Page 1 of 7 12345 ... LastLast
Results 1 to 25 of 174
    9:zero:7
    Reputation: Morej's Avatar
    Oct 2011
    Bike specs with pics
    I wanted to start a thread where everyone can publish a picture of their bike with the specs of components. Would be a big help to the ones who just planning to build a bike, and can provide owners with some good ideas. I know it took me a while to figure out what components to purchase, and even than I had to replace a few parts right away when the build started.
    Only the dead fish swims with the current!
    9:zero:7
    Oct 2011
    So here is one to start: 9:zero:7 2012 XL alu
    frame - 9:zero:7 170mm XL
    fork - White Brothers Snowpack
    rims - Surly Large Marge Lite Rim
    tubes - Q-Tubes Superlight 26" x 2.4-2.7" 32 mm Presta Valve Tube
    tires - Black Floyd 120tpi
    spokes - DT-Swiss Champion 2.0 black
    niples - DT-Swiss red
    scewers - Salsa
    headset - Cane Creek s-8
    handlebar - FSA Gravity
    grips - Odi Rogue lock on
    stem - Azonic Barretta
    seatpost - Thomson setback
    seat clamp - Salsa Lip-Lock 35.0mm Red
    saddle - WTB Rocket V Race
    disc brake system - Hayes Prime Expert black
    front hub - Hope pro 2 red
    rear hub - Hope pro 2 red
    bottom bracket - FSA Platinum DH 100mm ISIS
    crank set - FSA Alpha Drive ISIS
    pedals - Wellgo MG-1
    cassette - SRAM PG1070 11-36
    chain - KMC X10SL-Ti
    bashguard - BBG
    shifters - SRAM X.9
    front derailleur - Shimano XT
    rear derailleur - SRAM X9 red CARBON 10 SPEED med CAGE
    Attached Thumbnails Attached Thumbnails Bike specs with pics-542028_4018867869520_1216083657_3936184_1248928329_n.jpg
    Reputation: Tibor's Avatar
    my Surly Pugsley 20" (2012)
    frame - Surly Pugsley 20"
    fork - Surly Pugsley Offset 135mm
    rims - Robsson 26"x80mm 36h
    tubes - VeeRubber 21" Motorcycle Tubes
    tires - Surly Larry 3.8" 27tpi
    spokes - Sapim D-Light
    niples - Sapim plus Sapim Nipple Washers
    scewers - NC17 red anodized
    headset - Octane One Warp 1
    handlebar - Spank Tweet Tweet 70mm rise
    grips - Clarks Lock-On Red
    stem - FUNN Rippa 25.4
    seatpost - SARS red anodized 27.2mm 450mm long
    seat clamp - Surly Stainless Steel Seatpost Clamp
    saddle - Selle Royal Ellipse Athletic
    disc brake system - Avid Elixir 5 with Shimano 160mm rotor & Avid 160mm rotor
    front hub - Quando TX SS 135mm (copy of the Hope Pro Evo 2 SS) black (19tooth sprocket)
    rear hub - Shimano Alfine 8 silver (22tooth sprocket)
    bottom bracket - Truvativ Team DH
    crank set - NC17 DH + 38tooth chainring
    pedals - NC17
    cassette - none just 22t and 19t sprockets
    chain - KMC Premium Chain
    bashguard - NC17
    shifters - Shimano Alfine Trigger Shifter
    drev-il, not Dr. Evil!
    Reputation: Drevil's Avatar
    Vertigo Cycles Titanium Fat Bike
    frame - Vertigo Cycles Titanium with Paragon sliding dropouts (custom geometry)
    fork - Lefty with MCS-designed offset clamps
    rims - Surly Marge Lite (stripped off black anodization)
    tubes - Specialized 29" x 2.1" tubes
    tires - depends, but usually Surly Nate 120tpi front and 45NRTH Husker Du rear (or both)
    spokes - Phil Wood tapered on the front, DT tapered on the rear
    nipples - Brass (whatever they come with)
    skewers - Project 321 aluminum bolt for the front, Salsa 170mm rear
    headset - Chris King: upper inset cup, 44mm bottom cup (Chris King InSet)
    handlebar - Jones titanium Loop bar
    grips - Oury Chocolate Kiss
    stem - Thomson X4, 90mm, 10deg, pointed down
    seatpost - Eriksen Titanium Sweetpost, 30.9mm, 450mm long
    seat clamp - Salsa bolt-on
    saddle - Specialized Phenom 143 in brown
    disc brake system - Shimano XTR Trail w/ 185mm Avid front rotor and 160mm rear rotor
    front hub - Project 321 Lefty in silver
    rear hub - Fatback/Hadley 170mm in silver
    bottom bracket - Phil Wood Titanium, 100mm shell x ??mm spindle
    crank set - Middleburn RS-7 with 30T Surly 5-bolt
    pedals - XTR
    cassette - at the moment, singlespeed. Either 18T Endless or 19T King steel
    chain - SRAM PC-971
    bashguard - Salsa Tooth Fairy
    shifters - at the moment, none. When I do, I have Paul thumbies with IRC perches waiting.
