm running 15psi less.
    IMO, you need to dump some air before anything else.
    Once the air spring feels right, then you can fiddle with air volume and damper adjustments.
    Reputation: Fat907's Avatar
    Jun 2014
    I weigh 240 and have 160 lbs of air 3 turns out on rebound and 4 bottomless tokens installed....also have changed to 80mm with an air tube from a SID...I'm also thinking about changing from 5wt to 7.5 just to see what happens
    Loser
    I have only ridden my Fatboy with the Bluto around the yard, in my pump track and up and down a few curbs, hopefully I'll get it in the dirt tomorrow.
    At first I kept letting air out because I wasn't getting the travel or the response I was hoping for. I checked the rebound and it was all the way slow (doh!). Speeding it up improved things dramatically - as someone else mentioned, that knob does a lot and when its too slow it prevents the fork from moving through its travel.
    A few rides on the bluto now... 115psi is working for me (160 pounds with gear). The o-ring shows I've been bottoming it but I haven't felt it behave like it was bottoming.
    Must build all the wheels
    Reputation: chriskmurray's Avatar
    Dec 2013
    Be sure to play with the air tokens, if you are not getting full travel try removing a token. The more tokens you have in the air side of your fork the more the air spring ramps up through the travel.
    Also if you are really picky about your suspension, you can actually run the RCT3 damper in the Bluto over the stock damper. You will have to play around to find the right oil volumes though.
    Oct 2007
    ^Wow- good to know about the RCT3 Damper- I LOVE my Pike. Amazing feel. I took out a token last night. FWIW, there were two installed on a 100mm Bluto. I'll try it out sometime later this week.
    Dirt Huffer
    Reputation: AC/BC's Avatar
    Is there a way to reduce the 120 Bluto to a 100?
    Jul 2014
    Re: Bluto Tuning Thread
    It says in the manual you'll need 2 bottomless tokens and buy a new air shaft (part# 11.4018.026.015). Looks pretty straight forward.
    Oct 2007
    ^^You could take your air shaft out, send it to me, and I'll send you my 100 shaft.
    Loser
    Did my first real ride on my fatboy with the Bluto tonight. On the continuum of incremental to revolution change, it's somewhere in the middle. It was great to charge through rock gardens without worry. Catching air was awesome. Overall I'm very happy, it will take a few more rides to get it dialed. The best part is it didn't mess with the feel if the bike at all, I really didn't notice the weight or anything weird with the geometry.
    Jun 2010
    I'm 160 with gear too and I have it at 85psi but only on a few mild rides so far. I also feel like its sticky and not very plush out of the box.
    Dec 2013
    Quote Originally Posted by OCDKV View Post
    Yup, very simple swap and it looks like you have someone willing to swap air shafts!
    move on up...
    Reputation: Forged1's Avatar
    Dec 2011
    So Chris an 80mm Bluto can be changed to 100mm with a new air shaft and tokens? I haven't received my Bluto yet but should be here this week, so I haven"t read the manual yet. Thanks!
    Loser
    I ride often at my local trail system, its five minutes from my house and I can get 10 miles of riding in when I don't have time to drive further.
    I run Strava, I have a few KOMs out there, mostly because of the number of times I have ridden everything, sometimes the stars align. There's a nice switchback climb out there that I have been gunning for - today with the Fatboy and the Bluto I got the KOM back.
    Its weird because I really didn't feel like I was going that hard. Is it all because of the Bluto? No way, but at a minimum it didn't hurt my time either. I rode it with my Niner a week ago gunning for the KOM, I felt like I rode way harder than today and I didn't get it.
    All this to say that the Bluto is a good addition to this bike, happy to have it (and all this could be because my phone/Strava glitched too).
    Jul 2014
    Quote Originally Posted by Forged1 View Post
    The 80mm should come with all 4 tokens so to go from 80-100mm you should only need the longer air shaft and remove 2 tokens. You can download the manual and parts lists from Sram.
    Dec 2013
    Yep. It is a pretty simple change if you are comfortable taking a fork apart.
    Jun 2014
    I have the air shafts that I took out of my 100s if anyone needs one.......just pay to ship
    move on up...
