Results 1 to 8 of 8
    Jan 2013
    Biggest Tire clearance 170mm and 17.5mm frames?
    Does anyone make a frame that can comfortably run a 4.8 Bud or Lou with a 170mm hub or a 17.5mm offset 135mm hub? I know I would have to make gearing sacrifices.
    Jun 2013
    Salsa mukluk with alternator dropouts, for example. 4.8's on 2013 Mukluk?
    Classic weekend warrior
    Reputation: sk1er18's Avatar
    I haven't seen one in person yet, but 38 Frameworks Jackelope?
    -Carver Ti O'Beast
    -Niner RLT 9
    -'16 Trek Farley 7 (hers)
    I have a Ti Fatback with the sliding dropouts and I run Bud/Lou on 90mm Uma rims with full 1x10 gearing, no issues and plenty of room
    Fat & Single
    Reputation: ozzybmx's Avatar
    Carver Obeast. Fits easily with no offset.
    Evil Following
    Trek 9.9 Superfly SL
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
    turtles make me hot
    Reputation: NYrr496's Avatar
    Do you already have hubs? Why not just go to 190?
    I like turtles
    Jan 2013
    Quote Originally Posted by NYrr496 View Post
    I already have an investment in multiple sets of 135mm wheels. Having a frame with more clearance would be ideal but I could always relace my rims to 170mm hubs (190mm hubs would cost a fortune for multiple wheels sets.)
    We have had a harder than normal winter and I find that I could use a little more rear float than the pug allows. I am running marge lite/nate on the rear and am not sure if going to darryls/nate would be enough of an upgrade in terms of float. The new ground control tires look like they may just fit on my pugs frame. Maybe that is the route to go before giving up on the pugs.
    Thanks for the replies.
    Reputation: Tripower's Avatar
    Jan 2011
    Ventana
    I have a Ventana El Gordo with 170mm rear spacing running RD's and a Lou and there is plenty of room.
  1. 9zero7 170mm biggest tire in frame?
    By hknivers in forum Fat bikes
    Last Post: 12-04-2013, 06:54 AM
  2. Replies: 11
    Last Post: 01-27-2013, 06:29 PM
  3. biggest tire?
    By vqdriver in forum Titus
    Last Post: 09-22-2011, 04:02 PM
  4. 170mm frames - Pivot Firebird VS Trek Scratch
    By climbingbubba in forum All Mountain
    Last Post: 09-05-2011, 01:56 PM
  5. Replies: 2
    Last Post: 07-12-2011, 07:39 AM
