Page 2 of 7 FirstFirst 123456 ... LastLast
Results 26 to 50 of 174
  1. #26
    Reputation: NOBBY605's Avatar
    2012 XL 907
    Clownshoes laced with DT Champion 1.8-2.0 spokes
    Paul WHUB front hub
    Hope rear hub
    BFLs light casing
    Sram PG-1070 Cassette
    Salsa Bend 2 bars
    Thomson stem and seatpost
    SRAM XO 10sp gripshift, brakes, and rear derailleur
    XTR direct mount FR Derailleur w/Problem Solvers direct mount adapter
    KMC X-10 sl chain
    Selle Italia Saddle ti rails
    Carver carbon fork
    Cane Creek 40 headset
    FSA Carbon Team Issue cranks with FSA BB
    Xpedo Stainless/chromo pedals
    Revelate Jerrycan bag
    Attached Thumbnails Attached Thumbnails Bike specs with pics-phone-july-18th-034.jpg
  2. #27
    more than Hawg's
    Reputation: nvphatty's Avatar
    Mar 2012
    Quote Originally Posted by NOBBY605 View Post
    2012 XL 907
    nice rig...under 30lb without the bag n bottles??
  3. #28
    yes...not bad for BFLs and C-Shoes
  4. #29
    9:zero:7
    Reputation: Morej's Avatar
    Oct 2011
    Nice built...
    Only the dead fish swims with the current!
  5. #30
    Reputation: wrkgstiff's Avatar
    Feb 2012
    Steel Fatback
    Steel frame, 18"
    Steel fork, with anything mounts
    Frame Saver applied to frame and fork
    Hadley hubs and Ti Skewers
    UMA III 70mm Rims
    Shimano XT Front Derailleur
    SRAM X.9 Twist shifters
    Husker Du Tires, tubeless
    WTB Volt Saddle
    FSA XC 190 Handlebar 630mm width
    FSA XC 190 Stem
    Avid BB7 Mechanical / FR 5 Levers 180mm Front Rotor, 160mm Rear Rotor
    SRAM X.9 Rear Derailleur
    FSA / Fatback Cranks and BB (22,32,Bashguard)
    FSA Internal Headset
    FSA Chain
    SRAM 950 Cassette 11-34
    DMR Vault Platform Pedals
    Ergon GP-1 Twist Shifter Grips
  6. #31
    Reputation: bdundee's Avatar
    frame - Fatback med
    fork - Fatback carbon
    rims - Uma 90's
    tubes - None
    tires - BFL 120tpi
    spokes - DT-Swiss Comp 2.0 1.8
    niples - Brass Black
    scewers - Salsa
    grips- Crank Brothers
    seatpost - Thomson setback
    seat clamp - Specialized
    saddle - WTB Pure V Ti rails
    disc brake system - Formula RX
    front hub - Jeff Jones 135
    rear hub - Salsa 170mm
    bottom bracket - Chris King
    crank set - Fatback
    pedals - Wellgo MG-1 (now) Spd 540's summer use
    cassette - XT770
    chain - Sram 991
    bashguard - Salsa Ring Dinger
    shifters - XT 770
    front derailleur - Sram something direct mount
    rear derailleur- XT 770 med cage
    Headset- Cane Creek 110
    Stem-Thomson 90mm
    Handle Bars- Salsa Pro Moto carbon flat (now)
    30.5lbs
    29.5lbs with Rolling Darryls and Husker Du's.
    B/O is my friend!
  7. #32
    Quote Originally Posted by bdundee View Post
    frame - Fatback med
    rims - Uma 90's
    tubes - None
    tires - BFL 120tpi
    scewers - Salsa
    crank set - Fatback
    cassette - XT770
    chain - Sram 991
    shifters - XT 770
    Stem-Thomson 90mm
    30.5lbs
    How many cogs were you able to run with that crankset and the 90/BFL combo? Thanks
    Latitude 61
  8. #33
    Quote Originally Posted by sryanak View Post
    8 with no tire rubbing.
    B/O is my friend!
  9. #34
    Reputation: Allthatjazz's Avatar
    Oct 2012
    The way a bike should be
    Great looking bike
    I am in love
  10. #35
    Reputation: gcappy's Avatar
    Here is mine.
    Gene’s Fat Bike Build Specs
    1) 9-ZERO-7, 170, CENTERED, LARGE FRAME, BLACK
    2) 9-ZERO-7 REAR HUB, BLACK
    3) AVID X7 HYDRAULIC BRAKES
    4) ASHIMA 160 BRAKE ROTORS, RED CENTERS
    5) BONTRAGER SADDLE, BLACK, RED TRIM
    6) CANNONDALE LEFTY FORK, BLACK & RED, (RED COMING SOON)
    7) CANNONDALE LEFTY FRONT HUB, BLACK
    8) FSA CARBON STEM, BLACK, RED TRIM
    9) FSA HEAD SET, RED
    10) ODI LOCKING GRIPS, LARGE, BLACK, RED CLAMPS
    11) RACE FACE CARBON SEAT POST, BLACK
    12) SHIMANO M540 PEDALS, OOPS, NOT BLACK, HAD THEM HANGING AROUND
    13) SHIMANO XTR FRONT DERAILLEUR
    14) SHIMANO XT REAR DERAILLEUR
    15) SHIMANO XT SHIFTERS, 2 X 10
    16) SHIMANO 10 SPEED CHAIN OOPS, NOT BLACK
    17) SRAM TRUVATIV NDR T30 CARBON BAR, BLACK, RED TRIM
    18) SRAM 11 X 36 10 SPEED CASSETTE
    19) SURLY BIG FAT LARRY TIRES, 4.7 IN.