    Dec 2011
    Quote Originally Posted by Fat907 View Post
    I sent you a PM! Cheers!
    Reputation: winkster's Avatar
    Mar 2012
    Advice needed, I recentley installed the Bluto fork and after a couple of rides the fork has started loosing air pressure during the ride. It will go from 80 psi to 50 psi and feels very unresponsive. If I air it up it will hold pressure for a while into the ride but then it drops pressure at some point in the ride. Any clue as how to go about fixing this issue? Thanks for any help.
    aka bOb
    Reputation: bdundee's Avatar
    I think RS has been known for this problem (I think) Do a search but I remember someone recommended letting all the air out and cycling the fork a few times then pumping it up again. I could be completely wrong and pulling this out of my a$$ but it's worth a shot. Remember when you search that the Bluto is about the same as a Reba so what applies for one might apply to the other.
    Reputation: Father Guzzi Obrian's Avatar
    May 2014
    I pick up my fatboy with an 80mm bluto installed by the LBS, who will tune it for my riding style, however, this is hard in a parking lot. Based on the length of the Bluto 80mm, I suspect I should go for minimum sag and probably should have gone 100mm. Regardless, any input is appreciated before I pick it up.
    Thank you,
    FGO
    aka bOb
    Quote Originally Posted by Father Guzzi Obrian View Post
    Thank you,
    FGO
    A 80mm with 25% sag is about the exact same a-c as the stock fork. That being said my frame is a 69.8 HT angle at 468mm a-c (which is a 80mm Bluto with 25% sag) and I am running a 100mm Bluto and I love it.
    Jun 2010
    I am interested in getting one of these forks what did u use for hubs on these things.
    move on up...
    Dec 2011
    Bikeman.com has Hope 150mm front hubs for bluto in stock right now for $111.99 free shipping! Universal cycles has the Hope and salsa specific hub in stock too.
    Jun 2010
    Bluto Tuning Thread
    How much is reasonable to get the rim laced
    May 2014
    I know all the prices, but my LBS who has sold me my Camber and my Roubaix was willing to sharpen their pencil, buy all the bits, install them and then fit me when the install was done. It was a very fair price and they warranty this just like the bike. I really cant complain, I will be riding a fitted, warrantied Bluto for ~$900. Cheaper if I did it myself, but my LBS is two blocks from my house and have exemplary service.... No brainer for me.
    Cheers,
    FGO
    Quote Originally Posted by ridehard84 View Post
    i have the i9 front hub with their adapter kit. my gf has the salsa 150mm hub which doesn't require an adapter but i wanted to keep things matchy so i just got the adapter.
    overall the fork is great. a definite game changer imo. could it feel better...? yeah, i think it could but being the first mass produced fat bike fork i'm pretty stoked on it. i've since sold my niner sir 9 and haven't touched my full susp bikes and now i want a dropper post...
    Loser
    I took my Fatboy/Bluto out on a 10 mile ride this morning. The ride was full of intense rock gardens and screaming downhills. I have been reluctant to bring my fat bike on rides like this in the past, the necessity to slow down bugs me - I like going fast. I just put my dropper post back on - so I had a bit of an issue with seat positioning.
    The Bluto definitely made the Fatboy a full bore machine. I found myself able to keep my fingers off the brakes and really crank through the rock gardens. I was leading the ride and had a fast guy with me. I won't say I dropped him (because I didn't), but I was able to keep him behind me without him riding my wheel.
    So I guess I'm changing my earlier statement that it's not a game changer (if I made such a statement), the Bluto is a game changer. It's turned my Fatboy from a fun bike to ride in limited situations, to one that is fun in a lot broader situations.
    Definitely worth the money. So glad to have one on my bike.
    Dec 2013
    Quote Originally Posted by Jisch View Post
    You have the 100mm bluto?
    My wallet curses at your positive bluto reviews.
    Loser
    Yes, 100mm, it's only money.
    Reputation: Mr. Lynch's Avatar
    Jun 2010
    I just install a 120mm Bluto on my Fatboy and it is amazing! Glad I didnt go shorter. I need to find a token though, i think it would help. Ive tired a few different pressures and you can blow thru travel easy. I added a token to my Pike and it was a big help so Im hoping 1 or two in the Bluto will do the same.