    Derailleurs - none mounted, but that nub on the seat tube is a direct mount for an XT direct mount front derailleur sitting in a box in the basement, along with an XTR rear derailleur.
    I'm 5'8.5" w/ 32.5" inseam, and I wanted to be upright-ish so I spec'd a 23" top tube.
    "Keep your burgers lean and your tires fat." -h.d. | bikecentric | ssoft
    Fat & Single
    Reputation: ozzybmx's Avatar
    frame - Salsa Mukluk
    fork - Salsa enabler
    rims - Graceful; Fat Shebas
    tubes - Surly fat tubes
    tires - Surly Endomorph/Larry 27tpi's
    spokes - DT Champion
    nipples - DT alu
    skewers - Salsa 170mm rear, Hope 135 front
    handlebar - Salsa MotoAce 17d backswing
    grips - Ergon GX1
    stem - Thomson 90mm
    seatpost - Thomson 27.2 400mm
    seat clamp - Salsa
    saddle - Selle Italia SLR flow
    disc brake system - BB7
    front hub - Hope fatsno 135mm
    rear hub - Salsa 170mm
    bottom bracket - Truvativ 100mm
    crank set - Truvativ Hussefelt with 33t Rotor Q ring
    pedals - TIME XS Carbon
    cassette - XT 11-32 9speed
    chain - SRAM PC-971
    shifters - XT
    derailleurs - Xt Shadow rapid rise
    weight - 15.2kg or 33.5 lbs
    Feb 2012
    Surly Pugsley 18" (2012)
    frame - Surly Pugsley 18"
    rims - Vicious Cycles - Graceful Fat Sheba
    tubes - Surly
    tires - Origin-8 Devist-8er
    spokes - DT comp
    niples - DT Alloy
    skewers - Shimano
    headset - FSA Fat Pig
    handlebar - Truvativ Holzfeller
    grips - ODI Lock-On white
    stem - Ritchey Comp 100mm
    seatpost - FSA SL280
    saddle - Bontrager
    disc brake system - Avid BB7 160mm rotor
    brake levers - Tektro
    front hub - Shimano FH-R505 (cheap, but heavy)
    rear hub - Shimano Nexus Inter-3 (19tooth sprocket)
    bottom bracket - Raceface X-type DH 100mm
    crank set - Raceface Diabolus 175mm
    pedals - Shimano 324
    cassette - n/a
    chain - KMC white
    shifters - Shimano Nexus grip 3-speed
    Reputation: vmaxx4's Avatar
    Frame - Salsa Mukluk, Aluminum Alloy, Anodized Finish - XS
    Fork - Lefty with MCS-designed offset clamps in Spring/Summer/Fall - Salsa Enabler, 135mm Spacing w/ ED Coat Finish - in Winter
    Rims - Surly Rolling Darryl w/ Holes, Black, 32H
    Tubes - Q-Tubes Superlight 26" x 2.4-2.7" 32 mm Presta Valve Tube
    Tires - Surly Larry 120tpi front and Endo 120 tpi rear in Summer/Fall - Surly BFL front and Surly Nate rear in Winter/Spring.
    Skewers - Project 321 aluminum bolt for the front, Salsa 170mm rear
    Headset - Cane Creek 40-Series, TR, Black
    Handlebar - Salsa Pro-Moto - Carbon - 11 Deg
    Grips - Cannondale
    Stem - Titec - Pro-lite - 100mm inSpring/Summer/Fall - 90mm SunLine in Winter
    Seatpost - Easton EA - 90 - Carbon
    Seat clamp - Salsa Lip-Lock, Red
    Saddle - WTB Pure V
    Brakes - Avid BB7 Avid 160mm front/rear rotor - Avid speed dial 7 levers.
    Front hub - Project 321 Lefty, Red - Spring/Summer/Fall - Salsa Enabler, 135mm Spacing, 32H, Red - Winter.
