Results 1 to 12 of 12
    Feb 2017
    Bluto/Big Jon Headset
    Hi everyone
    As I am new on here I hope I have posted in the right place. I need some help, I have a Scott Big Jon and just got a set of Bluto forks. I am having trouble regards the lower headset and crownrace etc. I am confused by size or would appreciate some ideas for something available in the UK. I understand the OD51mm/ID55mm bit but what about the crownrace size. I have seen these but not sure if they fit Ritchey WCS Headset Lowers Press Fit | Chain Reaction Cycles
    Thanks in advance
    since 4/10/2009
    Reputation: Harold's Avatar
    FWIW, you bought ONE Bluto FORK.
    crown race should come with the lower cup, assuming you're talking about replacing the headset lower cup. because otherwise, it's sorta headset specific, which crown race you need to use. for some, it's not hard to find new crown races. but others (especially OEM stuff) can be difficult.
    since 4/10/2009
    Quote Originally Posted by GiantTurd View Post
    He is in the UK, the term "forks" is correct.
    A lot of differences between UK/Can/US/Aus/NZ English are no big, but this particular use of plural when there is no plural is not one of those.
    Feb 2017
    New question here. Thanks but!
    He is in the UK, the term "forks" is correctly used.
    The linked headset looks correct.
    I know the HT 55-61 is correct but what does the ZS 55-40 mean or refer too.
    Dec 2016
    That went well
    Reputation: Misterg's Avatar
    Jul 2014
    Quote Originally Posted by VincentJackson View Post
    Rather than try and re-type the explanation, have a look here...
    Standardized Headset Identification System | Park Tool
    ..and all will be explained
    (Oh, and I'd say "forks" )
    turtles make me hot
    Reputation: NYrr496's Avatar
    Limeys...
    I like turtles
    Jul 2014
    Reputation: dbhammercycle's Avatar
    It's a fork with 2 tines. Sheesh. The Brits can be sticklers for proper English too, especially in an argument with an American.
    I don't know why,... it's just MUSS easier to pedal than the other ones.
    Dec 2016
    I guess it's a fork with two tines, to be pedantic
  1. Need Fat bike advise Bluto or no Bluto
    By brianbmw in forum Fat bikes
    Last Post: 07-12-2016, 03:23 PM
  2. Replies: 6
    Last Post: 07-27-2015, 10:17 AM
  3. Lower Headset race...new shock install..new headset??
    By Burt4x4 in forum Shocks and Suspension
    Last Post: 01-31-2014, 10:06 AM
  4. Threaded headset to threadless headset conversion
    By op12389 in forum Bike and Frame discussion
    Last Post: 08-01-2013, 04:20 PM
  5. Replies: 6
    Last Post: 11-19-2012, 04:58 PM