    14 Aurum, 16 Fuse, 17 T130
    Jun 2010
    My experience on my first big ride Friday is the same!!! roots, rocks, not quite as fast as my FS, but fast... and the fat tires changed the game with grip. and, it just a different kind of fun.
    move on up...
    Dec 2011
    Did you check air pressure?
    May 2014
    Picked up my fatboy with the 80mm bluto, my LBS first install. The manual just addresses install in 50 languages. It is springy, seems limited in both compression and rebound damping and no info provided on what the doodads do. Is their a tuning manual that addresses the Bluto specifically, my LBS did not have one, and I see I am only getting ~2 inches of travel, and it is overly springy. Any suggestions on setup are appreciated, I don't blame my LBS, this is their first install. Thanks for any input.
    Cheers,
    FGO
    Loser
    Red compression knob on the bottom of the fork controls how fast the fork rebounds, if its overly springy, turn the knob 3 or 4 clicks slower - there is a LOT of difference between full slow and full fast. If you're not getting full compression - then try letting a little air out, I'm running about 90PSI, I weigh about 170 with my gear on, I get full travel on big hits (though I don't feel the fork bottoming out).
    Those two things interact - so if your rebound is overly slow then you will not get full compression - I had that problem at first until I sped up the rebound.
    May 2014
    Thanks, I am doing a tuning run tomorrow, I can already tell that with not tuning it is much more capable in the stuff I ride in.
    Thanks for the input, I will report back when I dial it in...
    Reputation: Way2ManyBikes's Avatar
    Bluto Tuning Thread
    Couple things to consider. Most fat bike where not designed with a suspension fork in mind. Therefore the head angle could be off and preventing the fork from actually using all the travel.
    I am going to go way back and talk about when suspension forks first came out and people where saying the same thing that you are saying now.
    I have a trek farley and when the designed the bike they designed it with a suspension fork in mind so for me the fork has worked perfect your of the box.
    In the old days we only had 65mm travel forks which worked but when they finally offered 80mm forks it changed the head angle enough to actually make the fork work.
    Ps I could be totally wrong here but some fat bikes just don't have the right head tube angle to allow the fork to work correctly.
    Marty
    12 JamisDakar650B
    14 FarleyBlue,Bluto,i9-Hed,4.JumboJims
    14 FarleyBlack,Jackalope
    17 Farley 9.6 Under Construction
    Jun 2010
    Quote Originally Posted by Way2ManyBikes View Post
    What is the "right" head tube angle then?
    Bluto Tuning Thread
    Not sure but the Farley has a 70 degree angle and if you read about the bike they built the entire geometry around a suspension fork.
    I was told buy the guys at Trek that they just copied the Geometry off of one of there current 29'r and just widened the rear triangle to make the 3.8 fit and the 4.0 barely fits with a 2x10 drivetrain.
    The Farley has the shortest rear chain stays out of any of the fat bikes which make it support short in its overall length which works great in the tight twisty single track trails.
    With the bluto on my bike it has now become the only bike i ride.
    Today I was forced to take a line I would have never I repeat never considered or even saw as a line but because I was riding faster them I have ever ridden and came up on a jogger it was either hit him or swerve to the right and hope for the best. Which I did and the bluto performed like magic and I didn't even notice all of the tree roots, wash outs and drops going down the hill all I did was aim between the two trees and smile.
    Ps my buddy's 9 Zero 7 works incredible with the 100mm fork even thought specs say it should be an 80
    Marty
    12 JamisDakar650B
    nothing to see here
    Reputation: Stevob's Avatar
    Switchback climbs/descents are notorious for false start/finish point readings on Strava. It's usually because different levels of the track come too close to each other.
    I see hills.
    I want to climb them.
    Loser
    Yep, and that could have happened here for sure, never trust strava.
    125psi and compression damping one click back from locked out... still not stiff enough for my tastes. (160 pounds of rider and gear)
    I'm gonna research adjusting the progressiveness. That's just some spacers right? Any suggestions?
    Jun 2010
    The Bluto can use the black 32mm bottomless tokens, but the fork didnt come with any and I'm not sure they are available for sale yet.