    Rear hub - Salsa Mukluk 2, 170mm Spacing, 32H, Red
    Bottom bracket - E-13 30mm External Bearing
    Crank set - E - 13 - 22/32 - 170mm crank
    Pedals - Time - ATAC Carbon
    Cassette - Sram PG - 990 11-32 - red
    Chain - SRAM PC - 991
    Bashguard - BBG - 104 BCD Drilled - 32
    Shifters - Sram X0 - Trigger
    Front Derailleur - SRAM X.7, 3-Speed, High Direct Mount
    Rear Derailleur - SRAM X.9, 9-Speed, Long Cage, Gray
    Accessories Bar Mitts in Winter and Custom Planet Bike 29er fenders in Spring/Fall
    Single Speed Junkie
    Reputation: crux's Avatar
    Quote Originally Posted by vmaxx4 View Post
    Don't know why, but I think the lefty look better on a fat bike than most anything else.
    Sandman Atacama M (2011)
    frame - Sandman Atacama
    fork - Surly
    rims - Trialtech SL
    tubes - Schwalbe 3.0
    tires - Surly Nate, Surly Larry
    spokes - DT comp
    niples - DT Messing
    skewers - front superstar comp, rear self made 12mm axle to QR
    headset - Ritchey
    handlebar - 3T
    grips - Ergon
    stem - 3T
    seatpost - 3T
    seat clamp - Miche
    disc brake system - Brake Force One 180/160
    front hub - Superstarcomponents (Rubisch)
    rear hub - 165mm Sun Ringle Lawwill
    bottom bracket - E-13
    crank set - E-13 (removed 44t)
    pedals - Exustar
    cassette - XT 12-36
    chain - XT
    shifters - SLX 10 speed
    9:zero:7
    Oct 2011
    Anyone else?
    Reputation: coastkid71's Avatar
    There was a thread started in the beginning of the forum for this by Big Hit titled `Post your fat bikes`.
    It dissapeared down the pages when the `Daily fatbike pic` thread was started and that became more popular. I did ask for it to become a sticky but it never did.
    A pity has it has all the original members bikes on here and a lot of stuff i have not seen for a while, like `Pugdozer` and `Panzer Pug` and Doc Feelygoods creations
    plan it...build it....ride it...love it....
    http://coastkid.blogspot.com/
    Chronic Underachiever
    Reputation: MauricioB's Avatar
    Oct 2007
    Ruby
    9:Zero:7 L (2010)
    frame - 9:Zero:7
    fork - Surly 100mm OLD
    rims - 70mm Speedway UMA II
    tires - Surly Big Fat Larry, (F) Surly Endomorph (R)
    tubes - Specialized 3.0
    spokes - Wheelsmith butted
    niples - Brass
    skewers - Shimano XT
    headset - Cane Creek S2
    handlebar - Titec H-Bar
    grips - Ergon
    stem - Ritchey WCS
    seatpost - Easton Havoc
    seat clamp - Hope
    saddle - WTB
    disc brakes - BBDB with 160 rotors
    brake levers - Avid Speed Dial
    front hub - Shimano Deore XT M755
    rear hub - Shimano Deore XT M756
    crank set - Origin 8 Sub Compact ISIS
    pedals - Crank Brothers Mallet 2
    shifters - Shimano 8-speed bar ends on Velo Orange Thumbies
    front derailleur - Shimano XTR E-type
    rear derailleur - Shimano Deore DX medium-cage
    cassette - XT 12-32
    chain - Sram PC48
    Rednose/Greenback
    Reputation: apbtlvr's Avatar
    greenback
    It's 96° in the shade right now (thus the deck shots) but here's the greenback in dusty summer attire.