    20) SURLY CLOWNSHOE 100 MM RIMS, BLACK, BLACK SPOKES, RED NIP’S
    21) SURLY MWOD CRANK SET, 175 MM, BLACK
    22) SURLY RIM STRIPS, RED
    23) SURLY TUBES FOR A FEW DAYS, (GOING TUBELESS NEXT WEEK)
    Attached Thumbnails Attached Thumbnails Bike specs with pics-thule-rack-mod13.jpg
  11. #36
    Oct 2012
    Nice !!!!
  12. #37
    more than Hawg's
    Mar 2012
    Frame: Surly Pugsley 18"
    Fork: WB snowpac
    Headset: Chris King nothreadset
    Stem: Ritchey 4 axis
    Handlebar: FSA afterburner riser bar
    Grips: Race Face strafe lock-ons
    Shifter: SRAM X9
    Derailleur: SRAM X9 med cage
    Brakes: Hayes stoker trail F/R
    Disc: Magura storm SL 160 F/R
    Rims: Surly marge lites
    Spokes/Nipples: DT Swiss Comp/DT Swiss Brass
    Hubs: Paul WHUB / Chris King 135 ISO QR
    Rim tape: White vinyl material
    Tires: Origin8 Devist8er UL
    Tubes: Q-tubes UL 2.4-2.7
    Crankset: Race Face Atlas
    Bottom bracket: Race Face
    Pedals: VP components
    Chain: SRAM PC 991
    Cassette: SRAM PG990 11/34
    Seat clamp: Salsa lip lock
    Seatpost: Race Face turbine
    Saddle: WTB speed
    Brake / Shifter housing: Jagwire MAXXIS orange
    Custom Surly rim decals
  13. #38
    Nov 2007
    Hey nvphatty. That's been put together with a lot of thought. Probably the most attractive Snowblind Pug I've seen. Awesome!
    Cheers
    FatMuz
  14. #39
    Fat & Single
    Reputation: ozzybmx's Avatar
    Very nice nvphatty, looks awesome !!!
  15. #40
    Oct 2012
    I would hate to get her dirty :-))
  16. #41
    Nvphatty - looks like you have 2 rings up front? Why no front der? And like others have said, very nice Pug
    Do you have any idea about the final weight?
  17. #42
    more than Hawg's
    Mar 2012
    Quote Originally Posted by russmu66 View Post
    Cheers
    FatMuz
    Yessir it was thank you kindly.
    @ ozz as you know it's been a long journey but ended up pretty sweet for my 1st fat. thank you.
    When i first began the research and part collection process it was with 1x9 in mind but i realized that my desire to use this bike as i do my full squishy 26er it would take a spider ring gear so i addded it late in the game and thought when the time comes to change it'll be done manually, ie stop and move it by hand so i still have a derailleur with me at all times it's just connected to my body.. As for weight i don't but that was also part of the equation when it started and i wanted it to be 30lbs when done, i'll know soon.
  18. #43
    Pretty awesome fat bike!