    I know on my Pike the Bottomless tokens made a huge difference and I'd love to get 1 or two for the Bluto.
    Hmmm, there 2014 rockshox spare parts catalog only lists bottomless tokens for the Pike.
    https://sram-cdn-pull-zone-gsdesign....pc_rev_a_0.pdf
    But it seems if a token existed for a 32mm stanchion fork, it should work. This article makes it sound like such a token should exist and would work at least for the RS-1, reba, SID and revelation.
    RockShox Officially Introduces The 29er specific RS1 Inverted XC Fork
    I'll contact rockshox and see what they have to say. Edit: Looks like I won't be contacting them since SRAM appears to not want any direct contact with customers. In my opinion, that's a shitty way to run a company.
    i heart singletrack
    Reputation: mgersib's Avatar
    You and I are in the same ball park. I have been surprised how much pressure I need to run to keep the fork from bottoming. I'll eventually try one or two bottomless tokens, but don't have them to try yet.
    I like bikes
    Quote Originally Posted by mgersib View Post
    Yep, and i'm up 10 125psi with it still a bit too easy to bottom. I'll try bumping it up a bit more but tokens (a more progressive spring rate) would be preferable.
    Loser
    Do you guys have 100 or 120mm Bluto's? I'm 170 or so with my pack on and I'm at 95PSI. I've maxed the fork out on every ride so far, but I don't notice any dive while pedaling and haven't felt any true bottoming out of the fork. I'm one of those guys who sets and forgets though, so sometimes I change something and I realize just how off I was before. Maybe I'll try adding a bit of air.
    Oh and I'm running a 100mm Bluto.
    Jun 2010
    The 32mm tokens wont be available until late August.
    I'm running the 120mm Bluto which doesnt come with any Pre-installed. The 100mm Bluto has 2 pre-installed and the 80mm version has 4, which is the max.
    https://www.sram.com/sites/default/f...tokens_eeu.pdf
    Oct 2007
    Converting my 100 to 120 and also thinking of picking up the RCT3 Damper (I'm a suspension snob): http://www.amazon.com/gp/product/B00...=faqloadcom-20
    Which bike are you running the bluto on? I'm really interested in this swap too...please keep us posted.
    Oct 2007
    ^Specialized Fatboy Comp (medium).
    leaning towards a 100mm for my AL Beargrease, gets me ready for eventual move to bucksaw
    Oct 2007
    Okay- got the air shaft to convert my 100 Bluto to 120, plus the RCT3 Damper. Anyone have any info on the conversion? Oil volumes/ weights? The "service manual" link from the SRAM page for the Bluto doesn't even have the Bluto listed on it. Treat it like a SID?
    Jun 2014
    I went 20cc less oil than spec with the RTC3, 4 tokens, and 165lbs........I weigh 230
    Oct 2007
    20cc less than what? I just found the 2015 service manual and it lists the Bluto and the oil volumes are the same for it as they are for the SID (with the RCT3), so I'm going to follow those levels.
    https://sram-cdn-pull-zone-gsdesign....chart_2015.pdf
    Any other tips? I haven't worked on a RS fork in a while- pretty straight-forward?
    Jun 2014
    20less than stock.......the easiest fork I ever worked on..took about 25 min to change it to an 80 from a 100
  67. #67
    Aug 2014
    Is the RTC3 damper worth it as an upgrade? I know upgrading to the Pike damper on my XC32 fork changed the ride and made it a lot better.
  68. #68
    Jun 2014
    Go to sram.com click service at top of page click forks then go to page 5 for the newest bluto service manual
  69. #69
    Jun 2014
    Worth every penny.......stock bluto felt soft and slow
  70. #70
    Oct 2007
    Fat907- what grease did you use on the Air Shaft? I have some Slick Honey, but the manual says only the RS/ SRAM Butter, or some military grease. Seems like for 20 less than stock on the damper side, you could just pull the old damper and insert the new one without changing fluids... For the air shaft, seems like I just need to remove the rebound adjuster knob and lower bolt on non-drive-side, drain oil, remove the lowers, remove the retaining ring, pull the air shaft out, grease up the new one and install the bumper and floating seals from the old one, and re-install, then add fluids. That's it?