    Frame: Fatback Alu 18" Green (late 2011 design)
    Fork: Fatback steel fork
    Rims: Fatback UMA II 70mm 26"x32H
    Tubes: Q-Tubes Super Light 26" x 2.4-2.7"
    Tires: Surly Larry 26x3.8" Tire 120tp
    Spokes: DT double butted, 265mm all around
    Nipples: brass
    Skewers: Fatback Ti 135mm/ 170mm Black
    Headset: Cane Creek 110 TR 1 1/8" Threadless 34mm
    Handlebar: Salsa Bend Bar 2 17 Degree 31.8 720mm
    Grips: Ergon GP1-L Twist Shift
    Stem: Thomson X4 Mountain 31.8 100mm 100 Degrees Black 1-1/8"
    Seatpost: Thomson 31.6 x 410mm Setback Black
    Saddle: WTB Pure V
    Disc Brakes: Avid BB7 Mtn 160mm G2 Rotor
    brake Levers: Avid FR-5
    Front Hub: Fatback Hadley Front Disc, 135mm, 32H, Black
    Rear Hub: Fatback Hub Hadley Rear Disc, 170mm, 32H, Black
    Crank Set: e*thirteen (Hive)100mm Spindle 175mm Crank with BB 22/32/ (44 removed)
    Bottom Bracket: Included w/ crank set
    Pedals: Wellgo B132
    Cassette: SRAM PG-970 11-32 9 speed Cassette
    Chain: SRAM PC-971 9-Speed Silver/Gray Chain with Powerlink
    Bashguard: TruVativ Stylo Mtn 32/33t 104 Bcd 4mm
    Shifters: SRAM X.0 3 x 9 Speed Twist Shifter Set
    Rear Derailleur: SRAM X.0 9-Speed Long Cage Rear
    Front Derailleur: SLX M660 E-Type Top- swing Dual-pull Front
    Cables (Brake & Derailleurs): Jagwire Ripcord
    Incidentals:
    Rear Rack: Old Man Mountain Sherpa
    GPS mount is for a Garmin eTex 30
    Wire mounted Sigma BC-1009 for basic odometer functions since I don't need GPS all the time.
    Revelate Designs (Large) Gas Tank Bag- is triple fabulous
    The seat bag is an older version Jandd Mountain Wedge.
    38° 54' -77° 15
    Geordie biker
    Reputation: saltyman's Avatar
    current spec (21/6/2012)
    Frame: 20'' 4130 CroMoly steel
    Fork: moonlander 135mm O.L.D.
    Headset: cane creek
    Stem: 110mm
    Handlebar: moots Ti 8 degree sweep
    Grips: pink ESI racers edge
    Brakes: avid BB7
    Brake levers: Avid SD-7
    Brake Pads: formula sintered gold
    Brake Discs: alligator 203mm front and rear
    Shifters: micro shift thumbshifters Model SA-109
    Front Derailleur: Shimano SLX, M661
    Rear Derailleur: Shimano Deore, M591-SGS
    Cassette: Shimano HG-61, 9-speed 11-12-14-16-18-21-24-28-34t
    Chain: SRAM PC-971
    Cranks: Surly Mr. Whirly Offset Double, 22/36t
    Bottom Bracket: Hope (red)
    Pedals: nukeproof electron
    Hub Skewers: XT
    Rims: Surly Clown Shoes, Single wall aluminum
    Hubs: Shimano XT 135mm, M756
    Tyres: Surly Big Fat Larry, 26 x 4.7" 120tpi
    Saddle: brooks B17 copper rivets, special
    Seatpost: Moots cinch layback, 27.2mm
    Seatpost Binder: Hope (red)
    Weight: 35.3 lbs
    complete current costs to date:
    bike £2,025 (posted)
    extras:
    hope BB £90
    brake upgrade £76.08
    bars £148.85 (including custom charges)
    post £268.88 (including custom charges)
    grips £11.05
    seatclamp £18.79
    saddle £55.84
    chainstay protector £6.65
    spare tube £13.59
    cages £19.14
    crudcatcher £6.99
    pedals £32
    surly nate tires x4 £359.96
    repairs and bits and bobs:
    £67.46
    total: £3,200.28
    moonlander - miles 1,925
    www.ukfatbikes.co.uk
    Nov 2008
    Surly Pugsley Neckromancer
    Cross-posted in Beach Thread:
    Mostly stock Surly Pugsley Neckromancer:
    Frame: Surly Pugsley
    Fork: Surly Moonlander
    Crankset: Surly Mr. Whirly , Offset Double 22/36t
    Front Derailleur: Shimano SLX E-Type
    Chain: SRAM PC-971
    Headset: Cane Creek 40
    Brakes: Avid BB7
    Brake Levers: Avid FR-5 , Black
    Shift Levers: Microshift Thumb Shifters, 9 speed. These are super rad.
    Stem: Thomson Elite, 25.4mm bar clamp
    Handlebar: Salsa MotoAce , 660mm. 17°
    Saddle: Specialized Phenom Comp
    Seatpost: Thomson Elite 27.2
    Front Hub: Surly New 135mm disc , 32h. 135mm. Unthreaded.
    Rear Hub: Shimano Deore , M525. QR. 32h.
