Results 1 to 12 of 12
    Reputation: yxan's Avatar
    Bike will be so fat it will need its own zip code
    the first step towards mega fatty 190mm in da house!
    Bike shop needs a bigger truing stand
    Not many two-leg bicycle wheel stands will go over 175mm. Some motorcycle stands might.
    Feb 2012
    Quote Originally Posted by Andy FitzGibbon View Post
    double/custom extensions should do the trick, a machine shop should be able to make them easily enough.
    Seriously though, how can Fatback sell them if no-one can build them up - should they not be providing a solution along with the hub?
    Down South Yooper
    Reputation: Plum's Avatar
    Sep 2004
    Quote Originally Posted by yxan View Post
    No way to flip those extensions opposite? So that they curve away from the outer lock nut?
    Plum
    This post is in 3B, three beers and it looks good eh!
    Anchorage, AK
    Reputation: Lars_D's Avatar
    You can build wheels in the frame.
    --Peace
    Reputation: wrkgstiff's Avatar
    Feb 2012
    You can build your own truing stand. I bought Roger Musson's "Professional Guide to Wheelbuilding". In this invaluable book, he lays out a DIY truing stand that can be modified to build any size hub wheel. Just make the base wider and the slots to adjust for width longer. Simple. He charges ~$15 or so for his work. I highly recommend it. Even a doofus like me was able to build up two wheels without issues.
    Steel Fatback
    they are altering their stand I'm not worried
    29er
    Hadley made?
    Reputation: duggus's Avatar
    Quote Originally Posted by Dan GSR View Post
    Hadley made?
    Yuppers.
    Quote Originally Posted by tscheezy View Post
    Custom 190mm Hadley hubs:
    Dr Gadget is IN
    Reputation: wadester's Avatar
    Quote Originally Posted by Plum View Post
    Plum
    You have to drill out the holes on the "outside" and add some flat washers for the QR - but then you find that the nice curve on that side hits the freehub and the disc mount, so you have to cut some metal away:
    Bike will be so fat it will need its own zip code-658712d1323454655-moonlander-clownshoe-landing-commence-img_1738s.jpg
    Actually, I think buying a latest version Park truing stand (which is the same as the old one with adapters) and then using the adapters would cover it.
    This isn't a "you're doing it wrong" topic.
    WSS/OSS: Open Source Sealant
    Reputation: Greenfin's Avatar
    looks great
    Still cleaning my Fatback.
    It's a life style.
    $15 worth of material, a bit of time, and if needed, throw a 12 pack at a welder ... Truing stand complete, minus paint.
    Glad to hear the OP's shop is modifying their stand to accommidate this hub ... They only need to do it once.
  1. Bike Wheel Warehouse Coupon Code
    By c_trail_biker in forum Where are the Best Deals?
    Last Post: 03-07-2013, 10:16 AM
  2. Replies: 18
    Last Post: 11-06-2012, 03:13 AM
  3. Tree Fort Bike Coupon Code?
    By illcomm33 in forum Where are the Best Deals?
    Last Post: 07-10-2012, 10:51 AM
  4. Differences between 2012 code and code r?
    By 99sf in forum Brake Time
    Last Post: 01-28-2012, 06:08 AM
  5. bike bling code?
    By mimi1885 in forum Where are the Best Deals?
    Last Post: 07-15-2011, 03:25 PM