  71. #71
    Jun 2014
    I bought the grease that they spec.....some military p-800 or something like that ..it's red and very tacky
  72. #72
    Aug 2014
    I will have to do this upgrade then. Have a 120mm Bluto coming on Sturgis Bullet, but swapping the Bullet to rigid and putting Bluto onto Bucksaw frame I ordered. :-)
  73. #73
    Oct 2007
    Any idea where you got it?
  74. #74
    curious why you went down to 80
  75. #75
    As I understand it, every 10mm increased in fork extension equals ~1 degree decrease in head angle. So working from a 25% sag, compare that Bluto fork length to your stock fork length, consider how increased sag would affect the current feel of your bike, and go from there.
    In my experience, more is not always better, especially when you are adding suspension to a frame that is not suspension corrected. Most fat bikes are not going to be suspension corrected unless they are a fairly new design...
    My Lurch arrives tomorrow, I'm probably swinging toward 80mm, 100mm if I want a little slack.
  76. #76
    Aug 2014
    Are the air shafts the same on the Reba and Bluto? I have a 100mm Reba and 120mm Bluto coming and was wondering if I could switch the Reba 10 120mm and the Bluto to 100mm by swapping them?
  77. #77
    Oct 2007
    Quote Originally Posted by Nurse Ben View Post
    Every 10mm is equal to ~.5 degrees in HA. So 20mm in fork length decreases the HA ~1 degree.
  78. #78
    I was close
  79. #79
    Reputation: pbasinger's Avatar
    Dec 2004
    Iíve been running the Bluto around Moab for about 2 months. For me a front suspension fork was the one thing really preventing me from riding the fat bike in the dirt more. The Bluto really helps close the gap between just a snow bike and a bike I take on summer trails.
    That said, I think itís one of the worst feeling RS forks Iíve owned. With 90 psi well bellow the recommend pressure for my weight I find itís super stiff and has tons of stiction. When I drop the pressure down to a point it moves on small to moderate size bumps it bottoms outs too easily.
    Iím not very knowledgeable about suspension stuff. For those that are, do people think this is more of an issue related to the damper or rather a lack of lubrication?
    Hereís a picture since this thread is lacking.
  80. #80
    Jun 2010
    Are you running any tokens? Which Bluto model do you have?
    I have the 120mm and it came stock with no tokens and I blew thru the travel and woudl bottom out hard on bigger drops. I now have two tokens installed and it is perfect. I was able to lower the pressure a bit which gives it even better small bump compliance, but it ramps up quicker and doesnt bottom as easy.
  81. #81
    Aug 2014
    I don't even have my Bluto yet and have already ordered these, based on reviews and I weigh 240#.
    Amazon.com : RockShox Pike Bottomless Tokens A1 Qty 3 : Sports & Outdoors
    I may order up the damper as well but the fat bike fund is a little skimpy right now...
    http://www.amazon.com/gp/product/B00...A3DZMBT0IIAXRS
  82. #82
    Jun 2010
    Those are the Pike tokens and wont fit! You need the black 32mm tokens. I had to order a 5pack thru my LBS.
  83. #83
    Aug 2014
    Quote Originally Posted by Mr. Lynch View Post
    You are correct! Pike now has 35mm stanchions so they will not fit. Thankfully Amazon makes returns easy!
  84. #84
    Running a 100mm Bluto on AL Beargrease for about two weeks now in Maine. Bunch of short rides and one good 25mile day up at Sugarloaf. Running around 85psi which is below recommended, still playing with pressure. Recommended was too stiff.
    Haven't looked inside at the token assortment yet.
    Next to my first set of disc brakes this might be the best bike upgrade ever for me, most likely will end up with a Bucksaw or King Kahn if that comes to production next year.
  85. #85
    aka bOb
    Quote Originally Posted by pbasinger View Post
    Same exact results here Pete!! I'm going to mess with the tokens when I can find some. Not a suspension guru here either.