    Rims: Surly Rolling Darryl , 32h. 82mm width. Black. No cutouts
    Front Tire: Surly Larry , 3.8"
    Rear Tire: Surly Endomorph , 3.7"
    Pedals: Fyxation MP nylon with sealed bearings
    Grips: Specialized Rocca lock on
    Extras:
    Specialized saddle bag
    Salsa Anything cages
    Specialized bottle cages
    36.5 pounds
    Reputation: smthgfshy's Avatar
    All weights measured by me, at home, in grams.
    Frame: 907, med, 170mm - 1887
    Fork: Carver O'Beast - 572
    Front Wheel: Uma70, Salsa Enabler, DT Comp-2Butted, alloy nips, tape - 1320
    Rear Wheel: Uma 70, Salsa Muk2, DT Comp-2Butted, alloy nips, tape - 1543
    Seatpost: Q2 -180
    Saddle: Terry Liberator Race - 265
    Seatclamp: Salsa liplock - 32
    Grips: Ergon GP1-L - 197
    Handlebar: Easton EC70 - 159
    Stem: Raceface Turbine, 100mm - 139
    Headset: Cane Creek 110 - 113
    Compression Plug: Carver - 23
    BB: Raceface X-type - 121
    Crank: Raceface Atlas - 753
    Pedals: VP alum - 352
    Cassette: SRAM 980 - 305
    Chainring: Raceface single, 34T - 36
    Bashgaurd: BBG - 55
    Derailleur: SRAM X9 - 207
    Chain: SRAM 991, 11-34T - 300
    Shifter: SRAM XO - 102
    Tires: 49Nrth HuskerDu - 2480
    Tubes: QTubes SL - 460
    Brakes/levers: BB7/SD7, 185mm - 797
    28.56 lbs
    Mar 2012
    Frame and fork: Surly Moonlander
    Derailers: XT 10 speed
    Shifters: XT
    Brakes: Formula RX with red spider
    Bar: Salsa
    Grips: Salsa
    Stem: Thomson Elite X4
    Sadle: Fizik Aliante Versus
    Rims: Surly Clownshoe
    Tires: Surly BFL (Big Fat Larry); Toobs: Surly Toobs
    Hub front: Surly
    Hub rear: XT
    Cassette: XT
    Chain: XT
    Cranks: Surly MWOD (Mr. Whirlie Offset Double)
    BB: Chris King
    Headset: Chris King
    Skewers: Salsa
    Seatpostclamp: Salsa
    Pedals: DMR Vaults
    Bottlecage: Tacx
    Reputation: Outsider's Avatar
    Salsa Mukluk 2012:
    - Salsa Mukluk 3 frame size XL with an FSA Alphadrive ISIS crankset (22/32/bash ring).
    - Surly Rolling Darryl rims with DT Competition spokes on Salsa 135/170 mm hubs, winter wheel set.
    - Surly Larry tires.
    - Onza Mtb FR inner tubes.
    - Avid Elixir 1 hydraulic disc brakes with 185 /160 mm discs.
    - Shimano M520 SPD pedals.
    - SRAM X.9 9-speed trigger shifters.
    - SRAM X.0 medium cage rear derailleur.
    - Shimano XT direct mount front derailleur.
    - Sunrace 11-32 cassette.
    - Sunrace 9-speed chain.
    - Salsa Pro Moto 2 seat post.
    - Rido R2 saddle.
    - Cane Creek 40 EC34 headset.
    - Race Face Deus XC 3/4 Rizer 680 mm handlebar.
    - Easton EA30 105 mm stem.
    - Ergon GX1 grips.
    A second lighter wheel set for summer use currently waits for the Hope Pro Evo 2 170 mm hub set to arrive at Foxcomp. I already have a pair of 47 mm Trialtech SL Rear rims waiting at home. The idea is to use the Larry tires on the summer wheel set and the Big Fat Larry on the winter wheel set.
    My bike blog: www.yetirides.com
    Dec 2011
    hi, new guy here. I got my Pugs in December and have been riding daily since. Love it.
    stock build
    Brooks saddle
    Fyxation pedals + straps
    Gamoh rack
    strap on fender
    I plan to break it down and frame-saver it before winter, and plan to do some component/color customization then. we'll see.