    2013 Epic Expert Carbon Evo R
    2012 Specialized Stumpjumper FSR Expert Carbon 29r
    2012 Ventana El Rey
  19. #44
    Bicycle Obsessed
    Reputation: jpettit's Avatar
    Dec 2011
    Surly Pugsley
    surly pugsley - front end by johnpettit, on Flickr
    surly pugsley - grassland by johnpettit, on Flickr
    Whole set can be found at Surly Pugsley - a set on Flickr
    Cable Housing: Gore Ride-On Sealed Low Friction System
    Bottom Bracket: Phil Wood 100mm Stainless Steel - JIS 145mm (1.37x24t)
    Bottom Bracket: Phil Wood Mud Guards
    Chain: SRAM PC-7X Singlespeed Chain (1/8")
    Crank: Middleburn RS7 Uno Crankset 170mm w/ 34t singlespeed chainring
    Pedals: Straitline SC Platform Pedal 2012
    Shifters: Shimano Alfine Rapidfire Plus 11
    Frame: Surly Pugsley w/ 135 mm fork
    Handlebar: Soma Clarence Bar 25.4mm
    Handlebar Grips: ODI Oury Lock On Grips
    Headset: Chris King NoThreadSet Griplock 1-1/8
    Saddle: Soma Kyudo Saddle
    Seatpost: Soma ZO 27.2mm x 350mm
    Seatpost Clamp: Straitline Seat Clamp 2012
    Stem: Soma Shotwell 100mm x 25.4mm
    Wheel - Hub - Front: Surly 32H Rear 135mm QR Disc
    Wheel - Hub - Rear: Shimano Alfine 11 speed 32H
    Wheel - Hub - Rear Cog: Shimano Alfine 20t
    Wheel - Rim: Surly Rolling Darryl 82mm - with cutouts (x2)
    Wheel - Rim Strip: Surly PVC rim strip 64mm for Darryl wheel (x2)
    Wheel - Skewers: Hope Rear 135mm
    Wheel - Tire Tubes: Surly Light Presta (x2)
    Wheel - Tires: Surly Endomorph 120TPI (x2)
  20. #45
    more than Hawg's
    Mar 2012
    ^ ^ the wht/blue is a great combo
  21. #46
    Human Test Subject
    Reputation: Volsung's Avatar
    Frame: 2012 Surly Moonlander 18"
    Fork: stock
    Headset: stock Cane Creek
    Stem: Thomson x4
    Headset Cap: Purely Custom with Valknuts
    Handlebar: ENVE Sweep
    Grips: ESI Chunky
    Shifter: Microshift
    Front Derailleur: Shimano XT
    Derailleur: stock Shimano Deore
    Brakes: Stock Avid SD-7
    Disc: Ashima Airotor 160
    Rims: Surly Clown Shoe
    Spokes/Nipples: Stock DT Swiss whatevers
    Hubs: Surly front, Shimano XT rear
    Tires: Bud and Lou
    Tubes: Specialized 3"
    Crankset: Surly MWOD with black titanium bolts for extra blackness
    Bottom bracket: Shimano Ultegra
    Pedals: Shimano XT Trail
    Chain: KNC something
    Cassette: Stock 11-34
    Seat clamp: Surly Stainless Steel
    Seatpost: Cheapass Chinese Carbon
    Saddle: Koobi PRS Omega
    I replaced all the back bolts with black titanium but didn't replace the front since I have a carver fork on order. Other future upgrades are new hubs and spokes. The XT rear hub wobbles constantly, causing the rotor to rub on the rim and the tire to spin off center.
  22. #47
    Dec 2011
    Frame/fork-2012 Moonlander 22"
    Headset-Cane creek 110 ,black
    Stem-Thomson x4 ,black
    Handlebar- Spank 777 Evo ,silver
    Grips-Odi Rogue
    Shifters-SRAM X0 9 speed trigger ,gold
    Front derailleur-Shimano Xt
    Rear derailleur-SRAM X0 medium ,gold
    Brakes-Formula Oro
    Rims-Clownshoe with black rim strips
    Spokes-Wheelsmith 15/14 double butted with brass nips ,silver
    Front hub-Surly Ultra new hub ,silver
    Rear hub- Chris King ISO with stainless steel drive shell and fun bolts ,silver
    Tires-Bfl for summer ...Bud n Lou for winter
    Tubes- Surly
    Crankset- Surly MWOD
    Bottom bracket- one that came with MWOD
    Pedals- Syncros Mental, heavy but have tons of grip
    Chain- Kmc X9 sl ti, gold
    Cassette- SRAM PG990 11-34 ,gold
    Seat post- Thomson Elite ,black
    Seat post clamp- Surly SS , silver
    Saddle- Wtb Rocket VBike specs with pics-imageuploadedbytapatalk1351902609.538259.jpgBike specs with pics-imageuploadedbytapatalk1351902676.675526.jpg
  23. #48
    Nov 2008
    First Full Fat.
    Christmas gift to myself, built December 2010, first ride January 2, 2011
    20" Fatback frame and steel fork.
    Cane Creek Solos headset.
    1st generation Shimano Dyna-Sys XT shifters.
    1st generation Shimano Dyna-Sys Xt Rear Derailleur.
    Shimano M810 2 ring front derailleur for 83mm shell.
    Shimano M770 11-34 Dyna-Sys Cassette.
    Shimano XT brakes 180 front 160 rear rotors.
    Phil Wood 145 symmetrical BB.
    Shimano M900 crankset 26-34 with Spot ring guard.
    Dt Competition spokes.
    Vicious Fat Shebas drilled @ 28mm.
    Salsa 170 rear hub.
    Bontrager SS hub in front.
    Bontrager Rear Skewer XTR front, I like the strong cam action.
    Bontrager King Earl seatpost.
    Bontrager Inform saddle.
    Bontrager race XXX lite handlebar.
    Bontrager Race Lite 100mm stem.
    Bontrager waffle grips.
    Old endomorph & Surly tube on the rear.
    Larry and Bontrager 2.8 tube in front.
    Old 20" inner tubes split for rim strip.
    Built up Kinda heavy, the wheels are 19.5 lbs but still the olnly mountain bike I rode all of 2011.
    DSCN2787
    DSCN2790
  24. #49
    Sweet! I like that color.
  25. #50
    Nov 2008
    Thanks! I really like it also, it was not my first choice but once I un boxed it I liked it.
    Quote Originally Posted by gcappy View Post
Hot Deals
Contests
Latest Mountain Bike Articles