  86. #86
    Aug 2014
    My son's bike has a 100mm Reba on it, I may just steal a token or two out of his for my 120mm Bluto once it gets here. He only weighs 70lbs so doesn't bottom anything out on his Horsethief. ;-) Per the RS chart here, the Reba should have two tokens from the factory -https://www.sram.com/sites/default/f...ess_tokens.pdf
  87. #87
    Reputation: letitsnow's Avatar
    You've just described every RS fork that I've had in the past. Waiting for Fox...
  88. #88
    Mar 2012
    I went to 3 tokens total and that made a nice difference plus I am running a little lower pressure now. Before, 2 tokens and 100psi, now 3 tokens and 75 psi. I weigh 185 pounds and the ride has a nice plush feel without bottoming out easily.
  89. #89
    Dec 2004
    Are people finding some of the Blutos are coming with no tokens? Anyone talk to RS or know whether they are supposed to have tokens?
  90. #90
    Loser
    I'm 175 or so all loaded up to ride, I run about 95PSI, feels great, I bottom on the biggest hits, but most rides I come back with about 1/4" of travel unused. I don't feel any stiction at all, but that could just be me. I had my fork lose air once, but it seems to be holding now, which is a little weird.
  91. #91
    Jul 2014
    80mm = 4 tokens
    100mm = 2 tokens
    120mm = 0 tokens
    At least that is what is supposed to be with them according to manuals found here:
    https://sram-cdn-pull-zone-gsdesign....ess_tokens.pdf
    and here
    https://sram-cdn-pull-zone-gsdesign....to_reba_sm.pdf
  92. #92
    aka bOb
    I did as well.
  93. #93
    Sep 2014
    Fitted a Bluto to my farley 6 few days ago...seems to be the same as some have found, im 180lbs tried it with recommended psi, and might as well have the ridged fork back on?! now at 85/90 psi seems more like it, but still doesn't seem quite right?
  94. #94
    Mar 2012
    Quote Originally Posted by andy586 View Post
    What travel fork are you working with? Try adding another token or two depending. I am running the Bluto at 100mm and have three tokens in there to get a great ride from it. I do however find it leaks down air after a ride some times, but only about 15psi. Not sure why the leak down happens as I have taken it apart and everything looks good. I have extra tokens if someone wants 1 or two.
  95. #95
    Jun 2014
    The biggest difference was changing from 10wt to 7.5wt.......running 4 tokens and 150 lbs of air...3 clicks out...RTC3
  96. #96
    Sep 2014
    Quote Originally Posted by winkster View Post
    this ones running at 120mm at the mo... these "tokens" from rockshox spare parts??
  97. #97
    Jun 2010
    I ordered mine from my LBS. They come in a 5 pack and are black. I believe they are around $15 for 5. I ended up putting two in my 120mm Bluto (I'm 160 lbs) and it feels really nice.
    The 80mm comes with 4 installed, the 100mm has 2 and the 120 has zero.
  98. #98
    Aug 2014
    I need to get some tokens, my bike w/ Bluto should be here at the end of the month or early November. I am 240# and have the 120mm version coming (on a Moto Sturgis Bullet). I have not found them online anywhere but will be heading to the LBS tomorrow and I will see if he can order me some.
    I have not pulled the trigger on the RTC3 damper yet. Have it sitting in my cart in Amazon debating if my wife will shoot me if I order more parts. Maybe in a couple weeks she will have forgotten?
  99. #99
    Sep 2014
    Okay just looked into these tokens, ie watched a few rockshox videos on YouTube :-) but I've the opposite problem, in that even though I'm running under pressure for my weight, the resistance still ramps up way to quickly and I'm getting nowhere near full travel ....any thoughts, or anyone else experience this??
  100. #100
    Jun 2010
    What size Bluto do you have? If it is 100mm or 80mm you can remove tokens.
  1. official xfusion rl2 fork service and tuning thread
    By dwyooaj in forum Shocks and Suspension
    Last Post: 3 Days Ago, 02:21 PM
  2. Bluto Hub Options
    By CJones in forum Fat bikes
    Last Post: 07-03-2017, 06:56 AM
  3. New Bluto Thread!
    Last Post: 05-02-2017, 08:04 AM
  4. Bluto - Thread Deleted?
    By dfiler in forum Fat bikes
    Last Post: 04-09-2014, 08:28 PM
Members who have read this thread: 174