    Reputation: bighit's Avatar
    Awesome thread. I can't wait to get another fat bike.
    bikeboatbrewski
    Reputation: scottybinwv's Avatar
    Jun 2010
    Moar porn from last year
    One Colorful Rider
    Reputation: Normbilt's Avatar
    2012 9:ZERO:7 170
    907 side shot
    907 Top Tube
    Frame:2012 9:ZERO:7 170 Small
    Fork: White Bros Snowpack
    Front Wheel: Pauls FHUB / Marge Light / Wheelsmith White DB Spokes Black AL Nips White Rim Liner
    Rear Wheel: Hope 170 / Marge Light / Wheelsmith White DB Spokes Black AL Nips White Rim Liner
    Seatpost: Ritchey WCS One Bolt
    Saddle: SDG Belair Ti
    Grips: Bontrager SSR
    Handlebar: Ritchey WCS Riser Wet White
    Stem: Ritchey WCS
    Headset: HOPE
    Compression Plug: HOPE Head Doctor
    BB: FSA 100 ISIS
    Crank: Race FACE Next LP's Bad Ass Black
    Pedals: Shimano XTR
    Cassette: SRAM 1070 12-32
    Chainring: Raceface single, 32T
    Bashgaurd: SPOT
    Derailleur: SRAM X9 10 Sp
    Chain: KMC XL Gold 10Sp
    Shifter: SRAM X9 10 Sp
    Tubes: Bontrager 26x2.80
    Brake Levers: AVID Ultimate Levers
    Brakes AVID BB7
    Reputation: kyttyra's Avatar
    Mar 2012
    In the bedroom:
    Hiding in the reeds (I was making a path for the upcoming Fixedcross event:
    Frame: Surly Pugsley 20"
    Fork: Surly Pugsley
    Headset: Cane Creek Forty EC34
    Spacers: carbon
    Stem: Ritchey WCS c260 90 mm
    Handlebar: FCF Riser 7005 700 mm
    Grips: Ritchey WCS Truegrip
    Shifter: Shimano Alfine trigger
    Brakes: Avid Elixir 1 185/160 mm
    Spokes/Nipples: DT Swiss Champion*/DT Swiss Brass
    Hubs: Surly Rear Disc 135 mm/Shimano Alfine 8 with 22 sprocket
    Rim tape: Surly 64 mm
    Tires: Surly Black Floyd (summer tyres)**
    Tubes: Onza FR 26 x 2.5
    Crankset: FSA Alpha Drive Isis 175 mm, Salsa 32T chainring
    Bottom bracket: FSA Platinum DH Isis 100 mm
    Pedals: Shimano M540
    Chain: KMC Z410 1/8
    Seat clamp: Hope
    Seatpost: SDG I-Beam
    Saddle: SDG Formula FX
    Weight: 14,76 kg (≈32,54 lbs)
    *should have been DT Competitions, but LBS made an error. I said I can live with the 60 g weight penalty
    **1020 and 1060 g
    What else? I'm 191 cm tall, but at least half of it is legs. Thus the 20" frame with relatively short stem.
    Reputation: Fat Bob's Avatar
    Quote Originally Posted by benswift View Post
    stock build
    Brooks saddle
    Gamoh rack
    strap on fender
    Love this, so utilitarian! That rack is pretty sweet
    Frame: 2010 Surly Pugsley 18"
    Fork: Surly Offset
    Front Wheel: Surly Hub / Rolling Darryl / Wheelsmith DB Spokes Black brass Nips Zebra striped rim strip
    Rear Wheel: Shimano M529 / Rolling Darryl / Wheelsmith DB Spokes Black brass Zebra striped rim strip
    Seatpost: Easton EA90
    Saddle: Bontrager SSR
    Seatclamp: Salsa fliplock
    Grips: Ergon GC2
    Handlebar: On-One Mary, white
    Stem: Kona
    Headset: FSA Orbit
    BB: Truvativ Howitzer
    Crank: Truvativ Holzfeller
    Pedals: Fyxation Mesa
    Cassette: SRAM PG990 11-34
    Chainrings: 34T Salsa, 22T Truvativ
    Bashgaurd: Salsa Ring Dinger
    Rear Derailleur: SRAM X9 9 Sp
    Chain: KMC X9.99
    Shifter: SRAM X0 9spd
    Tires: 45Nrth HuskerDu/Surly Endo (and Black Floyds for street)
    Tubes: QTubes 2.4-2.7
    Brake Levers: AVID Elixir R
    Brakes: AVID Elixir R
    Rotors: Ashima 160mm
    Jason
    Disclaimer: www.paramountsports.net
Hot Deals
Contests
Latest Mountain Bike Articles
