I know this is a more limited group, but for any/ all Bluto adopters, where are you running your fork? I am having to drop my pressure way below recommended to get any good action out of the fork and get full travel. Even at 75psi, I get 15% sag and the fork feels super stiction-ey. Dropped it down to 65 to try later today. I'm 165- 170 all kitted up, so should be 100+ psi.
Do you guys have 100 or 120mm Bluto's? I'm 170 or so with my pack on and I'm at 95PSI. I've maxed the fork out on every ride so far, but I don't notice any dive while pedaling and haven't felt any true bottoming out of the fork. I'm one of those guys who sets and forgets though, so sometimes I change something and I realize just how off I was before. Maybe I'll try adding a bit of air.
The 32mm tokens wont be available until late August.
I'm running the 120mm Bluto which doesnt come with any Pre-installed. The 100mm Bluto has 2 pre-installed and the 80mm version has 4, which is the max.
Okay- got the air shaft to convert my 100 Bluto to 120, plus the RCT3 Damper. Anyone have any info on the conversion? Oil volumes/ weights? The "service manual" link from the SRAM page for the Bluto doesn't even have the Bluto listed on it. Treat it like a SID?
20cc less than what? I just found the 2015 service manual and it lists the Bluto and the oil volumes are the same for it as they are for the SID (with the RCT3), so I'm going to follow those levels.
I will have to do this upgrade then. Have a 120mm Bluto coming on Sturgis Bullet, but swapping the Bullet to rigid and putting Bluto onto Bucksaw frame I ordered.
Fat907- what grease did you use on the Air Shaft? I have some Slick Honey, but the manual says only the RS/ SRAM Butter, or some military grease. Seems like for 20 less than stock on the damper side, you could just pull the old damper and insert the new one without changing fluids... For the air shaft, seems like I just need to remove the rebound adjuster knob and lower bolt on non-drive-side, drain oil, remove the lowers, remove the retaining ring, pull the air shaft out, grease up the new one and install the bumper and floating seals from the old one, and re-install, then add fluids. That's it?
As I understand it, every 10mm increased in fork extension equals ~1 degree decrease in head angle. So working from a 25% sag, compare that Bluto fork length to your stock fork length, consider how increased sag would affect the current feel of your bike, and go from there.
In my experience, more is not always better, especially when you are adding suspension to a frame that is not suspension corrected. Most fat bikes are not going to be suspension corrected unless they are a fairly new design...
My Lurch arrives tomorrow, I'm probably swinging toward 80mm, 100mm if I want a little slack.
Are the air shafts the same on the Reba and Bluto? I have a 100mm Reba and 120mm Bluto coming and was wondering if I could switch the Reba 10 120mm and the Bluto to 100mm by swapping them?
I’ve been running the Bluto around Moab for about 2 months. For me a front suspension fork was the one thing really preventing me from riding the fat bike in the dirt more. The Bluto really helps close the gap between just a snow bike and a bike I take on summer trails.
That said, I think it’s one of the worst feeling RS forks I’ve owned. With 90 psi well bellow the recommend pressure for my weight I find it’s super stiff and has tons of stiction. When I drop the pressure down to a point it moves on small to moderate size bumps it bottoms outs too easily.
I’m not very knowledgeable about suspension stuff. For those that are, do people think this is more of an issue related to the damper or rather a lack of lubrication?
I've been running the Bluto around Moab for about 2 months. For me a front suspension fork was the one thing really preventing me from riding the fat bike in the dirt more. The Bluto really helps close the gap between just a snow bike and a bike I take on summer trails.
That said, I think it's one of the worst feeling RS forks I've owned. With 90 psi well bellow the recommend pressure for my weight I find it's super stiff and has tons of stiction. When I drop the pressure down to a point it moves on small to moderate size bumps it bottoms outs too easily.
I'm not very knowledgeable about suspension stuff. For those that are, do people think this is more of an issue related to the damper or rather a lack of lubrication?
Are you running any tokens? Which Bluto model do you have?
I have the 120mm and it came stock with no tokens and I blew thru the travel and woudl bottom out hard on bigger drops. I now have two tokens installed and it is perfect. I was able to lower the pressure a bit which gives it even better small bump compliance, but it ramps up quicker and doesnt bottom as easy.
Running a 100mm Bluto on AL Beargrease for about two weeks now in Maine. Bunch of short rides and one good 25mile day up at Sugarloaf. Running around 85psi which is below recommended, still playing with pressure. Recommended was too stiff.
Haven't looked inside at the token assortment yet.
Next to my first set of disc brakes this might be the best bike upgrade ever for me, most likely will end up with a Bucksaw or King Kahn if that comes to production next year.
I went to 3 tokens total and that made a nice difference plus I am running a little lower pressure now. Before, 2 tokens and 100psi, now 3 tokens and 75 psi. I weigh 185 pounds and the ride has a nice plush feel without bottoming out easily.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
